SLP-03V
SLP-03V
    JST
    P=3.96mm
    1X3P 3.96MM
SLP-03V 数据手册
SL CONNECTOR 3.96mm pitch/Disconnectable Crimp style Wire-to-wire connectors Specifications ––––––––––––––––––– • Current rating: 7A AC, DC max. • Voltage rating: 300V AC, DC max. • Temperature range: -25˚C to +90˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/7m Ω max. After environmental testing/10m Ω max. • Insulation resistance: 1,000M Ω min. • Withstanding voltage: 1,500V AC/minute • Applicable wire: AWG #26 to #18 0.13 to 0.75mm2 * Compliant with RoHS. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. Inner-housing lock Housing lance Note: The current rating varies depending on the number of circuits and the wire size used in each connector. The table below lists the current rating as a function of the number of circuits and the wire size. Free spring Current unit: A Wire size (AWG) Circuits #18 #20 #22 #24 #26 1 7 5 4 3 2 2 7 5 4 3 2 3 6 4 4 3 2 4 6 4 4 3 2 6 6 4 4 3 2 Standards –––––––––––––––––––––– 0 • Low insertion force contact • Housing lance • Inner-housing lock Recognized E60389 1 Certified LR20812 2 R9351104 Assembly layout 1 to 4 circuits : 9.3 6 circuits : 14.3 31.4 Both side lock product 1 5.9 6.1A (31.4) 31.4 SL CONNECTOR Contact Applicable wire Model No. 1.4 Pin contact mm2 Insulation O.D. (mm) AWG # Pin contact Socket contact SSM-01T-P1.4 SSF-01T-P1.4 0.13∼0.5 26∼20 1.3∼2.5 SSM-21T-P1.4 SSF-21T-P1.4 0.3 ∼0.75 22∼18 1.5∼2.5 Q´ty / reel 6,000 Material and Finish 17.6 4.3 Phosphor bronze, tin-plated (reflow treatment) 0.5 RoHS compliance Note: Contact JST for special products. Socket contact Contact Crimping machine Crimp applicator SSM-01T-P1.4 SSF-01T-P1.4 12.6 4.3 MKS-L Applicator Dies − AP-K2N Crimp applicator with dies MK/SSF/M-01-14 APLMK SSF/M01-14 − − SSM-21T-P1.4 MKS-L SSF-21T-P1.4 − MK/SSF/M-21-14 APLMK SSF/M21-14 − − Contact position location numbers Contact position numbers are stamped Receptacle housing Plug housing 1 L 3 JST 1 2 L 3 6 5 JST L 4 3 3 1 2 2 4 1 3 5 JST L 6 2 1 3 2 1 2 1 4 3 2 1 Both side lock product 3 6 2 5 1 4 3 1 Both side lock product 6 3 5 2 4 1 2 1 3 2 1 1 2 JST 2 JST 2 JST 3 L L L 3 4 3 2 1 1 4 4 1 JST 1 JST 3 2 1 1 L 2 1 2 L L 1 2 JST Plug housing 1 JST Receptacle housing 3 2 1 2 SL CONNECTOR Housing Material: PA 66, UL94V-0, white Current rating Receptacle housing(for pin contact) Plug housing(for socket contact) 300V 7A 1 JST L 5.2 Q´ty / bag 5.9 1 SLP-01V 6.1 2.4 Q´ty / bag 2.4 SLR-01VF 1 JST L 1,000 24.2 1.0 Circuits Voltage rating 7.2 1,000 5.2 19.0 7A 2 L 1 JST 1 L 500 9.16 7.2 24.2 19.0 SLR-03VF Q´ty / bag 5.9 6A 2 JST 1 500 1 7.2 13.12 24.2 SLP-04V 6A 1 17.08 19.0 6A 3 6 L 2 1 5 JST 4 2 L 500 SLP-06V Q´ty / bag 1 500 4 L 13.12 4 3 JST 17.08 2.4 2.4 Q´ty / bag 11.1 300V 7.2 24.2 SLR-06VF 6 1 500 1.0 2 JST 10.9 3 L 1.0 4 Q´ty / bag 5.9 2.3 Q´ty / bag 6.1 300V 500 13.12 19.0 SLR-04VF 4 3 2 JST L 1.0 L 2.4 3 500 SLP-03V 2.3 300V 2 JST 9.16 2.4 Q´ty / bag 6.1 3 Q´ty / bag 1.0 300V 6.1 2 SLP-02V 5.9 2.3 Q´ty / bag 2.4 SLR-02VF 7.2 24.2 2 3 5 JST 6 500 13.12 19.0 Both side lock product *SLR-03VF-MD 6A 3 2 1 1 21.62 12.3 (11.9) 24.2 RoHS compliance Note: 1. *Marked products are not CSA/TU¨V approved. 2. Contact JST for special products. 3 Q´ty / bag 5.9 300V Both side lock product *SLP-03V-MD 6.1 3 Q´ty / bag 500 11.8 (7.2) 19 2 21.52 3 500
SLP-03V
物料型号是SSM-01T-P1.4(Pin contact)和SSF-01T-P1.4(Socket contact)以及SSM-21T-P1.4和SSF-21T-P1.4。
器件简介为SL CONNECTOR 3.96mm间距可断开的夹持式线对线连接器。
引脚分配未在文档中明确列出,但提供了接触位置定位编号。
参数特性包括电流额定值7A AC/DC最大,电压额定值300V AC/DC最大,工作温度范围为-25℃至+90℃,接触电阻初始值/7mΩ最大,环境测试后/10mΩ最大,绝缘电阻最小1,000MΩ,耐压1,500V AC/分钟。
功能详解包括低插入力接触,内锁和外锁结构,符合E60389标准,认证LR20812。
应用信息包括适用导线AWG #26至#18,0.13至0.75mm²,并符合RoHS。
封装信息包括磷青铜材质,锡镀层(回流处理),材料为PA 66,UL94V-0,白色。
SLP-03V 价格&库存
很抱歉,暂时无法提供与“SLP-03V”相匹配的价格&库存,您可以联系我们找货
SLP-03V
  • 34+2.2505734+0.29257
  • 100+1.97669100+0.25697
  • 500+1.87005500+0.24310
  • 1000+1.013601000+0.13177
库存:5668
SLP-03V
库存:5668
SLP-03V
    • 100+0.36220
    • 500+0.33800
    库存:3386
    SLP-03V
    • 5+0.68688
    • 50+0.55210
    • 150+0.48471
    • 500+0.43416
    • 2500+0.39377
    库存:4420
    SLP-03V
      库存:3907
      SLP-03V
        库存:7500
