AMS1117S-3.3
1A LOW DROPOUT VOLTAGE REGULATOR
Description
Features
The AMS1117 is a series of low dropout voltage
Low Dropout Voltage.
regulators which can provide up to 1A of output
Load regulation: 0.5% Max.
current. The AMS1117 is available in six fixed
Optimized for Low Voltage
voltage, 1.2, 1.5, 1.8, 2.5, 3.3 and 5.0V. Additionally
On-chip thermal limiting.
it is also available in adjustable version. On chip
Maximum Input Voltage : 30V
precision trimming adjusts the reference/ output
Adjustable Output Voltage or Fixed 1.2V,
voltage to within ± 2%. On-chip thermal limiting
1.5V, 1.8V, 2.5V, 3.3V,5V
provides protection against any combination of
MI
JS
overload and ambient temperatures that would
Standard SOT-223,TO-252 ,SOT89
Packages
Applications
The AMS1117 series is available in SOT-223, TO-
O
CR
create excessive junction temperatures.
Post Regulator for switching DC/DC
Converter
252, SOT89 packages. A minimum of 10uF
High Efficiency Linear Regulator
improve the transient response and stability.
Battery Chargers
Block Diagram
PC Add on Card
Motherboard clock supplies
LCD Monitor r
Set-top Box
r
to
uc
nd
co
mi
Se
tantalum capacitor is required at the output to
www.jsmsemi.com
第1/9页
AMS1117S-3.3
Pin Description
MI
JS
Absolute Maximum Ratings
Symbol
IOUT
TJ
Input Voltage
Description
Max
Units
30
O
CR
VIN
DC Output Current
Operating Junction Temperature Range
V
PD/(VIN-VOUT)
mA
-40 to 125
150
℃/W
Thermal Resistance (SOT-223)
θ JA
Thermal Resistance (TO-252)
125
℃/W
θ JA
Thermal Resistance (SOT89)
225
℃/W
PD
Maximum Power Dissipation (SOT-223)
600
mW
PD
Maximum Power Dissipation (TO-252)
900
mW
PD
Maximum Power Dissipation (SOT89)
400
mW
r
to
uc
nd
co
mi
Se
θ JA
www.jsmsemi.com
第2/9页
AMS1117S-3.3
Electrical Characteristics (Vin = 11μF.
www.jsmsemi.com
第5/9页
AMS1117S-3.3
Load Regulation
When the adjustable regulator is used (Fig.2), the best load regulation is accomplished when the top
of the resistor divider (R1) is connected directly to the output pin of the AMS1117. When so connected,
RP is not multiplied by the divider ratio. For Fixed output version, the top of R1 is internally connected to
the output and ground pins can be connected to low side of the load
Figure 2. Best Load Regulation Using Adjustable Output Regulator
O
CR
MI
JS
mi
Se
Thermal Protection
AMS1117 has thermal protection which limits junction temperature to 150 ℃ . However, device
functionality is only guaranteed to a maximum junction temperature of +125℃. The power dissipation
and junction temperature for AMS1117 in DPAK package are given by
nd
co
PD = (VIN – VOUT) * Iout
TJUNCTION =
TAMBIENT + (PD * θ
JA)
Note: TJUNCTION must not exceed 125℃
uc
Thermal Consideration
The AMS1117 series contain thermal limiting circuitry designed to protect itself from over-
r
to
temperature conditions. Even for normal load conditions, maximum junction temperature ratings must
not be exceeded. As mention in thermal protection section, we need to consider
all sources of thermal
resistance between junction and ambient. It includes junction-to case, case-to-heat-sink interface, and
heat sink thermal resistance itself.
Junction-to-case thermal resistance is specified from the IC junction to the bottom of the case directly
below the die. Proper mounting is required to ensure the best possible thermal flow from this area of the
package to the heat sink. The case of all devices in this series is electrically connected to the output.
Therefore, if the case of the device must be electrically isolated, a thermally conductive spacer is
recomme
www.jsmsemi.com
第6/9页
AMS1117S-3.3
PACKAGE DESCRIPTION
SOT-223 PACKAGE OUTLINE DIMENSIONS
O
CR
MI
JS
Min
Max
Min
Max
1.800
0.060
0.071
0.130
0.001
0.005
0.059
0.067
0.026
0.033
0.009
0.014
0.254
0.270
1.520
A1
0.020
A2
1.500
1.700
b
0.660
0.840
c
0.230
0.350
D
6.450
6.850
D1
2.900
3.000
0.114
0.122
E
3.450
3.850
0.136
0.152
E1
6.830
7.070
0.269
0.278
r
to
2.300(BSC)
uc
nd
co
A
e
Dimensions ln lnches
mi
Se
Dimensions ln Millimeters
Symbol
0.091(BSC)
e1
4.500
4.700
0.177
0.185
L
0.900
1.150
0.035
0.045
θ
0°
10°
www.jsmsemi.com
0°
10
第7/9页
AMS1117S-3.3
TO-252-2L PACKAGE OUTLINE DIMENSIONS
O
CR
MI
JS
Min
Max
Min
Max
2.400
0.087
0.094
0.127
0.000
0.005
2.200
A1
0.000
B
1.200
1.650
0.047
0.065
b
0.500
0.810
0.020
0.032
b1
0.700
0.900
0.028
0.035
c
0.460
0.580
0.018
0.023
c1
0.430
0.580
0.014
0.023
D
6.350
6.700
0.250
0.264
D1
5.200
5.400
0.205
0.213
E
5.400
6.200
0.213
0.244
r
to
2.300TYP
uc
nd
co
A
e
0.0901TYP
e1
4.500
4.700
0.177
0.185
L1
9.500
9.900
0.374
0.390
L2
0.950
1.600
0.037
0.063
L3
0.700
1.100
0.028
0.043
L4
2.550
2.900
0.100
0.114
V
mi
Se
Symbol
3.80REF
www.jsmsemi.com
0.150REF
第8/9页
AMS1117S-3.3
SOT89 PACKAGE OUTLINE DIMENSIONS
MI
JS
Max
Min
Max
1.400
1.600
0.055
0.063
b
0.350
0.520
0.013
0.197
b1
0.400
0.580
0.016
0.023
c
0.350
0.450
0.014
0.018
D
4.400
4.600
0.173
0.181
D1
1.550
1.750
0.061
0.069
E
2.350
2.600
0.091
0.102
E1
3.720
4.530
0.146
0.178
A
e
1.500TYP
e1
3.000TYP
0.820
1.100
www.jsmsemi.com
0.060TYP
0.118TYP
r
to
L
uc
nd
co
mi
Se
Min
O
CR
Symbol
0.032
0.047
第9/9页
很抱歉,暂时无法提供与“AMS1117S-5.0”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.58300
- 50+0.38830
- 1000+0.35200
- 国内价格
- 5+0.72805
- 50+0.58031
- 150+0.50644
- 1000+0.42364
- 2000+0.37931
- 5000+0.35705
