WMZ93-125HL60RVSUB4-G8C
    TYOHM(幸亚电阻)
    Radial,P=7.5mm
WMZ93-125HL60RVSUB4-G8C 数据手册
Spec. No. 20200619 PART NO. 料 号 Page (s): 1/6 WMZ93-125HL60RVSUB4-G8C PTC THERMISTOR 60.0Ω REV NO. 版 本 0/A (JUN. 19th, 2020) 1. APPEARANCE 外观 1-2. Marking 标志 WMZ93 ■ 60R □ No marking 1-3.Coating 包封 □ No coating 无包封 ■ Coating 包封 Material 包封材料 □PF resin 酚醛树脂 ■Silicon 硅树脂 □Epoxy 环氧树脂 □Others 其他 1-1. Dimensions (mm)尺寸 DMax: 18.0 F1.0 :7.5 E1.0 :4.5 TMax:7.0 d0.05:0.8 L0.5:4 Color 颜色 ■Green 绿色 □Red 红色 □Tan 黄色 □Black 黑色 1-4. Leads 引线 ■Tin-plated copper wire 铜线 □Tin-plated steel wire 镀锡钢线 ■Straight 直形 □Axis-formed 轴弯 □No Lead 无引线 □In-formed 内弯 2. RATINGS 额定参数 2-1. Max Working Voltage 最大工作电压 Umax: 340 Vrms 2-2. Max Working Current 最大工作电流 Imax:12A 2-3. Operating Temperature 工作温度: -25℃~+85℃ (U=0) -10℃~+60℃ (U=Umax) 3. MECHANICAL CHARACTERISTICS 机械性能 Item 指标项目 3-1. Solder-ability 可焊性 Specification 技术要求 The terminals shall be uniformly tinned, and its area ≥95% 浸润部分上锡均匀, 上锡面积≥95% Test Conditions & Methods 测试条件/方法 Dipping the PTC terminals to a depth of 15mm in a soldering bath of 245℃±5℃ and to the place of 6mm far from PTC body for 3±0.5s (See IEC68-2-20 /GB2423.28 Ta ) 将引出端沾助焊剂后,浸入到温度为 245℃±5℃、深 度为 15mm 的锡槽中锡面距 PTC 本体下端 1.6mm 处, 持续 2.5±0.5 秒。(参见 IEC68-2-20 /GB2423.28 试验 Ta) Dipping the terminals to a depth of 15mm in a soldering bath of 260℃±5℃ and to the place of 6mm far from PTC body for 3±0.5s. After recovering for 4~5 hours No visible mechanical damage. 3-2. Resistance To Soldering Heat 耐焊接热 无可见损伤 under normal temperature. The resistance (RN') shall be measured. (See IEC68-2-20 /GB2423.28 Tb) ΔR/RN ≤20% 将引出端沾助焊剂后,浸入到温度为 260℃±5℃、深 (ΔR =∣RN-RN'∣) 度为 15mm 的锡槽中锡面距 PTC 本体下端 2mm 处,持 续 10±1 秒。在常温条件下恢复 4~5 小时后,复测额定 零功率电阻值 RN'。(参见 IEC68-2-20 /GB2423.28 试验 Tb) Spec. No. 20200619 PART NO. 料 号 Page (s): 2/6 PTC THERMISTOR WMZ93-125HL60RVSUB4-G8C 3-3.Strength of lead terminal 引出端强度 60.0Ω No break out 无损坏 REV NO. 版 本 0/A (JUN. 19th, 2020) Fasten the body and apply a force gradually to each lead until 10 N and then keep for 10sec, Hold the body and apply a force to each lead until 90°Mowly at 5 N in the direction of lead axis and then keep for 10sec, and do this in the opposite direction repeat for other terminal. (See IEC68-2-21/GB2423.29 Ua / Ub) 根据 IEC68-2-21(GB2423 .29)试验 U 进行试验。 试验 Ua:拉力 10N,持续 10 S; 试验 Ub:弯曲 90°,拉力 8N,连续两次; 试验 Uc:扭转 180℃,连续两次。 在常温常湿条件下恢复 4~5 h 后,复测额定零功率电阻 Rn 4. ELECTRICAL CHARACTERISTICS 电气性能 Item 指标项目 4-1.Rated Zero Power Resistance 额定零功率电阻 (RN) Specification 技术要求 Test Conditions & Methods 测试条件/方法 60.0±25%Ω TA:25±2℃ Testing voltage:DC 2.0 Vmax After placing for 1~2 hours under TA, the resistance value shall be measured. 环境温度:25±2℃ 测试电压:DC 2.0 Vmax 在常温 TA 条件下,放置 1~2 小时后,测得阻值 RN 4-2.Max. Operating Current 最大工作电流(Imax) 12A TA:-10~+85℃; AC=340V,50HZ 4-3.Max. Operating Voltage 最大工作电压 (Vmax) 340V TA:-10~+85℃ 4-4.Curie Temperature 居里温度 (TC) (For information only) (仅供参考) 4-5.Tripping Time 动作时间(Tt) 125±7℃ The resistance at TC is twice of RN 电阻为零功率电阻的 2 倍时所对应的温度为 TC。 TA:25±2℃ Testing voltag 测试电压:340Vrms, 50~60Hz In Series Resistance 串联电阻 RL:25Ω In static air 静止空气中. The time of the current reducing from the Initial value to the half of the Initial value shall be measured 电流从初始值下降到初始值一半所需的时间 ≤2S Fig.1. Spec. No. 20200619 PART NO. 料号 Page (s): 3/6 WMZ93-125HL60RVSUB4-G8C 4-6.Restore Time 恢复时间 (Tr) 4-7.Dissipation Power 消耗功率(P) 4-8.Voltage Withstanding 耐电压(V) PTC THERMISTOR 60.0Ω REV NO. 版 本 0/A (JUN. 19th, 2020) TA:25±2℃ In static air 静止空气中 Testing voltage 测试电压:340Vrms In Series Resistance 串联电阻 RL:25Ω Testing time 测试时间:10min ≤100S Test Circuit:See Fig. 1. 测试电路:见图 1. The time of the resistance value reducing to the twice of the rated zero-power resistance shall be measured. 当电阻降低至零功率电阻的 2 倍时所用的时间。 TA:25±2℃ In static air 静止空气中 Testing voltage 测试电压:340Vrms In Series Resistance 串联电阻 RL:25Ω ≤4.5W Testing time 测试时间:10min Test Circuit:See Fig. 1. 环境温度: 25±2℃ 测试电路:见图 1. TA:25±2℃ Testing voltage 测试条件: 280V/1min→500V/3min, RL:25Ω Test Circuit:See Fig. 2. No damage. The resistance change ratio 环境温度: 25±2℃ within 测试电路:见图 2. ±20% 无可见损伤, 电阻变化率小于±20% Fig. 2 4.9.Insulation Compression 绝缘耐压 4.10. Insulation resistance 绝缘电阻 将金属箔紧紧地缠绕在热敏电阻体上。对于不是轴 向引出端的热敏电阻,箔的边缘与每个引出端间应 留有 1.5mm 的间隙。对于轴向引出端的热敏电阻, 试验后产品不能出现击穿、 用箔把整个热敏电阻体包住,并且在每端伸出至少 5mm,只要箔与引出端之间能够保持 1mm 的最小 燃烧等现象 间隙。箔的两端在超过电阻体两端处不应折曲。在 引脚与包封材料间施加相应电压: 750VAC/min (特殊情况下,若产品规格书有规定试验电压及时 间可以同上述要求进行比较,选严酷的进行测试) 绝缘电阻≥100MΩ 与 4.9 相同,但注意测试量电压应加上 1 分钟或为获 得稳定读数所必须的较短时间.绝缘电阻就在这个时 间之末读取. Spec. No. 20200619 PART NO. 料 号 Page (s): 4/6 PTC THERMISTOR WMZ93-125HL60RVSUB4-G8C 5 .RELIABILITY TEST 信赖性试验 Item 指标项目 60.0Ω REV NO. 版 本 0/A (JUN. 19th, 2020) Specification 技术要求 Test Conditions & Methods 测试条件/方法 TA:-20 ± 5 ℃ / 15min → 25 ± 2 ℃ / 5min → 120 ± 5 ℃ / 15min→25±2℃/ 5min Cycles: 10times After recovering 4~5 h under 25±2℃, the rated zero No damage. 无可见损伤, power resistance value RN' shall be measured. The resistance change ratio 在-20±5℃和 120±5℃的环境温度中各存放 15 分钟, within ±20%电阻变化率 循环 10 次.每次高低温循环都在 25±2℃的环境温度中 小于±20% 过渡 5 分钟。样品进行温度循环测试后,取出放置室 5.1.Temperature Cycling Testing 温度循环试验 温 (25±2℃)4~5 小时后测量零功率电阻 RN'. TA:100±5℃ 环境温度:100±5℃ Voltage 测试电压:AC340Vrms The resistance change ratio In Series Resistance 串联电阻 RL: 25Ω within ±20% Energized time 通电时间:1,000 小时 电阻变化率小于±20% Test Circuit:See Fig. 3. 测试电路:见图 3. Testing time 测试时间:1000Hr TA:25±2℃ Testing voltage 测试电压:340Vrms In Series Resistance 串联电阻 RL: 25Ω No damage. The resistance change ratio on 5Sec—.off 120 sec 通电 5 sec. –断电 120sec. within ±20% Testing times :200000 times 测试次数:200000 次 无可见损伤, 电阻变化率小于±20% 5.2.High Temperature Load Test 高温连续负荷 5-3.Room Temperature Intermittent Load Test 常温断续负荷 No damage. 无可见损伤 ,引线脚应无脱落 No desquamate on leads The resistance change ratio within ±20%电阻变化率 小于±20% 5-4.Low Temp. Storage 低温贮存 Fig. 3 在温度-20±5℃的环境下存放 1000 小时后,再在常 温条件下恢复 4~5 小时后,复测额定零功率电阻值 RN' After 1,000 h storage under -20 ± 5 ℃ , and then recovering 4~~5 h under normal temp. condition, re-test the rated zero power resistance RN' 6. INSPECTION 检验 Sampling withIEC410/DINISO2859-1(GB/T2828.1-2003);Testing with IEC60738-1 / QC 440000 (GB7153-2002) , Spec No. WL93-131225-1 . 抽样方法 IEC410/DINISO2859-1 (GB/T2828.1-2003) ;试验方法按照 IEC60738-1 / QC 440000 (GB7153-2002) , Spec No. WL93-131225-1 . Item Item IL AQL AC 项目 项目 6-1. Appearance 6-5.Voltage Withstanding S-4 0.65 外观 (无漏铜、锡脚、挂钩) 耐电压 6-6. Tripping time 6-2. Dimensions S-3 0.65 尺寸 动作时间(Tt) IL AQL S-3 1.0 S-3 1.0 6-3.Rated Zero-power Resistance 额定零功率电阻 (R25) Ⅱ 0.65 6-7 Dissipation Power 消耗功率 S-3 1.0 6-4. Restore Time 恢复时间 (Tr) S-3 0.65 6-8 Insulation resistance 绝缘电阻 S-3 1.0 AC Spec. No. 20200619 PART NO. 料 号 Page (s): 5/6 PTC THERMISTOR WMZ93-125HL60RVSUB4-G8C 60.0Ω REV NO. 版 本 0/A (JUN. 19th, 2020) 7. NUMBERING SYSTEM AND PACKING 编号方法和包装方式 7-1. Part Numbering 料号编号方法 125 WMZ93 ① ② HL 60R ③ ④ V S ⑤ ⑥ U ⑦ B 4 ⑧ ⑨ - G 8 C ⑩ 11 12 ○ ○ ① Series WMZ93: PTC thermistor for starting frequency conversion air-conditioner 系列 用于变频空调启动系列 PTC 热敏电阻器 ② Curie temperature 居里温度 125: 125℃ (130 : 130℃ 120: 120℃ ……) ③ Diameter 外径 Dmax HL : 18.0mm (LL: 21.0mm SL: 15.0mm……) ④ Rated zero power resistance 额定零功率电阻(RN)60R: 60Ω(68: 68Ω; 22: 22Ω 33:33Ω … ) ⑤ Tolerance 电阻允差 V: ±25%( N:±30% M: ±20% P: ±50% ;X:Else 其它 …… ) ⑥ Leads form 引线形状 U: Inside kink 内弯( A: Axis wind 轴弯 S: Straight 直形 ) ⑦ Leads 引线材质 U:Tin-plated copper wire 铜线(P:铜包钢线) ⑧ Packing Type 包装方式 B: Bulk 散装 ( A: Ammo 条带 C: Reel 盘带 ……) ⑨ Leads length 引线长度:4: 4±0.5mm 8: 8±0.5mm 5: 5.0±0.5mm 25: 25.0±1.0mm ⑩ Coating Material 包封材料:S - Black Silicone 硅树脂 G – Green Silicone 绿色硅树脂 N – No Coating 无包封 P-PF Resin 酚酫树指 E-Epoxy 环氧树脂 11 Leads Diameter 引线直径:5 – Φ0.5mm 6 – Φ0.6mm 8 – Φ0.8mm 1 – Φ1.0mm ○ 12 Leads Distance 引线间距:A – 2.5mm B – 5.5mm C – 7.5mm D – 10.0mm ○ 7-2.批号编号方法 125 HL A 1307226 ① ② ③ ④ - 1/2 ⑤ ① Curie temperature 居里温度 125: 125℃(105 : 105℃ 85: 85℃ ……). ② Diameter 外径 Dmax HL :18.0mm (M: 11.5mm S: 4.5mm L: 5.5mm……). ③ Series 系列: PTC thermistors for over-current protection 系列 PTC 热敏电阻。 ④ Pipelined batch number 流水批号: 1307226 : ⑤ Shipment branch card batch number 分卡号:1/2 ; 7-3.包装方式 ■散装 □条带 □ 盘带 Pcs / 袋 Pcs/ 带 Pcs/ 盘 KPcs, KPcs, KPcs, × × × × × × mm, mm, mm, Kg/Ctn Kg/Ctn Kg/Ctn Spec. No. 20200619 PART NO. 料 号 WMZ93-125HL60RVSUB4-G8C Page (s): 6/6 PTC THERMISTOR 60.0Ω REV NO. 版 本 0/A (JUN. 19th, 2020) 8.R-T 曲线图 9. 贮存环境条件 9-1. 温度: -10℃~+40℃ 9-2. 湿度: ≤70%RH 9-2. 期限: ≤6 月 (先进先出) 9-3. 地点: 不要暴露在下列环境条件下,否则将导致性能衰退或参数飘移: 1). 腐蚀性或易氧化气体 2) . 易燃易爆气体 3) . 油、水和化学溶液 4) . 太阳光下 9-4. 开封后的处理: 尽量保证开口最小化,立即重新封好,并贮存在密封、带有干燥剂的容器中。 注意.警告 ! 请不要在下列条件下使用本元件,否则将可能导致产品性能衰退或产品损毁,甚至引发火灾: 1) . 超过最大工作电流或工作电压 2) . 超过许可工作温度范围 3) . 散热不良(由于散热不良,本元件可能因部分过热而导致破坏)
WMZ93-125HL60RVSUB4-G8C 价格&库存
很抱歉,暂时无法提供与“WMZ93-125HL60RVSUB4-G8C”相匹配的价格&库存,您可以联系我们找货
