KH-1.27FH-2X6P-H4.3-SMT
    KINGHELM(金航标)
    SMD,P=1.27mm
    排母 间距:1.27mm 2x6P 立贴
KH-1.27FH-2X6P-H4.3-SMT 数据手册
SPECIFICATIONS Current Rating: 1.0 Amps Withstanding Voltage: AC 500V Insulation Resistance:1000M Min Contact Resistance: 20 mΩ Max Operation Temperature:-40 °to+105° Insrlator Material: Polyester(UL94V-0) Contact Material: Phosphor bronze Standard: PA6T Contact Plating: Gold Flash Max.Processing Temp: 240 °C for30-60seconds (260 °C for5seconds) RECOMMEND P.C.B LAYOUT PCB TOLERANCE:±0.05 (TOP VIEW) (1) Pin Spacing:127=1.27mm (2) Product Name:FH=Female Header (3) No.of Rows:1=Single Row ;2=Dual Row (4) No.of Pins Per Row:1~50 (5) Insulator Material Height:20=2.0mm;43=4.3mm (6) Connector Type:S=Straight;R=Right; Angle M=SMT (7) Connector Material Length: 24=2.4mm; 30=3.0mm (8) Insulator Material Width: 18=1.8mm 21=2.1mm (9) Contact Plating: G0=Gold Flash;AU10=Au 1.0u" (10) Insulator Material Option: A=BK-PA6T;B=BK-PA46;C=KB-LCP;S=Special 深圳市金航标电子有限公司 WWW.BDS666.COM KH-1.27FH-2X6P-H4.3-SMT 0755-83044319 UNLESS OTHEWIXE SPECIFIED TOLERANCE X :±0.3 X.X :±0.2 X.XX:±0.1 DRAW: X° :±5° X.X° :±1° X.XX°:±0.5° LI BEI LIN 12/03/07 No.of DIM.A 1.27FH 2xnPin H4.3 SMT SIZE REV A4 A CHECKED: SCALE PROUCT NO. UNIT PROJECT / / APPROVED: PAGE 1/1 / / DIM.B No. of DIM.A DIM.B No. of DIM.A DIM.B No. of DIM.A DIM.B No. of DIM.A DIM.B
KH-1.27FH-2X6P-H4.3-SMT 价格&库存
很抱歉,暂时无法提供与“KH-1.27FH-2X6P-H4.3-SMT”相匹配的价格&库存,您可以联系我们找货
    • 19+1.30000
    • 190+0.97373
    • 532+0.85958
    • 1900+0.71723
    • 9500+0.65373
    • 19000+0.61571
    库存:18
