Spec. No. 20200619
PART NO.
料 号
Page (s): 1/5
NTC THERMISTOR
WMF21 Series
REV NO.
版 本
0/A (JUN. 19th, 2020)
1. APPEARANCE 外观
1-2. Marking 标志
1-1. Dimensions (mm)尺寸
1-3.Coating 包封
□ No coating 无包封
■ Coating 包封
Material 包封材料
PF resin 酚醛树脂
Silicon 硅树脂
□Epoxy 环氧树脂
□Others 其他
Color 颜色
Green 绿色
□Red 红色
□Tan 黄色
Black 黑色
□Blue 兰色
1-4. Leads 引线
Tin – plated copper wire 镀锡铜线
Tin-plated steel wire 镀锡钢线
Axis-formed 轴弯
Straight 直形
In-Forming 内弯 □ No Lead 无引线
2. MECHANICAL CHARACTERISTICS 机械性能
Specification
技术要求
Item
指标项目
Test Conditions & Methods
测试条件/方法
Dipping theNTC terminals to a depth of 15mm in a soldering
2-1. Solder-ability 可焊性
The terminals shall be uniformly
bath of 245±5℃ and to the place of 6mm far from NTC
tinned, and its area≥95%
body for2-3s (See IEC68-2-20 /GB2423.28 Ta )
浸润部分上锡均匀,上锡面积
将引出端沾助焊剂后,浸入到温度为 245±5℃℃、深度
≥95%
为 15mm 的锡槽中锡面距 NTC 本体下端 6mm 处,持续
2-3 秒。(参见 IEC68-2-20 /GB2423.28 试验 Ta)
2-2. Resistance To Soldering Heat
耐焊接热
No visible mechanical damage.
无可见损伤
ΔR/RN ≤20%
(ΔR =∣RN-RN'∣)
Dipping the NTC terminals to a depth of 15mm in a
soldering bath of 260±5℃ and to the place for 6mm below
from NTC body for 10±1s.After recovering4-5h under 25±
2℃. The rated zero power resistance value RN' shall be
measured.
(See IEC68-2-20 /GB2423.28 Tb)
根据 IEC68-2-20(GB2423 .28)试验 Tb 进行试验。
采用焊槽法,将引出端沾助焊剂后,浸入到温度为 260±
5℃、深度为 15mm 的锡槽中,锡面距 NTC 本体下端 6mm
处,维持 10±1 秒. 在 25±2℃条件下恢复 4-5h 后,复
测额定零功率电阻 RN'.
Spec. No. 20200619
PART NO.
料 号
Page (s): 2/5
NTC THERMISTOR
WMF21 Series
2-3. Strength of lead terminal
引出端强度
No break out
无损坏
ΔR/RN ≤20%
(ΔR =∣RN-RN'∣)
REV NO.
版 本
Fasten the body and apply a force gradually to each lead until 10N and
then keep for 10sec, Hold body and apply a force to each lead until
90°slowly at 5N in the direction of lead axis and then keep for 10sec,
and do this in the opposite direction repeat for other terminal. After
recovering 4~5h under 25±2℃, the rated zero power resistance value
RN' shall be measured.
(See IEC68-2-21/GB2423.29 Ua / Ub)
根据 IEC68-2-21(GB2423 .29)试验 U 进行试验。
试验 Ua:拉力 10N,持续 10 S;
试验 Ub:弯曲 90°,拉力 5N,持续 10 S;
扭转 180°,拉力 5N,持续 10 S。
在 25±2℃条件下恢复 4~5 h 后,复测额定零功率电阻 RN'
3.ELECTRICAL CHARACTERISTICS 电气性能
3-1.Test Conditions & Method 测试条件/方法
Items
指标项目
Spec.
技术要求
Ambient temp. Range:25℃±2℃(TA).
Testing voltage: 1.5VDC
After placing for 1~2 hours under TA, the resistance value shall
be measured.
环境温度 TA: 25℃±2℃
测试电压: 1.5VDC
在常温 TA 条件下,放置 1~2 小时 后测得阻值 RN。
3-1-1.Rated Zero-Power Resistance
额定零功率电阻
RN (Ω)
3-1-2.Thermal Dissipation Constant
热耗散系数
(mW/°C)
3-1-3.Thermal Time Constant
热时间常数
τ (s)
3-1-4.Material Constant
材料常数
B (°K)
测试条件/方法
See WMF21 Series
Spec. Table attached
参见所附 WMF21 系列
规格表
The thermal dissipation constant(δ) could be calculated
by the ratio of a change in power dissipation(∆P) of the
thermistor to a change in temperature(∆T) of the
thermistor at a specified ambient temperature
在特定的环境温度下,热耗散系数(δ)为热敏电阻电功率消
耗(∆P)与本体温度变化量 (∆T)的比值.
The time(τ) shall be measured within which the
temperature change of NTC thermistor is reached at
63.2% of the ambient temperature change under zero
power condition
热时间常数(τ)为在零功率条件下,热敏电阻的温度下降到
其最初温度与最终温度之差为 63.2% 时所需要的时间
R1 , R2 is zero-power resistance at T1 , T2
R1 , R2 分别为 T1 , T2 温度下的零功率电阻
T1 = 298.15°K(25°C)
T2 = 323.15°K(50°C)
Spec. No. 20200619
PART NO.
料 号
WMF21 Series
3-1-5. Maximum permissible capacity.
最大允许电容量 (uF)
3-1-6.Max.Steady State Current
最大稳态电流(A)
Page (s): 3/5
NTC THERMISTOR
See WMF21 Series
参见所附 WMF21 系列规格表
See WMF21 Series
参见所附 WMF21 系列规格表
无可见损伤
ΔRN / RN ≤20%
REV NO.
版 本
Ambient temp. Range 环境温度:25℃±2℃.
Testing voltage 测试电压:240V
Testing Current 测试电流:参见所附 WMF21 系
列规格表
(ΔR =∣RN-RN'∣)
4. Reliability Test 可靠性试验
Items
Spec.
指标项目
技术要求
*4-1. Temp. Cycling Testing
温度循环测试
*4-2. Electrical Cycling Testing
电循环测试
无可见损伤
ΔRN / RN ≤20%
(ΔR =∣RN-RN'∣)
*4-3.LoadLife ( Endurance ) Testing
持久性测试
*4-3. Humidity Testing
耐湿性测试
无可见损伤
ΔRN / RN ≤20%
(ΔR =∣RN-RN'∣)
测试条件/方法
Ta:-40±3℃/ 30min→25±2℃/ 5min→ Tb:160±3℃/
30min→25±2℃/ 5min
Cycles: 5times
After recovering 4~5 h under 25±2℃, the rated zero
power resistance value RN' shall be measured.
在 Ta=-40±3℃和 Tb=160±3℃的环境温度中各存放 30
分钟, 循环 5 次.每次高低温循环都有在 25±2℃的环境
中过渡 5 分钟。
样品进行温度循环测试后,取出放置室温(25±2℃)4~5
小时后测量零功率电阻 RN'.
Ambient temp. Range:25℃±2℃.
Cycles: 2,000times
On / Off: 5 s / 55 s
Test Current:参见所附 WMF21 系列规格表
After recovering 4~5h under 25±2℃, the rated zero power
环境温度:25℃±2℃.
循环次数: 2,000 次
通/断: 5 s / 55 s
测试电流:参见所附 WMF21 系列规格表
样品置于室温(25±2℃)4~5 小时后,测量其零功率电
阻 RN'.
Ambient temp. Range:25℃±2℃;3A/ 1,000±24h
环境温度:25℃±2℃.
样品通过最大工作电流(参见所附 WMF21 系列规格表) ,
1,000±24 小时后,取出置于室温(25±2℃)4~5 小时
后,测量其零功率电阻 RN'.
Ambient temp. range : 40℃±2℃
R.H.:93±3% , Energized time:1000±24 h
在温度 40±2℃,相对湿度 93±3%的环境中放置 1000
±24 小时后,取出置于室温(25±2℃)4~5 小时后, 测
量其零功率电阻 RN'.
Spec. No. 20200619
PART NO.
料 号
Page (s): 4/5
NTC THERMISTOR
WMF21 Series
REV NO.
版 本
5. INSPECTION 检验方法
5-1. Lot Inspection 批量检验
Sampling with IEC410 / DIN ISO 2859-1 (GB/T2828.1-2003) ; Testing with SPEC.NO.: WL21-191225-2.
抽样方法按 IEC410/ DIN ISO 2859-1 ( GB/T2828.1-2003 ); 试验方法按 SPEC.NO.: WL21-191225-2.
Item 指标项目
IL
AQL
Appearance 外观(无露铜、锡脚、挂勾)
Ⅱ
0.65
S-2
1.5
Soldering-ability 可焊性
Item 指标项目
额定零功率电阻 RN
最大允许电容量 (uF)
5-2. Periodic Inspection 周期性试验
See the items with *参见*条目
6. NUMBERING SYSTEM AND PACKING 产品标号及包装
6-1. PART NUMBERING 产品编号
①
②
③
④
⑤
⑥
⑦
⑧
WMF21 - 10 D11
P
8
C
B
7
M
P
U
①
②
③
④
⑤
⑥
⑦
⑧
⑨ ⑩
⑪
Series WMF21: NTC thermistors for limiting of inrush current
WMF21 系列: 用于抑制浪涌电流系列 NTC 热敏电阻器
Rated zero power resistance 额定零功率电阻 4.7:4.7Ω 5:5.0Ω 10:10Ω
Disk diameter 芯片尺寸 D9:Φ9mm; D11:Φ11mm;
D13:Φ13mm; D15:Φ15mm
Tolerance of Resistance 阻值允差: M - ±20% ; U - ±15% ; K - ±10%
Coating Material 包封材料:S - Silicone 硅树脂
N - No Coating 无包封
P - PF Resin 酚酫树脂
E - Epoxy 环氧树脂
Shape of Leads 引线形状:U- Inside kink 内弯 S – Straight 直形 A - Axis Formed 轴弯
Coating materia 引线材质:U-Cu 铜线 P-Cp 钢线
Leads Diameter 引线直径:5 – Φ0.5mm 6 – Φ0.6mm 8 – Φ0.8mm 1 – Φ1.0mm
Leads Distance 引线间距:A – 2.5mm B – 5.0mm C – 7.5mm D –10.0mm
⑨
⑩ Packing Type 包装方式 B: Bulk 散装 A: Ammo 条带 C: Reel 盘带 ……
⑪ Leads length 引线长度:10: 10.0±1.0mm 3.2: 3.2±0.5mm 7: 7.0±1.0mm 20:20mm(最小值)
6-2.Lot Numbering 批号编号方法
TL1
130135
①
①
②
1/3
③
Material code 材料代号 TL1: TL 材料第 1 批;
② Pipelined batch number 流水批号: 130135;
②
Shipment branch card batch number 出货分卡号;
IL
AQL
Ⅱ
0.65
S-2
1.5
Spec. No.20200619
PART NO.
料 号
WMF21 Series
Page (s): 5/5
NTC THERMISTOR
REV NO.
版 本
6-3. Packing Type 包装方式
■ Bulk 散装
□ Ammo 条带
□ Reel 盘带
7. Operating Temperature Range 工作温度范围:
-40~ + 170℃
8. STORAGE CONDITIONS 存贮环境条件:
8-1.Temperature 温度: -10℃~+40℃
8-2. Humidity 湿度: ≤70%RH
8-3. Term 期限: ≤6 months (First-in/ First-out 先进先出)
8-4. Place 地点:
Do not exposing the components to the following conditions, otherwise, it may result in deterioration of characteristics.
不要暴露在下列环境条件下,否则将导致性能衰退或参数飘移:
1) Corrosive gas or deoxidizing gas. 腐蚀性或易氧化气体
2) Flammable and explosive gases. 易燃易爆气体
3) Oil, water and chemical liquid. 油、水和化学溶液
4) Under the sunlight. 太阳光下
8-5. Handling after seal open: After unpacking of the minimum package, reseal it promptly or store it inside a sealed container with a
drying agent.
尽量保证开口最小化,立即重新封好,并贮存在密封、带有干燥剂的容器中。
9. WARNING 注意、警告 !
Do not apply the components under the following conditions, otherwise, it may result in deterioration of characteristics,
destruction of components or in the worst case, to catching fire.
请不要在下列条件下使用本元件,否则将可能导致产品性能衰退或产品损毁,甚至引发火灾:
1) Exceeding Imax. 超过最大工作电流
2) Exceeding rated temperature range. 超过许可工作温度范围
3) Inferior thermal dissipation (Due to badly inferior thermal dissipation, some part of the components body will become
overheated and then be damaged.)
散热不良(由于散热不良,本元件可能因部分过热而导致破坏)
SPECIFICATIONS TABLE 规格表
最大 热耗散
零功率电 稳态电 系数
商品编号
商品名称
厂家型号
阻值
R25(Ω)
流
δ
Imax (mW/℃
(A)
热时间
常数
τ
(Sec)
外型尺寸
B
建议电
Value
容
B 值 @240Vac
C471924
热敏电阻
WMF21-5D5MGSU6BB20
5±20%
1
6
C471927
热敏电阻
WMF21-5D5MGUP6BB3.5
5±20%
1
6
C471932
热敏电阻
WMF21-47D5MGSU6BB25
47±20%
0.4
6
C471920
热敏电阻
WMF21-60D5MPSP5AB25
60±20%
0.4
6
18
3200
C471937
热敏电阻
WMF21-5D7MPUP
5±20%
2
10
30
2600
C471939
热敏电阻
WMF21-8D7MGUP
8±20%
1
9
28
2600
C471947
热敏电阻
WMF21-8D7MGUU
8±20%
1
9
28
2600
C471946
热敏电阻
WMF21-10D7MGUU
10±20%
1
9
27
2800
C471940
热敏电阻
WMF21-10D7MPAP
10±20%
1
9
27
2800
C471944
热敏电阻
WMF21-10D7MPSP
10±20%
1
9
27
2800
C471936
热敏电阻
WMF21-10D7MPUP
10±20%
1
9
27
2800
C471965
热敏电阻
WMF21-3D9MSUP
3±20%
4
11
35
2600
C471952
热敏电阻
WMF21-3D9XMPUP
3±20%
4
11
35
2600
C471964
热敏电阻
WMF21-5D9MGUP
5±20%
3
11
34
2600
C471961
热敏电阻
WMF21-5D9MPAU
5±20%
3
11
34
2600
C471966
热敏电阻
WMF21-5D9MPSP
5±20%
3
11
34
2600
C471953
热敏电阻
WMF21-5D9MPUP
5±20%
3
11
34
2600
C471948
热敏电阻
WMF21-5D9XMPUP
5±20%
3
11
34
2600
C471954
热敏电阻
WMF21-10D9MPAP
10±20%
2
11
32
2800
C471955
热敏电阻
WMF21-10D9MPUP
10±20%
2
11
32
2800
C471949
热敏电阻
WMF21-10D9XMPSP
10±20%
2
11
32
2800
C471950
热敏电阻
WMF21-10D9XMPUU
10±20%
2
11
32
2800
C471979
热敏电阻
WMF21-3.3D11MSAU8CB3.5 3.3±20%
5
13
43
2600
330
C471978
热敏电阻 WMF21-3.3D11MSAUT8CB3.5 3.3±20%
5
13
43
2600
330
C471985
热敏电阻
5
13
43
2600
330
C471945
热敏电阻
WMF21-5D10MSUP8CB3.5
5±20%
4
13
45
2800
C471987
热敏电阻
WMF21-5D11MGUU8CB3.5
5±20%
4
13
45
2800
WMF21-3.3D11MSOU8CB3.5 3.3±20%
68
100
200
Dmax
Tmax
6.5
5
8.5
10.50 5.50
12.5
C471986
热敏电阻
WMF21-5D11MPUP8CB3.5
5±20%
4
13
45
2800
330
C471994
热敏电阻
WMF21-5D11MPUP8CB4
5±20%
4
13
45
2800
(300)
C472002
热敏电阻
WMF21-5D11MPUP8CB5
5±20%
4
13
45
2800
C472001
热敏电阻
WMF21-5D11MPUU8CB20
5±20%
4
13
45
2800
C471975
热敏电阻
WMF21-5D11XMPUP8CB3.5
5±20%
4
13
45
2800
5
5.5
±0.05
d
F
±1
0.6
5
0.5
3
0.6
5
0.8
(0.6)
0.8
7.5(5)
7.5
(0.6) (5.0)
WMF21-5D11XMPUU8CB3.5
5±20%
4
13
45
2800
WMF21-5D11XMSSP8CB6
5±20%
4
13
45
2800
热敏电阻
WMF21-8D11MSAP8CB3.5
8±20%
3
14
47
2800
C471981
热敏电阻
WMF21-8D11MSOP8CB3.5
8±20%
3
14
47
2800
C471977
热敏电阻
WMF21-8D11XMPAP8CB20
8±20%
3
14
47
2800
C471968
热敏电阻
WMF21-8D11XMPAP8CB4
8±20%
3
14
47
2800
C471972
热敏电阻
WMF21-8D11XMSAU8CB3
8±20%
3
14
47
2800
C471990
热敏电阻
WMF21-10D11MPUP8CB5
10±20%
3
14
47
2800
C471993
热敏电阻
WMF21-10D11MPUP8CB9
10±20%
3
14
47
2800
C472003
热敏电阻
WMF21-10D11MSUP8CB25
10±20%
3
14
47
2800
C471992
热敏电阻
WMF21-10D11MSUP8CF18
10±20%
3
14
47
2800
C471984
热敏电阻
WMF21-16D11MPUP8CB4
16±20%
2
14
50
2800
C471997
热敏电阻
WMF21-22D11MPUP8CB3.5
22±20%
2
15
52
3000
C471980
热敏电阻
WMF21-33D11MPUP8CB4
33±20%
1.5
15
52
3000
C472008
热敏电阻
WMF21-5D13MGSP
5±20%
5
15
68
2800
C472014
热敏电阻
WMF21-5D13MGUP
5±20%
5
15
68
2800
C472019
热敏电阻
WMF21-5D13MPAP
5±20%
5
15
68
2800
C472010
热敏电阻
WMF21-5D13MPSP
5±20%
5
15
68
2800
C472007
热敏电阻
WMF21-5D13MPUP
5±20%
5
15
68
2800
C472011
热敏电阻
WMF21-5D13MSUU
5±20%
5
15
68
2800
C472018
热敏电阻
WMF21-8D13MGSP
8±20%
4
15
60
3000
C472013
热敏电阻
WMF21-8D13MPUP
8±20%
4
15
60
3000
C472012
热敏电阻
WMF21-10D13MPUP
10±20%
4
15
65
3000
C472032
热敏电阻
WMF21-2.2D15MSAUT
2.2±20%
7
19
69
2800
C472027
热敏电阻
WMF21-2.2D15MSUU
2.2±20%
7
19
69
2800
C472036
热敏电阻
WMF21-2.5D15MGSU
2.5±20%
7
19
69
2800
C472029
热敏电阻
WMF21-2.5D15MSAU
2.5±20%
7
19
69
2800
C472049
热敏电阻
WMF21-3D15MPUP
3±20%
7
18
76
2900
C472039
热敏电阻
WMF21-3D15MSAP
3±20%
7
18
76
2900
C472047
热敏电阻
WMF21-3.3D15MSUU
3.3±20%
7
18
76
2900
C472034
热敏电阻
WMF21-5D15MGUP
5±20%
6
3000
C472028
热敏电阻
WMF21-5D15MGUU
5±20%
6
3000
C472042
热敏电阻
WMF21-5D15MPUP
5±20%
6
3000
C472035
热敏电阻
WMF21-5D15MSAU
5±20%
6
3000
C472037
热敏电阻
WMF21-5D15MSAUT
5±20%
6
3000
C472030
热敏电阻
WMF21-5D15MSUU
5±20%
6
3000
C472051
热敏电阻
WMF21-10D15MGUP
5±20%
5
3200
C472046
热敏电阻
WMF21-10D15MPUP
10±20%
5
3200
C471970
热敏电阻
C471969
热敏电阻
C471996
(MF71)
220
560
14.5
6
16.5
6
0.8
10.0
(1.0) (7.5)
820
610
610
0.8
10.0
(1.0) (7.5)
C472054
热敏电阻
WMF21-10D15MSSU
10±20%
5
3200
C472038
热敏电阻
WMF21-10D15MSUU
10±20%
5
3200
C472053
热敏电阻
WMF21-10D15USUP
10±20%
5
3200
C472041
热敏电阻
WMF21-15D15MPUU
15±20%
4
21
85
3200
C472033
热敏电阻
WMF21-20D15MSUU
20±20%
4
17
86
3200
500
C472043
热敏电阻
WMF21-40D15MSSU
40±20%
3.5
18
86
3200
470
C472040
热敏电阻
WMF21-47D15MPUU
47±20%
3
21
86
3200
470
C472059
热敏电阻
WMF21-5D22MSSU
5±20%
7
23
87
3000
1100
21.5
7
0.8
10.0
(1.0) (7.5)
WMF21-10D13MPUP8CB5 价格&库存
很抱歉,暂时无法提供与“WMF21-10D13MPUP8CB5”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.03670
- 50+0.81897
- 150+0.72566
