S215R
S215R
2.0AMPS. SCHOTTKY BARRIER RECTIFIERS
FEATURE
SMF
.043(1.1)
.059(1.5)
.173(4.40)
.189(4.80)
.132(3.35)
.144(3.65)
MECHANICAL DATA
.Terminal: Solder plated
.Case: Molded with UL-94 Class V-0 recognized
Flame Retardant Epoxy(free halogen)
.Polarity: color band denotes cathode
.Packaging:12mm tape per EIA STD RS-481
.006(0.15)
.010(0.25)
.051(1.3)
.059(1.5)
.096(2.45)
.108(2.75)
.For surface mounted application
.High current capability
.Low forward voltage drop
.Low power loss, high efficiency
.High surge current capability
.High temperature soldering guaranteed
260℃/10 seconds at terminals.
.Easy pick and place
.016(0.40)
.028(0.70)
.028(0.70)
.047(1.20)
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25℃ ambient temperature unless otherwise specified.
Single phase, half wave, 60Hz,resistive or inductive load.
For capacitive load, derate current by 20%.
Type Number
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC blocking Voltage
Maximum Average Forward Rectified Current
SYM
BOL
S215R
units
VRRM
VRMS
VDC
IF(AV)
150
V
105
V
150
V
2.0
A
IFSM
50.0
A
VF
0.95
V
Peak Forward Surge Current 8.3ms single half
sine-wave superimposed on rated load (JEDEC
method)
Maximum Forward Voltage at 2.0A DC
Maximum DC Reverse Current
@TJ=25°C
atrated DCblockingvoltage
@TJ=100°C
Typical Junction Capacitance (Note1)
Typical Thermal Resistance (Note2)
Storage Temperature
Operating Junction Temperature
0.1
IR
10.0
CJ
R(JA)
TSTG
TJ
Note:
1. Measured at 1.0 MHz and applied reverse voltage of 4.0Vdc
2. Measured on P.C.Board with 0.2×0.2”(5.0×5.0mm)Copper Pad Areas.
1
mA
55
pF
80
°C/W
-55 to +150
°C
-55 to +150
°C
S215R
RATING AND CHARACTERISTIC CURVES (S215R)
FIG.2-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
INSTANEOUS FORWARD
CURRENT,(A)
AVERGE FORWARD
RECTIFIED CURRENT,(A)
FIG.1-TYPICAL FORWARD CURRENT
DERATING CURVE
Single Phase Half
Wave 60Hz
Resistive or
inductive Load
.2
LEAD TEMPERTURE,( )
.4
.6
.8
1.0
INSTANEOUS FORWARD VOLTAGE,(V)
FIG.4-TYPICAL REVERSE
CHARACTERISTICS
INSTANEOUS REVERSE
CURRENT,(uA)
FIG.3-MAXIMUN NON-REPETITIVE
FORWARD SURGE CURRENT
PEAK FORWARD SURGE
CURRENT,(A)
TJ=25℃
Pulse Width=300μ
s 1% Duty Cycle
8.3ms Single Half
Sine-Wave (JEDEC
Method)
TJ=25℃
PERCENT OF RATED PEAK REVERSE
VOLTAGE,(%)
NUMBER OF CYCLES AT 60Hz
2
S215R
Marking and packaging illustration
1、Marking
S215R
SYMBOL
B
C
A
XXX
A
B
C
Explanation
Color Band Denotes Cathode
Product Name
Date Code
2、Packaging
d
Top cover tape thickness
0.10mm(0.004") max.thick
W1
Embossed
carrier tape
°MAX
A
°MAX
Embossed cavity
SPECIFICATIONS
mm(inch)
SYMBOL
PACKAGE
SMF
ITEM
Carrier width
A
2.93(0.115)Max
Carrier length
B
4.85(0.191)Max
Sprocket hole
d
ø1.55(0.061)Typ
Reel outer diameter
D
330.0(13.0)Typ
Reel inner diameter
D1
50.0(1.969)Min
Feed hole diameter
D2
13.0(0.512)Typ
Sprocket hole position
J
1.75(0.069)Typ
Punch hole position
H
5.50(0.217)Typ
Carrier depth
K
1.42(0.056)Typ
Punch hole pitch
P
4.00(0.157)Typ
Sprocket hole pitch
P0
4.00(0.157)Typ
Embossment center
P1
2.00(0.079)Typ
Overall tape thickness
T
0.25(0.010)Typ
Tape width
W
12.0(0.472)Typ
Reel width
W1
12.4(0.488)Min
3
很抱歉,暂时无法提供与“S215R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.38664
- 100+0.30888
- 300+0.27000
- 1000+0.24084
- 7500+0.18998
- 15000+0.17820
