CR2016
CR2016
    MAXELL(万胜)
    BATT-CASE_D20X1.6MM
    尺寸20*1.6(mm)
CR2016 数据手册
Data Sheet Coin Type Lithium Manganese Dioxide Battery CR2016 Model CR2016 System Manganese Dioxide–Li/Organic Electrolyte Nominal Voltage (V) 3 Nominal Capacity (mAh)* 90 Nominal Discharge Current (mA) 0.1 Operating Temperature Range (deg. C)** –20 to +85 Weight (g)*** 1.7 Diameter 20.0 Height 1.6 UL Recognition 1.6 ø20.0 Dimensions (mm)*** (–) MH12568 (+) Characteristics  Discharge Characteristics  Temperature Characteristics Temperature: 20 deg. C Discharge load: 15 k 3.5 3.5 3.0 3.0 Voltage (V) Voltage (V) 60 deg. C 2.5 2.0 1.5 101 102 103 104 Discharge duration time (h) 0 Discharge capacity (mAh) 300 5sec. 1M 2.0 300 5sec. 0 20 40 60 Discharge capacity (mAh) 100 150 200 250 300 350 400 450 500 Final voltage: 2.0V 1M continuous 2.5 50  Relationship between Discharge Current and Discharge Capacity 100 3.0 –10 deg. C Discharge duration time (h) Temperature: 20 deg. C 3.5 Voltage (V) 1.5 105  Pulse Discharge Characteristics 1.5 0 deg. C 2.0 390k 1M 2.7M 39k 2.5 20 deg. C 80 60 deg. C 20 deg. C 80 –10 deg. C –20 deg. C 60 40 101 102 103 Discharge current (A) * Nominal capacity indicates duration until the voltage drops down to 2.0V when discharged at a nominal discharge current at 20 deg. C. ** When using these batteries at temperatures outside the range of 0 to +40 deg. C, please consult Maxell in advance for conditions of use. *** Dimensions and weight are for the battery itself, but may vary depending on terminal specifications and other factors. Maxell, Ltd. • Data and dimensions are not guaranteed. For further details, please contact us at your nearest Maxell office. • Contents on this website are subject to change without notice. Date of issue: October 2017
CR2016 价格&库存
很抱歉,暂时无法提供与“CR2016”相匹配的价格&库存,您可以联系我们找货
