PBVP-04V-S
PBVP-04V-S
    JST
    P=2mm
    1X4P 2MM
PBVP-04V-S 数据手册
PBV CONNECTOR 2.0 2.0 mm mm pitch/Disconnectable pitch/Disconnectable Crimp Crimp style style connectors connectors ●S  ecure locking structure ● Sucking area on header ● High reliability contact PBV PBV CONNECTOR CONNECTOR Specifications • Current rating: 3 A AC/DC (AWG #22) • Voltage rating: 100 V AC/DC • Temperature range: -25℃ to +85℃ (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 10 mΩ max. After environmental tests/ 20 mΩ max. • Insulation resistance: lnitial/ 1,000 MΩ min. • Withstanding voltage: 800 VAC/minute • Applicable wire: Conductor size/ AWG#28 to #22 Insulation O.D./ 0.9 to 1.5 mm * In using the products,refer to "Handling Precautions for Terminals and Connectors" described on our website (Technical documents of Product information page). * RoHS2 compliance * Dimensional unit: mm * Contact JST for details. ® ® This PBV connector, which is mainly used for connecting PCB of flat television, is a crimping type connector and is designed to have a secure locking structure and a sucking area. ® Standards ® ® Recognized E 60389 PC board layout and Assembly layout Side entry type Top entry type < 2 circuits > < 2 circuits > Circuit No.1 1 min. < 3 to 15 circuits > 6.8 2.7 min. ±0.05 1.45 ±0.1 1.8 ±0.1 3.8 ±0.1 2.8 1.8 ±0.1 5 ±0.1 3.6 1.85 1 +0.1 0 ±0.1 5 ±0.1 Circuit No.1 2.9 min. A ±0.1 1 min. 2 (12.1) 8.9 < 3 to 15 circuits > 1.45 ±0.1 Pattern prohibition area, excluding product with applicable circuit-number (1.1) A±0.1 Circuit No.1 1 min. 2 ±0.05 A±0.1 Note: 1  . The above figure is the figure viewed from the connector mounting side. 2. Tolerances are non-cumulative: ± 0.03 mm for all centers. The dimensions above should serve as a guideline. Contact JST for details. 1 (6.8) 1.8±0.1 3.8±0.1 2.8 5 ±0.1 (1.4) 2.7 min. (6.8) 1.8±0.1 (12.1) 1.45±0.1 1.45±0.1 2.9 min. Circuit No.1 1 1.85 +0.1 0 1 min. 3.6±0.1 Pattern prohibition area, excluding product with applicable circuit-number 5±0.1 A±0.1 PBV CONNECTOR Contact Applicable wire AWG # mm2 Model No. SPHD-001T-P0.5 SPHD-002T-P0.5 Insulation O.D. (mm) Q'ty/reel 0.13~0.33 26~22 1.0~1.5 8,000 0.08~0.21 28~24 0.9~1.5 8,000 PBV CONNECTOR 1.5 Material and Finish Phosphor bronze, tin-plated (reflow treatment) RoHS2 compliance 6.5 2.85 Contact 1.3 SPHD-001T-P0.5 SPHD-002T-P0.5 Crimping machine Crimp applicator MKS-L-10 AP-K2N Applicator Dies Crimp applicator with dies MK/SPHD-001-05 APLMK SPHD001-05 MK/SPHD-002-05 APLMK SPHD002-05 Note: Contact JST for fully automatic crimping applicator. Housing No. of circuits < 3 (2 circuits in common use) to 8 circuits > B A *3 (3) 2 4 6.4 6 8 5.8 9 10 12 15 Circuit No.1 Model No. PBVP-03V-S PBVP-04V-S PBVP-06V-S PBVP-08V-S PBVP-10V-S PBVP-12V-S PBVP-15V-S Dimensions (mm) A B Q'ty/ bag 4.0 10.0 2,000 6.0 12.0 2,000 10.0 16.0 1,000 14.0 20.0 1,000 18.0 24.0 1,000 22.0 28.0 500 28.0 34.0 500 Material and Finish < 9 to 12 circuits > PA 66, UL94V-0, natural (white) B A RoHS2 compliance Note*: 2 circuits in common use. (3) 6.4 5.8 9 2 Circuit No.1 < 13 to 15 circuits > B (3) 6.4 5.8 2 9 A Circuit No.1 2 PBV CONNECTOR Shrouded header No. of circuits Top entry type < 2 circuits > B < 3 to 8 circuits > B 4 8.9 6.8 8.9 6.8 Circuit No.1 Circuit No.1 2 A < 9 to 12 circuits > B 8.9 B 8.9 6.8 Circuit No.1 A < 2 circuits > B < 3 to 8 circuits > B 6.8 8.9 8.9 6.8 4 Circuit No.1 Circuit No.1 2 A < 9 to 12 circuits > B 6.8 8.9 2 Circuit No.1 A < 13 to 15 circuits > B 8.9 6.8 Circuit No.1 2 A 3 BM02(4.0)B-PBVSS-TF SM02(4.0)B-PBVSS-TB 4.0 10.0 700 800 3 BM03B-PBVSS-TF SM03B-PBVSS-TB 4.0 10.0 700 800 4 BM04B-PBVSS-TF SM04B-PBVSS-TB 6.0 12.0 700 800 6 BM06B-PBVSS-TF SM06B-PBVSS-TB 10.0 16.0 700 800 8 BM08B-PBVSS-TF SM08B-PBVSS-TB 14.0 20.0 700 800 10 BM10B-PBVSS-TF SM10B-PBVSS-TB 18.0 24.0 700 800 12 BM12B-PBVSS-TF SM12B-PBVSS-TB 22.0 28.0 700 800 15 BM15B-PBVSS-TF SM15B-PBVSS-TB 28.0 34.0 700 800 RoHS2 compliance This product displays (LF)(SN) on a label. Note: 1. These products listed above are supplied on embossed-tape. 2. *2 circuits product: Removing center pin from 3 circuits product < 13 to 15 circuits > Side entry type *2 Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: Polyamide resin, UL94V-0, natural (ivory) Reinforcement: Copper alloy, copper-undercoated, tin-plated (reflow treatment) A 2 Dimensions (mm) Q'ty/reel A B Top type Side type Material and Finish 6.8 Circuit No.1 2 Model No. Side entry type Top entry type
PBVP-04V-S 价格&库存
很抱歉,暂时无法提供与“PBVP-04V-S”相匹配的价格&库存,您可以联系我们找货
PBVP-04V-S
    • 1+0.532531+0.06893
    • 10+0.4277710+0.05537
    • 50+0.3579350+0.04633
    • 100+0.30555100+0.03955
    • 500+0.27936500+0.03616
    • 1000+0.261901000+0.03390
    • 2000+0.261902000+0.03390
    库存:48
    PBVP-04V-S
    • 10+0.34982
    • 100+0.27983
    • 300+0.24484
    • 2000+0.19236
    • 4000+0.17393
    • 10000+0.16470
    库存:3753
    PBVP-04V-S
      • 1+0.398091+0.05153
      • 500+0.34833500+0.04509
      • 1000+0.290271000+0.03758
      • 4000+0.257104000+0.03328
      • 5000+0.248815000+0.03221
      • 10000+0.2488110000+0.03221
      • 30000+0.2405130000+0.03114
      库存:2000
      PBVP-04V-S
        • 2000+0.21870
        库存:4000
        PBVP-04V-S
          • 100+0.24870
          库存:3047
          PBVP-04V-S
            • 200+0.20519
            库存:34970
