SCT2632ASTER
SCT2632ASTER
    SCT(芯洲科技)
    ESOP-8
    降压型 3.5A 4.5V~60V
SCT2632ASTER 数据手册
芯 洲 科 SCT2632A 技 Silicon Content Technology Rev. 1.1 4.5V-60V Vin, 3.5A, High Efficiency Step-down DCDC Converter with Programmable Frequency FEATURES DESCRIPTION            The SCT2632A is 3.5A buck converter with wide input voltage, ranging from 4.5V to 60V, which integrates an 80mΩ high-side MOSFET. The SCT2632A, adopting the peak current mode control, supports the Pulse Skipping Modulation (PSM) which assists the converter on achieving high efficiency at light load or standby condition.     Wide Input Range: 4.5V-60V Up to 3.5A Continuous Output Current 0.8V ±1% Feedback Reference Voltage Integrated 80mΩ High-Side MOSFET Low Quiescent Current: 100uA Pulse Skipping Mode (PSM) in light load 130ns Minimum On-time Programmable Soft-start Time Adjustable Frequency 100KHz to 1.2MHz External Clock Synchronization Precision Enable Threshold for Programmable Input Voltage Under-Voltage Lock Out Protection (UVLO) Threshold and Hysteresis Low Dropout Mode Operation Derivable Inverting Voltage Regulator Over-voltage and Over-Temperature Protection Available in an ESOP-8 Package APPLICATIONS    12-V, 24-V, 48-V Industry and Telecom Power System Industrial Automation and Motor Control Vehicle Accessories The SCT2632A features programmable switching frequency from 100kHz to 1.2MHz with an external resistor, which provides the flexibility to optimize either efficiency or external component size. The converter supports external clock synchronization with a frequency band from 100kHz to 1.2MHz. The SCT2632A allows power conversion from high input voltage to low output voltage with a minimum 130ns ontime of high-side MOSFET. The device offers adjustable soft start to prevent inrush current during the startup of output voltage ramping. The SCT2632A features internal loop compensation to simplify the loop compensation design. The SCT2632A provides cycle-by-cycle current limit, thermal shutdown protection, output over-voltage protection and input voltage under-voltage protection. The device is available in an 8-pin ESOP-8 package. TYPICAL APPLICATION 100 90 BOOT VIN VIN C1 C2 L1 SW GND EN SS RT/CLK FB D1 C5 R1 C4 R4 80 VOUT R2 Efficiency(%) C3 70 60 50 40 30 Vout=3.3V 20 Vout=5V 10 0 0.001 Vout=12V 0.01 0.1 1 Output Current(A) Efficiency, Vin=24V, Fsw=500KHz 4.5V-60V, Asyncronous Buck Converter For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2632A 1 SCT2632A REVISION HISTORY NOTE: Page numbers for previous revisions may differ from page numbers in the current version. Revision 1.0: Production Revision 1.1: Update IEN_H in EC and system UVLO calculation formula by EN pin resistor divider DEVICE ORDER INFORMATION PART NUMBER PACKAGE MARKING PACKAGE DISCRIPTION SCT2632ASTE 632A ESOP-8 1) For Tape & Reel, Add Suffix R (e.g. SCT2632ASTER) ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION Over operating free-air temperature unless otherwise noted(1) DESCRIPTION MIN MAX UNIT VIN, EN -0.3 65 V BOOT -0.3 71 V SW -1 65 V BOOT-SW -0.3 6 V SS, FB, RT/CLK -0.3 6 V Operating junction temperature TJ(2) -40 150 °C Storage temperature TSTG -65 150 °C (1) (2) BOOT 1 VIN 2 EN 3 RT/CLK 4 Thermal Pad 8 SW 7 GND 6 SS 5 FB Figure 1. 8-Lead Plastic ESOP Stresses beyond those listed under Absolute Maximum Rating may cause device permanent damage. The device is not guaranteed to function outside of its Recommended Operation Conditions. The IC includes over temperature protection to protect the device during overload conditions. Junction temperature will exceed 150°C when over temperature protection is active. Continuous operation above the specified maximum operating junction temperature will reduce lifetime. PIN FUNCTIONS NAME NO. BOOT 1 VIN 2 EN 3 RT/CLK 4 FB 5 SS 6 2 PIN FUNCTION Power supply bias for high-side power MOSFET gate driver. Connect a 0.1uF capacitor from BOOT pin to SW pin. Bootstrap capacitor is charged when SW voltage is low. Input supply voltage. Connect a local bypass capacitor from VIN pin to GND pin. Path from VIN pin to high frequency bypass capacitor and GND must be as short as possible. Enable pin to the regulator with internal pull-up current source. Pull below 1.05V to disable the converter. Float or connect to VIN to enable the converter. The tap of resistor divider from VIN to GND connecting EN pin can adjust the input voltage lockout threshold. Set the internal oscillator clock frequency or synchronize to an external clock. Connect a resistor from this pin to ground to set switching frequency. An external clock can be input directly to the RT/CLK pin. The internal oscillator synchronizes to the external clock frequency with PLL. If detected clocking edges stops, the operation mode automatically returns to resistor programmed frequency. Inverting input of the trans-conductance error amplifier. The tap of external feedback resistor divider from the output to GND sets the output voltage. The device regulates FB voltage to the internal reference value of 0.8V typical. Connect a cap to ground, program the soft start time. For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2632A SCT2632A GND 7 Ground SW Thermal Pad 8 Regulator switching output. Connect SW to an external power inductor Heat dissipation path of die. Electrically connection to GND pin. Must be connected to ground plane on PCB for proper operation and optimized thermal performance. 9 RECOMMENDED OPERATING CONDITIONS Over operating free-air temperature range unless otherwise noted PARAMETER DEFINITION VIN VOUT TJ Input voltage range Output voltage range Operating junction temperature MIN MAX UNIT 4.5 0.8 -40 60 57 150 V V °C MIN MAX UNIT -1 +1 kV -0.5 +0.5 kV ESD RATINGS PARAMETER DEFINITION Human Body Model(HBM), per ANSI-JEDEC-JS-001-2014 specification, all pins(1) Charged Device Model(CDM), per ANSI-JEDEC-JS-0022014 specification, all pins(2) VESD (1) JEDEC document JEP155 states that 500V HBM allows safe manufacturing with a standard ESD control process. (2) JEDEC document JEP157 states that 250V CDM allows safe manufacturing with a standard ESD control process. THERMAL INFORMATION PARAMETER THERMAL METRIC ESOP-8L 𝜃𝑗𝑎 Junction-to-ambient thermal resistance (standard board) 42 𝜓𝑗𝑡 Junction-to-top characterization parameter 5.9 UNIT °C/W ELECTRICAL CHARACTERISTICS VIN=24V, TJ=-40°C~125°C, typical value is tested under 25°C. SYMBOL PARAMETER TEST CONDITION Power Supply VIN Operating input voltage ISHDN Input UVLO Threshold Hysteresis Shutdown current from VIN pin IQ Quiescent current from VIN pin VIN_UVLO TYP 4.5 VIN rising 4.2 320 2 EN=0, no load EN floating, no load, nonswitching, BOOT-SW=5V Power MOSFETs RDSON_H High-side MOSFET on-resistance Reference VREF MIN VBOOT-VSW=5V Reference voltage of FB UNIT 60 V 4.4 V mV μA 5 100 μA 80 mΩ 0.792 0.8 0.808 V 4.7 5.5 6.3 A © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved 3 Current Limit and Over Current Protection High-side power MOSFET peak ILIM_HS current limit threshold For more information www.silicontent.com MAX Product Folder Links: SCT2632A SCT2632A SYMBOL PARAMETER TEST CONDITION MIN TYP MAX UNIT Enable and Soft Startup VEN_H Enable high threshold 1.2 V VEN_L Enable low threshold 1.05 V IEN_L Enable pin pull-up current EN=1V 1 μA IEN_H Enable pin pull-up current EN=1.5V 4 uA ISS SS pin current 3 uA Switching Frequency and External Clock Synchronization FRANGE_RT Frequency range using RT mode 100 FSW Switching frequency RRT=200 kΩ(1%) 450 tON_MIN Minimum on-time VIN=24V 130 ns VBOOTUV Feedback overvoltage with respect to reference voltage BOOT-SW UVLO threshold TSD Thermal shutdown threshold * VFB/VREF rising VFB/VREF falling BOOT-SW falling Hysteresis TJ rising 110 105 2.52 230 172 % % V mV °C 12 °C 500 1200 kHz 550 kHz Protection VOVP Hysteresis *Derived from bench characterization 4 For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2632A SCT2632A TYPICAL CHARACTERISTICS 90 80 80 70 70 60 50 40 30 Vin=7V Vin=12V 20 Vin=24V Vin=36V Vin=48V Vin=60V 10 0 0.001 0.01 0.1 Efficiency(%) 100 90 Efficiency(%) 100 60 50 40 30 Vout=3.3V 20 Vout=5V 10 Vout=12V 0 0.001 1 0.01 Output Current(A) Figure 3. Efficiency vs Load Current, Vin=24V 3.308 5.60 3.306 5.55 Current Limit(A) Output Voltage(V) 1 Output Current(A) Figure 2. Efficiency vs Load Current, Vout=5V 3.304 3.302 3.3 3.298 5.50 5.45 5.40 5.35 3.296 0 0.5 1 1.5 2 2.5 3 3.5 5.30 -50 Output Curent(A) Figure 4. Load Regulation, Vin=24V, Vout=3.3V 0 50 Temperature(ºC) 100 150 Figure 5. Current Limit VS Temperature 500 1,100 1,000 499 498 497 496 495 494 493 -50 0 50 100 150 Temperature(ºC) Switching Frequency (kHz) Switching Frequency(KHz) 0.1 900 800 700 600 500 400 300 200 100 0 100 200 300 400 500 600 RT (kΩ) Figure 6. Switching Frequency VS Temperature For more information www.silicontent.com Figure 7. Switching Frequency vs RT Resistor © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2632A 5 SCT2632A FUNCTIONAL BLOCK DIAGRAM VIN 1uA 3uA Thermal Shutdown + EN EN LOGIC VIN UVLO Reference 1.2V VREF VCC 3uA VCC HS MOSFET Current limit SS Boot Charge BOOT Slope FB 0.8V + + EA Boot UVLO PWM + + OVP Q1 Control Logic SW 0.88V RT/CLK Oscillator With PLL CLK GND Figure 8. Functional Block Diagram 6 For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2632A SCT2632A OPERATION Overview The SCT2632A is a 4.5V-60V input, 3.5A output, buck converter with integrated 80mΩ Rdson high-side power MOSFET. It implements constant frequency peak current mode control to regulate output voltage, providing excellent line and load transient response. The switching frequency is programmable from 100kHz to 1.2MHz with two setting modes, resistor setting frequency mode and the clock synchronization mode, to optimizes either the power efficiency or the external components’ sizes. The SCT2632A features programmable soft-start time to avoid large inrush current and output voltage overshoot during startup. The device also supports monolithic startup with pre-biased output condition. The seamless mode-transition between PWM mode and PSM mode operations ensure high efficiency over wide load current range. The quiescent current is typically 100uA under no load or sleep mode condition to achieve high efficiency at light load. The SCT2632A has a default input start-up voltage of 4.2V with 320mV hysteresis. The EN pin is a high-voltage pin with a precision threshold that can be used to adjust the input voltage lockout thresholds with two external resistors to meet accurate higher UVLO system requirements. Floating EN pin enables the device with the internal pull-up current to the pin. Connecting EN pin to VIN directly starts up the device automatically. The SCT2632A full protection features include the input under-voltage lockout, the output over-voltage protection, over current protection with cycle-by-cycle current limiting, output hard short protection and thermal shutdown protection. Peak Current Mode Control The SCT2632A employs fixed frequency peak current mode control. An internal clock initiates turning on the integrated high-side power MOSFET Q1 in each cycle, then inductor current rises linearly. When the current through high-side MOSFET reaches the threshold level set by the COMP voltage of the internal error amplifier, the integrated high-side MOSFET is turned off. The error amplifier serves the COMP node by comparing the voltage of the FB pin with an internal 0.8V reference voltage. When the load current increases, a reduction in the feedback voltage relative to the reference raises COMP voltage till the average inductor current matches the increased load current. This feedback loop well regulates the output voltage to the reference. The device also integrates an internal slope compensation circuitry to prevent subharmonic oscillation when duty cycle is greater than 50% for a fixed frequency peak current mode control. The SCT2632A operates in Pulse Skipping Mode (PSM) with light load current to improve efficiency. When the load current decreases, an increment in the feedback voltage leads COMP voltage drop. When COMP falls to a low clamp threshold (470mV typically), device enters PSM. The output voltage decays due to output capacitor discharging during skipping period. Once FB voltage drops lower than the reference voltage, and the COMP voltage rises above low clamp threshold. Then high-side power MOSFET turns on in next clock pulse. After several switching cycles with typical 400mA peak inductor current, COMP voltage drops and is clamped again and pulse skipping mode repeats if the output continues light loaded. This control scheme helps achieving higher efficiency by skipping cycles to reduce switching power loss and gate drive charging loss. The controller consumption quiescent current is 100uA during skipping period with no switching to improve efficiency further. Enable and Under Voltage Lockout Threshold The SCT2632A is enabled when the VIN pin voltage rises above 4.2V and the EN pin voltage exceeds the enable threshold of 1.2V. The device is disabled when the VIN pin voltage falls below 3.9V or when the EN pin voltage is below 1.05V. An internal 1uA pull up current source to EN pin allows the device enable when EN pin floats. EN pin is a high voltage pin that can be connected to VIN directly to start up the device. For a higher system UVLO threshold, connect an external resistor divider (R1 and R2) shown in Figure 9 from VIN to EN. The UVLO rising and falling threshold can be calculated by Equation 1 and Equation 2 respectively. For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2632A 7 SCT2632A VIN 𝑉𝑟𝑖𝑠𝑒 ∗ 0.875 − 𝑉𝑓𝑎𝑙𝑙 𝑅1 = 3.125𝑢𝐴 (1) 𝑅1 × 1.05 − 1.05 + 𝑅1 ∗ 4𝑢𝐴 (2) 𝑅2 = 𝑉𝑓𝑎𝑙𝑙 1uA 3uA R1 EN R2 + 1.2V /1.05V where  Vrise is rising threshold of Vin UVLO  Vfall is falling threshold of Vin UVLO Figure 9. System UVLO by enable divide Output Voltage The SCT2632A regulates the internal reference voltage at 0.8V with 1% tolerance over the operating temperature and voltage range. The output voltage is set by a resistor divider from the output node to the FB pin. It is recommended to use 1% tolerance or better resistors. Use Equation 3 to calculate resistance of resistor dividers. To improve efficiency at light loads, larger value resistors are recommended. However, if the values are too high, the regulator will be more susceptible to noise affecting output voltage accuracy. 𝑉𝑂𝑈𝑇 𝑅𝐹𝐵_𝑇𝑂𝑃 = ( − 1) ∗ 𝑅𝐹𝐵_𝐵𝑂𝑇 𝑉𝑅𝐸𝐹 (3) where  RFB_TOP is the resistor connecting the output to the FB pin.  RFB_BOT is the resistor connecting the FB pin to the ground. Programmable Soft-Start The SCT2632A features programmable soft-start time to prevent inrush current during start-up stage. The soft-start time can be programmed easily by connecting a soft-start capacitor Css from SS pin to ground. The SS pin sources an internal 3µA current charging the external soft-start capacitor Css when the EN pin exceeds turn-on threshold. The device adopts the lower voltage between the internal voltage reference 0.8V and the SS pin voltage as the reference input voltage of the error amplifier and regulates the output. The soft-start completes when the voltage at the SS pin exceeds the internal reference voltage of 0.8V. The soft-start capacitor value can be calculated going with following equation 4. Attention should be taken here that the programmed soft-start time should be larger than 4ms. 𝐶𝑠𝑠 = 𝑡𝑠𝑠 ∗ 3𝑢𝐴 0.8𝑉 (4) Where:   CSS is the soft-start capacitor connected from SS pin to the ground tss is the soft-start time Switching Frequency and Clock Synchronization The switching frequency of the SCT2632A is set by placing a resistor between RT/CLK pin and the ground, or synchronizing to an external clock. In resistor setting frequency mode, a resistor placed between RT/CLK pin to the ground sets the switching frequency over a wide range from 100KHz to 1.2MHz. The RT/CLK pin voltage is typical 0.5V. RT/CLK pin is not allowed to be left floating or shorted to the ground. Use Equation 5 or the plot in Figure 10. to determine the resistance for a switching frequency needed. 8 For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2632A SCT2632A 𝑅𝑇(𝐾𝛺) = RT/CLK 100000 𝑓𝑠𝑤(𝐾𝐻𝑧) (5) Oscillator With PLL CLK where, fsw is switching clock frequency Figure 10. Setting Frequency and Clock Synchronization In clock synchronization mode, the switching frequency synchronizes to an external clock applied to RT/CLK pin. The synchronization frequency range is from 100KHz to 1.2MHz and the rising edge of the SW synchronizes to the falling edge of the external clock at RT/CLK pin with typical 66ns time delay. A square wave clock signal to RT/CLK pin must have high level no lower than 2V, low level no higher than 0.4V, and pulse width larger than 80ns. In applications where both resistor setting frequency mode and clock synchronization mode are needed, the device can be configured as shown in Figure 10. Before an external clock is present, the device works in resistor setting frequency mode. When an external clock presents, the device automatically transitions from resistor setting mode to external clock synchronization mode. An internal phase locked loop PLL locks internal clock frequency onto the external clock within typical 85us. The converter transitions from the clock synchronization mode to the resistor setting frequency mode when the external clock disappears. Bootstrap Voltage Regulator and Low Drop-out Operation An external bootstrap capacitor between BOOT pin and SW pin powers the floating gate driver to high-side power MOSFET. The bootstrap capacitor voltage is charged from an integrated voltage regulator when high-side power MOSFET is off and the external low-side diode conducts. The recommended value of the BOOT capacitor is 0.1 μF. The UVLO of high-side MOSFET gate driver has rising threshold of 2.52V and hysteresis of 230mV. When the device operates with high duty cycle or extremely light load, bootstrap capacitor may be not recharged in considerable long time. The voltage at bootstrap capacitor is insufficient to drive high-side MOSFET fully on. When the voltage across bootstrap capacitor drops below 2.29V, BOOT UVLO occurs. The converter forces turning on an integrated low-side MOSFET periodically to refresh the voltage of bootstrap capacitor to guarantee the converter’s operation over a wide duty range. During the condition of ultra-low voltage difference from the input to the output, SCT2632A operates in Low DropOut LDO mode. High-side MOSFET remains turning on as long as the BOOT pin to SW pin voltage is higher than BOOT UVLO threshold 2.52V. When the voltage from BOOT to SW drops below 2.29V, the high-side MOSFET turns off and low-side MOSFET turns on to recharge bootstrap capacitor periodically in the following several switching cycles. Low-side MOSFET only turns on for 100ns in each refresh cycle to minimize the output voltage ripple. Low-side MOSFET may turn on for several times till the bootstrap voltage is charged to higher than 2.52V for high-side MOSFET working normally. The effective duty cycle of the converter during LDO operation can be approaching to 100%. During slowing power up and power down application, the output voltage can closely track the input voltage ramping down thanks to LDO operation mode. As the input voltage is reduced to near the output voltage, i.e. during slowing power-up and power-down application, the off-time of the high side MOSFET starts to approach the minimum value. Without LDO operation mode, beyond this point the switching may become erratic and/or the output voltage will fall out of regulation. To avoid this problem, the SCT2632A LDO mode automatically reduces the switching frequency to increase the effective duty cycle and maintain regulation. Over Current Limit The SCT2632A implements over current protection with fold back current limit. The SCT2632A cycle-by-cycle limits high-side MOSFET peak current to avoid inductor current running away during unexpected overload or output hard short condition. When overload or hard short happens, the converter cannot provide output current to satisfy loading requirement. The inductor current is clamped at over current limitation. Thus, the output voltage drops below regulated voltage For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2632A 9 SCT2632A with FB voltage less than internal reference voltage continuously. The COMP voltage ramps up to high clamp voltage 2.25V typical. The SCT2632A implements frequency foldback to protect the converter in unexpected overload or output hard short condition at higher switching frequencies and input voltages. The oscillator frequency is divided by 1, 2, 4, and 8 as the FB pin voltage falls from 0.8 V to 0 V. The SCT2632A uses a digital frequency foldback to enable synchronization to an external clock during normal start-up and fault conditions. During short-circuit events, the inductor current can exceed the peak current limit because of the high input voltage and the minimum on-time. When the output voltage is forced low by the shorted load, the inductor current decreases slowly during the switch off-time. The frequency foldback effectively increases the off-time by increasing the period of the switching cycle providing more time for the inductor current to ramp down. With a maximum frequency foldback ratio of 8, there is a maximum frequency at which the inductor current can be controlled by frequency foldback protection. Equation 6 calculates the maximum switching frequency at which the inductor current remains under control when V OUT is forced to VOUT_SHORT. The selected operating frequency must not exceed the calculated value. 𝑓𝑠𝑤(max 𝑠𝑘𝑖𝑝) = 𝑓𝐷𝐼𝑉 𝐼𝐿𝐼𝑀𝐼𝑇 × 𝑅𝐷𝐶 + 𝑉𝑂𝑈𝑇_𝑆𝐻𝑂𝑅𝑇 + 𝑉𝑑 ×( ) 𝑡𝑚𝑖𝑛_𝑂𝑁 𝑉𝐼𝑁_𝑀𝐴𝑋 − 𝐼𝐿𝐼𝑀𝐼𝑇 × 𝑅𝐷𝑆(𝑜𝑛) + 𝑉𝑑 (6) where ILIMIT: Limited average current RDC: Inductor DC resistance VIN_MAX: Maximum input voltage VOUT_SHORT: Output voltage during short Vd: Diode voltage drop RDS(on): Integrated high side FET on resistance Tmin_ON: Controllable minimum on time fDIV: Frequency divide equals (1,2,4 or 8) Over voltage Protection The SCT2632A implements the Over-voltage Protection OVP circuitry to minimize output voltage overshoot during load transient, recovering from output fault condition or light load transient. The overvoltage comparator in OVP circuit compares the FB pin voltage to the internal reference voltage. When FB voltage exceeds 110% of internal 0.8V reference voltage, the high-side MOSFET turns off to avoid output voltage continue to increase. When the FB pin voltage falls below 105% of the 0.8V reference voltage, the high-side MOSFET can turn on again. Thermal Shutdown The SCT2632A protects the device from the damage during excessive heat and power dissipation conditions. Once the junction temperature exceeds 172°C, the internal thermal sensor stops power MOSFETs switching. When the junction temperature falls below 160°C, the device restarts with internal soft start phase. 10 For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2632A SCT2632A APPLICATION INFORMATION Typical Application C12 0.1uF BOOT L1 D1 VIN=4.5V~60V VIN R1 309K C1 C2 C3 C4 C5 4.7uF 4.7uF 4.7uF 4.7uF 0.1uF R2 76.8K VOUT=3.3V IOUT= 3A 5.5uH SW C8 C9 47uF 47uF GND C10 47uF C11 47uF SCT2632A EN R5 31.6K C13 Optional SS RT/ CLK FB C6 22nF R3 200K R6 10.2K Figure 11. SCT2632A Design Example, 3.3V Output with Programmable UVLO Design Parameters Design Parameters Example Value Input Voltage 24V Normal 4.5V to 60V Output Voltage 3.3V Maximum Output Current 3.5A Switching Frequency 500 KHz Output voltage ripple (peak to peak) 16.5mV Transient Response 0.75A to 2.25A load step ∆Vout = 60mV Start Input Voltage (rising VIN) 5.73V Stop Input Voltage (falling VIN) 4.045V For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2632A 11 SCT2632A Output Voltage The output voltage is set by an external resistor divider R5 and R6 in typical application schematic. Recommended R6 resistance is 10.2KΩ. Use equation 7 to calculate R5. where: 𝑉𝑂𝑈𝑇 𝑅5 = ( − 1) ∗ 𝑅6 𝑉𝑅𝐸𝐹 Table 1. R5, R6Value for Common Output Voltage (Room Temperature) (7)  VREF is the feedback reference voltage, typical 0.8V VOUT R5 R6 2.5 V 21.5 KΩ 10.2 KΩ 3.3 V 31.6 KΩ 10.2 KΩ 5 V 53.6 KΩ 10.2 KΩ 12 V 143 KΩ 10.2 KΩ 24V 294 KΩ 10.2 KΩ 36V 442 KΩ 10.2 KΩ 48V 604 KΩ 10.2 KΩ Switching Frequency Higher switching frequencies support smaller profiles of output inductors and output capacitors, resulting in lower voltage and current ripples. However, the higher switching frequency causes extra switching loss, which downgrades converter’s overall power efficiency and thermal performance. The 130ns minimum on-time limitation also restricts the selection of higher switching frequency. In this design, a moderate switching frequency of 500 kHz is selected to achieve both small solution size and high efficiency operation. The resistor connected from RT/CLK to GND sets switching frequency of the converter. The resistor value required for a desired frequency can be calculated using equation 8, or determined from Figure 7. 𝑅3 (KΩ) = 100000 Table 2. RFSW Value for Common Switching Frequencies (Room Temperature) (8) fsw (KHz ) where:  fSW is the desired switching frequency Fsw R3 (RFSW) 200 KHz 500 KΩ 330 KHz 301 KΩ 500 KHz 200 KΩ 1100 KHz 90.9 KΩ Under Voltage Lock-Out An external voltage divider network of R1 from the input to EN pin and R2 from EN pin to the ground can set the input voltage’s Under Voltage Lock-Out (UVLO) threshold. The UVLO has two thresholds, one for power up when the input voltage is rising and the other for power down or brown outs when the input voltage is falling. For the example design, the supply should turn on and start switching once the input voltage increases above 5.73V (start or enable). After the regulator starts switching, it should continue to do so until the input voltage falls below 4.045 V (stop or disable). Use Equation 9 and Equation 10 to calculate the values 309 kΩ and 76.8 kΩ of R1 and R2 resistors. 𝑉𝑟𝑖𝑠𝑒 ∗ 0.875 − 𝑉𝑓𝑎𝑙𝑙 3.125𝑢𝐴 (9) 𝑅1 × 1.05 𝑉𝑓𝑎𝑙𝑙 − 1.05 + 𝑅1 ∗ 4𝑢𝐴 (10) 𝑅1 = 𝑅2 = 12 For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2632A SCT2632A Inductor Selection There are several factors should be considered in selecting inductor such as inductance, saturation current, the RMS current and DC resistance(DCR). Larger inductance results in less inductor current ripple and therefore leads to lower output voltage ripple. However, the larger value inductor always corresponds to a bigger physical size, higher series resistance, and lower saturation current. A good rule for determining the inductance to use is to allow the inductor peak-to-peak ripple current to be approximately 20%~40% of the maximum output current. The peak-to-peak ripple current in the inductor ILPP can be calculated as in Equation 11. 𝐼𝐿𝑃𝑃 = Where      𝑉𝑂𝑈𝑇 ∗ (𝑉𝐼𝑁 − 𝑉𝑂𝑈𝑇 ) 𝑉𝐼𝑁 ∗ 𝐿 ∗ 𝑓𝑆𝑊 (11) ILPP is the inductor peak-to-peak current L is the inductance of inductor fSW is the switching frequency VOUT is the output voltage VIN is the input voltage Since the inductor-current ripple increases with the input voltage, so the maximum input voltage in application is always used to calculate the minimum inductance required. Use Equation 12 to calculate the inductance value. 𝐿𝑀𝐼𝑁 = Where       𝑉𝑂𝑈𝑇 𝑉𝑂𝑈𝑇 ∗ (1 − ) 𝑓𝑆𝑊 ∗ 𝐿𝐼𝑅 ∗ 𝐼𝑂𝑈𝑇(𝑚𝑎𝑥) 𝑉𝐼𝑁(𝑚𝑎𝑥) (12) LMIN is the minimum inductance required fsw is the switching frequency VOUT is the output voltage VIN(max) is the maximum input voltage IOUT(max) is the maximum DC load current LIR is coefficient of ILPP to IOUT The total current flowing through the inductor is the inductor ripple current plus the output current. When selecting an inductor, choose its rated current especially the saturation current larger than its peak operation current and RMS current also not be exceeded. Therefore, the peak switching current of inductor, ILPEAK and ILRMS can be calculated as in equation 13 and equation 14. 𝐼𝐿𝑃𝐸𝐴𝐾 = 𝐼𝑂𝑈𝑇 + 𝐼𝐿𝑃𝑃 2 𝐼𝐿𝑅𝑀𝑆 = √(𝐼𝑂𝑈𝑇 )2 + Where     (13) 1 ∗ (𝐼𝐿𝑃𝑃 )2 12 (14) ILPEAK is the inductor peak current IOUT is the DC load current ILPP is the inductor peak-to-peak current ILRMS is the inductor RMS current In overloading or load transient conditions, the inductor peak current can increase up to the switch current limit of the device which is typically 5.5A. The most conservative approach is to choose an inductor with a saturation current rating greater than 5.5A. Because of the maximum ILPEAK limited by device, the maximum output current that the SCT2632A can deliver also depends on the inductor current ripple. Thus, the maximum desired output current also For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2632A 13 SCT2632A affects the selection of inductance. The smaller inductor results in larger inductor current ripple leading to a lower maximum output current. Diode Selection The SCT2632A requires an external catch diode between the SW pin and GND. The selected diode must have a reverse voltage rating equal to or greater than VIN(max). The peak current rating of the diode must be greater than the maximum inductor current. Schottky diodes are typically a good choice for the catch diode due to their low forward voltage. The lower the forward voltage of the diode, the higher the efficiency of the regulator. Typically, diodes with higher voltage and current ratings have higher forward voltages. A diode with a minimum of 60-V reverse voltage is preferred to allow input voltage transients up to the rated voltage of the SCT2632A. For the example design, the B560C-13-F Schottky diode is selected for its lower forward voltage and good thermal characteristics compared to smaller devices. The typical forward voltage of the B560C-13-F is 0.7 volts at 5 A. The diode must also be selected with an appropriate power rating. The diode conducts the output current during the off-time of the internal power switch. The off-time of the internal switch is a function of the maximum input voltage, the output voltage, and the switching frequency. The output current during the off-time is multiplied by the forward voltage of the diode to calculate the instantaneous conduction losses of the diode. At higher switching frequencies, the ac losses of the diode need to be taken into account. The ac losses of the diode are due to the charging and discharging of the junction capacitance and reverse recovery charge. Equation 14 is used to calculate the total power dissipation, including conduction losses and ac losses of the diode. The B560C-13-F diode has a junction capacitance of 300 pF. Using Equation 15, the total loss in the diode at the maximum input voltage is 2.58 W. If the power supply spends a significant amount of time at light load currents or in sleep mode, consider using a diode which has a low leakage current and slightly higher forward voltage drop. 𝑃𝐷 = (𝑉𝐼𝑁_𝑀𝐴𝑋 − 𝑉𝑂𝑈𝑇 ) × 𝐼𝑂𝑈𝑇 × 𝑉𝑑 𝐶𝑗 × 𝑓𝑆𝑊 × (𝑉𝐼𝑁 + 𝑉𝑑 )2 + 𝑉𝐼𝑁_𝑀𝐴𝑋 2 (15) Input Capacitor Selection The input current to the step-down DCDC converter is discontinuous, therefore it requires a capacitor to supply the AC current to the step-down DCDC converter while maintaining the DC input voltage. Use capacitors with low ESR for better performance. Ceramic capacitors with X5R or X7R dielectrics are usually suggested because of their low ESR and small temperature coefficients, and it is strongly recommended to use another lower value capacitor (e.g. 0.1uF) with small package size (0603) to filter high frequency switching noise. Place the small size capacitor as close to VIN and GND pins as possible. The voltage rating of the input capacitor must be greater than the maximum input voltage. And the capacitor must also have a ripple current rating greater than the maximum input current ripple. The RMS current in the input capacitor can be calculated using Equation 16. ICINRMS = IOUT ∗ √ VOUT VOUT ∗ (1 − ) VIN VIN (16) The worst case condition occurs at VIN=2*VOUT, where: (17) ICINRMS = 0.5 ∗ IOUT For simplification, choose an input capacitor with an RMS current rating greater than half of the maximum load current. 14 For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2632A SCT2632A When selecting ceramic capacitors, it needs to consider the effective value of a capacitor decreasing as the DC bias voltage across a capacitor increasing. The input capacitance value determines the input ripple voltage of the regulator. The input voltage ripple can be calculated using Equation 18 and the maximum input voltage ripple occurs at 50% duty cycle. ∆VIN = IOUT VOUT VOUT ∗ ∗ (1 − ) fSW ∗ CIN VIN VIN (18) For this example, four 4.7μF, X7R ceramic capacitors rated for 100 V in parallel are used. And a 0.1 μF for highfrequency filtering capacitor is placed as close as possible to the device pins. Bootstrap Capacitor Selection A 0.1μF ceramic capacitor must be connected between BOOT pin and SW pin for proper operation. A ceramic capacitor with X5R or better grade dielectric is recommended. The capacitor should have a 10V or higher voltage rating. Output Capacitor Selection The selection of output capacitor will affect output voltage ripple in steady state and load transient performance. The output ripple is essentially composed of two parts. One is caused by the inductor current ripple going through the Equivalent Series Resistance ESR of the output capacitors and the other is caused by the inductor current ripple charging and discharging the output capacitors. To achieve small output voltage ripple, choose a low-ESR output capacitor like ceramic capacitor. For ceramic capacitors, the capacitance dominates the output ripple. For simplification, the output voltage ripple can be estimated by Equation 19 desired. ∆VOUT = Where       𝑉𝑂𝑈𝑇 ∗ (𝑉𝐼𝑁 − 𝑉𝑂𝑈𝑇 ) (19) 8 ∗ 𝑓𝑆𝑊 2 ∗ 𝐿 ∗ 𝐶𝑂𝑈𝑇 ∗ 𝑉𝐼𝑁 ΔVOUT is the output voltage ripple fSW is the switching frequency L is the inductance of inductor COUT is the output capacitance VOUT is the output voltage VINis the input voltage Due to capacitor’s degrading under DC bias, the bias voltage can significantly reduce capacitance. Ceramic capacitors can lose most of their capacitance at rated voltage. Therefore, leave margin on the voltage rating to ensure adequate effective capacitance. Typically, four 47μF ceramic output capacitors work for most applications. For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2632A 15 SCT2632A Inverting Power application The SCT2632A can be used to convert a positive input voltage to a negative output voltage. Typical applications are amplifiers requiring a negative power supply. L1 C3 BOOT GND SW D1 VIN VIN GND SCT2632A Cin C1 C2 EN SS RT/CLK FB C4 R1 C5 R2 R4 V OUT Figure 12. SCT2632A Inverting Power Supply 16 For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2632A SCT2632A Application Waveforms Vin=24V, Vout=3.3V, unless otherwise noted Figure 13. Power up(Iload=3A) Figure 14. Power down(Iload=3A) Figure 15.EN toggle (Iload=3A) Figure 16. EN toggle (Iload=20mA) Figure 17. Over Current Protection(3A to hard short) Figure 18. Over Current Release (hard short to 3A) For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2632A 17 SCT2632A Application Waveforms(continued) Vin=24V, Vout=3.3V, unless otherwise noted 18 Figure 19. Load Transient (0.3A-2.7A, 1.6A/us) Figure 20. Load Transient (0.75A-2.25A, 1.6A/us) Figure 21. Output Ripple (Iload=0A) Figure 22. Output Ripple (Iload=100mA) Figure 23. Output Ripple (Iload=3A) Figure 24. Thermal, 24VIN, 3.3Vout, 3.5A For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2632A SCT2632A Layout Guideline Proper PCB layout is a critical for SCT2632A’s stable and efficient operation. The traces conducting fast switching currents or voltages are easy to interact with stray inductance and parasitic capacitance to generate noise and degrade performance. For better results, follow these guidelines as below: 1. Power grounding scheme is very critical because of carrying power, thermal, and glitch/bouncing noise associated with clock frequency. The thumb of rule is to make ground trace lowest impendence and power are distributed evenly on PCB. Sufficiently placing ground area will optimize thermal and not causing over heat area. 2. Place a low ESR ceramic capacitor as close to VIN pin and the ground as possible to reduce parasitic effect. 3. Freewheeling diode should be place as close to SW pin and the ground as possible to reduce parasitic effect. 4. For operation at full rated load, the top side ground area must provide adequate heat dissipating area. Make sure top switching loop with power have lower impendence of grounding. 5. The bottom layer is a large ground plane connected to the ground plane on top layer by vias. The power pad should be connected to bottom PCB ground planes using multiple vias directly under the IC. The center thermal pad should always be soldered to the board for mechanical strength and reliability, using multiple thermal vias underneath the thermal pad. Improper soldering thermal pad to ground plate on PCB will cause SW higher ringing and overshoot besides downgrading thermal performance. it is recommended 8mil diameter drill holes of thermal vias, but a smaller via offers less risk of solder volume loss. On applications where solder volume loss thru the vias is of concern, plugging or tenting can be used to achieve a repeatable process. 6. Output inductor and freewheeling diode should be placed close to the SW pin. The switching area of the PCB conductor minimized to prevent excessive capacitive coupling. 7. The RT/CLK terminal is sensitive to noise so the RT resistor should be located as close as possible to the IC and routed with minimal lengths of trace. 8. UVLO adjust and RT resistors and feedback components should connect to small signal ground which must return to the GND pin without any interleaving with power ground. 9. Route BOOT capacitor trace on the other layer than top layer to provide wide path for topside ground. 10. For achieving better thermal performance, a four-layer layout is strongly recommended. VOUT Inductor Output Capacitors GND Top layer ground area Via Via Input bypass capacitor VIN BOOT 1 8 2 7 VIN EN RT/CLK SW GND 3 4 Thermal Pad Small signal ground SS 6 5 FB Feedback resistors Programmable UVLO resistors Fsw Set Resistor GND Top layer ground area Figure 25. PCB Layout Example For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2632A 19 SCT2632A PACKAGE INFORMATION SOP8/PP(95x130) Package Outline Dimensions Symbol A A1 A2 b c D D1 E E1 E2 e L  Dimensions in Millimeters Min. Max. 1.300 1.700 0.000 0.100 1.350 1.550 0.330 0.510 0.170 0.250 4.700 5.100 3.050 3.250 3.800 4.000 5.800 6.200 2.160 2.360 1.270(BSC) Dimensions in Inches Min. Max. 0.051 0.067 0.000 0.004 0.053 0.061 0.013 0.020 0.007 0.010 0.185 0.201 0.120 0.128 0.150 0.157 0.228 0.244 0.085 0.093 0.050(BSC) 0.400 0° 0.016 0° 1.270 8° 0.050 8° NOTE: 1. 2. 3. 4. 5. 6. Drawing proposed to be made a JEDEC package outline MO-220 variation. Drawing not to scale. All linear dimensions are in millimeters. Thermal pad shall be soldered on the board. Dimensions of exposed pad on bottom of package do not include mold flash. Contact PCB board fabrication for minimum solder mask web tolerances between the pins. 20 For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2632A SCT2632A TAPE AND REEL INFORMATION Orderable Device SCT2632ASTER Package Type ESOP For more information www.silicontent.com Pins 8 SPQ 4000 © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2632A 21
