WNM2021-3/MS
WNM2021-3/MS
    MSKSEMI(美森科)
    SOT323
    WNM2021-3/MS
WNM2021-3/MS 数据手册
www.msksemi.com WNM2021-3/MS Semiconductor Compiance Features D 3 ● Trench Technology ● Supper high density cell design ● Excellent ON resistance 2 S 1 G ● Extremely Low Threshold Voltage ● Small package SOT-323 Pin configuration (Top view) Applications SOT-323 ● DC-DC converter circuit ● Small Signal Switch ● Load Switch ● Level Shift N-Channel, 20V, 0.89A, Small Signal MOSFET VDS (V) 20 Absolute Maximum ratings Parameter Symbol Rds(on) (Ω) ID (A) 0.220@ VGS=4.5V 0.55 0.260@ VGS=2.5V 0.45 0.320@ VGS=1.8V 0.35 10 S Steady State Drain-Source Voltage VDS 20 Gate-Source Voltage VGS ±6 TA=25°C Continuous Drain Current a Maximum Power Dissipation TA=70°C a Pulsed Drain Current TA=70°C TA=25°C Continuous Drain Current b Maximum Power Dissipation TA=25°C TA=70°C b TA=25°C TA=70°C ID PD ID PD Unit V 0.89 0.82 0.71 0.65 0.37 0.31 0.23 0.20 0.78 0.70 0.62 0.56 0.29 0.23 0.18 0.14 A W A W IDM 1.4 A Operating Junction Temperature TJ 150 °C Lead Temperature TL 260 °C Storage Temperature Range Tstg -55 to 150 °C c Thermal resistance ratings Parameter Junction-to-Ambient Thermal Resistancea Junction-to-Ambient Thermal Resistanceb Junction-to-Case Thermal Resistance Symbol t ≤ 10 s Steady State t ≤ 10 s Steady State Steady State Typical Maximum 275 335 325 395 375 430 445 535 260 300 RθJA RθJA RθJC a Surface mounted on FR4 Board using 1 square inch pad size, 1oz copper b Surface mounted on FR4 board using minimum pad size, 1oz copper c Repetitive rating, pulse width limited by junction temperature, tp=10µs, Duty Cycle=1% d Repetitive rating, pulse width limited by junction temperature TJ=150°C. Unit °C/W www.msksemi.com WNM2021-3/MS Semiconductor Compiance Electronics Characteristics (Ta=25oC, unless otherwise noted) Parameter Symbol Test Conditions Min Typ Max Unit OFF CHARACTERISTICS Drain-to-Source Breakdown Voltage BVDSS VGS = 0 V, ID = 250uA 20 V Zero Gate Voltage Drain Current IDSS VDS =16 V, VGS = 0V 100 nA Gate-to-source Leakage Current IGSS VDS = 0 V, VGS =±5V 5 uA VGS(TH) VGS = VDS, ID = 250uA V ON CHARACTERISTICS Gate Threshold Voltage Drain-to-source On-resistance Forward Transconductance RDS(on) gFS 0.58 0.85 VGS = 4.5V, ID = 0.55A 0.45 220 260 VGS = 2.5V, ID = 0.45A 260 310 VGS = 1.8V, ID = 0.35A 320 380 VDS = 5 V, ID = 0.55A 2.0 mΩ S CHARGES, CAPACITANCES AND GATE RESISTANCE Input Capacitance CISS Output Capacitance COSS Reverse Transfer Capacitance CRSS 50 VGS = 0 V, f = 1.0 MHz, VDS = pF 13 10 V 8 Total Gate Charge QG(TOT) Threshold Gate Charge QG(TH) VGS = 4.5 V, VDS = 10 V, 1.15 0.06 Gate-to-Source Charge QGS ID = 0.55A 0.15 Gate-to-Drain Charge QGD nC 0.23 SWITCHING CHARACTERISTICS Turn-On Delay Time td(ON) 22 Rise Time tr VGS = 4.5 V, VDS = 10V, 80 Turn-Off Delay Time td(OFF) RL=3 Ω, RG=6 Ω 700 Fall Time tf ns 380 BODY DIODE CHARACTERISTICS Forward Voltage VSD VGS = 0 V, IS = 0.35A 0.5 0.7 1.1 V www.msksemi.com WNM2021-3/MS Semiconductor Compiance PACKAGE MECHANICAL DATA Symbol A A1 A2 b c D E E1 e e1 L L1 0 Dimensions In Millimeters Min Max 0.900 1.100 0.000 0.100 0.900 1.000 0.200 0.400 0.080 0.150 2.000 2.200 1.150 1.350 2.150 2.450 0.650 TYP 1.200 1.400 0.525 REF 0.260 0.460 0° 8° Dimensions In Inches Min Max 0.035 0.043 0.000 0.004 0.035 0.039 0.008 0.016 0.003 0.006 0.079 0.087 0.045 0.053 0.085 0.096 0.026 TYP 0.047 0.055 0.021 REF 0.010 0.018 0° 8° REEL SPECIFICATION P/N WNM2021-3/MS PKG QTY SOT-323 3000 www.msksemi.com WNM2021-3/MS Semiconductor Compiance Attention ■ Any and all MSKSEMI Semiconductor products described or contained herein do not have specifications that can handle applications that require extremely high levels of reliability, such as life-support systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your MSKSEMI Semiconductor representative nearest you before using any MSKSEMI Semiconductor products described or contained herein in such applications. ■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described orcontained herein. ■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment. ■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention circuitsfor safedesign, redundant design, and structural design. ■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from theauthorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of MSKSEMI Semiconductor. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringementsof intellectual property rights or other rightsof third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the MSKSEMI Semiconductor productthat you intend to use. www.msksemi.com
WNM2021-3/MS 价格&库存
很抱歉,暂时无法提供与“WNM2021-3/MS”相匹配的价格&库存,您可以联系我们找货
WNM2021-3/MS
  • 5+0.47645
  • 50+0.37951
  • 150+0.33103
  • 500+0.29468
  • 3000+0.26559
  • 6000+0.25107
库存:64
