SE90-600X
SE90-600X
    SURGING(绍鑫)
    SE90-600X
SE90-600X 数据手册
SurgeArresters 陶瓷气体放电管 SE90 Series http://www.szshaoxin.com/ 绍 鑫 实 业 Gas Discharge Tube - SE 9 0 Series Gas discharge tubes (GDT) use noble gasses enclosed in ceramic tubes to provide an alternate circuit path for voltage spikes.The ceramic envelope and with nickel connectors allow for high loads and Surging offers products that function at 20KA,40KA,50KA,60KA,100KA&150KA.The breakdown voltages of the devices have a wide range (up to 20% tolerance).Major applications are high frequency telecommunication lines,stations, security systems,HID and high quality Surge Protection Devices (SPD). Features • RoHS & HF compliant • High insulation resistance. • High holdover voltage. • Size:7.2mm*5.0mm • Large absorbing transient current capability. • DC Spark-over voltage: 75~1100V • Low Capacitance • Stable breakdown voltage. • Micro-Gap Design Recommended Applications • Cable Modem • Power supplier • xDSL • Consumer electronics • Set-Top Box • General telecom equipment • Satellite and CATV equipment Product Name SE 90 - 230X Series: Lead Type: DC Line Voltage: SE 90系列:ф5 * 7.6 0=SMD 3=Thrust 90X=90V 230X=230V 102X=1000V http://www.szshaoxin.com/ 绍 鑫 实 业 Gas Discharge Tube - SE 9 0 Series Electriacl Characteristics Part Number Max. Impulse Breakdown Voltage DC Spark-over Voltage Max. Impulse Impulse Life Normal Alternating Discharge (10/1000μs) Discharge Current Current (8/20μs) 1 time 10 times 100A 50Hz, 1Sec 100V/S 100V/μs 1KV/μs (V) (V) (V) SE90-75X 75±20% 600 700 10 5 300 5 SE90-90X 90±20% 500 600 10 5 300 SE90-120X 120±20% 500 600 10 5 SE90-150X 150±20% 500 600 10 SE90-200X 200±20% 600 700 SE90-230X 230±20% 600 SE90-250X 250±20% SE90-350X (KA) (Times) DC Holdover Voltage Minimum Maximum Insulation Capacitance Resistance (1MHz) Single 9 Cycles (V) (GΩ) (pF) 30 52 1 2 5 30 52 1 2 300 5 30 80 1 2 5 300 5 30 80 1 2 10 5 300 10 60 135 1 2 700 10 5 300 10 60 135 1 2 600 700 10 5 300 10 60 135 1 2 350±20% 650 750 10 5 300 10 60 135 1 2 SE90-400X 400±20% 700 800 10 5 300 10 60 135 1 2 SE90-420X 420±20% 700 800 10 5 300 10 60 135 1 2 SE90-470X 470±20% 800 900 10 5 300 10 60 135 1 2 SE90-600X 600±20% 900 1000 10 5 300 5 30 135 1 2 SE90-800X 800±20% 1150 1400 10 5 300 5 30 135 1 2 SE90-112X 1100±20% 1450 1750 10 5 300 5 30 135 1 2 DC Spark-over Voltage DC Measuring Voltage 75-90V 50V 120-400V 100V 420-1100V 250V (A) http://www.szshaoxin.com/ 绍 鑫 实 业 Gas Discharge Tube - SE 9 0 Series Product size (Unit:mm) Recommended Pad Size Dimension 7.2±0.3 8.2 7. 6 ± 0.3 0.4 0.4 1.5 1.5 0.4 3.3 5.0±0.1 5.0±0.1 5.0±0.1 5.0±0.1 5.6 1.6 0.4 Packaging Taping Unit:mm P0 D . 330 ± 4.0 E F >1.5 W 100typ . t P K 18. typ Quantity:1000pcs per reel (13”) Item P PO W F E D K t Spec. 12.0 4.0 16.0 7.5 1.75 Φ1.55 6.7 0.5 Tolerance ±0.1 ±0.1 ±0.3 ±0.1 ±0.1 ±0.05 ±0.1 ±0.05 http://www.szshaoxin.com/
SE90-600X 价格&库存
很抱歉,暂时无法提供与“SE90-600X”相匹配的价格&库存,您可以联系我们找货
