MUR2060CT
MUR2060CT
    RUILON(瑞隆源)
    TO-220AB
    耐压:600V 电流:5A 反向恢复时间:50NS
MUR2060CT 数据手册
MUR2010CT THRU MUR2060CT Ultra-Fast Recovery Rectifier Diodes Features ● ● ● ● Super-fast recovery time for high efficiency Glass passivated chip junction Low leakage current High forward surge capability Typical Application For use in high frequency rectification and freewheeling application in switching mode converters and inverters for consumer ,computer and telecommunication. Mechanical Data ● ● ● Package: TO-220AB Molding compound meets UL 94 V-0 flammability rating,RoHS-compliant Terminals: Tin plated leads, solderable per J-STD-002 and JESD22-B102 Polarity: Color Band denotes cathode end ■ Maximum Ratings (Ta=25℃ Unless otherwise specified) PARAMETER Repetitive Peak Reverse Voltage Average Forward Current Surge(Nonrepetitive)Forward Current Symbol Unit VRRM V IO A IFSM A Current Squared Time I²t Storage Temperature Junction Temperature Tstg Tj Conditions 2010 2015 100 150 MUR-CT 2020 2040 200 With heatsink Tc =90℃ 60Hz sine wave,R-load Without heatsink Tc =25℃ 60HZ sine wave, 1 cycle, Ta=25℃ 1ms≤t<8.3ms Tj=25℃,Rating of per diode A²s ℃ ℃ 2060 400 600 20 5 125 65 -55 ~ +150 -55 ~ +150 Electrical Characteristics(Ta=25℃ Unless otherwise specified) PARAMETER Peak Forward Voltage Peak Reverse Current Maximum reverse recovery time Thermal Resistance Symbol Unit Conditions VFM V IFM=10A IRRM1 IRRM2 Trr RθJ-C 2015 MUR-CT 2020 2040 2060 1.3 1.7 0.975 Ta=25℃ 10 Ta=125℃ 500 μA VRM=VRRM ns IF=0.5A,IR=1.0A,Irr=0.25A RθJ-C Between junction and case Specifications are subject to change without notice. Please refer to http://www.ruilon.com.cn for current information. 2010 Revised: 2021-11-29 25 50 2.0 Page:1 ■ Characteristics(Typical) MUR2010CT THRU MUR2060CT FIG1: Forward Current Derating Curve FIG2:Surge Forward Current Capability FIG3:Instantaneous Forward Voltage FIG4:Typical Reverse Characteristics FIG5:Diagram of circuit and Testing wave form of reverse recovery time Specifications are subject to change without notice. Please refer to http://www.ruilon.com.cn for current information. Revised: 2021-11-29 Page:2 MUR2010CT THRU MUR2060CT ■ Ordering Information (Example) PREFERED MUR1010CT~MUR1060CT PACKAGE MINIMUM CODE PACKAGE(pcs) TO-220AB 50 INNER BOX OUTER CARTON QUANTITY(pcs) QUANTITY(pcs) 1000 5000 DELIVERY MODE Tube ■ Outline Dimensions Specifications are subject to change without notice. Please refer to http://www.ruilon.com.cn for current information. Revised: 2021-11-29 Page:3
MUR2060CT 价格&库存
很抱歉,暂时无法提供与“MUR2060CT”相匹配的价格&库存,您可以联系我们找货
MUR2060CT
  • 1+3.83400
  • 10+3.07800
  • 50+2.59200
  • 100+2.22480
  • 500+1.99800
  • 1000+1.87920
库存:73
