LP5305
Preliminary Datasheet
Over Voltage and Over Current Protection IC
General Description
Features
The LP5305 is a highly integrated circuits, it used to
protect low voltage system from abnormal high input
voltage. The IC continuously check the input voltage,
the input current, and the battery voltage. When the
protection status is occur, the power MOS will turn off
at the same time. The LP5305 is safety devices to
ensure worked against accidents.
In case of the input voltage exceeds a OVP threshold
voltage level, the power MOS will turn off within 1μs.
The current limit can is adjustable by external resistor
between ISET and GND. And the current is also
limited to prevent charging the battery with an
excessive current. The LP5305 also monitors the
Li-ion battery voltage, when the battery voltage
exceeds 4.35V, the IC will turn off the MOS.
Other features include over temperature protection
and under-voltage lockout (UVLO). The LP5305
is available in a space saving DFN-8 package.
F: Green
Package Type
QV: DFN-8
LP5305 Version 0.2 JUN.-2018
Applications
Cell Phones
Digital Cameras
Portable Instruments
Marking Information
Order Information
LP5305 □□□
Withstand High Input Voltage Up to 26V
Adjustable Over Current Protection
Input Over Voltage Protection
Battery Over Voltage Protection
High Accuracy Protection Thresholds
Fault Signal Output
Enable Control
Under Voltage Lockout
Output Short-Circuit Protection
Over-Temperature Protection
Available in DFN-8
RoHS Compliant and Halogen Free
Device
Marking
Package
Shipping
LP5305
LPS
DFN-8
3K/REEL
LP5305
YWX
Y: Y is year code. W: W is week code. X: X is series number.
Email: marketing@lowpowersemi.com
www.lowpowersemi.com
Page 1 of 8
LP5305
Typical Application Circuit
VBUS
VIN
VOUT
LP5305
Cin
Fault
BAT
EN
H/L
ISET GND
VOUT
VDD
COUT
RPU
Fault
RBAT
RSET
Battery
Figure 1. Typical Application Circuit of LP5305 .
Pin Configuration
VIN
1
GND
2
NC
3
Fault
4
Exposed
Pad
8
VOUT
7
ISET
6
BAT
5
EN
Figure 2. Package Top View
Page 2 of 8
LP5305
Function Block Diagram
VOUT
VIN
Driver
OCP
ISET
Switch
BAT
EN
UVLO
OTP
OVP
OSC
Control
Logic
Fault
GND
Fault
Figure 3. Function Block Diagram
Functional Pin Description
Pin NO.
DFN8
VIN
1
Power source input. Connect a ceramic capacitor between VIN and GND.
GND
2
Ground.
NC
3
No connect.
Fault
4
Fault output pin. Open-drain output, device status.
EN
5
Enable pin.
BAT
6
Battery voltage detector input.
ISET
7
OCP level setting by an external resistor to GND.
VOUT
8
Output through the power MOSFET.
EP
Description
Exposed pad. Connect EP to GND is suggested.
Page 3 of 8
LP5305
Absolute Maximum Ratings Note1
VIN to GND -------------------------------------------------------------------------------------------------------- -0.3V to +30V
VOUT to GND ---------------------------------------------------------------------------------------------------- -0.3V to +7V
All Other Pin to GND -------------------------------------------------------------------------------------------- -0.3V to +7V
Operating Junction Temperature Range (TJ) -------------------------------------------------------- -40℃ to 150℃
Operation Ambient Temperature Range ------------------------------------------------------------- -40°C to +105°C
Storage Temperature Range
Maximum Soldering Temperature (at leads, 10sec)
---------------------------------------------------------------------------- -65°C to +150°C
----------------------------------------------- +260°C
Note1. Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress
ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of
the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability.
Thermal Information
Thermal Resistance
DFN-8, θJA -------------------------------------------------------------------------------------------------------------- 76.11
°C/W
Recommended Operating Conditions
Input Voltage, VIN ------------------------------------------------------------------------------------------------- 3.3V to 5V
Output Current, IOUT --------------------------------------------------------------------------------------------- 0.3A to 1.5A
OCP Set Resistance, RSET ------------------------------------------------------------------------------------ 15kΩ to 90kΩ
Junction Temperature, TJ -------------------------------------------------------------------------------------- -40°C to 125°C
Page 4 of 8
LP5305
Electrical Characteristics
(VIN = 5V, TA = 25°C, Unless Otherwise Specified)
Parameter
Symbol
Test Conditions
Min
Typ
Max
Units
General Function
Power Source Voltage
VIN
TJ= +25 °C
3.3
5
26
V
Input UVLO Threshold
VUVLO
VIN Rising
2.5
2.7
2.9
V
UVLO Threshold Hysteresis
ΔVUVLO
Power On Deglitch Time
Soft Start Time
Falling Hysteresis
200
mV
TDeglitch
8
ms
TSS
8.2
ms
Power Source Current
IIN
VIN=5V, EN=L
400
µA
Shutdown Current
ISD
VIN=5V, EN=H
55
uA
Thermal Shutdown Threshold
TSD
140
°C
Hysteresis
ΔTSD
°C
Logic Function
EN Threshold Voltage
VENH
1.4
V
VENL
IEN
0.4
V
EN=2V
15
uA
FAULT Output Logic Low
Sink 5mA
0.2
V
FAULT Logic High Leakage Current
Fault=5V
EN Input Resistance to GND
10
uA
250
mΩ
Power MOS
Switch On Resistance
RDS(ON)
IOUT=1A
160
VLDO
VIN=5.7V
5.5
V
VIOVP
VIN from 5V to 10V
5.85
V
Input OVP threshold Hysteresis
ΔVIOVP
VIN from 10V to 5V
100
mV
Input OVP Recovery Delay Time
TOVPR
8.2
ms
1
A
Regulation Function
Output Voltage Regulation
Protection Functions
Input Over Voltage Protect threshold
RSET = 24.9K,
3.3V
很抱歉,暂时无法提供与“LP5305QVF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.17700
- 100+0.90750
- 1000+0.75680
- 2000+0.68750
- 4000+0.63800
- 国内价格
- 5+1.47647
- 50+1.19891
- 150+1.07990
