ME6119
400mA Adjustable Voltage High Speed LDO Regulators ME6119 Series
General Description
Features
The ME6119 series are highly accurate, low
Maximum Output Current: 400mA
noise, LDO Voltage Regulators .On chip trimming
Dropout Voltage:104mV@ IOUT =100mA
adjusts the reference/output voltage to within ±2%
Operating Voltage Range: 2.5V~18V
accuracy. Internal protection features consist of
Highly Accuracy: ±2%
output
area
Adjustable Output Voltage Option
compensation, and thermal shutdown. The current
Standby Current: 60uA(TYP.)
limiter’s feedback circuit also operates as a short
Line Regulation: 30mV(TYP.)
protect for the output current limiter and the output
Temperature Stability≤0.5%
pin. The CE function allows the output of regulator
Thermal Shutdown Protection:164℃
current
limiting,
safe
operating
to be turned off, resulting in greatly reduced power
consumption. The ME6119 series can operate with
up to 18V input.
Typical
Application
Package
Consumer and Industrial Equipment Point of
3-pin SOT89-3、SOT23-3
Regulation
5-pin SOT23-5
Switching Power Supply Post Regulation
Hard Drive Controllers
Battery
Chargers
Typical
Application
Circuit
V05
www.microne.com.cn
Page 1 of 12
ME6119
Selection Guide
ME 6119X X X X X G
Environment mark
Package:
P-SOT89-3
M5-SOT23-5
M3-SOT23-3
Output Voltage
Function
Product Type
Product Series
Microne
product series
NOTE:
V05
product description
ME6119A30PG
VOUT =3.0V;Have no enable ; Package:SOT89-3
ME6119A30M3G
VOUT =3.0V; Have no enable ; Package:SOT23-3
ME6119C30M5G
VOUT =3.0V; Have enable ; Package:SOT23-5
At present ,there are five kinds of voltage value: 3.0V、3.3V、3.6V、4.0V、4.4V、5.0V。
If you need other voltage and package, please contact our sales staff。
www.microne.com.cn
Page 2 of 12
ME6119
Pin Configuration
Pin Assignment
ME6119CXX
Pin Number
Pin Name
Functions
1
VIN
Power Input
2
VSS
Ground
3
CE
ON / OFF Control
4
NC
No Connect
5
VOUT
Output
Pin Name
Functions
SOT23-5
ME6119AXX
Pin Number
SOT89-3
SOT23-3
1
1
VSS
Ground
2
3
VIN
Power Input
3
2
VOUT
Output
Absolute Maximum Ratings
Parameter
Symbol
Ratings
Units
Input Voltage
VIN
18
V
Output Current
IOUT
500
mA
Output Voltage
VOUT
Vss-0.3~VIN +0.3
V
CE Pin Voltage
VCE
Vss-0.3~VIN +0.3
V
SOT23
PD
300
mW
SOT89
PD
500
mW
Operating Temperature Range
TOPR
-40~+125
Storage Temperature Range
TSTG
-40~+150
Power Dissipation
Lead Temperature
V05
260℃,4sec
www.microne.com.cn
Page 3 of 12
ME6119
Block Diagram
V05
www.microne.com.cn
Page 4 of 12
ME6119
Electrical Characteristics
ME6119A33/C33
(VIN= VOUT+1V,VCE=VIN ,CIN=CL=10uF,Ta=25OC,unless otherwise noted)
Parameter
Symbol
Conditions
Min.
Typ.
Max.
Units
Output Voltage
VOUT(E)
(Note 2)
IOUT=30mA,
VIN= VOUT+1V
X 0.98
VOUT (T)
(Note 1)
X 1.02
V
Maximum Output
Current
IOUTMAX
VIN= VOUT+1V
400
mA
Load Regulation
∆VOUT
VIN= VOUT+1V , 1mA≤IOUT≤100mA
8
mV
Dropout Voltage
(Note 1)
VDIF1
IOUT =100mA
130
mV
VDIF2
IOUT =200mA
260
mV
Supply Current
ISS
VIN= VOUT+1V
60
μA
Stand-by Current
ICEL
VCE=0V
μA
Line Regulation
∆VOUT
IOUT =30mA
VOUT+1V ≤VIN≤18V
mV
CE “High”
Voltage
VCEH
Start up
CE “Low”
Voltage
VCEL
Shut down
Short-circuit
Current
ISHORT
VIN= VOUT+1V, VCE=VIN, VOUT=0V
60
mA
Thermal Shutdown
Protection
Tsd
IOUT=1mA,
VIN= VOUT+1V
164
Over Current
Protection
Ilimit
VIN= 4.3V
550
mA
V05
www.microne.com.cn
1.20
V
0.8
V
Page 5 of 12
ME6119
ME6119A50/C50
Parameter
Symbol
Conditions
Min.
Typ.
Max.
Units
Output Voltage
VOUT(E)
(Note 2)
IOUT=30mA,
VIN= VOUT+1V
X 0.98
VOUT (T)
(Note 1)
X 1.02
V
Maximum Output
Current
IOUTMAX
VIN= VOUT+1V
400
mA
Load Regulation
∆VOUT
8
mV
Dropout Voltage
(Note 1)
VDIF1
IOUT =100mA
104
mV
VDIF2
IOUT =200mA
210
mV
Supply Current
ISS
VIN= VOUT+1V
60
μA
Stand-by Current
ICEL
VCE=0V
μA
Line Regulation
∆VOUT
IOUT =30mA
VOUT+1V ≤VIN≤18V
30
mV
CE “High”
Voltage
VCEH
Start up
CE “Low”
Voltage
VCEL
Shut down
Short-circuit
Current
ISHORT
50
mA
Thermal Shutdown
Protection
Tsd
IOUT=1mA,
VIN= VOUT+1V
164
Over Current
Protection
Ilimit
VIN= 6.0V
510
mA
1.20
V
0.8
V
Note :
1. VOUT (T) :Specified Output Voltage
2.VOUT (E) :Effective Output Voltage ( le. The output voltage when “VOUT (T)+1.0V”is provided at the Vin pin while
maintaining a certain IOUT value.)
3.VDIF:VIN1 –VOUT (E)’
VIN1 :The input voltage when VOUT(E)’ appears as input voltage is gradually decreased.
VOUT (E)’=A voltage equal to 98% of the output voltage whenever an amply stabilized IOUT {VOUT (T)+1.0V} is
input.
V05
www.microne.com.cn
Page 6 of 12
ME6119
Type Characteristics
(VOUT=5.0V)
(1)Output Voltage VS. Output Current
(VIN=VOUT+1V)
(2) Output Voltage VS. Temperature
(VIN=VOUT+1V , IOUT=1mA)
Output Voltage VS.Output Current
5.05
Output Voltage(V)
Output Voltage(V)
5.10
5.00
4.95
4.90
4.85
4.80
200
300
5.06
5.04
5.02
5.00
4.98
4.96
4.94
4.92
4.90
400
60
90
120
150
Temperature(℃)
Output Current(mA)
(3)Dropout Voltage VS. Output Current(Ta = 25 °C) (4)Output Voltage VS. Input Voltage(IOUT =10mA)
(Ta = 25 °C)
Output Voltage VS.Input Voltage
600
500
Output Voltage(V)
Dropout Voltage(mV)
Dropout Voltage VS.Output Current
400
300
200
100
200
300
400
5.80
5.30
4.80
4.30
3.80
3.30
2.80
2.30
1.80
2
Output Current(mA)
4
6
8
10
12
14
16
Input Voltage(V)
(5)Quiescent Current VS. Input Voltage
Quiescent Current(uA)
105
90
75
60
45
30
15
2
4
6
8
10
12
14
16
18
Input Voltage(V)
V05
www.microne.com.cn
Page 7 of 12
18
ME6119
Applications Information
1. Input Bypass Capacitor
An input capacitor is recommended. A 10uF tantalum on the input is a suitable input bypassing for almost all
applications.
2. Output Capacitor
The output capacitor is critical in maintaining regulator stability, and must meet the required conditions for both
minimum amount of capacitance and ESR (Equivalent Series Resistance).The minimum output capacitance
required by the ME6119 is 10µF,if a tantalum capacitor is used. Any increase of the output capacitance will
merely improve the loop stability and transient response. The ESR of the output capacitor should be less than
0.5Ω .
3. Load Regulation
The ME6119 regulates the voltage that appears between its output and ground pins, or between its output and
adjust pins. In some cases, line resistances can introduce errors to the voltage across the load. To obtain the
best load regulation, a few precautions are needed. Figure1, shows a typical application using a fixed output
regulator. The Rt1 and Rt2 are the line resistances. It is obvious that the VLOAD is less than the VOUT by the sum of
the voltage drops along the line resistances. In this case, the load regulation seen at the RLOAD would be
degraded from the datasheet specification. To improve this , the load should be tied directly to the output terminal
on the positive side and directly tied to the ground terminal on the negative side.
FIGURE 1. Typical Application using Fixed Output Regulator
V05
www.microne.com.cn
Page 8 of 12
ME6119
Packaging Information
● SOT23-5
DIM
Millimeters
Inches
Min
Max
Min
Max
A
0.9
1.45
0.0354
0.0570
A1
A2
0.9
1.3
0.0354
0.0511
B
0.2
0.5
0.0078
0.0196
C
0.09
0.26
0.0035
0.0102
D
2.7
3.10
0.1062
0.1220
E
2.2
3.2
0.0866
0.1181
E1
1.30
1.80
0.0511
0.0708
e
0.95REF
0.0374REF
e1
1.90REF
0.0748REF
L
0.10
0.60
0.0039
0.0236
a0
00
300
00
300
V05
www.microne.com.cn
Page 9 of 12
ME6119
● SOT89-3
DIM
Millimeters
Inches
Min
Max
Min
Max
A
1.4
1.6
0.0551
0.0630
A1
1.4
1.6
0.0551
0.0630
a
0.36
0.48
0.0142
0.0189
b
0.41
0.53
0.0161
0.0209
c
0.36
0.48
0.0142
0.0189
d
1.4
1.75
0.0551
0.0689
B
0.38
0.43
0.015
0.0169
C
1.4
1.6
0.0551
0.0630
D
4.4
4.6
0.1732
0.181
E
4.25
0.1673
e
2.4
2.6
0.0945
0.1023
L1
0.4
0.0157
L2
0.8
0.0315
V05
www.microne.com.cn
Page 10 of 12
ME6119
● SOT23-3
DIM
V05
Millimeters
Inches
Min
Max
Min
Max
A
2.7
3.1
0.1063
0.122
B
1.7
2.1
0.0669
0.0827
b
0.35
0.5
0.0138
0.0197
C
1.0
1.2
0.0394
0.0472
c
0.1
0.25
0.0039
0.0098
d
0.2
0.0079
E
2.6
3.0
0.1023
0.1181
e
1.5
1.8
0.059
0.0708
www.microne.com.cn
Page 11 of 12
ME6119
The information described herein is subject to change without notice.
Nanjing Micro One Electronics Inc is not responsible for any problems caused by circuits or diagrams
described herein whose related industrial properties, patents, or other rights belong to third parties.
The application circuit examples explain typical applications of the products, and do not guarantee the
success of any specific mass-production design.
Use of the information described herein for other purposes and/or reproduction or copying without the
express permission of Nanjing Micro One Electronics Inc is strictly prohibited.
The products described herein cannot be used as part of any device or equipment affecting the human
body, such as exercise equipment, medical equipment, security systems, gas equipment, or any
apparatus installed in airplanes and other vehicles, without prior written permission of Nanjing Micro
One Electronics Inc.
Although Nanjing Micro One Electronics Inc exerts the greatest possible effort to ensure high quality
and reliability, the failure or malfunction of semiconductor products may occur. The user of these
products should therefore give thorough consideration to safety design, including redundancy,
fire-prevention measures, and malfunction prevention, to prevent any accidents, fires, or community
damage that may ensue.
V05
www.microne.com.cn
Page 12 of 12
很抱歉,暂时无法提供与“ME6119A33M3G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.57640
- 200+0.37180
- 1500+0.32340
- 3000+0.28600
