4409
4409
    KUU(永裕泰)
    SOP-8
    P沟道增强型功率MOSFET 1个P沟道 耐压:30V 电流:15A
4409 数据手册
4409 P-Channel Enhancement Mode Power MOSFET SOP-8 Description S 1 8 D S 2 7 D excellent RDS(ON), low gate charge and operation with gate S 3 6 D voltages as low as 4.5V. G 4 5 D The 4409 uses advanced trench technology to provide Top View General Features Equiva len t Cir cu it ● VDS = -30V RDS(ON) < 15mΩ @ VGS=-4.5V I D = -12.0A RDS(ON) < 12mΩ @ VGS=-10V S G I D = -15.0A ● High power and current handing capability D ● Lead free product is acquired MARKING ● Surface mount package 4409 Application ● Battery Switch o ● Load switch ● Power management Absolute Maximum Ratings (TA=25oC, unless otherwise noted) Symbol Parameter Ratings Units VDS Drain-Source Voltage -30 V VGS Gate-Source Voltage ±20 V -15 A -60 A 30 A 135 mJ o ID Drain Current @TA=25 C IDM Drain Current (Pulsed) IAR Avalanche Current EAR Repetitive Avalanche Energy L=0.3mH PD IS Tj, Tstg RqJA a o 3.1 o Total Power Dissipation @TA=75 C 2.1 Maximum Diode Forward Current -2.1 A -55 to +150 °C 40 °C/W Total Power Dissipation @TA=25 C Operating Junction and Storage Temperature Range b Thermal Resistance Junction to Ambient (PCB mounted) a: Repetitive Rating: Pulse width limited by the maximum junction temperation. 2 b: 1-in 2oz Cu PCB board 1/6 W 4409 Electrical Characteristics (TA=25°C, unless otherwise noted) Symbol Characteristic Test Conditions Min. Typ. Max. Unit · Off Characteristics BVDSS Drain-Source Breakdown Voltage VGS=0V, ID=-250uA -30 - - V IDSS Zero Gate Voltage Drain Current VDS=-24V, VGS=0V - - -1 uA IGSS Gate-Body Leakage Current VGS=±25V, VDS=0V - - ±100 nA · On Characteristicsc VGS(th) Gate Threshold Voltage VDS=VGS, ID=-250uA -1.0 -1.5 IDS(on) On State Drain Current VDS=-5V, VGS=-10V 60 - - VGS=-10V, ID=-15A - 9.5 12 RDS(on) Drain-Source On-State Resistance gFS Forward Transconductance · Dynamic Characteristics -3.0 V A mW VGS=-4.5V, ID=-12 A - 13 15 VDS=-10V, ID=-5A - 26 - - 2900 - - 410 - - 280 - 1 2 3 - 48 - - 12 - S d Ciss Input Capacitance Coss Output Capacitance Crss Reverse Transfer Capacitance Rg Gate Resistance · Switching Characteristics VDS=-15V, VGS=0V, f=1MHz VDS=0V, VGS=0V, f=1MHz pF W d Qg Total Gate Charge Qgs Gate-Source Charge Qgd Gate-Drain Charge - 14 - td(on) Turn-on Delay Time - 15 - tr Turn-on Rise Time VDD =-15V, ID=-10A, - 11 - td(off) Turn-off Delay Time VGS=-10V, RG=3W - 44 - - 21 - - 33 40 nS - 23 - nC - - -1 V - - -2.1 A tf Turn-off Fall Time trr Reverse Recovery Time Qrr Reverse Recovery Charge VDS=-15V, ID=-10A, VGS=-10V IDS=-12A, dI/ dt=100A/ uS nC nS · Drain-Source Diode Characteristics VSD Drain-Source Diode Forward Voltage IS Drain-Source Diode Forward Current VGS=0V, IS=-1A Note: Pulse Test: Pulse Width £300us, Duty Cycle£2% 2/6 4409 Typical Electrical and Thermal Characteristics ton tr td(on) toff tf td(off) 90% VOUT 90% INVERTED 10% 10% 90% VIN 50% 50% 10% PULSE WIDTH Figure 2 Switching Waveforms PD Power(W) ID- Drain Current (A) Figure 1 Switching Test Circuit Vds Drain-Source Voltage (V) TJ-Junction Temperature(℃) Figure 4 Safe Operation Area ID- Drain Current (A) Rdson On-Resistance(mΩ) Figure 3 Power Dissipation ID- Drain Current (A) Vds Drain-Source Voltage (V) Figure 6 Drain-Source On-Resistance Figure 5 Output Characteristics 3/6 ID- Drain Current (A) Normalized On-Resistance 4409 TJ-Junction Temperature(℃) Vgs Gate-Source Voltage (V) Figure 8 Drain-Source On-Resistance C Capacitance (pF) Rdson On-Resistance(mΩ) Figure 7 Transfer Characteristics Vgs Gate-Source Voltage (V) Vds Drain-Source Voltage (V) Figure 10 Capacitance vs Vds Vgs Gate-Source Voltage (V) Is- Reverse Drain Current (A) Figure 9 Rdson vs Vgs Qg Gate Charge (nC) Vsd Source-Drain Voltage (V) Figure 11 Gate Charge Figure 12 Source- Drain Diode Forward 4/6 r(t),Normalized Effective Transient Thermal Impedance 4409 Square Wave Pluse Duration(sec) Figure 13 Normalized Maximum Transient Thermal Impedance 5/6 4409 SOP-8 Package Information Symbol Dimensions In Millimeters Dimensions In Inches Min. Max. Min. Max. A 1.350 1.750 0.053 0.069 A1 0.100 0.250 0.004 0.010 A2 1.350 1.550 0.053 0.061 b 0.330 0.510 0.013 0.020 c 0.170 0.250 0.006 0.010 D 4.700 5.100 0.185 0.200 E 3.800 4.000 0.150 0.157 E1 5.800 6.200 0.228 0.244 e 1.270(BSC) 0.050(BSC) L 0.400 1.270 0.016 0.050 θ 0° 8° 0° 8° 6/6
很抱歉,暂时无法提供与“4409”相匹配的价格&库存,您可以联系我们找货
