UM3308
8-Bit Bidirectional Voltage-Level Translator with
Auto Direction Sensing and ±15kV ESD Protection
UM3308/UM3308H CSP20 2.4×1.9
UM3308UK TSSOP20
UM3308QA QFN20 4.5×3.5
UM3308QB QFN20 3.0×3.0
General Description
UM3308/UM3308H/UM3308UK/UM3308QA/UM3308QB is an 8-channel bidirectional voltage
level translator with auto direction sensing and ±15kV ESD protection. This 8-channel
non-inverting translator uses two separate configurable power-supply rails. The A port is designed
to track VCCA. VCCA accepts any supply voltage from 1.2V to 3.6V. The B port is designed to track
VCCB. VCCB accepts any supply voltage from 1.65V to 5.5V. This allows for universal low-voltage
bidirectional translation between any of the 1.2V, 1.5V, 1.8V, 2.5V, 3.3V, and 5V voltage nodes.
Both I/O ports are auto-sensing; thus, no direction pin is required, making it ideal for data transfer
between low-voltage ASICs/PLDs and higher voltage systems.
The UM3308/UM3308H/UM3308UK/UM3308QA/UM3308QB operates at a guaranteed data
rate of 20Mbps over the entire specified operating voltage range. Within specific voltage domains,
higher data rates are up to 100Mbps.
When the output-enable (OE) input is low, all outputs are placed in the high-impedance state. The
UM3308/UM3308H/UM3308UK/UM3308QA/UM3308QB is designed so that the OE input
circuit is supplied by VCCA.
To ensure the high-impedance state during power up or power down, OE should be tied to GND
through a pull down resistor; the minimum value of the resistor is determined by the
current-sourcing capability of the driver.
The UM3308 and UM3308H are both available in CSP20 2.4×1.9 BGA package while the
UM3308H specially features in wafer backside coating process, minimize chip breakage risk. The
UM3308UK is available in TSSOP20 package, the UM3308QA is available in QFN20 4.5×3.5
package and the UM3308QB is available in QFN20 3.0×3.0 package.
Applications
Features
Low-Voltage ASIC Level Translation
Cell-Phone Cradles
Portable POS Systems
Portable Communication Devices
Low-Cost Serial Interfaces
Cell-Phones
GPS
Telecommunications Equipment
1.2V to 3.6V on A Port and 1.65V to 5.5V
on B Port (VCCA≤VCCB)
VCC Isolation Feature – If Either VCC Input
is at GND, All Outputs are in the
High-Impedance State
OE Input Circuit Referenced to VCCA
Low Power Consumption
Latch-Up Performance Exceeds 100mA
±15kV ESD Protection on B Ports
________________________________________________________________________
http://www.union-ic.com Rev.15 Aug.2021
1/18
UM3308
Pin Configurations
Top View
(Bottom View)
XX: Date Code
UM3308/UM3308H
CSP20 2.4×1.9
(Top View)
A1
1
20 B1
VCCA
2
19 VCCB
A2
3
18 B2
A3
4
17 B3
A4
5
16 B4
A5
6
15 B5
A6
7
14 B6
A7
8
13 B7
A8
9
12
OE 10
UM3308UK
XX
Pin #1 ID
B8
11 GND
XX: Week Code
UM3308UK
TSSOP20
(Top View)
2
3
4
5
6
7
8
9
VCCA
A2
A3
A4
A5
A6
A7
A8
A1
B1
1
11
OE
GND
19 VCCB
18 B2
17 B3
16 B4
15 B5
14 B6
13 B7
12
B8
UM
3308QA
XX
XX: Week Code
UM3308QA
QFN20 4.5×3.5
(Top View)
VCCA
A1
B1
VCCB
B2
18
17
16
A2
1
15
B3
A3
2
14
B4
A4
3
13
B5
A5
4
12
B6
A6
5
11
B7
GND
6
7
A7
A8
8
9
10
UM
3308
XX
XX: Week Code
UM3308QB
QFN20 3.0×3.0
OE GND B8
2/18
UM3308
Ball Mapping for UM3308/UM3308H
5
4
3
2
1
B8
B6
B4
B2
VCCB
C GND B7
B5
B3
B1
D
B
OE
A7
A5
A3
A1
A
A8
A6
A4
A2
VCCA
Transparent Top View
Pin Description
Pin Name
A1
VCCA
A2
A3
A4
A5
A6
A7
A8
OE
GND
B8
B7
B6
B5
B4
B3
B2
VCCB
B1
Function
Input/Output 1. Referenced to VCCA
A-Port Supply Voltage. 1.1V≤VCCA≤3.6V and VCCA≤VCCB
Input/Output 2. Referenced to VCCA
Input/Output 3. Referenced to VCCA
Input/Output 4. Referenced to VCCA
Input/Output 5. Referenced to VCCA
Input/Output 6. Referenced to VCCA
Input/Output 7. Referenced to VCCA
Input/Output 8. Referenced to VCCA
3-State Output Enable. Pull OE low to place all outputs in 3-state mode.
Referenced to VCCA
Ground
Input/Output 8. Referenced to VCCB
Input/Output 7. Referenced to VCCB
Input/Output 6. Referenced to VCCB
Input/Output 5. Referenced to VCCB
Input/Output 4. Referenced to VCCB
Input/Output 3. Referenced to VCCB
Input/Output 2. Referenced to VCCB
B-Port Supply Voltage. 1.65V≤VCCB≤5.5V
Input/Output 1. Referenced to VCCB
3/18
UM3308
Ordering Information
Part Number
UM3308
UM3308H
Packaging Type
Marking Code
CSP20 2.4×1.9
YE08
UM3308UK
TSSOP20
UM3308UK
UM3308QA
QFN20 4.5×3.5
UM3308QA
UM3308QB
QFN20 3.0×3.0
UM3308QB
Shipping Qty
3000pcs/7Inch
Tape & Reel
3000pcs/13Inch
Tape & Reel
3000pcs/13Inch
Tape & Reel
3000pcs/13Inch
Tape & Reel
4/18
UM3308
Absolute Maximum Ratings (Note 1)
Over operating free-air temperature range (unless otherwise noted)
Symbol
Parameter
Value
Unit
VCCA
Supply Voltage Range
-0.5 to +4.5
V
VCCB
V
A ports
B ports
-0.5 to +6.5
-0.5 to +4.5
-0.5 to +6.5
A ports
-0.5 to +4.5
B ports
-0.5 to +6.5
A ports
-0.5 to (VCCA+0.5)
B ports
-0.5 to (VCCB+0.5)
IIK
Voltage Range Applied to Any
Output in the High-Impedance or
Power-Off State (Note 2)
Output in the High or Low State
(Note 2, 3)
Input Clamp Current
VI
很抱歉,暂时无法提供与“UM3308UK”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+6.15600
- 10+5.13000
- 30+4.61160
- 100+3.89880
- 500+3.17034
- 1000+3.01644
