MMST3906
SOT-323 Plastic-Encapsulate Transistors
MMST3906
TRANSISTOR (PNP)
SOT–323
FEATURES
Complementary to MMST3904
MARKING:K5N
MAXIMUM RATINGS (Ta=25℃ unless otherwise noted)
Symbol
Parameter
Value
Unit
VCBO
Collector-Base Voltage
-40
V
VCEO
Collector-Emitter Voltage
-40
V
VEBO
Emitter-Base Voltage
-5
V
IC
Collector Current
-200
mA
PC
Collector Power Dissipation
200
mW
Thermal Resistance From Junction To Ambient
625
℃/W
Tj
Junction Temperature
150
Tstg
Storage Temperature
-55~+150
RΘJA
1. BASE
2. EMITTER
3. COLLECTOR
ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified)
Parameter
Symbol
Test conditions
Min
Typ
Max
Unit
Collector-base breakdown voltage
V(BR)CBO*
IC=-10µA, IE=0
-40
V
Collector-emitter breakdown voltage
V(BR)CEO*
IC=-1mA, IB=0
-40
V
Emitter-base breakdown voltage
V(BR)EBO*
IE=-10µA, IC=0
-5
V
Base cut-off current
IBL*
VCE=-30V, VEB(Off)=-3V
-50
nA
Collector cut-off current
ICEX*
-50
nA
DC current gain
hFE*
Collector-emitter saturation voltage
VCE(sat)*
Base-emitter saturation voltage
VBE(sat)*
Transition frequency
fT
VCE=-1V, IC=-100µA
60
VCE=-1V, IC=-1mA
80
VCE=-1V, IC=-10mA
100
300
IC=-10mA, IB=-1mA
-0.2
V
IC=-50mA, IB=-5mA
-0.3
V
-0.85
V
-0.95
V
IC=-10mA, IB=-1mA
-0.65
IC=-50mA, IB=-5mA
VCE=-20V,IC=-10mA , f=100MHz
250
MHz
Collector output capacitance
Cob
VCB=-5V, IE=0, f=1MHz
4.5
pF
Cib
VEB=-0.5V, IE=0, f=1MHz
10
pF
Delay time
td
VCC=-3V, VBE(off)=-0.5V, IC=-10mA,
35
ns
Rise time
tr
IB1=-1mA
35
ns
Storage time
ts
225
ns
Fall time
tf
75
ns
VCC=3V, IC=-10mA, IB1= IB2=-1mA
*Pulse test: pulse width ≤300μs, duty cycle≤ 2.0%.
www.yongyutai.com
PAGE 1
Typical Characteristics
Static Characteristic
-80
hFE
200
DC CURRENT GAIN
COLLECTOR CURRENT
IC
Ta=100℃
-350uA
-300uA
-250uA
-200uA
-40
COMMON EMITTER
VCE=-1V
COMMON
EMITTER
Ta=25℃
-400uA
-60
hFE
300
-500uA
-450uA
IC
(mA)
-100
-150uA
Ta=25℃
100
-100uA
-20
IB=-50uA
-0
-0
-4
-8
-12
-16
COLLECTOR-EMITTER VOLTAGE
VCEsat
-500
VCE
-20
-1
-0.3
-10
-3
COLLECTOR CURRENT
(V)
IC
VBEsat
-1.2
-100
-30
IC
-200
(mA)
IC
BASE-EMITTER SATURATION
VOLTAGE VBEsat (V)
COLLECTOR-EMITTER SATURATION
VOLTAGE VCEsat (mV)
-300
Ta=100℃
-100
Ta=25℃
-30
Ta=25℃
-0.8
Ta=100℃
-0.4
β=10
-10
β=10
-0.0
-1
-3
-30
-10
COLLECTOR CURRENT
IC
-100
IC
-100
-200
-1
-10
-3
(mA)
-100
-30
COLLECTOR CURRENT
—— VBE
Cob/ Cib
9
IC
VCB/ VEB
f=1MHz
IE=0/IC=0
-30
Ta=25℃
Cob
(pF)
Ta=100℃
Cib
C
-10
CAPACITANCE
IC
(mA)
COMMON EMITTER
VCE=-1V
COLLECTOR CURRENT
-200
(mA)
-3
Ta=25℃
-1
3
-0.3
-0.1
-0.2
-0.4
-0.6
-0.8
-1.0
1
-0.1
-1.2
fT
600
—— IC
-1
-3
REVERSE VOLTAGE
V
-0.3
BASE-EMMITER VOLTAGE VBE (V)
PC
250
-10
-20
(V)
Ta
VCE=-20V
TRANSITION FREQUENCY
fT
COLLECTOR POWER DISSIPATION
PC (mW)
(MHz)
Ta=25℃
400
200
200
150
100
50
-3
-10
COLLECTOR CURRENT
www.yongyutai.com
www.cj-elec.com
-30
IC
(mA)
-50
50
75
AMBIENT TEMPERATURE
100
Ta
125
150
PAGE 2
A,Jun,2014
SOT-323 Package Outline Dimensions
Symbol
A
A1
A2
b
c
D
E
E1
e
e1
L
L1
θ
Dimensions In Millimeters
Min
Max
0.900
1.100
0.000
0.100
0.900
1.000
0.200
0.400
0.080
0.150
2.000
2.200
1.150
1.350
2.150
2.450
0.650 TYP
1.200
1.400
0.525 REF
0.260
0.460
0°
8°
Dimensions In Inches
Min
Max
0.035
0.043
0.000
0.004
0.035
0.039
0.008
0.016
0.003
0.006
0.079
0.087
0.045
0.053
0.085
0.096
0.026 TYP
0.047
0.055
0.021 REF
0.010
0.018
0°
8°
SOT-323 Suggested Pad Layout
www.cj-elec.com
www.yongyutai.com
A,Jun,2014
PAGE 3
很抱歉,暂时无法提供与“MMST3906”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.21287
- 100+0.16622
- 300+0.14030
- 3000+0.12669
- 6000+0.11319
- 9000+0.10595
