SA5.0A
SA5.0A
    SEMBO(深波)
    DO-15
    SA5.0A
SA5.0A 数据手册
SA5.0A FEATURES      Glass passivated junction. 500W Peak Pulse Power capability at1.0 ms Excellent clamping capability. Low incremental surge resistance. Fast response time; typically lessthan 1.0 ps from 0 volts to BV forunidirectional and 5.0 ns forbidirectional.  Typical IR less than 1.0 A above 10V. DO-204AC/DO-15 MECHANICAL DATA  Case: Molded plastic  Lead: Pure tin plated lead free, solderable per MIL-STD-750, Method 2026.  Polarity : Color band denotes cathode except bipolar.  Weight : 0.34 gram. DEVICES FOR BIPOLAR APPLICATIONS  Bidirectional types use CA suffix.  Electrical Characteristics apply in both directions. MAXIMUM RATINGS AND CHARACTERISTICS Ratings at 25 ambient temperature unless otherwise specified. Type Number Peak Power Dissipation at TA= 25°C, Tp= 1ms (Note 1) Symbol PPPM Value Units Minimum 500 Watts Steady State Power Dissipation at TL= 75°C Lead Lengths 0.375 Inch 9.5mm (Note 2) Peak Forward Surge Current, 8.3ms Single Half Sine-wave Superimposed on Rated Load (JEDEC method) (Note 3) Maximum Instantaneous Forward Voltage at 35A for Unidirectional Only (Note 4) Operating and Storage Temperature Range PD 3.2 IFSM 70 VF TJ, TSTG 3.5 / 5.0 -55 to + 175 Notes: Notes: 1. Non-repetitive current pulse and derated above TA= 25°C. 2. Mounted on copper pad area of 1.6 x 1.6 inch (40 x 40mm) per. 3. 8.3ms single half sine-wave or equivalent square wave, duty cycle = 4 pulses per minutes maximum. 4. VF= 3.5V for devices of VBR200V and VF= 5.0V maximum for devices of VBR>200V. http://www.sembo.com.cn Amps Volts °C SA5.0A PACKAGE DIMENSIONS DO-204AC/DO-15 ORDERING INFORMATION 5.0 SA A 5% Voltage Tolerance Bi-Directional Voltage PACKAGING Part Number Component Package Quantity DO-204AC/DO-15 2000 SA5.0A ELECTRICAL CHARACTERISTICS SA DEVICES SA5.0A REVERSE STAND-LFF VOLTAGE VRWM(v) BREAKDOWN VOLTAGE Min.@IT VBR Min.(V) BREAKDOWN VOLTAGE Max.@IT VBR Max.(V) TEST CURRENT IT(mA) MAXIMUM CLAMPING VOLTAGE @Ipp VC(V) PEAK PULSE CURRENT Ipp(A) REVERSE LEAKAGE @VRWM IR(uA) 5.00 6.40 7.25 10 9.2 55.4 1000 http://www.sembo.com.cn SA5.0A TYPICAL CHARACTERISTICS http://www.sembo.com.cn
SA5.0A 价格&库存
很抱歉,暂时无法提供与“SA5.0A”相匹配的价格&库存,您可以联系我们找货
