RS3005
150mA, Low Power Consumption,
High Voltage CMOS LDO Regulator
DESCRIPTION
FEATURES
150mA Nominal Output Current
Low Dropout Voltage
Low Temperature Coefficient
High Input Voltage (up to 36V)
Output Voltage Accuracy: ±2.5%
Operating Temperature Range:
-40°C to +85°C
Micro SIZE PACKAGES: SOT23-3、
The RS3005 series is a set of low power high voltage
regulators implemented in CMOS technology. It can
operate from 2.5V to 36V. which can provide 150mA
output current. The device allows input voltage as high
as 36V.
The RS3005 series is available in several fixed output
voltages. CMOS technology ensures low dropout
voltage and low quiescent current.
The RS3005 is available in Green SOT23-3 and
SOT89-3L packages. It operates over an ambient
temperature range of -40°C to +85°C.
SOT89-3L and SOT89-3L(L-Type)
Function Block Diagram
APPLICATIONS
Audio/Video Equipment
Communication Equipment
Battery-Powered Equipment
Laptop, Palmtops, Notebook Computers
RevA.2
1
www.run-ic.com
RS3005
PIN CONFIGURATIONS
VOUT
SCXX
GND
1
2
3
VIN
SOT23-3
GND
VIN
SCXX
SCXXL
1
2
3
1
2
3
VOUT
GND
VIN
GND
VIN
VOUT
SOT89-3L
SOT89-3L(L-Type)
NOTE: XX indicate Output Voltage
For example: SC33 (VOUT=3.3V)
PIN DESCRIPTION
PIN
NAME
FUNCTION
SOT23-3
SOT89-3L
SOT89-3L
(L-Type)
GND
1
2
1
Ground.
VIN
3
3
2
Regulator Input. Up to 36V input voltage. At least
1μF supply bypass capacitor is recommended.
VOUT
2
1
3
Regulator Output. Recommended output capacitor
range:1μF to 10μF.
RevA.2
2
www.run-ic.com
RS3005
ABSOLUTE MAXIMUM RATINGS (1)
VIN to GND.........................................................-0.3 to 40V
VOUT to GND......................... -0.3V to Min (VIN + 0.3V,7V)
Power Dissipation, PD @ TA = 25°C
SOT23-3 ……….……………………………………..…0.31W
SOT89-3L ……….………………………………………. 1.3W
SOT89-3L(L-Type) ……….………………………….…. 0.6W
Junction Temperature..............................................+150°C
Operating Temperature Range ...................-40°C to +85°C
Package Thermal Resistance @ TA = 25°C
SOT23-3………………….…………………….…….320°C/W
SOT89-3L……….…………......................................75°C/W
SOT89-3L(L-Type) ……….…………………...…….165°C/W
Storage Temperature Range......................-65°C to +150°C
Lead Temperature (Soldering, 10s) …………….........260°C
ESD Susceptibility
HBM ….......................................................................1000V
MM ……………………….........………………...……….100V
ESD SENSITIVITY CAUTION
ESD damage can range from subtle performance
degradation to complete device failure. Precision
integrated circuits may be more susceptible to
damage because very small parametric changes
could cause the device not to meet its published
specifications.
(1) Stresses above these ratings may cause permanent damage. Exposure to
absolute maximum conditions for extended periods may degrade device
reliability. These are stress ratings only, and functional operation of the
device at these or any other conditions beyond those specified is not
implied.
PACKAGE/ORDERING INFORMATION
PRODUCT
RS3005-3.3
RS3005-5.0
ORDERING
NUMBER
VOUT(V)
PACKAGE
LEAD
PACKAGE
MARKING
PACKAGE OPTION
RS3005-3.3YF3
3.3
SOT23-3
SC33
XXXX
Tape and Reel,3000
RS3005-3.3YE3
3.3
SOT89-3L
SC33
XXXX
Tape and Reel,1000
RS3005-3.3YE3L
3.3
SOT89-3L
(L-Type)
SC33L
XXXX
Tape and Reel,1000
RS3005-5.0YF3
5.0
SOT23-3
SC50
XXXX
Tape and Reel,3000
RS3005-5.0YE3
5.0
SOT89-3L
SC50
XXXX
Tape and Reel,1000
RS3005-5.0YE3L
5.0
SOT89-3L
(L-Type)
SC50L
XXXX
Tape and Reel,1000
NOTE: XXXX = Date Code and Vendor Code.
3
www.run-ic.com
RS3005
ELECTRICAL CHARACTERISTICS
(VIN = VOUT + 2V, CIN = COUT = 1μF, Full = -40°C to +85°C, typical values are at TA = +25°C, unless otherwise noted.)
PARAMETER
Input Voltage
SYMBOL
VIN
CONDITIONS
MIN
VOUT = 3.3V
+25°C 2.5(1)
IOUT = 1mA
+25°C
No load
Ground Pin Current
TEMP
-2.5
VIN = VOUT + 2V
VIN = 36V
+25°C
IOUT = 50mA
Line Regulation
Load Regulation
Power Supply Rejection
Ratio
Output Voltage Temperature
Coefficient (4)
+25°C
VDROP
IOUT = 150mA
ΔVOUT
VIN = VOUT + 2V to 36V, IOUT = 1mA
ΔVIN × VOUT
ΔVOUT
PSRR
VIN =VOUT+2V, IOUT = 1mA to150mA
VOUT = 3.3V,
IOUT = 10mA
MAX
UNITS
36
V
11
18
16
25
μA
11
Maximum Output Current (2)
Dropout Voltage (3)
TYP
f = 217Hz
f = 1KHz
ΔVOUT
IOUT = 1mA
ΔTA × VOUT
150
mA
+25°C
1300 1800
mV
+25°C
0.005 0.012
%/V
+25°C
+25°C
FULL
10
65
63
25
mV
dB
70
ppm/°C
120
°C
THERMAL PROTECTION
Thermal Shutdown
Temperature
TSHDN
NOTES:
1. VIN = VOUT (NOMINAL) or 2.5V, whichever is greater.
2. Maximum output current is affected by the PCB layout, size of metal trace, the thermal conduction path between metal
layers, ambient temperature and the other environment factors of system. Attention should be paid to the dropout voltage
when VIN < VOUT + VDROP.
3. The dropout voltage is defined as VIN - VOUT, when VOUT is 100mV below the value of VOUT for VIN = VOUT (NOMINAL) + 2V.
4. Output voltage temperature coefficient is defined as the worst-case voltage change divided by the total temperature
range.
4
www.run-ic.com
RS3005
TYPICAL CHARACTERISTICS
VIN = 5.3V, VOUT = 3.3V, CIN = COUT = 1μF, TA = 25°C unless otherwise noted.
Line-Transient Response
Load-Transient Response
IOUT=10mA to 100mA
VVININ=4.4V
=5.3Vto
to5.4V,I
6.3V,IOUT
OUT
=50mA
=50mA
100mA/div
IOUT
VIN
1V/div
100mV/div
100mV/div
VOUT
VOUT
Time(2ms/div)
Time(2ms/div)
Power-Up/Power-Down Output Waveform
Output Short Waveform
VOUT
2V/div
2V/div
VIN
100mA/div
2V/div
VOUT
VIN=0 to 3.4V,IOUT=50mA
IOUT
Time(1ms/div)
Time(2ms/div)
Dropout Voltage vs. Temperature
Dropout Voltage vs. Output Current
600
1600
IOUT=50mA
Dropout Voltage(mV)
550
Dropout Voltage(mV)
1200
500
450
400
350
300
800
400
-25
50
75
100
Temperature(℃)
25
50
75
100
125
150
Output Current(mA)
5
www.run-ic.com
RS3005
APPLICATION NOTES
Input Capacitor and Output Capacitor
For proper operation, using a ceramic capacitor (CIN) between 1μF and 10μF between the input pin and ground.
The input capacitor must be located a distance of not more than 0.5 inch from the input pin of the IC and returned
to a clean analog ground. The capacitor with larger value and lower ESR (equivalent series resistance) provides
better PSRR and line-transient response. The output capacitor must meet both requirements for minimum
amount of capacitance and ESR in all LDOs application for stable operation, use a ceramic capacitor (COUT)
between 1μF and 10μF. Larger values in this range will help improve load transient response and reduce noise.
Output capacitors of other dielectric types may be used, but are not recommended as their capacitance can
deviate greatly from their rated value over temperature.
Thermal Considerations
When the junction temperature is too high, the thermal protection circuitry sends a signal to the control logic
that will shut down the IC. The IC will restart when the temperature has sufficiently cooled down.
The maximum power dissipation is dependent on the thermal resistance of the case and the circuit board, the
temperature difference between the die junction and the ambient air, and the rate of air flow. The GND pin must
be connected to the ground plane for proper dissipation.
VIN
VIN
CIN
1μF
VOUT
RS3005
VOUT
COUT
1μF
GND
Typical Application Circuit
6
www.run-ic.com
RS3005
PACKAGE OUTLINE DIMENSIONS
SOT23-3
D
1.90
b
2.59
E1
E
0.99
0.95
0.69
e
e1
RECOMMENDED LAND PATTERN (Unit: mm)
0.2
A A2
L
A1
Symbol
c
θ
Dimensions In Millimeters
Dimensions In Inches
Min
Max
Min
Max
A
1.050
1.250
0.041
0.049
A1
0.000
0.100
0.000
0.004
A2
1.050
1.150
0.041
0.045
b
0.300
0.500
0.012
0.020
c
0.100
0.200
0.004
0.008
D
2.820
3.020
0.111
0.119
E
1.500
1.700
0.059
0.067
E1
2.650
2.950
0.104
0.116
e
0.950(BSC)
0.037(BSC)
e1
1.800
2.000
0.071
0.079
L
0.300
0.600
0.012
0.024
θ
0°
8°
0°
8°
7
www.run-ic.com
RS3005
SOT89-3L
D
2.0
A
D1
3.0
E
E1
0.7
45°
b1
L
e
1.5
b
c
1.5
e1
1.0
Symbol
Min
Max
Min
Max
A
1.400
1.600
0.055
0.063
b
0.320
0.520
0.013
0.020
b1
0.400
0.580
0.016
0.023
c
0.350
0.440
0.014
0.017
D
4.400
4.600
0.173
0.181
D1
1.550 REF
0.061 REF
E
2.300
2.600
0.091
0.102
E1
3.940
4.250
0.155
0.167
e
1.500 BSC
0.060 BSC
e1
3.000 BSC
0.118 BSC
L
0.900
1.200
8
0.035
0.047
www.run-ic.com
很抱歉,暂时无法提供与“RS3005-3.3YE3”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.66150
- 50+0.51030
- 150+0.43470
