EGT827M1HI20RR
EGT827M1HI20RR
    MANYUE(万裕科技)
    插件,D12.5xL20mm
    820UF ±20% 50V
EGT827M1HI20RR 数据手册
GT +105˚C, High Ripple Current (高紋波), Longer Life Assurance (較長壽命), Low Impedance (低阻抗品) Series FEATURES Low impedance for high frequency. Load life of 4,000~10,000 hours at 105˚C.   SPECIFICATIONS Item Performance Characteristics Operating Temperature Range -40 to +105˚C Rated Working Voltage Range 6.3 to 100V Nominal Capacitance Range 15 to 3900μF Capacitance Tolerance ±20% at 120Hz, +20˚C I ≤0.01CV or 3 (μA) Leakage Current whichever is greater measured after 2 minutes application of rated working voltage at +20˚C Working Voltage (V) 6.3 10 16 tan δ (max.) 0.22 0.19 0.16 For capacitance value >1000μF, add 0.02 per another 1000μF Low Temperature Characteristics Impedance ratio max. at 120Hz Rated Voltage (V) 6.3 Z-25˚C / Z+20˚C 4 Z-40˚C / Z+20˚C 8 GT tan δ (120Hz, +20˚C) Test time High Temperature Loading : ΦD 6.3~10WV 16~100WV 10 3 6 5~6.3 4,000h 5,000h 8~10 6,000h 7,000h 25 0.14 35 0.12 50 0.10 63 0.09 100 0.08 25 2 3 35 2 3 50 2 3 63 2 3 100 2 3 16 2 4 12.5 8,000h 10,000h Post test requirements at +20˚C Leakage current : ≤Initial specified value Cap. change : within ±25% of the initial measured tan δ : ≤200% of the initial specified value value Test temperature : +105˚C Test conditions : Rated DC working voltage with rated ripple current Miniature Aluminum Electrolytic Capacitors Shelf Life At +105˚C no voltage applied after 1,000 hours and then being stabilized at +20˚C the capacitors shall meet the following limits Leakage current : ≤Initial specified value Cap. change : within ±25˚% of the initial measured value tan δ : ≤200% of the initial specified value Industrial Standard JIS C - 5101-4 (IEC 60384-4) CASE SIZE TABLE ΦD 6.3 8 (L
EGT827M1HI20RR 价格&库存
很抱歉,暂时无法提供与“EGT827M1HI20RR”相匹配的价格&库存,您可以联系我们找货
EGT827M1HI20RR
库存:1
