KSD103AX
Low Forward Voltage Drop
SOD523 Micro SMD Package
RoHS Compliant / Green EMC
Matte Tin (Sn) Lead Finish
Cathode Band / Device Marking
Surface Mount Package Ideally Suited
For Automatic Insertion
Maximum Ratings (Ta = 25 ℃)
Symbol
Parameter
Value
Units
VRRM
Peak Repetive Reverse Voltage
40
V
VRWM
Working Peak Reverse Voltage
40
V
VR
DC Blocking Voltage
40
V
VR(RMS)
RMS Reverse Voltage
28
V
IFM
Forward Continuous Current
350
mA
IFSM
Non-Repetitive Peak Forward Surge Current
2.0
A
( @t=8..3ms )
PD
Power Dissipation
200
mW
TJ
Junction Temperature
125
TSTG
Storage Temperature
-55 to +150
RθJA
Thermal Resistance From Junction To Ambient
625
℃/W
Electrical Characteristics (Ta = 25 ℃)
Symbol
Parameter
VBR
Reverse Voltage
VF
Forward Voltage
IR
Reverse current
CT
Capacitance
trr
Typical Reverse Recovery Time
Conditions
IF = 100uA
Min
Typ
Max
Units
V
40
IF = 20mA
0.37
V
IF = 200mA
0.60
V
VR= 30V
5
μA
VR = 0V, f = 1MHz
50
pF
IF = IR =200mA,
Irr=0.1*IR,RL = 100Ω
1/3
10
ns
KSD103AX
Curve Characteristics
Typical Instantaneous Forward Characteristics
Typical Reverse Leakage Characteristics
Power Derating Curve
2/3
KSD103AX
Package Dimensions
Package outline : SOD-523
Unit
A
A1
b
c
D
E
E1
E2
L
Max.
0.70 0.70 0.35 0.15 0.85 1.30 1.70 0.25 0.07
Min.
0.51 0.50 0.25 0.08 0.75 1.10 1.50 0.15 0.01
θ
7°
REF.
Note:
1. Halogen free,EMC
2. Pb free solder
3. Lead thickness includes solder plating
4. Lead frame: Cu
5. Other Tolerance: ±0.05
6. Dimensions are exclusive of Burrs,Mold Flash and Tie Bar extrusions
7. Unit: mm
SOD523Package Outline
Land Pattern Recommendation
3/3
很抱歉,暂时无法提供与“KSD103AX”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.08845
- 500+0.07007
- 1500+0.05992
- 8000+0.05500
- 24000+0.04976
- 48000+0.04690
- 国内价格
- 1+0.22330
- 500+0.07469
- 4000+0.04983
- 8000+0.04092
