MB220S
MB220S
    SK(時科)
    MBS
    MB220S
MB220S 数据手册
MB24S THRU MB220S 2A SURFACE MOUNT SCHOTTKY BRIDGE PINNING FEATURES: PIN DESCRIPTION 1 Input Pin(~) 2 Input Pin(~) Reverse Voltage - 40 to 200 V 3 Output Anode(+) Forward Current - 2 A 4 Output Cathode(-) High Surge Current Capability Designed for Surface Mount Application 3 4 MECHANICAL DATA • Case: MBS • Terminals: Solderable per MIL-STD-750, Method 2026 • Approx. Weight: 100mg / 0.0035oz 2 1 MBS Package Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %. Symbols MB24S MB26S MB28S MB210S MB220S Units Maximum Repetitive Peak Reverse Voltage V RRM 40 60 80 100 200 V Maximum RMS voltage V RMS 28 42 56 70 140 V Maximum DC Blocking Voltage V DC 40 60 80 100 200 V Parameter Maximum Average Forward Rectified Current at Tc = 100°C Peak Forward Surge Current,8.3ms Single Half Sine-wave Superimposed on Rated Load (JEDEC method) Max Instantaneous Forward Voltage at 2 A Maximum DC Reverse Current T a = 25°C at Rated DC Reverse Voltage T a =100°C Typical Junction Capacitance 1) Typical Thermal Resistance 2) Operating Junction Temperature Range Storage Temperature Range I F(AV) 2.0 I FSM VF 50 0.55 0.70 80 220 A 0.85 V mA pF °C/W RθJA 75 Tj -55 ~ +150 °C T stg -55 ~ +150 °C Note: 1. Measured at 1MHz and applied reverse voltage of 4 V D.C. 2. Mounted on glass epoxy PC board with 4×1.5"×1.5"(3.81×3.81 cm)copper pad. REV.08 40 0.3 5 0.5 10 IR Cj A 1 of 3 MB24S THRU MB220S Fig.2 Typical Reverse Characteristics Instaneous Reverse Current ( μA) Fig.1 Forward Current Derating Curve Average Forward Current (A) 3.0 2.5 2.0 1.5 1.0 0.5 Resistive or Inductive Load 0.0 25 50 75 100 125 150 10 4 T J =100°C 10 3 T J =75°C 10 2 MB24S/MB26S MB28S-MB220S 10 1 T J =25°C 10 0 0 Case Temperature (°C) Junction Capacitance ( pF) 1.0 MB24S MB26S MB28S/MB220S 0.1 0.4 0.6 0.8 1.0 1.2 1.4 1.6 100 50 MB24S 20 MB26F-MB220S 10 1 100 10 Reverse Voltage (V) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current Fig.6- Typical Transient Thermal Impedance MB28S-MB220S 50 40 30 20 8.3 ms Single Half Sine Wave (JEDEC Method) 00 10 100 Number of Cycles at 60Hz REV.08 T J =25°C 0.1 MB24S-MB26S 1 100 Instaneous Forward Voltage (V) 60 10 80 200 1.8 Transient Thermal Impedance( °C /W) Instaneous Forward Current (A) Peak Forward Surage Current (A) 10 0.2 60 500 T J =25°C 0 40 Fig.4 Typical Junction Capacitance Fig.3 Typical Forward Characteristic 20 20 Percent of Rated Peak Reverse Voltage(%) 1000 100 10 1 0.01 0.1 1 10 t, Pulse Duration(sec) 2 of 3 100 MB24S THRU MB220S PACKAGE OUTLINE Plastic surface mounted package; 4 leads MBS A ∠ALL ROUND C a L1 L d HE e D e E MBS mechanical data A C D E HE d e L L1 a max 2.6 0.22 5.0 4.1 7.0 2.7 0.7 1.7 1.1 0.2 min 2.2 0.15 4.5 3.6 6.4 2.3 0.5 1.3 0.5 max 102 8.7 197 161 276 106 28 67 43 min 94 5.9 177 142 252 91 20 51 20 UNIT ∠ mm 7° mil 6.0 236 2.5 100 0.9 35 2.4 94 REV.08 mm Unit : (mil) 3 of 3 8
MB220S 价格&库存
很抱歉,暂时无法提供与“MB220S”相匹配的价格&库存,您可以联系我们找货
MB220S
    • 1+0.61990
    库存:599
