SMF5.0A-LLC
SMF5.0A-LLC
    PTTC(聚鼎)
    SOD123
    SMF5.0A-LLC
SMF5.0A-LLC 数据手册
T VS Diode – SMF5.0A-LLC Features  Plastic package, excellent insulation strength.  Glass passivated chip junction in SOD-123 package.  Excellent voltage clamping capability.  Low Zener impedance.  200W peak pulse power capability on 10/1000s waveform.  Typical leakage current less than 10A  Very fast response time, typically less than 1.0ps from 0 volt to  High temperature soldering guaranteed: 265°C/10 sec.  MSL: JEDEC-J-STD-020, Level 1  Automotive grade AEC-Q101 qualified. VBR minimum. Applications  I/O interface, VCC bus  Telecom / Automotive  Industrial and consumer electronic applications.  Relay and electromagnetic valve surge absorption.  Battery Management System Agency Approval  Pending Mechanical and Physical Data  Case: JEDEC SMF molded plastic.  Axial leaded, solderable per MIL-STD-750, Method 2026  Polarity: Color band denoted cathode except bidirectional. Maximum Ratings and Thermal Characteristics Symbol Value Unit Peak Pulse Power Dissipation on 10/1000s waveform (Note 1, Fig.1). Parameter PPPM Min 200 Watt Peak Pulse Current of 10/1000s waveform (Note 1, Fig.3). IPPM See Table Amp IFSM 20 Amp TJ, TSTG -55~150 °C Peak Forward Surge Current, 8.3 ms Single Half Sine Wave Superimposed on Rated Load (Note 2, Fig.6). Operating Junction and Storage Temperature Range. Note: 1. Non-repetitive current pulse, per Fig.3 and derated above TA = 25°C per Fig.2. 2. 8.3ms single half sine wave, or equivalent square wave, Duty cycle = 4 pulses per minutes maximum. Part Number Code SMF 5.0 A - LLC LLC: Low leakage current VBR Voltage tolerance (A: 5%; Blank: 10%) Reverse Stand-Off Voltage or Typical Breakdown Voltage SMF Series (200W) 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 1 of 5 2018/05/11 Rev: B T VS Diode – SMF5.0A-LLC I-V Curve Characteristics PPPM Peak Pulse Power Dissipation – Maximum power dissipation VR Stand-off Voltage – Maximum voltage that can be applied to the TVS without operation VBR Breakdown Voltage – Maximum voltage that flows through the TVS at a specified test current (IT) VC Clamping Voltage – Peak voltage measured across the TVS at a specified IPPM (Peak Impulse Current) IR Reverse Leakage Current – Current measured at VR VF Forward Voltage Drop for Uni-directional Electrical Characteristics Part Number Marking SMF5.0A-LLC FE Reverse Stand Breakdown Voltage VBR Test Current (V) @ IT Off Voltage VR IT (V) (mA) Min. Max. 5.0 6.40 7.00 10 Maximum Clamping Voltage VC (V) @ IPP 9.2 Maximum Peak Maximum Pulse Current Reverse Leakage IPP (A) IR (A) @ VR 21.74 10 Ratings and Characteristic Curves Fig 1 - Peak Pulse Power Rating Curve Fig 2 - Pulse Derating Curve 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 2 of 5 2018/05/11 Rev: B T VS Diode – SMF5.0A-LLC Fig 3 - Pulse Waveform Fig 4 – Typical Junction Capacitance Uni-directional Fig 5 – Steady State Power Dissipation Derating Curve Fig 6 – Maximum Non-Repetitive Forward Surge Current (Uni-directional Only) 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 3 of 5 2018/05/11 Rev: B T VS Diode – SMF5.0A-LLC Marking Definitions Marking Code Cathode Band (For Uni-directional product only) Physical Dimensions Millimeters Dimension A B C D E F G H Inches Min Max Min Max 2.50 3.40 0.70 1.50 0.35 0.05 0.95 2.90 3.90 1.20 2.00 0.90 0.26 0.10 1.30 0.0984 0.1339 0.0275 0.0591 0.0138 0.0020 0.0374 0.1142 0.1535 0.0472 0.0787 0.0354 0.0102 0.0039 0.0512 Lead Free Reflow Soldering Recommendations Preheat - Temperature Min (Ts_min) 150ºC - Temperature Max (Ts_max) 200ºC - Time (Ts_min to Ts_max) 60-180 seconds - Average Ramp-Up Rate 1~3ºC/second Peak Temperature Time within 5ºC of actual Peak Temperature (tp) Ramp-Down Rate 260ºC max. 40 seconds max. 6 ºC /second max. Note: If the soldering temperatures exceed the recommended profile, devices may not meet the performance requirements. 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 4 of 5 2018/05/11 Rev: B T VS Diode – SMF5.0A-LLC Packaging Information Part Number Component Package Quantity SMF5.0A-LLC SOD-123 3000 Packaging Option Tape & Reel – 8mm tape/7” reel Packaging Specification EIA STD RS-481 Tape and Reel Specifications 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 5 of 5 2018/05/11 Rev: B
SMF5.0A-LLC 价格&库存
很抱歉,暂时无法提供与“SMF5.0A-LLC”相匹配的价格&库存,您可以联系我们找货
