BM16B-GHDS-TF(LF)(SN)
    JST
    SMD,P=1.25mm
    线对板针座 2x8P 立贴 间距:1.25mm
BM16B-GHDS-TF(LF)(SN) 数据手册
GHDCONNECTOR/TIN-PLATED PRODUCT Emboss Tape 1.25 mm pitch/Disconnectable Crimp style connectors ● ● ● ●  ecure lock device S Low insertion force Prevention of contact deformation Suction area for picking up GHD CONNECTOR/TIN-PLATED PRODUCT Specifications In order to correspond to the various highdensity PC board designing, this GHD connector is designed as 1.25 mm pitch double row type connector. Provide a full lineup of 10 to 40 circuits for top and side entry types. Its operability is very well, in spite of the small size with tin-plated. • Current rating: 1.25 A AC/DC (AWG #26)        1.0 A AC/DC (AWG #28)        0.8 A AC/DC (AWG #30) • Voltage rating: 50 V AC/DC • Temperature range: -25℃ to +85℃ (including temperature rise in applying electrical current) • Contact resistance:   Initial value/Top entry type: 30 mΩ max. Side entry type: 50 mΩ max   After environmental tests/Top entry type: 50 mΩ max. Side entry type: 70 mΩ max • Insulation resistance: 100 MΩ min. • Withstanding voltage: 500 VAC/minute • Applicable wire: Conductor size/ AWG #32 to #26 Insulation O.D./ 0.4 to 1.0 mm * In using the products,refer to "Handling Precautions for Terminals and Connectors" described on our website (Technical documents of Product information page). * RoHS2 compliance * Dimensional unit: mm * Contact JST for details. PC board layout and Assembly layout Side entry type Circuit No.1 1.35 ±0.1 1±0.1 Circuit No.N-1 A ±0.1 0.6 ±0.05 1.25 ±0.05 Circuit No.1 Circuit No.N Circuit No.2 1.7 ±0.05 Connector outline 1.7 ±0.05 Circuit No.N-1 1.7 ±0.05 0.6 1.25 ±0.05 0.3 7.25 ±0.1 0.3 ±0.05 2.8 ±0.1 Connector outline Circuit No.N A ±0.1 ±0.05 1.7 ±0.05 Circuit No.2 7.55 ±0.05 Top entry type (Mating side faces to this side) (8.6) (8.05) (10.1) Note: 1. The above figure is the figure viewed from the connector mounting side 2. Tolerance for the centers of pattern on PCB is ± 0.05, and shall be not cumulative more than ± 0.1. The dimensions above should serve as a guideline. Contact JST for details. 1 (8.55) (8.5) (9.35) GHD CONNECTOR/TIN-PLATED PRODUCT Contact Applicable wire AWG # mm2 Model No. SGHD-002T-C0.2A SGHD-003T-C0.2A Insulation O.D. (mm) Q'ty/reel 0.05 ~ 0.13 30~26 0.76~1.0 25,000 0.032~0.08 32~28 0.4 ~0.8 28,000 GHD CONNECTOR/TIN-PLATED PRODUCT 1 Material and Finish Copper alloy, tin-plated (reflow treatment) RoHS2 compliance 5.8 Contact Crimping machine Crimp applicator SGHD-002T-C0.2A AP-K2N SGHD-003T-C0.2A MKS-L-10-3 Applicator Dies Crimp applicator with dies MK/SSHL-002-02 APLMK SSHL002-02 MK/SGHD-003-02 APLMK SGHD003-02 Note: Contact JST for fully automatic crimping applicator. Housing No. of circuits 10 8.05 B 12 Circuit No.1 mark 14 16 6.6 18 20 22 24 1.25 26 A 28 30 32 34 36 B 38 8.05 40 Circuit No.1 mark A GHDR-10V-S-1 GHDR-12V-S-1 GHDR-14V-S-1 GHDR-16V-S-1 GHDR-18V-S-1 GHDR-20V-S-1 GHDR-22V-S-1 GHDR-24V-S-1 GHDR-26V-S-1 GHDR-28V-S-1 GHDR-30V-S-1 GHDR-32V-S-1 GHDR-34V-S-1 GHDR-36V-S-1 GHDR-38V-S-1 GHDR-40V-S-1 (F) (F) (F) (F) (F) (F) (F) (F) (F) (F) (F) (F) (F) (F) (F) (F) Dimensions (mm) A B Q'ty/ bag 5.00 9.50 1,000 6.25 10.75 1,000 7.50 12.00 1,000 8.75 13.25 1,000 10.00 14.50 1,000 11.25 15.75 1,000 12.50 17.00 1,000 13.75 18.25 1,000 15.00 19.50 1,000 16.25 20.75 1,000 17.50 22.00 1,000 18.75 23.25 1,000 20.00 24.50 1,000 21.25 25.75 1,000 22.50 27.00 1,000 23.75 28.25 1,000 Material and Finish 6.6 1.25 Model No. PBT, UL94V-0, natural (white) RoHS2 compliance As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. GHDR-20V-S-1 (F)S...natural (white) K...black E...blue TR...tomato red 2 GHD CONNECTOR/TIN-PLATED PRODUCT Header No. of circuits Top entry type BM10B-GHDS-TF BM12B-GHDS-TF BM14B-GHDS-TF BM16B-GHDS-TF BM18B-GHDS-TF BM20B-GHDS-TF BM22B-GHDS-TF BM24B-GHDS-TF BM26B-GHDS-TF BM28B-GHDS-TF BM30B-GHDS-TF BM32B-GHDS-TF BM34B-GHDS-TF BM36B-GHDS-TF BM38B-GHDS-TF BM40B-GHDS-TF 10 B 6.8 12 0.55 14 Circuit No.1 mark 16 18 5 20 22 1.25 24 6.85 A 26 28 30 32 B 6.8 0.55 Circuit No.1 mark Model No. 34 36 38 Q'ty/ reel 5.00 9.50 1,250 6.25 10.75 1,250 7.50 12.00 1,250 8.75 13.25 1,250 10.00 14.50 1,250 11.25 15.75 1,250 12.50 17.00 1,250 13.75 18.25 1,250 15.00 19.50 1,250 16.25 20.75 1,250 17.50 22.00 1,250 18.75 23.25 1,250 20.00 24.50 1,250 21.25 25.75 1,250 22.50 27.00 1,250 23.75 28.25 1,250 5 40 Dimensions (mm) A B Material and Finish 1.25 Contact: Phosphor bronze, copper-undercoated, tin-plated (reflow treatment) Housing: PA 9T, UL94V-0, natural (ivory) Reinoforcement: Brass, copper-undercoated, tin-plated (reflow treatment) 6.85 A RoHS2 compliance This product displays (LF)(SN) on a label. 6.8 B 0.55 Circuit No.1 mark As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. BM20B-GHDS-TF- 5 S...natural (ivory) K...black E...blue TR...tomato red 0.25 B 1.25 5.85 A 0.75 6.85 6.1 1番極表示 No. of circuits 1.25 A Side entry type 10 12 B 0.25 5.85 14 0.75 16 18 Circuit No.1 mark 20 22 6.1 24 26 28 1.25 30 A 32 34 36 38 B 0.25 5.85 0.75 40 Model No. SM10B-GHDS-A-TF SM12B-GHDS-A-TF SM14B-GHDS-A-TF SM16B-GHDS-A-TF SM18B-GHDS-A-TF SM20B-GHDS-A-TF SM22B-GHDS-A-TF SM24B-GHDS-A-TF SM26B-GHDS-A-TF SM28B-GHDS-A-TF SM30B-GHDS-A-TF SM32B-GHDS-A-TF SM34B-GHDS-A-TF SM36B-GHDS-A-TF SM38B-GHDS-A-TF SM40B-GHDS-A-TF Dimensions (mm) A B Q'ty/ reel 5.00 9.50 900 6.25 10.75 900 7.50 12.00 900 8.75 13.25 900 10.00 14.50 900 11.25 15.75 900 12.50 17.00 900 13.75 18.25 900 15.00 19.50 900 16.25 20.75 900 17.50 22.00 900 18.75 23.25 900 20.00 24.50 900 21.25 25.75 900 22.50 27.00 900 23.75 28.25 900 Material and Finish Circuit No.1 mark 6.1 Contact: Phosphor bronze, copper-undercoated, tin-plated (reflow treatment) Housing: PA 9T, UL94V-0, natural (ivory) 1.25 A RoHS2 compliance This product displays (LF)(SN) on a label. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. SM20B-GHDS-A-TFS...natural (ivory) K...black E...blue TR...tomato red 3
BM16B-GHDS-TF(LF)(SN) 价格&库存
很抱歉,暂时无法提供与“BM16B-GHDS-TF(LF)(SN)”相匹配的价格&库存,您可以联系我们找货
  • 1+4.899441+0.63506
  • 50+4.0886850+0.52997
  • 100+3.54817100+0.45991
  • 300+3.18202300+0.41245
  • 500+3.11228500+0.40341
  • 1000+3.059971000+0.39663
    • 1+5.82120
    • 10+4.79520
    • 30+4.28760
    • 100+3.78000
    库存:476
