R16-160
R16-160
    SEA&LAND(台湾陆海)
    插件,P=5.1mm
    PTC自恢复保险丝 1.6A 16V
R16-160 数据手册
SEA & LAND ELECTRONIC CORP. WWW.SEALAND-PPTC.COM ALPHA-TOP TECHNOLOGY CORP. WWW.ALPHA-TOP.COM APPROVAL SHEET R16-160 MODEL NO.: CUSTOMER: CUSTOMER'S APPROVAL: AUTHORIZED SIGNATURE/STAMP: DATE MANUFACTURER: HEAD OFFICE: 13F.,No.120-10,Sec.3,Zhongshan Rd.,Zhonghe Dist.,New Taipei City 23544,Taiwan Tel: 886-2-8221-2567 Fax:882-2-2225-7268 E-mail:service@chipfast.com.tw China Branch: 31 Chang-Xin-Zon Road,Gao-Ling lndustrial Zone,Chiu-chang Town, Huey Yang Distric,Huey Zhou City,Guang Dong516221,CHINA Tel: 86-752-3562001 Fax:86-752-3558696 E-mail:service@atpptc.com Submitted by: Chung Cheng Approved by: YC Lin DATE: 9-Apr-13 SEA & LAND ELECTRONIC CORP. 第1页 Features Applications ■Radial Leaded Devices Almost anywhere there is a low voltage ■Cured, flame, retardant epoxy polymer power supply, up to 16V and a load to be insulating material meets protected, including: UL 94V-0 requirements ■Personal computer ■Bulk packaging, or tape and reel ■Medical electronics ■Personal care product available on most models R16-160 Alpha-Top (Sea & Land Alliance) Maximum Time Model R16-160 Vmax Imax Ihold Itrip Pd Resistance Agency Approval To Trip Typ. Current Time Ri min Ri max R1 max (Vdc) (A) (A) (A) (W) (A) (Sec) () () () 16 100 1.60 3.20 0.90 8.00 9.0 0.030 0.0610 0.110 UL TUV Ihold = Hold Current : maximum current device will sustain for 4 hours without tripping in 25°C still air. Itrip = Trip Current : minimum current at which the device will trip in 25°C still air. Vmax = Maximum voltage device can withstand without damage at rated current (I max). Imax = Maximum fault current device can withstand without damage at rated voltage (V Pd max). = Power dissipated from device when in the tripped state at 25°C still air. Ri min/max = Minimum/Maximum resistance of device in initial (un-soldered) state. R1 max = Maximum resistance of device at 25°C measured one hour after tripping. CAUTION : Operation beyond the specified ratings may result in damage and possible arcing and flame. Environmental Specifications Test Conditions Resistance change Passive aging +85°C, 1000 hrs. ±5% typical Humidity aging +85°C, 85% R.H.,1000 hrs ±5% typical Thermal shock +85°C to -40°C, 20 times ±10% typical Resistance to solvent MIL-STD-202,Method 215 No change Vibration MIL-STD-202,Method 201 No change Ambient operating /storage conditions : - 40 °C to +85 °C Maximum surface temperature of the device in the tripped state is 125 °C Agency Approvals : UL pending Regulation/Standard: 2002/95/EC EN14582 PHYSICAL SPECIFICATIONS : Materials : Leads Tin plated copper-clad steel, 24 AWG (0.51mm/0.020" Dia.) Lead Solderability : MIL-STD-202, Method 208E Device Labeling : Device is marked with Logo, amperage rating , voltage rating & date code. · Use PPTC beyond the maximum ratings or improper use may result in device damage and possible electrical arcing and flame. · PPTC are intended for protection against occasional over current or over temperature fault conditions and should not be used when repeated fault conditions or prolonged trip events are anticipated. · Device performance can be impacted negatively if devices are handled in a manner inconsistent with recommended electronic, thermal, and mechanical procedures for electronic components. · Use PPTC with a large inductance in circuit will generate a circuit voltage (L di/dt) above the rated voltage of the PPTC. · Avoid impact PPTC device its thermal expansion like placed under pressure or installed in limited space. 第2页 R16-160 Alpha-Top (Sea & Land Alliance) Physical Dimensions (Unit: mm) Model R16-160 A B C D E Lead Max. Max. Typ. Min. Max. Style 8.90 15.20 5.10 7.6 3 Kink A E B B D D C Note : Stand-offs only used for R16-090 ~ R16-250 Typical Time-To-Trip Curve at 25°C Thermal Derating Curve Average Time Current Curves 0.75A Derating Curves for R16 Series 0.90A 1000 1.8 Percentage of Derating Current 1.10A 1.35A Time In Seconds 100 1.60A 1.85A 2.50A 10 3.00A 4.00A 5.00A 1 6.00A 7.00A 0.1 8.060A 9.00A 10.0A 0.01 1 10 100 Current In Amperes 11.0A 1.6 1.4 1.2 1.0 0.8 0.6 0.4 0.2 0.0 14.0A -40 -20 15.0A Packing : Model Reel QTY R16-160 0 20 40 Temperature (C°) 16.0A Bag QTY 500 3000 Tape & Reel packaging per EIA468-B standard. Labeling Information Sea & Land Electronic Corp. Pb RoHS Model: Part no.: Spec.: Lot no.: Q'ty: 倉儲:密封!溫度:18~33℃/濕度:30~60% A 第3页 60 80
R16-160 价格&库存
很抱歉,暂时无法提供与“R16-160”相匹配的价格&库存,您可以联系我们找货
R16-160
    • 10+0.36699
    • 100+0.28923
    • 500+0.22950
    库存:75
