B10B-XADSS-N-A(LF)(SN)
    JST
    插件,P=2.5mm
    线对板针座 2x5P 直插 间距:2.5mm
B10B-XADSS-N-A(LF)(SN) 数据手册
ラジアル XAD CONNECTOR 2.5mm pitch/Disconnectable Crimp style connectors Specifications ––––––––––––––––––– • Current rating: 3A AC, DC (AWG #20) • Voltage rating: 250V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/10m Ω max. After environmental testing/20m Ω max. • Insulation resistance: 1,000M Ω min. • Withstanding voltage: 1,000V AC/minute • Applicable wire: AWG #28 to #20 • Applicable PC board thickness: 1.6mm * Compliant with RoHS. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. Double-row construction connector with secure locking device. Standards –––––––––––––––––––––– • Secure locking device • Solder crack preventive material • Polarizing boss • Mis-insertion preventive design 0 Recognized E60389 1 Certified LR20812 2 R9851219 PC board layout (viewed from component side) and Assembly layout Top entry type 11.5 With a boss +0.1 φ0.9 0 Without a boss 0.1 φ0.9+  0 Circuit No.1 1.7±0.05 A±0.05 Side entry type 2.5±0.05 Even number circuits Odd number circuits 13.8 2.5±0.05 2.5±0.05 1.8±0.05 Even number circuits Odd number circuits 2.5±0.05 +0.1 φ1.1 0 Circuit No.1 A±0.05 2.8±0.05 2.5±0.05 A±0.05 13.5 2.5 ±0.05 Even number circuits 7.6±0.05 Circuit No.1 Odd number circuits 2.0±0.05 19.9 0.1 φ0.9+  0 Note: 1. Tolerances are non-cumulative: ±0.05mm for all centers. 2. Hole dimensions differ according to the kind of PC board and piercing method. The dimensions above should serve as a guideline. Contact JST for details. 1 XAD CONNECTOR Contact Model No. 1.9 SXA-01T-P0.6 SXA-001T-P0.6 SXA-001T-P0.6L Applicable wire mm2 AWG# 0.22∼0.5  0.08∼0.33 0.13∼0.33 6.5 3.1 1.3 Insulation O.D. (mm) Q'ty / reel 24∼20 1.5∼1.9 8,000 28∼22 0.8∼1.9 8,000 26∼22 1.3∼1.7 8,000 Material and Finish 1.6 Phosphor bronze, tin-plated (reflow treatment) 2.3 RoHS compliance Note: 1. SXA-001T-P0.6L is low-insertion force type contact, for easier insertion/withdrawal, which would be less resistant to the vibration. The crimp height is different from the standard contact. 2. Contact JST for gold-plated products. Crimping machine Crimp applicator Contact SXA-001T-P0.6 AP-K2N SXA-001T-P0.6L Applicator Dies Crimp applicator with dies MKS-L MK/SXA/M-001-06 APLMK SXA/M001-06 *MKS-SC SC/SXA/M-001-06 APLSC SXA/M001-06 MKS-L MK/SXA-001-06L APLMK SXA001-06L *MKS-SC SC/SXA-001-06L Contact SXA-01T-P0.6 Crimping machine Crimp applicator AP-K2N MKS-L *MKS-SC Applicator Dies Crimp applicator with dies MK/SXA/M-01-06 APLMK SXA/M01-06 SC/SXA/M-01-06 APLSC SXA/M01-06 Note:*Strip-crimp applicator APLSC SXA001-06L Housing (8 to 16 circuits) B A 2.5 Circuit No.1 mark 3.6 11.4 12.0 6.8 H JST 12 (18 to 40 circuits) B A 2.5 Circuit No.1 mark 3.6 11.4 12.0 6.8 H JST 30 Circuits Model No. Dimensions (mm) A B 8 XADRP-08V 7.5 14.7 1,000 10 XADRP-10V 10.0 17.2 1,000 12 XADRP-12V 12.5 19.7 1,000 14 XADRP-14V 15.0 22.2 1,000 16 XADRP-16V 17.5 24.7 1,000 18 XADRP-18V 20.0 27.2 1,000 20 XADRP-20V 22.5 29.7 500 22 XADRP-22V 25.0 32.2 500 24 XADRP-24V 27.5 34.7 500 26 XADRP-26V 30.0 37.2 500 28 XADRP-28V 32.5 39.7 500 30 XADRP-30V 35.0 42.2 500 32 XADRP-32V 37.5 44.7 500 34 XADRP-34V 40.0 47.2 500 36 XADRP-36V 42.5 49.7 250 40 XADRP-40V 47.5 54.7 250 Material PA 66, UL94V-0, natural (white) RoHS compliance Note: Contact JST if retainers are required. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. 2 Q'ty / bag XADRP-08V-oo(blank)…natural (white) K…black R…red E…blue O…orange M…green L…lemon yellow PK…pink XAD CONNECTOR Shrouded header Model No. Top entry type B A 2.5 8 B08B-XADSS-N B08B-XADSS-N-A S08B-XADSS-N 7.5 15.0 200 270 10 B10B-XADSS-N B10B-XADSS-N-A S10B-XADSS-N 10.0 17.5 200 234 12 B12B-XADSS-N B12B-XADSS-N-A S12B-XADSS-N 12.5 20.0 200 198 14 B14B-XADSS-N B14B-XADSS-N-A S14B-XADSS-N 15.0 22.5 150 180 16 B16B-XADSS-N B16B-XADSS-N-A S16B-XADSS-N 17.5 25.0 150 10.1 JST 12 φ0.6 162 18 B18B-XADSS-N B18B-XADSS-N-A S18B-XADSS-N 20.0 27.5 150 144 20 B20B-XADSS-N B20B-XADSS-N-A S20B-XADSS-N 22.5 30.0 100 126 22 B22B-XADSS-N B22B-XADSS-N-A − 25.0 32.5 100 − 24 B24B-XADSS-N B24B-XADSS-N-A − 27.5 35.0 100 − 26 B26B-XADSS-N B26B-XADSS-N-A S26B-XADSS-N 30.0 37.5 100 108 28 B28B-XADSS-N B28B-XADSS-N-A − 32.5 40.0 100 − 30 B30B-XADSS-N B30B-XADSS-N-A − 35.0 42.5 50 − 32 B32B-XADSS-N B32B-XADSS-N-A − 37.5 45.0 50 − 34 B34B-XADSS-N B34B-XADSS-N-A − 40.0 47.5 50 − 36 B36B-XADSS-N B36B-XADSS-N-A − 42.5 50.0 50 − 40 B40B-XADSS-N B40B-XADSS-N-A − 47.5 55.0 50 − Without a boss 2.5 1.7 (18 to 40 circuits) 1.5 H Top entry type 10.1 Circuit No.1 Mark (3.5) (8 to 16 circuits) 1.8 φ0.9 Circuit No.1 Mark B A 10.1 2.5 (3.5) 10.1 1.5 2.5 H JST 22 1.7 φ0.6 1.8 φ0.9 Dimensions (mm) Q'ty / box Top Side Side entry type A B entry entry type type Circuits With a boss Side entry type Material and Finish (8 to 16 circuits) Pin: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: Glass-filled PA 66, UL94V-0, natural (white) B A 3.5 12.1 9.9 RoHS compliance This product displays (LF)(SN) on a label. Note: Contact JST for the headers with gold-plated pins. φ0.6 16.2 10.3 2.5 2.5 2.7 2.5 As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. (3.4) 9.9 (18 to 26 circuits) B A 3.5 12.1 φ0.6 9.9 2.5 2.7 16.2 10.3 2.5 2.5 B08B-XADSS-NS…natural (white) K…black R…red E…blue O…orange M…green L…lemon yellow PK…pink (3.4) 9.9 3
1. 物料型号:文档列出了不同型号的XAD连接器,例如SXA-01T-P0.6、SXA-001T-P0.6和SXA-001T-P0.6L。
2. 器件简介:XAD连接器是2.5mm间距的可断开压接式连接器,具有安全锁定装置、防止焊接裂纹的材料、极性凸台和防误插设计。
3. 引脚分配:文档提供了顶入式和侧入式XAD连接器的PCB布局和组装布局图,展示了不同电路数量的引脚分配
4. 参数特性:包括额定电流、额定电压、温度范围、接触电阻、绝缘电阻、耐电压等。
5. 功能详解:描述了连接器的双排结构、安全锁定装置、焊接裂纹预防材料等特性。
6. 应用信息:文档提到了连接器的适用电线范围和PCB板厚度。
7. 封装信息:提供了连接器的外形尺寸、材料和完成方式,包括磷青铜锡镀层(回流处理)和符合RoHS的材料。
B10B-XADSS-N-A(LF)(SN) 价格&库存
很抱歉,暂时无法提供与“B10B-XADSS-N-A(LF)(SN)”相匹配的价格&库存,您可以联系我们找货
    • 72+5.4593472+0.70914
    • 91+4.5494591+0.59095
    • 360+3.63956360+0.47276
    库存:1316
      • 1+3.079571+0.40002
      • 50+2.9403850+0.38194
      • 100+2.40972100+0.31301
      • 300+2.06175300+0.26781
      • 500+1.99215500+0.25877
      • 1000+1.939961000+0.25199
      库存:1
      • 5+2.51187
      • 50+2.05071
      • 200+1.85296
      • 400+1.60640
      库存:2225
        • 1+2.925591+0.38002
        • 50+2.7933650+0.36285
        • 100+2.28924100+0.29736
        • 300+1.95866300+0.25442
        • 500+1.89255500+0.24584
        • 1000+1.842961000+0.23939
        • 4000+1.801644000+0.23403
        库存:46
          库存:1600
          • 1+5.701501+0.74070
          • 10+4.9230010+0.63960
          • 25+4.5037025+0.58510
          • 100+3.42570100+0.44510
          • 200+3.41370200+0.44350
          • 1000+2.850801000+0.37040
          • 5000+2.778905000+0.36100
          • 10000+2.7070010000+0.35170
          库存:49
