LM393AM/TR
LM393AM/TR
    HGSEMI(华冠)
    SOP8
    LM393AM/TR
LM393AM/TR 数据手册
LM393A Dual Differential Comparators DESCRIPTION The LM393A consists of two independent voltage comparators. These were designed specifically to operate from a single power supply over a wide range of voltages. Operation from split power supplies is also possible and the low power supply current drain is independent of the magnitude of the power supply voltage. The outputs can be connected to other open-collector outputs to achieve wired-AND relationships. FEATURES Wide supply voltage range  Low supply current drain independent of the supply voltage.  Low input biasing current  Low input offset current  Low input offset voltage  Input common-mode voltage range includes GND  Differential input voltage range equal to the power supply voltage  Low output saturation voltage  Output voltage compatible with TTL, MOS and CMOS logic SOP8 PACKAGE INFORMATION DIP8 PIN1 PIN1 ORDERING INFORMATION DEVICE Package Type MARKING Packing Packing Qty LM393AN DIP8 LM393A TUBE 2000/box LM393AM/TR SOP8 LM393A REEL 2500/reel http://www.hgsemi.com.cn 1 2019 OCT LM393A ELECTRICAL CHARACTERISTICS at specified free-air temperature, VCC=5V (unless otherwise noted) PARAMETER TEST CONDITIONS* VIO Vcc=5V to 30V, Input offset voltage VIC=VICR min, Vo=1.4V Vo=1.4V lIO Input offset current IIB TYP MAX UNIT 25 С Full range MIN 2 5 mV 25 С 5 50 nA -25 150 -250 nA 9 Full range Vo=1.4V 25 С Full range Input bias current VICR 25 С Full range Common-mode input voltage range** AVD Large-signal differential voltage amplification lOH Vcc=15V, Vo=1.4V to 11.4V, RL 15k tO VCC VOH=5V, VID=1V, High-level output current VOH=30V, VID=1V VOL Low-level output voltage lOL Low-level output current ICC 25 С -400 0 to Vcc-1.5 V 0 to Vcc-2 50 200 25 С Full range 0.1 IOL=4mA, VID=-1V 25 С Full range 150 VOL=1.5V, VID=-1V 25 С RL= Supply current VCC=5V 50 nA 1 A 400 mV 700 6 25 С Full range VCC=30V V/mV mA 0.8 1 mA 2.5 *Full range (MIN to MAX), for the LM393A is -40 С to 125 С. All characteristics are measured with zero common-mode input voltage unless otherwise specified. **The voltage at either input or common-mode should not be allowed to go negative by more than 0.3V. The upper end of the common-mode voltage range is VCC-1.5V, but either or both inputs can go to 30V without damage. SWITCHING CHARACTERISTICS, VCC=5V, ТA=25°C PARAMETER Response time TEST CONDITIONS MIN TYP RL connected to 5V through 5.1k , 100-mV input step with 5-mV overdrive 1.3 CL=15pF* (See Note 1) TTL-level input step 0.3 MAX UNIT s *CL includes probe and jig capacitance. NOTE 1: The response time specified is the interval between the input step function and the instant, when the output crosses 1.4V. http://www.hgsemi.com.cn 2 2019 OCT LM393A PACKAGE SOP8       Dimensions In Millimeters Symbol Min A 1.250 Max 1.570 Symbol D Min  Max  A1   Q  B    a  C    b  C1    DIP8                 http://www.hgsemi.com.cn  3                                         2019 OCT LM393A Important statement: Huaguan Semiconductor Co,Ltd. reserves the right to change the products and services provided without notice. Customers should obtain the latest relevant information before ordering, and verify the timeliness and accuracy of this information. Customers are responsible for complying with safety standards and taking safety measures when using our products for system design and machine manufacturing to avoid potential risks that may result in personal injury or property damage. Our products are not licensed for applications in life support, military, aerospace, etc., so we do not bear the consequences of the application of these products in these fields. Our documentation is only permitted to be copied without any tampering with the content, so we do not accept any responsibility or liability for the altered documents. http://www.hgsemi.com.cn 4 2019 OCT
