SLM8833EC
SLM8833EC
    SILLUMIN(数明半导体)
    QFN-24-EP(4x4)
SLM8833EC 数据手册
SLM8833 Ultracompact, 1.5 A Thermoelectric Cooler (TEC) Controller GENERAL DESCRIPTION FEATURES The SLM8833 is a monolithic TEC controller with an integrated TEC controller. It has a linear power stage and a pulse-width modulation (PWM) power stage. The linear controller works with the PWM driver to control the internal power MOSFETs in an H-bridge configuration. Depending on the control voltage at the CONT input, the SLM8833 drives current through a TEC to settle the temperature of a laser diode or a passive component attached to the TEC module to the programmed target temperature.  The control voltage applied to the CONT input pin is generated by a digital-to-analog converter (DAC) closing the digital proportional, integral, derivative (PID) loop of temperature control system. The internal 2.50 V reference voltage provides a 1% accurate output that is used to bias a thermistor temperature sensing bridge as well as a voltage divider network to program the maximum TEC current and voltage limits for both the heating and cooling modes. It can also be a reference voltage for the DAC and the temperature sensing circuit, including a thermistor bridge and an analog-to-digital converter (ADC).           Integrated super low RDSON MOSFETs for the TEC controller High efficiency single inductor architecture TEC voltage and current operation monitoring No external sense resistor required Independent TEC heating and cooling current limit settings Programmable maximum TEC voltage 2.0 MHz PWM driver switching frequency External synchronization 2.50 V reference output with 1% accuracy Digital thermal control loop compatible Available in a 25-ball, 2.5 mm × 2.5 mm WLCSP or in a 24-lead, 4 mm × 4 mm QFN APPLICATIONS      TEC temperature control Optical modules Optical fiber amplifiers Optical networking systems Instruments requiring TEC temperature control SYSTEM BLOCK DIAGRAM Figure 1. TEC System Block Diagram Copyright© 2019, Sillumin® Semiconductor Co., Ltd. Rev0.2 September 2019 1 SLM8833 TYPICAL APPLICATION CIRCUIT Figure 2. Typical Application Circuit with Digital PID Compensation in a Temperature Control Loop Figure 3. TEC Controller in a Digital Temperature Control Loop (WLCSP) Copyright© 2019, Sillumin® Semiconductor Co., Ltd. Rev0.2 September 2019 2 SLM8833 PIN CONFIGURATION Package 25-ball, 2.5 mm × 2.5 mm WLCSP 24-lead, 4 mm × 4 mm QFN Pin Configuration (Top View) PIN DESCRIPTION Pin No. WLCSP QFN Pin Name Description A1, A2 A3 to A5, B3, B4 B1, B2 18, 19 PGNDL Power Ground of the Linear TEC Controller. 1, 20 to 24 DNC Do Not Connect. Don’t connect to pins. 17 LDR B5 3 VLIM/SD C1, C2 N/A1 PVIN Output of the Linear TEC Controller. Voltage Limit/Shutdown. This pin sets the cooling and heating TEC voltage limits. When this pin is pulled low, the device shuts down. Power Input for the TEC Controller. N/A1 16 PVINL Power Input for the Linear TEC Driver. N/A1 15 PVINS Power Input for the PWM TEC Driver. C3 11 ITEC TEC Current Output. C4 2 CONT C5 4 ILIM Current Limit. This pin sets the TEC cooling and heating current limits. D1, D2 14 SW Switch Node Output of the PWM TEC Controller. D3 9 VTEC D4 8 EN/SY D5 5 VDD TEC Voltage Output. Enable/Synchronization. Set this pin high to enable the device. An external synchronization clock input can be applied to this pin. Power for the Controller Circuits. E1, E2 12, 13 PGNDS Power Ground of the PWM TEC Controller. E3 10 SFB Feedback of the PWM TEC Controller Output. E4 7 AGND Signal Ground. E5 6 VREF 2.5 V Reference Output. N/A1 0 EPAD Exposed Pad. Solder to the analog ground plane on the board. N/A1: Control Input of the TEC Driver. Apply a control signal from the DAC to this pin to close the thermal loop. Not Available. Copyright© 2019, Sillumin® Semiconductor Co., Ltd. Rev0.2 September 2019 3 SLM8833 ORDERING INFORMATION Industrial Range: -40°C to +125°C Order Part No. SLM8833FA-7G SLM8833EC Package 25-ball, 2.5 mm × 2.5 mm WLCSP 24-lead, 4 mm × 4 mm QFN QTY 500/Reel 1000/Reel ABSOLUTE MAXIMUM RATINGS PVIN to PGNDL / PGNDS (WLCSP) PVINL to PGNDL; PBINS to PGNDS (QFN) LDR to PGNDL (WLCSP) LDR to PGNDL (QFN) SW to PGNDS SFB / VLIM/SD / ILIM /CONT/ EN/SY to AGND AGND to PGNDL / PGNDS VDD / ITEC / VTEC to AGND VREF to AGND Maximum Current VREF to AGND ITEC to AGND VTEC to AGND Maximum junction temperature, TJMAX Storage temperature range, TSTG Operating temperature range, TJ Package Thermal Resistance Junction to Ambient, Rth-JA Junction to Case, Rth-JC ESD (HBM) ESD (MM) ESD (FICDM) Latch-up -0.3 V ~ 6.0 V -0.3 V ~ 6.0 V -0.3 V ~ VPVIN -0.3 V ~ VPVINL -0.3 V ~ 6.0 V -0.3 V ~ VVDD -0.3 V ~ 0.3 V -0.3 V ~ 6.0 V -0.3 V ~ 3 V WLCSP QFN WLCSP QFN 20 mA 50 mA 50 mA 150°C -65°~+150°C -40°C~+125°C 48 °C/w 37 °C/w 0.6 °C/w 1.65 °C/w 2000 V 200 V 1500 V +/- 100 mA Note: Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other condition beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Copyright© 2019, Sillumin® Semiconductor Co., Ltd. Rev0.2 September 2019 4 SLM8833 ELECTRICAL CHARACTERISTICS (TBD) Test condition is VIN = 2.7 V to 5.5 V, TJ = −40°C ~ +125°C for minimum/maximum specifications, and T A = 25°C for typical specifications, unless otherwise specified. Symbol Parameter Condition Min. Typ. Max. Unit Power Supply VPVIN Driver Supply Voltage 2.7 5.5 V VVDD Controller Supply Voltage 2.7 5.5 V IVDD Supply Current ISD Shutdown Current Under Voltage Lockout Threshold UVLO Under Voltage Lockout Hysteresis Reference Voltage VVREF Reference Voltage Linear Output Output Voltage Low VLDR Output Voltage High ILDR_SOURCE ILDR_SINK RDSON_PMOS RDSON_NMOS Maximum Source Current Maximum Sink Current P-MOSFET ON Resistance (ILDR = 0.6 A) N-MOSFET ON Resistance (ILDR = 0.6 A) PWM switching EN/SY = AGND or VLIM/SD = AGND VVDD Rising IVREF = 0 mA to 10 mA 12 mA 350 700 μA 2.45 2.55 2.65 V 80 90 100 mV 2.47 5 2.50 2.52 5 V 0 VPVIN ILDR = 0 A TJ = -40°C to +105°C 1.5 TJ = -40°C to +125°C 1.2 V A TJ = -40°C to +105°C 1.5 TJ = -40°C to +125°C 1.2 WLCSP, VPVIN = 5.0 V 28 35 WLCSP, VPVIN = 3.3 V 31 38 QFN, VPVIN = 5.0 V 50 65 QFN, VPVIN = 3.3 V 53 70 WLCSP, VPVIN = 5.0 V 21 30 WLCSP, VPVIN = 3.3 V 23 35 QFN, VPVIN = 5.0 V 37 55 QFN, VPVIN = 3.3 V 40 65 A mΩ mΩ ILDR_P_LKG P-MOSFET Leakage Current 0.1 10 μA ILDR_N_LKG N-MOSFET Leakage Current 0.1 10 μA ALDR Linear Amplifier Gain ILDR_SH_GNDL LDR Short-Circuit Threshold LDR short to PGNDL, enter hiccup ILDR_SH_PVIN(L) LDR Short-Circuit Threshold LDR short to PVIN, enter hiccup THICCUP Hiccup Cycle 40 V/V 2.2 A -2.2 A 15 ms 0.06 x VPVIN 0.93 x VPVIN V PWM Output VSFB ISW_SOURCE Output Voltage Low Output Voltage High Maximum Source Current ISFB = 0 A TJ = -40°C to +105°C 1.5 TJ = -40°C to +125°C 1.2 Copyright© 2019, Sillumin® Semiconductor Co., Ltd. Rev0.2 September 2019 A 5 SLM8833 ISW_SINK RDSON_PMOS RDSON_NMOS Maximum Sink Current P-MOSFET ON Resistance (ILDR = 0.6 A) N-MOSFET ON Resistance (ILDR = 0.6 A) TJ = -40°C to +105°C 1.5 TJ = -40°C to +125°C 1.2 WLCSP, VPVIN = 5.0 V 47 65 WLCSP, VPVIN = 3.3 V 60 80 QFN, VPVIN = 5.0 V 60 80 QFN, VPVIN = 3.3 V 70 95 WLCSP, VPVIN = 5.0 V 40 60 WLCSP, VPVIN = 3.3 V 45 65 QFN, VPVIN = 5.0 V 45 75 QFN, VPVIN = 3.3 V 55 85 A mΩ mΩ ILDR_P_LKG P-MOSFET Leakage Current 0.1 10 μA ILDR_N_LKG N-MOSFET Leakage Current 0.1 10 μA tSW_R SW Node Rise Time DSW PWM Duty Cycle ISFB SFB Input Bias Current 1 CSW = 1 nF 6 ns 93 % 1 2 μA 2.0 2.15 MHz 0.8 V PWM Oscillator fOSC Internal Oscillator Frequency VEN/SY_ILOW EN/SY Input Voltage Low VEN/SY_IHIGH EN/SY Input Voltage High External Synchronization Frequency Synchronization Pulse Duty Cycle EN/SY Rising to PWM Rising Delay fSYNC DSYNC tSYNC_PWM tSY_LOCK IEN/SY IPULL-DOWN 1.85 2.1 V 1.85 3.25 MHz 10 90 % 50 ns EN/SY Input Current 0.3 0.5 Cycl es μA Pull-Down Current 0.3 0.5 μA 1.3 VVREF – 0.2 V 0.2 1.2 V EN/SY to PWM Lock Time TEC Current Limit ILIM Input Voltage Range VILIMC Cooling ILIM Input Voltage Range VILIMH Heating Current-Limit Threshold VILIMC_TH Cooling Current-Limit Threshold VILIMH_TH Heating IILIMH ILIM Input Current Heating IILIMC ILIM Input Current Cooling Cooling to Heating Current ICOOL_HEAT_TH Detection Threshold TEC Voltage Limit AVLIM EN/SY high Voltage Limit Gain 10 Number of SYNC cycles VITEC = 0.5 V 1.98 2.0 2.02 V VITEC = 2 V 0.48 0.5 0.52 V +0.2 μA 42.5 μA -0.2 Sourcing current (VDRL - VSFB)/VVLIM Copyright© 2019, Sillumin® Semiconductor Co., Ltd. Rev0.2 September 2019 37.5 40 40 mA 2 V/V 6 SLM8833 VLIM VLIM/SD Input Voltage Range IILIMC VLIM/SD Input Current Cooling VOUT2 < VVREF/2 VLIM/SD Input Current Heating VOUT2 > VVREF/2, sinking current IILIMH 0.2 VVDD/2 V -0.2 +0.2 μA 12 μA 8 10 TEC Current Measurement (WLCSP) 0.52 5 0.52 5 VPVIN = 3.3 V RCS Current Sense Gain VPVIN = 5 V ILDR_ERROR Current Measurement Accuracy VITEC_@_700m A VITEC_@_ -700mA VITEC_@_800m ITEC Voltage Accuracy A VITEC_@_ -800mA 700mA ≤ ILDR≤ 1 A, VPVIN = 3.3 V 800mA ≤ ILDR≤ 1 A, VPVIN = 5V VPVIN = 3.3 V, cooling, VVREF/2 + ILDR × RCS VPVIN = 3.3 V, heating, VVREF/2 - ILDR × RCS VPVIN = 5 V, cooling, VVREF/2 + ILDR × RCS VPVIN = 5 V, heating, VVREF/2 - ILDR × RCS V/A V/A -10 +10 % -10 +10 % 1.59 7 0.84 6 1.65 7 0.78 3 1.61 8 0.88 3 1.67 8 0.82 2 1.64 9 0.89 1 1.71 8 0.83 6 V V V V TEC Current Measurement (QFN) 0.52 5 0.52 5 VPVIN = 3.3 V RCS Current Sense Gain VPVIN = 5 V ILDR_ERROR Current Measurement Accuracy VITEC_@_700m A VITEC_@_ -700mA VITEC_@_800m ITEC Voltage Accuracy A VITEC_@_ -800mA VITEC VITEC_BIAS IITEC_Max 700mA ≤ ILDR≤ 1 A, VPVIN = 3.3 V 800mA ≤ ILDR≤ 1 A, VPVIN = 5V VPVIN = 3.3 V, cooling, VVREF/2 + ILDR × RCS VPVIN = 3.3 V, heating, VVREF/2 - ILDR × RCS VPVIN = 5 V, cooling, VVREF/2 + ILDR × RCS VPVIN = 5 V, heating, VVREF/2 - ILDR × RCS ITEC Voltage Output Range ITEC = 0 A ITEC Bias Voltage ILDR = 0 A Maximum ITEC Output Current V/A V/A -15 +15 % -15 +15 % 1.37 4 0.75 0 1.41 9 0.70 5 1.61 8 0.88 3 1.67 8 0.83 0 1.86 1 1.01 5 1.92 1 0.95 5 VVREF – 0.05 0 1.21 5 -2 1.25 0 0.24 1.47 5 0.00 5 1.22 5 -2 0.25 1.50 0 1.28 5 +2 V V V V V V mA TEC Voltage Measurement AVTEC VVTEC_@_1_V VVTEC VVTEC_B Voltage Sense Gain Voltage Measurement Accuracy VLDR – VSFB = 1 V, VVREF/2 + AVTEC × (VLDR – VSFB) VTEC Output Voltage Range VTEC Bias Voltage Maximum VTEC Output IVTEC_Max Current Internal Soft Start VLDR = VSFB Copyright© 2019, Sillumin® Semiconductor Co., Ltd. Rev0.2 September 2019 1.25 0 0.26 1.52 5 2.62 5 1.27 5 +2 V/V V V V mA 7 SLM8833 tSS Soft Start Time 80 VLIM/SD SHUTDOWN VVLIM/SD_THL VLIM/SD Low Voltage Threshold Thermal SHUTDOWN ms 0.07 V TSHDN_TH Thermal Shutdown Threshold 170 °C TSHDN_HYS Thermal Shutdown Hysteresis 17 °C Copyright© 2019, Sillumin® Semiconductor Co., Ltd. Rev0.2 September 2019 8 SLM8833 TYPICAL OPERATING CHARACTERISTICS TA = 25°C, unless otherwise specified. Figure 4. Efficiency vs. ITEC at VIN=3.3V in Cooling Mode Figure 5. Efficiency vs. ITEC at VIN=3.3V in Heating Mode Figure 6. Efficiency vs. ITEC at VIN=3.3V and 5.0V with 2Ω Load in Cooling Mode Figure 7. Efficiency vs. ITEC at VIN=3.3V and 5.0V with 2Ω Load in Heating Mode Figure 8. Soft Start into Cooling Mode (VIN=3.3V with 5Ω load) Figure 9. Soft Start into Heating Mode (VIN=3.3V with 5Ω load) Copyright© 2019, Sillumin® Semiconductor Co., Ltd. Rev0.2 September 2019 9 SLM8833 Figure 10. Cooling to Heating Transient (Line 1: LDR (TEC+), Line Figure 11. Zero Acrossing TEC Current Zoom-in from Heating to 2: SFB (TEC-), Line 4: ITEC) Cooling (Line 1: LDR (TEC+), Line 2: SFB (TEC-), Line 4: ITEC) Figure 12. Zero Acrossing TEC Current Zoom-in from Cooling to Heating (Line 1: LDR (TEC+), Line 2: SFB (TEC-), Line 4: ITEC) Copyright© 2019, Sillumin® Semiconductor Co., Ltd. Rev0.2 September 2019 10 SLM8833 APPLICATION INFORMATION & WAVEFORMS The SLM8833 is a single chip TEC controller that sets and stabilizes a TEC temperature. A control voltage from a DAC applied to the CONT input pin of the SLM8833 corresponds to the temperature setpoint of the target object attached to the TEC. . The SLM8833 controls an internal FET H-bridge whereby the direction of the current fed through the TEC can be either positive (for cooling mode), to pump heat away from the object attached to the TEC, or negative (for heating mode), to pump heat into the object attached to the TEC. Temperature is measured with a thermal sensor attached to the target object and the sensed temperature (voltage) is fed back to an ADC to complete a closed digital thermal control loop of the TEC. For the best overall stability, couple the thermal sensor close to the TEC. In most laser diode modules, a TEC and a NTC thermistor are already mounted in the same package to regulate the laser diode temperature. The TEC is differentially driven in an H-bridge configuration. The SLM8833 drives its internal MOSFET transistors to provide the TEC current. To provide good power efficiency and zero crossing quality, only one side of the H-bridge uses a PWM driver. Only one inductor and one capacitor are required to filter out the switching frequency. The other side of the H-bridge uses a linear output without requiring any additional circuitry. This proprietary configuration allows the SLM8833 to provide efficiency of >90%. For most applications, a 1 μH inductor, a 10 μF capacitor, and a switching frequency of 2 MHz maintain less than 1% of the worst-case output voltage ripple across a TEC. The maximum voltage across the TEC and the current flowing through the TEC are set by using the VLIM/SD and ILIM pins. The maximum cooling and heating currents can be set independently to allow asymmetric heating and cooling limits. For additional details, see the Maximum TEC Voltage Limit section and the Maximum TEC Current Limit section. for the driver and internal reference. The PVIN input power pins are combined for both the linear and the switching driver. Apply the same input voltage to all power input pins: VDD and PVIN. In some circumstances, an RC lowpass filter can be added optionally between the PVIN for the WLCSP (PVINS and PVINL for the LFCSP) and VDD pins to prevent high frequency noise from entering VDD, as shown in Figure 3. The capacitor and resistor values are typically 10 Ω and 100 nF, respectively. When configuring power supply to the SLM8833, keep in mind that at high current loads, the input voltage may drop substantially due to a voltage drop on the wires between the front-end power supply and the PVIN for the WLCSP (PVINS and PVINL for the LFCSP) pin. Leave a proper voltage margin when designing the front-end power supply to maintain the performance. Minimize the trace length from the power supply to the PVIN for the WLCSP (PVINS and PVINL for the LFCSP) pin to help mitigate the voltage drop. The features internal automatic overvoltage protection, when output voltage is higher than 115%. ENABLE AND SHUTDOWN To enable the SLM8833, apply a logic high voltage to the EN/SY pin while the voltage at the VLIM/SD pin is above the maximum shutdown threshold of 0.07 V. If either the EN/SY pin voltage is set to logic low or the VLIM/SD voltage is below 0.07 V, the controller goes into an ultralow current state. The current drawn in shutdown mode is 350 μA typically. Most of the current is consumed by the VREF circuit block, which is always on even when the device is disabled or shut down. The device can also be enabled when an external synchronization clock signal is applied to the EN/SY pin, and the voltage at VLIM/SD input is above 0.07 V. Table 6 shows the combinations of the two input signals that are required to enable the SLM8833. EN/SY Input >2.1 V Switching between high >2.1 V and low < 0.8 V 0.07 V >0.07 V Controller Enabled Enabled No effect1 No effect1 ≤0.07 V Shutdown Shutdown Shutdown 1 No effect means this signal has no effect in shutting down or in enabling the device. OSCILLATOR CLOCK FREQUENCY The SLM8834 has an internal oscillator that generates a 2.0 MHz switching frequency for the PWM output stage. This oscillator is active when the enabled voltage at the EN/SY pin is set to a logic 11 SLM8833 level higher than 2.1 V and the VLIM/SD pin voltage is greater than the shutdown threshold of 0.07 V. External Clock Operation The PWM switching frequency of the SLM883 can be synchronized to an external clock from 1.85 MHz to 3.25 MHz, applied to the EN/SY input pin as shown on Figure 13. Figure 13. Synchronize to an External Clock Connecting Multiple SLM8833 Devices Multiple SLM883 devices can be driven from a single master clock signal by connecting the external clock source to the EN/SY pin of each slave device. The input ripple can be greatly reduced by operating the SLM8834 devices 180° out of phase from each other by placing an inverter at one of the EN/SY pins as shown in Figure 14. generates aramp with a typical 150 ms profile to minimize inrush current during power-up. The settling time and the final voltage across the TEC depends on the TEC voltage required by the control voltage of voltage loop. The higher the TEC voltage is, the longer it requires to be built up. When the SLM8833 is first powered up, the linear side discharges the output of any prebias voltage. As soon as the prebias is eliminated, the soft start cycle begins. During the soft start cycle, both the PWM and linear outputs track the internal soft start ramp until they reach midscale, where the control voltage, VC, is equal to the bias voltage, VB. From the midscale voltage, the PWM and linear outputs are then controlled by VC and diverge from each other until the required differential voltage is developed across the TEC or the differential voltage reaches the voltage limit. The voltage developed across the TEC depends on the control point at that moment in time. Figure 15 shows an example of the soft start in cooling mode. Note that, as both the LDR and SFB voltages increase with the soft start ramp and approach VB, the ramp slows down to avoid possible current overshoot at the point where the TEC voltage starts to build up. Figure 15. Soft Start Profile in Cooling Mode TEC VOLTAGE/CURRENT MONITOR The TEC real-time voltage and current are detectable at VTEC and ITEC, respectively. Voltage Monitor VTEC is an analog voltage output pin with a voltage proportional to the actual voltage across the TEC. A center VTEC voltage of 1.25 V corresponds to 0 V across the TEC. Convert the voltage at VTEC and the voltage across the TEC using the following equation: VVTEC = 1.25 V + 0.25 × (VLDR − VSFB) Figure 14. Multiple SLM8833 Devices Driven from a Master Clock SOFT START ON POWER-UP The SLM8833 has an internal soft start circuit that Copyright© 2019, Sillumin® Semiconductor Co., Ltd. Rev0.2 September 2019 Current Monitor ITEC is an analog voltage output pin with a voltage proportional to the actual current through the TEC. A center ITEC voltage of 1.25 V corresponds to 0 A through the TEC. Convert the voltage at ITEC and 12 SLM8833 the current through the TEC using the following equations: VITEC_COOLING = 1.25 V + ILDR × RCS where the current sense gain (RCS) is 0.525 V/A. VITEC_HEATING = 1.25 V − ILDR × RCS limits in cooling and heating directions are set by applying a voltage combination at the ILIM pin. MAXIMUM TEC VOLTAGE LIMIT The internal current sink circuitry connected to ILIM draws a 40 μA current when the SLM8833 drives the TEC in a cooling direction, which allows a high cooling current. Use the following equations to calculate the maximum TEC currents: VILIM_HEATING = VREF × RC2/(RC1 +RC2) where VREF = 2.5 V. VILIM_COOLING = VILIM_HEATING + ISINK_ILIM × RC1||RC2 where ISINK_ILIM = 40 μA. The maximum TEC voltage is set by applying a voltage divider at the VLIM/SD pin to protect the TEC. The voltage limiter operates bidirectionally and allows the cooling limit to be different from the heating limit. Using a Resistor Divider to Set the TEC Voltage Limit Separate voltage limits are set using a resistor divider. The internal current sink circuitry connected to VLIM/SD draws a current when the SLM8833 drives the TEC in a heating direction, which lowers the voltage at VLIM/SD. The current sink is not active when the TEC is driven in a cooling direction; therefore, the TEC heating voltage limit is always lower than the cooling voltage limit. Figure 16. Using a Resistor Divider to Set the TEC Voltage Limit Using a Resistor Divider to Set the TEC Current Limit where RCS = 0.525 V/A. VILIM_HEATING must not exceed 1.2 V and VILIM_COOLING must be more than 1.3 V to leave proper margins between the heating and the cooling modes. Figure 17. Using a Resistor Divider to Set the TEC Current Limit Calculate the cooling and heating limits using the following equations: VVLIM_COOLING = VREF × RV2/(RV1 +RV2) where VREF = 2.5 V. VVLIM_HEATING = VVLIM_COOLING − ISINK_VLIM × RV1//RV2 where ISINK_VLIM = 10 μA. VTEC_MAX_COOLING = VVLIM_COOLING × AVLIM where AVLIM = 2 V/V. VTEC_MAX_HEATING = VVLIM_HEATING × AVLIM MAXIMUM TEC CURRENT LIMIT To protect the TEC, separate maximum TEC current Copyright© 2019, Sillumin® Semiconductor Co., Ltd. Rev0.2 September 2019 13 SLM8833 CLASSIFICATION REFLOW PROFILES Profile Feature Pb-Free Assembly Preheat & Soak Temperature min (Tsmin) Temperature max (Tsmax) Time (Tsmin to Tsmax) (ts) 150°C 200°C 60-120 seconds Average ramp-up rate (Tsmax to Tp) 3°C/second max. Liquidous temperature (TL) Time at liquidous (tL) 217°C 60-150 seconds Peak package body temperature (Tp)* Max 260°C Time (tp)** within 5°C of the specified classification temperature (Tc) Max 30 seconds Average ramp-down rate (Tp to Tsmax) 6°C/second max. Time 25°C to peak temperature 8 minutes max. Figure 18. Classification Profile Copyright© 2019, Sillumin® Semiconductor Co., Ltd. Rev0.2 September 2019 14 SLM8833 PACKAGE INFORMATION 25-ball, 2.5 mm × 2.5 mm WLCSP 24-lead, 4 mm × 4 mm QFN Copyright© 2019, Sillumin® Semiconductor Co., Ltd. Rev0.2 September 2019 15 SLM8833 Revision History Note: page numbers for previous revisions may differ from page numbers in current version Page or Item Subjects (major changes since previous revision) Rev 0.2 datasheet, 2019-9-3 Whole document Page 1 New company logo released Remove “Rev0.1 January 2019” Copyright© 2019, Sillumin® Semiconductor Co., Ltd. Rev0.2 September 2019 16
SLM8833EC 价格&库存
很抱歉,暂时无法提供与“SLM8833EC”相匹配的价格&库存,您可以联系我们找货
SLM8833EC
    • 1+59.50800
    • 10+50.29560
    • 30+44.67960
    • 100+39.96000
