SLESD5Z5.0C
SLESD5Z5.0C
    SLKOR(萨科微)
    SOD-523(SC-79)
    PPP(W) 80 VRWM(V) 5 VBR(V) 8 VC(V) 9 IPP(A) 1 IR(uA) 2 CJ(pF) 6
SLESD5Z5.0C 数据手册
SLESD5Z5.0C Low Capacitance Bidirectional TVS/ESD Protection Diode DESCRIPTION FEATURES The SLESD5Z5.0C is designed to protect voltage sensitive components from ESD and transient voltage events. Excellent clamping capability, low leakage, and fast response time, make these parts ideal for ESD protection on designs where board space is at a premium. Because of its small size, it is suited for use in cellular phones, portable devices, digital cameras, power supplies and many other portable applications where board space comes at a premium. Also because of its low capacitance, it is suited for use in high frequency designs such as USB 2.0 high speed, VGA, DVI, SDI and other high speed line applications. This device has been specifically designed to protect sensitive components which are connected to data and transmission lines from overvoltage caused by ESD(electrostatic discharge), and EFT (electrical fast transients). — IEC61000-4-2 (ESD) ±15kV (air), ±8kV (contact) — IEC61000-4-4 (EFT) 40A (5/50ηs) — Peak power dissipation: 80W (8/20μs) — Protects one directional I/O line — Low clamping voltage — Working voltages : 5V — Low leakage current — Low capacitance MACHANICAL DATA — SOD-523 package — Terminals: Gold plated, solderable per MIL-STD-750, method 2026 — Packaging: Tape and Reel — Reel size: 7 inch — Weight: 0.001 gram (approx.) PIN CONFIGURATION APPLICATIONS — High Speed Line :USB1.0/2.0, VGA, DVI, SDI, — Serial and Parallel Ports — Notebooks, Desktops, Servers — Projection TV — Cellular handsets and accessories — Portable instrumentation — Peripherals www.slkormicro.com 1 SLESD5Z5.0C ABSOLUTE MAXIMUM RATING Symbol Parameter Value Units VESD ESD per IEC 61000-4-2 (Air) ESD per IEC 61000-4-2 (Contact) ±15 ±8 kV PPP Peak Pulse Power (8/20μs) 80 W TOPT Operating Temperature -55~150 °C TSTG Storage Temperature -55~150 °C ELECTRICAL CHARACTERISTICS (Tamb=25°C) Symbol Parameter Max Units VRWM Reverse Working Voltage 5.0 V VBR Reverse Breakdown Voltage IT = 1mA 8.0 V IR Reverse Leakage Current VRWM = 5V 2.0 μA VC Clamping Voltage IPP = 1A, tp = 8/20μs 9 V CJ Junction Capacitance VR = 0V, f = 1MHz 6 pF www.slkormicro.com Test Condition 2 Min Typ 5.2 4.5 SLESD5Z5.0C ELECTRICAL CHARACTERISTICS CURVE www.slkormicro.com 3 SLESD5Z5.0C SOD-523 PACKAGE OUTLINE DIMENSIONS www.slkormicro.com 4
SLESD5Z5.0C 价格&库存
很抱歉,暂时无法提供与“SLESD5Z5.0C”相匹配的价格&库存,您可以联系我们找货
SLESD5Z5.0C
  • 1+0.17680
  • 100+0.16960
库存:20
