MUR320SHV6G
MUR320SHV6G
    TAIWANSEMICONDUCTOR(台湾半导体)
    SMC(DO-214AB)
    MUR320SHV6G
MUR320SHV6G 数据手册
MUR305S - MUR360S Taiwan Semiconductor 3A, 50V - 600V Surface Mount Ultrafast Power Rectifier FEATURES KEY PARAMETERS ● ● ● ● ● Glass passivated junction Ideal for automated placement Built-in strain relief Ultrafast recovery time for high efficiency Compliant to RoHS Directive 2011/65/EU and in accordance to WEEE 2002/96/EC ● Halogen-free according to IEC 61249-2-21 APPLICATIONS PARAMETER VALUE UNIT IF(AV) 3 A VRRM 50 - 600 V IFSM 75 A TJ MAX 175 °C Package DO-214AB (SMC) Configuration Single die ● High frequency rectification ● Freewheeling application ● Switching mode converters and inverters in computer, automotive and telecommunication. MECHANICAL DATA ● ● ● ● Case: DO-214AB (SMC) Molding compound meets UL 94V-0 flammability rating Part no. with suffix "H" means AEC-Q101 qualified Packing code with suffix "G" means green compound (halogen-free) ● Moisture sensitivity level: level 1, per J-STD-020 ● Terminal: Matte tin plated leads, solderable per J-STD-002 DO-214AB (SMC) ● Meet JESD 201 class 2 whisker test ● Polarity: As marked ● Weight: 0.21 g (approximately) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) Repetitive peak reverse voltage VRRM MUR 305S MUR 305S 50 Reverse voltage, total rms value VR(RMS) 35 70 105 140 280 420 V Maximum DC blocking voltage VDC 50 100 150 200 400 600 V Forward current Surge peak forward current, 8.3 ms single half sine-wave superimposed on rated load per diode Junction temperature IF(AV) 3 A IFSM 75 A TJ - 55 to +175 °C Storage temperature TSTG - 55 to +175 °C PARAMETER SYMBOL Marking code on the device 1 MUR 310S MUR 310S 100 MUR 315S MUR 315S 150 MUR 320S MUR 320S 200 MUR 340S MUR 340S 400 MUR 360S MUR 360S 600 UNIT V Version:H1903 MUR305S - MUR360S Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER Junction-to-lead thermal resistance per diode SYMBOL TYP UNIT RӨJL 11 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage per diode CONDITIONS (1) Reverse current @ rated VR (2) per diode Reverse recovery time MUR305S MUR310S MUR315S MUR320S MUR340S MUR360S MUR305S MUR310S MUR315S MUR320S MUR340S MUR360S MUR305S MUR310S MUR315S MUR320S MUR340S MUR360S MUR305S MUR310S MUR315S MUR320S MUR340S MUR360S MUR305S MUR310S MUR315S MUR320S MUR340S MUR360S IF = 3A, TJ = 25°C IF = 3A, TJ = 150°C TJ = 25°C SYMBOL TYP. MAX. UNIT - 0.875 V - 1.250 V - 0.710 V - 1.050 V - 5 μA - 10 μA - 150 μA - 250 μA - 25 ns - 50 ns VF VF IR TJ = 150°C IF=0.5A , IR=1.0A IRR=0.25A IR trr Notes: 1. Pulse test with PW=0.3 ms 2. Pulse test with PW=30 ms 2 Version:H1903 MUR305S - MUR360S Taiwan Semiconductor ORDERING INFORMATION PART NO. PART NO. SUFFIX MUR3xxS (Note 1,2) H PACKING CODE PACKING CODE SUFFIX PACKAGE PACKING R7 SMC 850 / 7" Plastic reel R6 SMC 3,000 / 13" Paper reel SMC 3,000 / 13" Plastic reel V7 Matrix SMC 850 / 7" Plastic reel V6 Matrix SMC 3,000 / 13" Plastic reel M6 G Note : 1. "xx" defines voltage from 50V (MUR305S) to 600V (MUR340S) 2. Only V6 and V7 are all green compound (halogen free) EXAMPLE EXAMPLE P/N PART NO. PART NO. SUFFIX PACKING CODE PACKING CODE SUFFIX DESCRIPTION MUR305SHR7G MUR305S H R7 G AEC-Q101 qualified Green compound 3 Version:H1903 MUR305S - MUR360S Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 1000 3 CAPACITANCE (pF) AVERAGE FORWARD CURRENT (A) 4 2 1 MUR305S - MUR320S 100 MUR340S - MUR360S 10 0 0 25 50 75 100 125 150 0.1 175 1 Fig.4 Typical Forward Characteristics MUR305S - MUR320S 10 TJ=150℃ 0.1 0.01 TJ=25℃ 0.001 20 30 40 50 60 70 80 90 10 10 MUR305S - MIR320S 1 TJ=125°C TJ=150℃ 0.1 TJ=25°C 0.01 TJ=25℃ Pulse width 0.001 0.3 0.1 0 100 UF1DLW 1 (A) 100 INSTANTANEOUS FORWARD CURRENT (A) INSTANTANEOUS REVERSE CURRENT (μA) Fig.3 Typical Reverse Characteristics 10 100 REVERSE VOLTAGE (V) LEAD TEMPERATURE (oC) 1 10 0.2 0.4 0.4 0.5 0.6 0.6 0.7 0.8 0.8 1 0.9 1.2 1 1.1 1.4 1.6 FORWARD VOLTAGE (V) PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 4 Version:H1903 1.2 MUR305S - MUR360S Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Typical Forward Characteristics MUR340S - MUR360S 10 TJ=150℃ 1 0.1 TJ=25℃ 0.01 0.001 10 20 30 40 50 60 70 80 90 10 10 MUR340S - MUR360S UF1DLW 1 TJ=125°C TJ=150℃ TJ=25℃ 0.01 Pulse width 0.001 0.1 0.3 0 100 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) TJ=25°C 0.1 1 (A) 100 INSTANTANEOUS FORWARD CURRENT (A) INSTANTANEOUS REVERSE CURRENT (μA) Fig.5 Typical Reverse Characteristics 0.4 0.2 0.5 0.4 0.6 0.7 0.8 0.9 1 0.6 0.8 1 1.2 1.4 1.6 FORWARD VOLTAGE (V) 1.1 1.8 PEAK FORWARD SURGE CURRENT (A) Fig.7 Maximum Non-repetitive Forward Surge Current 80 8.3ms Single Half Sine Wave 70 60 50 40 30 20 10 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 5 Version:H1903 1.2 2 MUR305S - MUR360S Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-214AB (SMC) Unit (mm) DIM. Unit (inch) Min. Max. Min. Max. A 2.90 3.20 0.114 0.126 B 6.60 7.11 0.260 0.280 C 5.59 6.22 0.220 0.245 D 2.00 2.62 0.079 0.103 E 1.00 1.60 0.039 0.063 F 7.75 8.13 0.305 0.320 G 0.10 0.20 0.004 0.008 H 0.15 0.31 0.006 0.012 SUGGESTED PAD LAYOUT Symbol Unit (mm) Unit (inch) A 3.30 0.130 B 2.50 0.098 C 6.80 0.268 D 4.40 0.173 E 9.40 0.370 MARKING DIAGRAM Matrix SMC SMC P/N =Marking Code G =Green Compound YW =Date Code F =Factory Code 6 Version:H1903 MUR305S - MUR360S Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 7 Version:H1903
MUR320SHV6G 价格&库存
很抱歉,暂时无法提供与“MUR320SHV6G”相匹配的价格&库存,您可以联系我们找货
