HS2D
HS2D
    RUILON(瑞隆源)
    SMB(DO-214AA)
    耐压:200V 电流:2A 反向恢复时间:50NS
HS2D 数据手册
HS2A THRU HS2M(US2A THRU US2M) High Efficient Rectifier Features ● ● ● ● ● ● Low profile package Ideal for automated placement Glass passivated chip junction Ultra-fast reverse recovery time High forward surge capability Meets MSL level 1, per J-STD-020,LF maximum peak of 260 °C Typical Application For use in high frequency rectification of power supply, inverters, converters, and freewheeling diodes for consumer and telecommunication. Mechanical Data ● Package: DO-214AA(SMB) Molding compound meets UL 94 V-0 flammability rating,RoHS-compliant Terminals: Tin plated leads, solderable per J-STD-002 and JESD22-B102 Polarity: Cathode line denotes the cathode end ● ● ■ Maximum Ratings (Ta=25℃ Unless otherwise specified) PARAMETER Unit VRRM V IF(AV) A Surge(Nonrepetitive)Forward Current IFSM A Storage Temperature Tstg ℃ -55 ~ +150 Junction Temperature Tj ℃ -55 ~ +150 Repetitive Peak Reverse Voltage Average Forward Current Conditions HS2/US2 F G Symbol A 50 B D J K M 100 200 300 400 600 800 1000 60HZ Half-sine wave,Resistance 2.0 load, TL=110℃ 60HZ Half-sine wave, 1 cycle 50 , Ta=25℃ ■ Electrical Characteristics(Ta=25℃ Unless otherwise specified) PARAMETER Peak Forward Voltage Peak Reverse Current Maximum reverse recovery time Symbol Unit Conditions VFM V IFM =2.0A IRRM1 IRRM2 Trr Thermal RθJ-A Resistance(Typical) RθJ-L B D 1.0 HS2/US2 F G 1.3 Ta=25℃ 5.0 Ta=100℃ 100 μA VRM=VRRM ns IF=0.5A,IR=1.0A,Irr=0.25A ℃/W A 50 J K M 1.7 75 Between junction and ambient 801) Between junction and terminal 201) Notes: 1) Thermal resistance from junction to ambient and from junction to lead mounted on P.C.B. with 0.2" x 0.2" (5.0 mm x 5.0 mm) copper pad areas. Specifications are subject to change without notice. Please refer to http://www.ruilon.com.cn for current information. Revised: 2021-11-29 Page:1 HS2A THRU HS2M(US2A THRU US2M) ■ Characteristics(Typical) FIG1: Forward Current Derating Curve FIG2:Surge Forward Current Capability FIG3:Instantaneous Forward Voltage FIG4:Typical Reverse Characteristics FIG5:Diagram of circuit and Testing wave form of reverse recovery time Specifications are subject to change without notice. Please refer to http://www.ruilon.com.cn for current information. Revised: 2021-11-29 Page:2 HS2A THRU HS2M(US2A THRU US2M) ■ Ordering Information (Example) PREFERED HS2A THRU HS2M PACKAGE CODE MINIMUM PACKAGE(pcs) DO-214AA(SMB) 3000 INNER BOX OUTER CARTON QUANTITY(pcs) QUANTITY(pcs) 6000 48000 DELIVERY MODE 13” reel (US2A THRU US2M) ■ Outline Dimensions Specifications are subject to change without notice. Please refer to http://www.ruilon.com.cn for current information. Revised: 2021-11-29 Page:3
很抱歉,暂时无法提供与“HS2D”相匹配的价格&库存,您可以联系我们找货
HS2D
  • 10+0.21909
  • 100+0.17472
  • 300+0.15256
  • 3000+0.12852
  • 6000+0.11522
  • 9000+0.10857
库存:75
