MPP105J2G1910178LC
MPP105J2G1910178LC
    SRD(圣融达)
    插件,P=15mm
    1UF ±5% 400V
MPP105J2G1910178LC 数据手册
环氧粉末包封型金属化聚丙烯膜电容器---CBB21(MPP)系列 Metallized Polypropylene Film Capacitors(Dipped )---CBB21(MPP)series ■ 引用标准 Reference standards GB10190(IEC384-16) ■ 结构 Structure 介质:聚丙烯膜 电极:金属真空蒸发层 封装:阻燃粉末环氧树脂,符合 UL94 V-0 Dielectric: Polypropylene film Electrode: metal vacuum evaporation layer Encapsulation: Flame retardant power epoxy resin, conforming to UL94 V-0 ■ 典型应用 Typical Application 用于开关电源,电子镇流器和变频器等中间电路直流滤波(如 DC filter,DC-link,PFC 等) As intermediate circuit capacitor for SMPS, LED driver, inverter (i.e. DC filter,DC-link, DC filter and P.F.C) ■ 特点 Features 有良好自愈性能 ,缩小产品尺寸,高频损耗小,温升低 Reduced size depended on good self-healing property, low dissipation at high frequency, low temperature rise ■ 符合 RoHS 及 REACH 环保标准 Compliance with RoHs & ■ 电性能规范 Performance Specifications REACH requirements. 气候类别 Climate category 40/105/56 额定温度 Rated Temperature 85℃ 工作温度范围 -40℃--+105℃. Operating Temperature range (+85℃~+105℃): decreasing factor 1.5% per ℃ for R.V(DC) (+85℃~+105℃): 额定电压降额使用系数 1.5% per ℃ for R.V(DC) 额定电压 Rated Voltage 400(450)VDC, 630VDC 容量误差 Capacitance Tolerance J: ±5% 容量范围 0.001μF~22μF Capacitance Range 测试条件 Test Condition: 耐电压 损耗角 Dissipation factor ≤0.001 绝缘电阻或时间常数 CR≤0.33μF IR≥30000MΩ Insulation Resistance CR>0.33μF IR≥10000S Max. Pulse Rise Time (dV / dt) 无击穿或飞弧 1.6UR,5S Withstand Voltage 最大脉冲爬升速率 20℃, 1KHz, 1Vrms No breakdown or electric arcing 测试条件 Test Condition : (1KHZ ) 20℃ 1Vrms 测试条件 Test Condition : 20℃ 100V 1 min UR(V) P7.5 P10 P15 P20 P25 P31 400(450)V 120 80 65 35 20 10 630V 150 120 80 60 40 20 环氧粉末包封型金属化聚丙烯膜电容器---CBB21(MPP)系列 Metallized Polypropylene Film Capacitors(Dipped )---CBB21(MPP)series 电性能规范 Performance Specifications ■ 稳态湿热 温度 Temp.:40±2℃ 无可见损伤,标志清晰 Steady-state Damp-heat Test 相对湿度 Humidity:93%RH no visible damage,clear mark 绝缘电阻 IR:≥ 额定值的 50% IR:≥ 50% of Rated value 持续时间 Duration Time:56 Days 容量变化(相对初始值): Capacitance change ( relative to the initial value):△C/C≤±5% 损耗角增加 Dissipation factor: Rise ≤0.0020(1KHZ),CR>1uF 耐久性试验 温度 Temp.: +85℃, 绝缘电阻 Insulation Resistance Endurance Test 电压 Voltage: IR:≥ 额定值的 50% IR:≥ 50% of rated value 1.25 Times Rated Voltage 持续时间 Duration Time: 1000H 损耗角增加:≤0.0040 dissipation factor rise:≤0.0040 容量变化(相对初始值):△C/C≤±10% Capacitance change (relative to the initial value):△C/C≤±10% 产品编码说明 Part No. Description: ■ 18 位产品编码如下: The Part No. Is total 18 digits, details as follow: 1 2 3 4 5 6 7 8 9 10 M P P 1 0 5 J 2 G 1 11 12 13 14 15 16 17 18 9 0 7 1 4 8 * * Digit 1-3 型号代码 Product series Code MPP= CBB21 series Digit 4-6 Digit 7 Digit 8-9 Digit 10-15 Digit 16 Digit 17-18 标称容量 Rated Capacitance Value For example : 105 = 10×105pF = 1.0F J=±5% 2G=400VDC 2W=450VDC 2J=630VDC 容量偏差 Capacitance Tolerance 额定电压 Rated Voltage Code 外形尺寸 Dimensions Code 线径代码 Line diameter code 6=0.6 8=0.8 成型或内部识别码 Forming Type or Internal Use 1=1.0 环氧粉末包封型金属化聚丙烯膜电容器---CBB21(MPP)系列 Metallized Polypropylene Film Capacitors(Dipped )---CBB21(MPP)series ■ 料号明细及尺寸 Part No. List and Dimensions UR :400(450)Vdc 成品编码 系列 Part No. 容量 尺寸 Dimension (mm) Series Capacitance (μF) Wmax Tmax Hmax P±0.5 d±0.05 MPP823J##1004075** CBB21 0.082 10 5.0 8.0 7.5 0.5 MPP104J##1004075** CBB21 0.1 10 5.5 8.5 7.5 0.5 MPP124J##1004085** CBB21 0.12 10 5.5 9.0 7.5 0.5 MPP154J##1005085** CBB21 0.15 10 6.0 9.5 7.5 0.5 MPP184J##1005105** CBB21 0.18 10 6.0 10.5 7.5 0.5 MPP224J##1005105** CBB21 0.22 10 6.5 11.5 7.5 0.5 MPP274J##1006115** CBB21 0.27 10 7.0 12.0 7.5 0.5 MPP334J##1006135** CBB21 0.33 10 7.5 14.0 7.5 0.5 MPP394J##1007145** CBB21 0.39 10 8.0 14.5 7.5 0.5 MPP474J##1008155** CBB21 0.47 10 9.0 15.5 7.5 0.5 MPP124J##1304075** CBB21 0.12 13 5.0 8.5 10 0.5 MPP154J##1304075** CBB21 0.15 13 5.5 8.5 10 0.5 MPP184J##1304085** CBB21 0.18 13 6.0 9.0 10 0.5 MPP224J##1305085** CBB21 0.22 13 6.5 10.5 10 0.5 MPP274J##1305105** CBB21 0.27 13 6.5 10.5 10 0.5 MPP334J##1305115** CBB21 0.33 13 7.5 12.5 10 0.5 MPP394J##1306116** CBB21 0.39 13 8.0 13.0 10 0.6 MPP474J##1306136** CBB21 0.47 13 7.5 14.5 10 0.6 MPP564J##1307146** CBB21 0.56 13 8.5 15.5 10 0.6 MPP684J##1308156** CBB21 0.68 13 9.5 16.0 10 0.6 MPP824J##1308166** CBB21 0.82 13 9.5 16.5 10 0.6 MPP105J##1309176** CBB21 1.0 13 10.5 18.5 10 0.6 MPP474J##1905106** CBB21 0.47 18 6.5 11.5 15 0.6 MPP564J##1905106** CBB21 0.56 18 6.5 12.0 15 0.6 MPP684J##1906116** CBB21 0.68 18 7.5 12.5 15 0.6 MPP824J##1907128** CBB21 0.82 18 8.5 13.0 15 0.8 MPP105J##1907148** CBB21 1.0 18 8.5 15.0 15 0.8 MPP125J##1908148** CBB21 1.2 18 9.0 15.5 15 0.8 MPP155J##1908168** CBB21 1.5 18 9.5 17.5 15 0.8 MPP185J##1909178** CBB21 1.8 18 10.0 18.0 15 0.8 说明 Note: 1. “##” 表示标称电压 2. “**”表示内部特征码 “##” =Rated voltage 2G=400V, 2W=450V “**”=Internal use. 环氧粉末包封型金属化聚丙烯膜电容器---CBB21(MPP)系列 Metallized Polypropylene Film Capacitors(Dipped )---CBB21(MPP)series ■ 料号明细及尺寸 Part No. List and Dimensions UR :400(450)Vdc 成品编码 系列 Part No. 容量 尺寸 Dimension (mm) Series Capacitance (μF) Wmax Tmax Hmax P±0.5 d±0.05 MPP225J##1910198** CBB21 2.2 18 11.5 20.0 15 0.8 MPP275J##1911218** CBB21 2.7 18 12.0 22.0 15 0.8 MPP335J##1912228** CBB21 3.3 18 14.5 24.0 15 0.8 MPP105J##2406116** CBB21 1.0 23 7.5 12.5 20 0.6 MPP125J##2407128** CBB21 1.2 23 8.0 13.0 20 0.8 MPP155J##2407148** CBB21 1.5 23 8.5 15.0 20 0.8 MPP185J##2408158** CBB21 1.8 23 9.0 15.5 20 0.8 MPP225J##2408178** CBB21 2.2 23 9.0 17.5 20 0.8 MPP275J##2409188** CBB21 2.7 23 10.0 18.5 20 0.8 MPP335J##2410198** CBB21 3.3 23 11.5 20.0 20 0.8 MPP395J##2411218** CBB21 3.9 23 12.0 22.0 20 0.8 MPP475J##2412228** CBB21 4.7 23 13.5 23.5 20 0.8 MPP565J##2414248** CBB21 5.6 23 14.5 25.0 20 0.8 MPP685J##2415258** CBB21 6.8 23 16.5 26.5 20 0.8 MPP825J##2416298** CBB21 8.2 23 17.0 30.0 20 0.8 MPP106J##2418318** CBB21 10.0 23 19.0 32.0 20 0.8 MPP185J##2907138** CBB21 1.8 28 7.5 14.5 25 0.8 MPP225J##2907148** CBB21 2.2 28 9.0 17.5 25 0.8 MPP275J##2908158** CBB21 2.7 28 9.5 18.0 25 0.8 MPP335J##2909178** CBB21 3.3 28 10.5 18.5 25 0.8 MPP395J##2910188** CBB21 3.9 28 11.0 19.0 25 0.8 MPP475J##2910208** CBB21 4.7 28 11.5 21.5 25 0.8 MPP685J##2913238** CBB21 6.8 28 14.0 24.0 25 0.8 MPP825J##2915258** CBB21 8.2 28 16.0 25.5 25 0.8 MPP106J##2915288** CBB21 10.0 28 16.5 29.5 25 0.8 MPP126J##2917308** CBB21 12.0 28 18.0 31.0 25 0.8 MPP156J##2919328** CBB21 15.0 28 20.5 33.5 25 0.8 MPP335J##3508168** CBB21 3.3 35 9.0 17.0 31 0.8 MPP395J##3508178** CBB21 3.9 35 9.5 18.0 31 0.8 MPP475J##3509188** CBB21 4.7 35 10.5 19.0 31 0.8 说明 Note: 1. “##” 表示标称电压 2. “**”表示内部特征码 “##” =Rated voltage 2G=400V, 2W=450V “**”=Internal use. 环氧粉末包封型金属化聚丙烯膜电容器---CBB21(MPP)系列 Metallized Polypropylene Film Capacitors(Dipped )---CBB21(MPP)series ■ 料号明细及尺寸 Part No. List and Dimensions UR :400(450)Vdc 成品编码 系列 Part No. 容量 尺寸 Dimension (mm) Series Capacitance (μF) Wmax Tmax Hmax P±0.5 d±0.05 MPP565J##3510208** CBB21 5.6 34 11.0 21.0 31 0.8 MPP685J##3511218** CBB21 6.8 34 12.5 22.5 31 0.8 MPP825J##3513238** CBB21 8.2 34 14.0 24.0 31 0.8 MPP106J##3514248** CBB21 10.0 34 15.5 25.5 31 0.8 MPP126J##3514288** CBB21 12.0 34 16.0 29.0 31 0.8 MPP156J##3517308** CBB21 15.0 34 18.0 31.0 31 0.8 MPP186J##3519328** CBB21 18.0 34 20.0 33.0 31 0.8 MPP226J##3521348** CBB21 22.0 34 22.0 35.0 31 0.8 说明 Note: 1. “##” 表示标称电压 2. “**”表示内部特征码 “##” =Rated voltage 2G=400V, 2W=450V “**”=Internal use. UR :630Vdc 成品编码 系列 Part No. 容量 尺寸 Dimension (mm) Series Capacitance (μF) Wmax Tmax Hmax P±0.5 d±0.05 MPP102J2J1004075** CBB21 0.001 10.0 4.5 7.5 7.5 0.5 MPP122J2J1004075** CBB21 0.0012 10.0 4.5 8.0 7.5 0.5 MPP152J2J1004075** CBB21 0.0015 10.0 5.0 8.5 7.5 0.5 MPP182J2J1004075** CBB21 0.0018 10.0 5.5 9.0 7.5 0.5 MPP222J2J1004075** CBB21 0.0022 10.0 5.5 8.0 7.5 0.5 MPP272J2J1004075** CBB21 0.0027 10.0 5.5 8.5 7.5 0.5 MPP332J2J1004075** CBB21 0.0033 10.0 5.5 8.5 7.5 0.5 MPP392J2J1004075** CBB21 0.0039 10.0 5.5 8.5 7.5 0.5 MPP472J2J1004075** CBB21 0.0047 10.0 6.5 9.5 7.5 0.5 MPP562J2J1004075** CBB21 0.0056 10.0 5.0 8.5 7.5 0.5 MPP682J2J1004075** CBB21 0.0068 10.0 5.5 8.5 7.5 0.5 MPP822J2J1004085** CBB21 0.0082 10.0 5.5 9.0 7.5 0.5 MPP103J2J1004075** CBB21 0.01 10.0 5.0 8.5 7.5 0.5 MPP123J2J1004075** CBB21 0.012 10.0 5.5 9.0 7.5 0.5 MPP153J2J1004075** CBB21 0.015 10.0 5.5 9.0 7.5 0.5 MPP183J2J1004075** CBB21 0.018 10.0 5.5 8.5 7.5 0.5 MPP223J2J1004075** CBB21 0.022 10.0 5.5 9.0 7.5 0.5 MPP273J2J1004075** CBB21 0.027 10.0 6.0 9.5 7.5 0.5 环氧粉末包封型金属化聚丙烯膜电容器---CBB21(MPP)系列 Metallized Polypropylene Film Capacitors(Dipped )---CBB21(MPP)series ■料号明细及尺寸 Part No. List and Dimensions UR :630Vdc 成品编码 系列 Part No. 容量 尺寸 Dimension (mm) Series Capacitance (μF) Wmax Tmax Hmax P±0.5 d±0.05 MPP333J2J1004075** CBB21 0.033 10.0 5.5 8.5 7.5 0.5 MPP393J2J1004075** CBB21 0.039 10.0 5.5 9.0 7.5 0.5 MPP473J2J1004075** CBB21 0.047 10.0 5.5 8.5 7.5 0.5 MPP563J2J1004075** CBB21 0.056 10.0 6.0 9.0 7.5 0.5 MPP683J2J1005085** CBB21 0.068 10.0 6.0 9.0 7.5 0.5 MPP823J2J1004105** CBB21 0.082 10.0 6.5 11.5 7.5 0.5 MPP104J2J1005105** CBB21 0.1 10.0 6.5 11.5 7.5 0.5 MPP124J2J1005115** CBB21 0.12 10.0 7.0 12.0 7.5 0.5 MPP154J2J1006125** CBB21 0.15 10.0 6.5 13.5 7.5 0.5 MPP184J2J1006135** CBB21 0.18 10.0 7.0 14.0 7.5 0.5 MPP224J2J1007145** CBB21 0.22 10.0 8.0 15.0 7.5 0.5 MPP102J2J1304075** CBB21 0.001 13.0 5.0 9.0 10.0 0.5 MPP122J2J1304075** CBB21 0.0012 13.0 5.5 9.5 10.0 0.5 MPP152J2J1304085** CBB21 0.0015 13.0 5.5 9.0 10.0 0.5 MPP182J2J1304075** CBB21 0.0018 13.0 5.0 8.5 10.0 0.5 MPP222J2J1304075** CBB21 0.0022 13.0 5.5 8.5 10.0 0.5 MPP272J2J1304075** CBB21 0.0027 13.0 5.0 8.5 10.0 0.5 MPP332J2J1304085** CBB21 0.0033 13.0 5.5 9.0 10.0 0.5 MPP392J2J1304075** CBB21 0.0039 13.0 5.5 8.5 10.0 0.5 MPP472J2J1304085** CBB21 0.0047 13.0 5.5 8.5 10.0 0.5 MPP562J2J1304075** CBB21 0.0056 13.0 5.5 8.5 10.0 0.5 MPP682J2J1304075** CBB21 0.0068 13.0 5.5 8.5 10.0 0.5 MPP822J2J1304075** CBB21 0.0082 13.0 5.5 8.5 10.0 0.5 MPP103J2J1304085** CBB21 0.01 13.0 5.5 8.5 10.0 0.5 MPP123J2J1304095** CBB21 0.012 13.0 5.5 10.5 10.0 0.5 MPP153J2J1304075** CBB21 0.015 13.0 5.0 8.5 10.0 0.5 MPP183J2J1304075** CBB21 0.018 13.0 5.5 9.5 10.0 0.5 MPP223J2J1304075** CBB21 0.022 13.0 6.0 9.0 10.0 0.5 MPP273J2J1304075** CBB21 0.027 13.0 5.5 9.5 10.0 0.5 MPP333J2J1304075** CBB21 0.033 13.0 5.5 9.0 10.0 0.5 说明 Note: “**”表示内部特征码 “**”=Internal use. 环氧粉末包封型金属化聚丙烯膜电容器---CBB21(MPP)系列 Metallized Polypropylene Film Capacitors(Dipped )---CBB21(MPP)series ■料号明细及尺寸 Part No. List and Dimensions UR :630Vdc 成品编码 系列 Part No. 容量 尺寸 Dimension (mm) Series Capacitance (μF) Wmax Tmax Hmax P±0.5 d±0.05 MPP393J2J1304075** CBB21 0.039 13.0 5.5 9.0 10.0 0.5 MPP473J2J1304075** CBB21 0.047 13.0 5.5 9.0 10.0 0.5 MPP563J2J1304075** CBB21 0.056 13.0 5.5 9.0 10.0 0.5 MPP683J2J1304075** CBB21 0.068 13.0 5.0 8.5 10.0 0.5 MPP823J2J1304075** CBB21 0.082 13.0 5.5 9.0 10.0 0.5 MPP104J2J1304095** CBB21 0.1 13.0 5.5 10.5 10.0 0.5 MPP124J2J1304105** CBB21 0.12 13.0 5.5 10.5 10.0 0.5 MPP154J2J1305105** CBB21 0.15 13.0 6.5 12.0 10.0 0.5 MPP184J2J1306116** CBB21 0.18 13.0 7.0 12.0 10.0 0.6 MPP224J2J1306126** CBB21 0.22 13.0 7.5 14.5 10.0 0.6 MPP274J2J1306136** CBB21 0.27 13.0 7.5 14.5 10.0 0.6 MPP334J2J1307146** CBB21 0.33 13.0 8.5 15.5 10.0 0.6 MPP394J2J1307166** CBB21 0.39 13.0 8.5 16.5 10.0 0.6 MPP474J2J1308176** CBB21 0.47 13.0 9.5 18.0 10.0 0.6 MPP224J2J1904106** CBB21 0.22 18.0 6.0 11.0 15.0 0.6 MPP274J2J1905106** CBB21 0.27 18.0 6.5 11.5 15.0 0.6 MPP334J2J1905126** CBB21 0.33 18.0 6.5 13.0 15.0 0.6 MPP394J2J1906126** CBB21 0.39 18.0 7.0 13.5 15.0 0.6 MPP474J2J1906136** CBB21 0.47 18.0 7.5 14.5 15.0 0.6 MPP564J2J1907148** CBB21 0.56 18.0 8.0 15.0 15.0 0.8 MPP684J2J1907168** CBB21 0.68 18.0 8.5 17.0 15.0 0.8 MPP824J2J1908178** CBB21 0.82 18.0 9.0 17.5 15.0 0.8 MPP105J2J1909198** CBB21 1.0 18.0 9.5 19.5 15.0 0.8 MPP125J2J1910208** CBB21 1.2 18.0 11.0 21.0 15.0 0.8 MPP155J2J1911218** CBB21 1.5 18.0 12.5 22.5 15.0 0.8 MPP474J2J2406116** CBB21 0.47 23.0 7.0 12.0 20.0 0.6 MPP564J2J2406116** CBB21 0.56 23.0 7.5 13.5 20.0 0.6 MPP684J2J2406136** CBB21 0.68 23.0 7.5 14.0 20.0 0.6 MPP824J2J2407148** CBB21 0.82 23.0 8.0 15.0 20.0 0.8 MPP105J2J2407168** CBB21 1.0 23.0 9.5 17.5 20.0 0.8 MPP125J2J2408178** CBB21 1.2 23.0 9.5 18.0 20.0 0.8 说明 Note:“**”表示内部特征码 “**”=Internal use. 环氧粉末包封型金属化聚丙烯膜电容器---CBB21(MPP)系列 Metallized Polypropylene Film Capacitors(Dipped )---CBB21(MPP)series ■料号明细及尺寸 Part No. List and Dimensions UR :630Vdc 成品编码 系列 Part No. 容量 尺寸 Dimension (mm) Series Capacitance (μF) Wmax Tmax Hmax P±0.5 d±0.05 MPP155J2J2409188** CBB21 1.5 23.0 11.0 19.0 20.0 0.8 MPP185J2J2410208** CBB21 1.8 23.0 11.5 21.0 20.0 0.8 MPP225J2J2411218** CBB21 2.2 23.0 13.0 23.0 20.0 0.8 MPP275J2J2413238** CBB21 2.7 23.0 14.5 24.5 20.0 0.8 MPP335J2J2415248** CBB21 3.3 23.0 16.0 26.0 20.0 0.8 MPP395J2J2415288** CBB21 3.9 23.0 16.0 29.0 20.0 0.8 MPP475J2J2416308** CBB21 4.7 23.0 17.5 30.5 20.0 0.8 MPP105J2J2907148** CBB21 1.0 28.0 8.5 15.0 25.0 0.8 MPP125J2J2908148** CBB21 1.2 28.0 9.0 15.5 25.0 0.8 MPP155J2J2908168** CBB21 1.5 28.0 9.0 17.5 25.0 0.8 MPP185J2J2909178** CBB21 1.8 28.0 10.0 18.5 25.0 0.8 MPP225J2J2910191** CBB21 2.2 28.0 11.0 19.5 25.0 1.0 MPP275J2J2911211** CBB21 2.7 28.0 12.5 22.5 25.0 1.0 MPP335J2J2912221** CBB21 3.3 28.0 12.5 23.5 25.0 1.0 MPP395J2J2914241** CBB21 3.9 28.0 14.5 24.5 25.0 1.0 MPP475J2J2915251** CBB21 4.7 28.0 16.5 26.5 25.0 1.0 MPP565J2J2916291** CBB21 5.6 28.0 16.5 29.5 25.0 1.0 MPP685J2J2917311** CBB21 6.8 28.0 18.5 32.0 25.0 1.0 MPP185J2J3508168** CBB21 1.8 34.0 9.0 17.0 31.0 0.8 MPP225J2J3509171** CBB21 2.2 34.0 9.5 18.0 31.0 1.0 MPP275J2J3509191** CBB21 2.7 34.0 10.5 20.5 31.0 1.0 MPP335J2J3510201** CBB21 3.3 34.0 10.5 21.5 31.0 1.0 MPP395J2J3512221** CBB21 3.9 34.0 13.0 23.0 31.0 1.0 MPP475J2J3513231** CBB21 4.7 34.0 15.5 25.5 31.0 1.0 MPP565J2J3513261** CBB21 5.6 34.0 15.0 27.5 31.0 1.0 MPP685J2J3515281** CBB21 6.8 34.0 16.0 29.0 31.0 1.0 MPP825J2J3517301** CBB21 8.2 34.0 18.0 31.0 31.0 1.0 MPP106J2J3519321** CBB21 10.0 34.0 20.5 33.5 31.0 1.0 说明 Note: “**”表示内部特征码 “**”=Internal use. Note: We can customize the capacitors according to customers special requirements.
MPP105J2G1910178LC 价格&库存
很抱歉,暂时无法提供与“MPP105J2G1910178LC”相匹配的价格&库存,您可以联系我们找货
MPP105J2G1910178LC
  • 10+0.49597
  • 100+0.40240
  • 500+0.33161
  • 1000+0.29652
  • 5000+0.26851
  • 10000+0.25445
库存:377
