SCT2A11STER
SCT2A11STER
    SCT(芯洲科技)
    ESOP8
    SCT2A11STER
SCT2A11STER 数据手册
SILICON CONTENT TECHNOLOGY SCT2A11 4.5V-100V Vin, 0.6A, High Efficiency Synchronous Step-down DCDC Converter with Programmable Frequency FEATURES DESCRIPTION     The SCT2A11 is 0.6A synchronous buck converters with wide input voltage, ranging from 4.5V to 100V, which integrates an 750mΩ high-side MOSFET and a 500mΩ low-side MOSFET. The SCT2A11, adopting the constant-on time (COT) mode control, supports the Force Pulse Width Modulation (FPWM) Mode to achieve the small output ripple at light load condition.         Wide Input Range: 4.5V-100V 0.6A Continuous Output Current 0.8V ±1% Feedback Reference Voltage Integrated 750mΩ High-Side and 500mΩ LowSide Power MOSFETs Force Pulse Width Modulation (FPWM) Mode 4ms Internal Soft-start Time Adjustable Frequency 300KHz to 800KHz Precision Enable Threshold for Programmable Input Voltage Under-voltage Lock Out Protection (UVLO) Threshold and Hysteresis Cycle-by-Cycle Current Limiting Over-Voltage Protection Over-Temperature Protection Available in an ESOP-8 Package The SCT2A11 features programmable switching frequency from 300 kHz to 800kHz, which provides the flexibility to optimize either efficiency or external component size. The SCT2A11 offers cycle-by-cycle current limit and hiccup over current protection, thermal shutdown protection, output over-voltage protection and input voltage under-voltage protection. The device is available in an 8-pin thermally enhanced SOP-8 package. APPLICATIONS    E-Tools E-bike, Scooter GPS Tracker TYPICAL APPLICATION 100 90 L1 80 SW C1 C2 VIN VIN BST SCT2A11 R1 EN C4 R4 NC R2 RT FB R6 Efficiency(%) V OU T GND 70 60 50 40 Vin=24V 30 Vin=36V Vin=48V 20 R5 Vin=56V 10 R3 Vin=72V 0 0.001 0.01 0.1 1 Output Current(A) Typical Application Efficiency, VOUT=12V For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2A11 1 SCT2A11 REVISION HISTORY NOTE: Page numbers for previous revisions may differ from page numbers in the current version. Revision 1.0: Release to market Revision 1.2: Upgrade to 100V Revision 1.3: Add application waveforms Revision 1.4: Update R1 and R2 calculation value in page 11 DEVICE ORDER INFORMATION PART NUMBER PACKAGE MARKING PACKAGE DISCRIPTION SCT2A11STE 2A11 8-Lead Plastic ESOP 1)For Tape & Reel, Add Suffix R (e.g. SCT2A11STER). ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION Over operating free-air temperature unless otherwise DESCRIPTION MIN noted(1) MAX UNIT VIN, EN -0.3 105 V BOOT -0.3 111 V SW -1 105 V BOOT-SW -0.3 6 V FB, RT -0.3 6 V Ambient temperature TA -40 85 °C Operating junction temperature TJ(2) -40 125 °C Storage temperature TSTG -65 150 °C (1) (2) GND 1 VIN 2 EN 3 RT 4 Thermal PAD 9 8 SW 7 BST 6 NC 5 FB Figure 1. 8-Lead Plastic E-SOP Stresses beyond those listed under Absolute Maximum Rating may cause device permanent damage. The device is not guaranteed to function outside of its Recommended Operation Conditions. The IC includes over temperature protection to protect the device during overload conditions. Junction temperature will exceed 150°C when over temperature protection is active. Continuous operation above the specified maximum operating junction temperature will reduce lifetime. PIN FUNCTIONS NAME NO. PIN FUNCTION GND 1 VIN 2 EN 3 RT 4 FB 5 NC 6 Ground Input supply voltage. Connect a local bypass capacitor from VIN pin to GND pin. Path from VIN pin to high frequency bypass capacitor and GND must be as short as possible. Enable pin to the regulator with internal pull-up current source. Pull below 1.05V to disable the converter. Float or connect to VIN to enable the converter. The tap of resistor divider from VIN to GND connecting EN pin can adjust the input voltage lockout threshold. Set the internal oscillator clock frequency. Connect a resistor from this pin to ground to set switching frequency. Inverting input of the trans-conductance error amplifier. The tap of external feedback resistor divider from the output to GND sets the output voltage. The device regulates FB voltage to the internal reference value of 0.8V typical. NC 2 For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2A11 SCT2A11 BST 7 SW Thermal Pad 8 9 Power supply bias for high-side power MOSFET gate driver. Connect a 0.1uF capacitor from BOOT pin to SW pin. Bootstrap capacitor is charged when low-side power MOSFET is on or SW voltage is low. Regulator switching output. Connect SW to an external power inductor Heat dissipation path of die. Electrically connection to GND pin. Must be connected to ground plane on PCB for proper operation and optimized thermal performance. RECOMMENDED OPERATING CONDITIONS Over operating free-air temperature range unless otherwise noted PARAMETER DEFINITION VIN VOUT TJ Input voltage range Output voltage range Operating junction temperature MIN MAX UNIT 4.5 0.8 -40 100 24 125 V V °C MIN MAX UNIT -2 +2 kV -0.5 +0.5 kV ESD RATINGS PARAMETER DEFINITION Human Body Model(HBM), per ANSI-JEDEC-JS-001-2014 specification, all pins(1) Charged Device Model(CDM), per ANSI-JEDEC-JS-0022014 specification, all pins(2) VESD (1) JEDEC document JEP155 states that 500V HBM allows safe manufacturing with a standard ESD control process. (2) JEDEC document JEP157 states that 250V CDM allows safe manufacturing with a standard ESD control process. THERMAL INFORMATION PARAMETER THERMAL METRIC RθJA Junction to ambient thermal resistance(1) RθJC Junction to case thermal resistance(1) DFN-20L UNIT 42 °C/W 45.8 (1) SCT provides RθJA and RθJC numbers only as reference to estimate junction temperatures of the devices. RθJA and RθJC are not a characteristic of package itself, but of many other system level characteristics such as the design and layout of the printed circuit board (PCB) on which the SCT2A11 is mounted, thermal pad size, and external environmental factors. The PCB board is a heat sink that is soldered to the leads and thermal pad of the SCT2A11. Changing the design or configuration of the PCB board changes the efficiency of the heat sink and therefore the actual RθJA and RθJC. ELECTRICAL CHARACTERISTICS VIN=48V, TJ=-40°C~125°C, typical value is tested under 25°C. SYMBOL PARAMETER TEST CONDITION Power Supply VIN Operating input voltage ISHDN Input UVLO Threshold Hysteresis Shutdown current from VIN pin IQ Quiescent current from VIN pin VIN_UVLO MIN TYP 4.5 VIN rising EN=0, no load EN floating, no load, nonswitching, BOOT-SW=5V Power MOSFETs RDSON_H High-side MOSFET on-resistance VBOOT-VSW=5V For more information www.silicontent.com MAX 100 V 4.2 400 3 V mV μA 130 μA 750 mΩ © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2A11 UNIT 3 SCT2A11 SYMBOL PARAMETER TEST CONDITION RDSON_L Low-side MOSFET on-resistance MIN TYP MAX 500 Reference and Control Loop VREF Reference voltage of FB 0.792 0.8 UNIT mΩ 0.808 V Enable and Soft-startup VEN_H Enable high threshold 1.21 V VEN_L Enable low threshold 1.05 V IEN_L Enable pin pull-up current EN=1V 1 μA IEN_H Enable pin pull-up current EN=1.5V 4 uA Tss Internal soft start time 4 ms Switching Frequency Timing FRANGE_RT Frequency range using RT mode 300 FSW Switching frequency RRT=500 kΩ(1%) TOFF_MIN Minimum off-time VIN=12V Current Limit and Over Current Protection ILIM_P LS MOSFET positive current limit From source to drain 0.8 THICCUP Hiccup waiting time Numbers of soft-start cycles DHICCUP Hiccup duty cycle 420 800 kHz 500 600 kHz 200 260 ns 7 A cycles 12.5 % 110 105 167 35 % % °C °C Protection VOVP TSD 4 Feedback overvoltage with respect to reference voltage Thermal shutdown threshold For more information www.silicontent.com VFB/VREF rising VFB/VREF falling TJ rising Hysteresis © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2A11 SCT2A11 100 100 90 90 80 80 70 70 Efficiency(%) Efficiency(%) TYPICAL CHARACTERISTICS 60 50 40 Vin=24V 30 Vin=36V Vin=48V 20 0.01 0.1 40 Vin=24V 30 Vin=36V Vin=48V Vin=56V 10 Vin=72V 0 0.001 50 20 Vin=56V 10 60 Vin=72V 0 0.001 1 0.01 Output Current(A) 0.1 1 Output Current(A) Figure 2. Efficiency vs Load Current (Vout=5V) Figure 3. Efficiency vs Load Current (Vout=12V) 11.930 750 700 11.925 650 fsw (KHz) Vout(V) 600 11.920 Vin=24V Vin=36V Vin=48V Vin=56V Vin=72V 11.915 11.910 550 500 450 400 Rt=487K 350 Rt=698K 300 11.905 0.001 0.01 0.1 20 1 Output Current(A) 30 40 50 60 70 80 90 Input Votlage (V) Figure 4. Load Regulation (Vout=12V) Figure 5.Frequency vs Temperature 160 7.00 150 6.00 140 130 Iq(uA) Isd (uA) 5.00 4.00 120 110 3.00 100 2.00 90 1.00 80 -50 0 50 100 150 -50 0 Temperature (°C) 50 100 150 Temperature(ºC) Figure 6. Shut-down Current vs Temperature For more information www.silicontent.com Figure 7. Iq vs Temperature © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2A11 5 SCT2A11 FUNCTIONAL BLOCK DIAGRAM VIN 1uA 3uA Thermal Shutdown Start-up Regulator 20K + EN EN LOGIC VIN UVLO Reference 1.21V VCC NC VREF VCC Boot Charge Soft-start Timer 0.8V BST + + EA + + FB Boot UVLO ICMP Control Logic + OVP SW VCC 110%VREF RT On Timer GND Figure 8. Functional Block Diagram 6 For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2A11 SCT2A11 OPERATION Overview The SCT2A11 is a 4.5V-100V input, 0.6A output, internal-compensated synchronous buck converter with built-in 750mΩ Rdson high-side and 500mΩ Rdson low-side power MOSFETs. It implements constant on time control to regulate output voltage, providing excellent line and load transient response. The switching frequency is programmable from 300kHz to 800KHz with resistor setting to optimizes either the power efficiency or the external components’ sizes. The SCT2A11 features an internal 4ms soft-start time to avoid large inrush current and output voltage overshoot during startup. The device also supports monolithic startup with prebiased output condition. The quiescent current is typically 130uA under no load non-switching condition to achieve high efficiency at light load. The SCT2A11 has a default input start-up voltage of 3.5V with 400mV hysteresis. The EN pin is a high-voltage pin with a precision threshold that can be used to adjust the input voltage lockout thresholds with two external resistors to meet accurate higher UVLO system requirements. Floating EN pin enables the device with the internal pull-up current to the pin. Connecting EN pin to VIN directly starts up the device automatically. The SCT2A11 full protection features include the input under-voltage lockout, the output over-voltage protection, over current protection with cycle-by-cycle current limiting and hiccup mode, output hard short protection and thermal shutdown protection. Constant On-Time Mode Control The SCT2A11 employs constant-On-Time Mode control providing fast transient with pseudo fixed switching frequency. At the beginning of each switching cycle, the high-side MOSFET (Q1) is turned on for a fixed interval and the inductor current rises to charge up the output voltage. When the high-side MOSFET (Q1) is turned off and the low-side MOSFET (Q2) is turned on after a dead time duration. When sensed the valley current passing on the low side MOSFET lower than the COMP current threshold, the device turns on Q1 and the low-side MOSFET (Q2) turns off. Based on Vin and Vout voltage, the device predicts required off-time and turns off low-side MOSFET Q2. This repeats on cycle-by-cycle based. Force Pulse Width Modulation (FPWM) Working Modes To provide the lower output ripple in light load condition, the SCT2A11 offers the fixed switching frequency which set by the Rt resistor and works at the Force Pulse Width Modulation (FPWM) mode. Enable and Under Voltage Lockout Threshold The SCT2A11 is enabled when the VIN pin voltage rises about 4.2V and the EN pin voltage exceeds the enable threshold of 1.21V. The device is disabled when the VIN pin voltage falls below 3.8V or when the EN pin voltage is below 1.05V. An internal 1uA pull up current source to EN pin allows the device enable when EN pin floats. EN pin is a high voltage pin that can be connected to VIN directly to start up the device. For a higher system UVLO threshold, connect an external resistor divider (R3 and R4) shown in Figure 15 from VIN to EN. The UVLO rising and falling threshold can be calculated by Equation 1 and Equation 2 respectively. For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2A11 7 SCT2A11 𝑅3 = 𝑉𝑆𝑡𝑎𝑟𝑡 ( 𝑉𝐸𝑁𝐹 ) − 𝑉𝑆𝑡𝑜𝑝 𝑉𝐸𝑁𝑅 𝑉𝐸𝑁𝐹 𝐼1 (1 − 𝑉𝐸𝑁𝑅 ) + 𝐼2 VIN (1) I2 3uA I1 1uA R3 𝑅3 × 𝑉𝐸𝑁𝐹 𝑅4 = 𝑉𝑆𝑡𝑜𝑝 − 𝑉𝐸𝑁𝐹 + 𝑅3 (𝐼1 + 𝐼2 ) 20K EN (2) + EN 1.21V R4 Where Vstart: Vin rise threshold to enable the device Vstop: Vin fall threshold to disable the device I1=1uA I2=3uA VENR=1.21V VEMF=1.05V Figure 9. System UVLO by enable divide Output Voltage The SCT2A11 regulates the internal reference voltage at 0.8V with 1% tolerance over the operating temperature and voltage range. The output voltage is set by a resistor divider from the output node to the FB pin. It is recommended to use 1% tolerance or better resistors. Use Equation 3 to calculate resistance of resistor dividers. To improve efficiency at light loads, larger value resistors are recommended. However, if the values are too high, the regulator will be more susceptible to noise affecting output voltage accuracy. 𝑉𝑂𝑈𝑇 𝑅𝐹𝐵_𝑇𝑂𝑃 = ( − 1) ∗ 𝑅𝐹𝐵_𝐵𝑂𝑇 𝑉𝑅𝐸𝐹 (3) where  RFB_TOP is the resistor connecting the output to the FB pin.  RFB_BOT is the resistor connecting the FB pin to the ground. Internal Soft-Start The SCT2A11 integrates an internal soft-start circuit that ramps the reference voltage from zero volts to 0.8V reference voltage in 4ms. If the EN pin is pulled below 1.05V, switching stops and the internal soft-start resets. The soft-start also resets during shutdown due to thermal overloading. Switching Frequency The switching frequency of the SCT2A11 is set by placing a resistor between RT pin and the ground. In resistor setting frequency mode, a resistor placed between RT pin to the ground sets the switching frequency over a wide range from 300KHz to 800KHz. RT pin is not allowed to be left floating or shorted to the ground. Use Equation 4 or the plot in Figure 11. to determine the resistance for a switching frequency needed. 𝑅𝑇(𝐾𝛺) = 𝑓𝑠𝑤(𝐾𝐻𝑧) (4) RT On-Off Timer Where, fsw is switching clock frequency Figure 10. Setting Frequency 8 For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2A11 SCT2A11 . Bootstrap Voltage Regulator An external bootstrap capacitor between BOOT pin and SW pin powers the floating gate driver to high-side power MOSFET. The bootstrap capacitor voltage is charged from an integrated voltage regulator when high-side power MOSFET is off and low-side power MOSFET is on. Over Current Limit and Hiccup Mode The inductor current is monitored during low-side MOSFET Q2 on. The SCT2A11 implements over current protection with cycle-by-cycle limiting low-side MOSFET valley current and low-side MOSFET valley current to avoid inductor current running away during unexpected overload or output hard short condition. Over voltage Protection The SCT2A11 implements the Over-voltage Protection OVP circuitry to minimize output voltage overshoot during load transient, recovering from output fault condition or light load transient. The overvoltage comparator in OVP circuit compares the FB pin voltage to the internal reference voltage. When FB voltage exceeds 110% of internal 0.8V reference voltage, the high-side MOSFET turns off to avoid output voltage continue to increase. When the FB pin voltage falls below 105% of the 0.8V reference voltage, the high-side MOSFET can turn on again. Thermal Shutdown The SCT2A11 protects the device from the damage during excessive heat and power dissipation conditions. Once the junction temperature exceeds 167C, the internal thermal sensor stops power MOSFETs switching. When the junction temperature falls below 132C, the device restarts with internal soft start phase. For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2A11 9 SCT2A11 APPLICATION INFORMATION Typical Application L1 82uH VOU T=12V IOU T=600mA SW GND C1 2.2uFx2 VIN VIN =24~100V C7 22 uF C4 0.1uF C2 0.1uF R1 100K BST R5 280K SCT2A11 EN R2 Optional NC R4 2K RT FB R6 20K R3 510K Figure 11. SCT2A11 Design Example, 12V Output with Programmable UVLO Design Parameters 10 Design Parameters Example Value Input Voltage 48V Normal, 24V to 100V Output Voltage 12V Maximum Output Current 600mA Switching Frequency 500 KHz Output voltage ripple (peak to peak) 50mV Transient Response 60mA to 540mA load step ∆Vout = 300mV For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2A11 C8 100p SCT2A11 Output Voltage The output voltage is set by an external resistor divider R5 and R6 in typical application schematic. Recommended R6 resistance is 10.2KΩ. Use equation 5 to calculate R5. 𝑉𝑂𝑈𝑇 𝑅5 = ( − 1) ∗ 𝑅6 𝑉𝑅𝐸𝐹 where: (5) Table 1. R5, R6Value for Common Output Voltage (Room Temperature) VOUT R5 R6 3.3 V 63.5 KΩ 20 KΩ 5V 105 KΩ 20 KΩ 12 V 280 KΩ 20 KΩ 24 V 580 KΩ 20 KΩ  VREF is the feedback reference voltage, typical 0.8V Under Voltage Lock-Out An external voltage divider network of R1 from the input to EN pin and R2 from EN pin to the ground can set the input voltage’s Under Voltage Lock-Out (UVLO) threshold. The UVLO has two thresholds, one for power up when the input voltage is rising and the other for power down or brown outs when the input voltage is falling. For the example design, the supply should turn on and start switching once the input voltage increases above 32.7V (start or enable). After the regulator starts switching, it should continue to do so until the input voltage falls below 26.5 V (stop or disable). Use Equation 6 and Equation 7 to calculate the values 599 kΩ and 22.6 kΩ of R1 and R2 resistors. 𝑉 𝑉𝑆𝑡𝑎𝑟𝑡 ( 𝐸𝑁𝐹 ) − 𝑉𝑆𝑡𝑜𝑝 𝑉𝐸𝑁𝑅 𝑅1 = (6) 𝑉 𝐼1 (1 − 𝐸𝑁𝐹 ) + 𝐼2 𝑉𝐸𝑁𝑅 𝑅2 = 𝑅1 × 𝑉𝐸𝑁𝐹 𝑉𝑆𝑡𝑜𝑝 − 𝑉𝐸𝑁𝐹 + 𝑅1 (𝐼1 + 𝐼2 ) (7) Where Vstart: Vin rise threshold to enable the device Vstop: Vin fall threshold to disable the device I1=1uA I2=3uA VENR=1.21V VEMF=1.05V Inductor Selection There are several factors should be considered in selecting inductor such as inductance, saturation current, the RMS current and DC resistance (DCR). Larger inductance results in less inductor current ripple and therefore leads to lower output voltage ripple. However, the larger value inductor always corresponds to a bigger physical size, higher series resistance, and lower saturation current. A good rule for determining the inductance to use is to allow the inductor peak-to-peak ripple current to be approximately 20%~50% of the maximum output current. The peak-to-peak ripple current in the inductor ILPP can be calculated as in Equation 8. 𝐼𝐿𝑃𝑃 = 𝑉𝑂𝑈𝑇 ∗ (𝑉𝐼𝑁 − 𝑉𝑂𝑈𝑇 ) 𝑉𝐼𝑁 ∗ 𝐿 ∗ 𝑓𝑆𝑊 (8) Where  ILPP is the inductor peak-to-peak current  L is the inductance of inductor  fSW is the switching frequency For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2A11 11 SCT2A11   VOUT is the output voltage VIN is the input voltage Since the inductor-current ripple increases with the input voltage, so the maximum input voltage in application is always used to calculate the minimum inductance required. Use Equation 9 to calculate the inductance value. 𝐿𝑀𝐼𝑁 = Where       𝑉𝑂𝑈𝑇 𝑉𝑂𝑈𝑇 ∗ (1 − ) 𝑓𝑆𝑊 ∗ 𝐿𝐼𝑅 ∗ 𝐼𝑂𝑈𝑇(𝑚𝑎𝑥) 𝑉𝐼𝑁(𝑚𝑎𝑥) (9) LMIN is the minimum inductance required fsw is the switching frequency VOUT is the output voltage VIN(max) is the maximum input voltage IOUT(max) is the maximum DC load current LIR is coefficient of ILPP to IOUT The total current flowing through the inductor is the inductor ripple current plus the output current. When selecting an inductor, choose its rated current especially the saturation current larger than its peak operation current and RMS current also not be exceeded. Therefore, the peak switching current of inductor, ILPEAK and ILRMS can be calculated as in equation 10 and equation 11. 𝐼𝐿𝑃𝐸𝐴𝐾 = 𝐼𝑂𝑈𝑇 + 𝐼𝐿𝑃𝑃 2 𝐼𝐿𝑅𝑀𝑆 = √(𝐼𝑂𝑈𝑇 )2 + Where     (10) 1 ∗ (𝐼𝐿𝑃𝑃 )2 12 (11) ILPEAK is the inductor peak current IOUT is the DC load current ILPP is the inductor peak-to-peak current ILRMS is the inductor RMS current In overloading or load transient conditions, the inductor valley current can increase up to the switch current limit of the device which is typically 0.8A. The most conservative approach is to choose an inductor with a saturation current rating greater than 0.8A. Because of the maximum ILVALLEY limited by device, the maximum output current that the SCT2A11 can deliver also depends on the inductor current ripple. Thus, the maximum desired output current also affects the selection of inductance. The smaller inductor results in larger inductor current ripple leading to a higher maximum output current. For this design, use LIR=0.2 or 0.3, and the inductor value is calculated to be 33uH. The RMS inductor current is 600mA, and the and peak and valley inductor current is 860mA and 340mA respectively. The chosen inductor is a WE 7447714330, which has a saturation current rating of 2.9A Input Capacitor Selection The input current to the step-down DCDC converter is discontinuous, therefore it requires a capacitor to supply the AC current to the step-down DCDC converter while maintaining the DC input voltage. Use capacitors with low ESR for better performance. Ceramic capacitors with X5R or X7R dielectrics are usually suggested because of their low ESR and small temperature coefficients, and it is strongly recommended to use another lower value capacitor (e.g. 0.1uF) with small package size (0805) to filter high frequency switching noise. Place the small size capacitor as close to VIN and GND pins as possible. 12 For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2A11 SCT2A11 The voltage rating of the input capacitor must be greater than the maximum input voltage. And the capacitor must also have a ripple current rating greater than the maximum input current ripple. The RMS current in the input capacitor can be calculated using Equation 12. ICINRMS = IOUT ∗ √ VOUT VOUT ∗ (1 − ) VIN VIN (12) The worst case condition occurs at VIN=2*VOUT, where: ICINRMS = 0.5 ∗ IOUT (13) For simplification, choose an input capacitor with an RMS current rating greater than half of the maximum load current. When selecting ceramic capacitors, it needs to consider the effective value of a capacitor decreasing as the DC bias voltage across a capacitor increases. The input capacitance value determines the input ripple voltage of the regulator. The input voltage ripple can be calculated using Equation 14 and the maximum input voltage ripple occurs at 50% duty cycle. ∆VIN = IOUT VOUT VOUT ∗ ∗ (1 − ) fSW ∗ CIN VIN VIN (14) For this example, three 2.2μF, X7R ceramic capacitors rated for 100 V in parallel are used. And a 0.1 μF for highfrequency filtering capacitor is placed as close as possible to the device pins. Bootstrap Capacitor Selection A 0.1μF ceramic capacitor must be connected between BOOT pin and SW pin for proper operation. A ceramic capacitor with X5R or better grade dielectric is recommended. The capacitor should have a 25V or higher voltage rating. Output Capacitor Selection The selection of output capacitor will affect output voltage ripple in steady state and load transient performance. The output ripple is essentially composed of two parts. One is caused by the inductor current ripple going through the Equivalent Series Resistance ESR of the output capacitors and the other is caused by the inductor current ripple charging and discharging the output capacitors. To achieve small output voltage ripple, choose a low-ESR output capacitor like ceramic capacitor. For ceramic capacitors, the capacitance dominates the output ripple. For simplification, the output voltage ripple can be estimated by Equation 15 desired. ∆VOUT = Where       𝑉𝑂𝑈𝑇 ∗ (𝑉𝐼𝑁 − 𝑉𝑂𝑈𝑇 ) (15) 8 ∗ 𝑓𝑆𝑊 2 ∗ 𝐿 ∗ 𝐶𝑂𝑈𝑇 ∗ 𝑉𝐼𝑁 ΔVOUT is the output voltage ripple fSW is the switching frequency L is the inductance of inductor COUT is the output capacitance VOUT is the output voltage VINis the input voltage Due to capacitor’s degrading under DC bias, the bias voltage can significantly reduce capacitance. Ceramic capacitors can lose most of their capacitance at rated voltage. Therefore, leave margin on the voltage rating to ensure adequate effective capacitance. Typically, one 22μF ceramic output capacitors work for most applications. For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2A11 13 SCT2A11 Application Waveforms Vin=48V, Vout=12V, unless otherwise noted 14 Figure 12. Power up Figure 13. Power down Figure 14.Load Transient (0.06A-0.54A, 0.25A/us) Figure 15. Load Transient (0.15A-0.45A, 0.25A/us) Figure 16. SW and Vout Ripple Figure 17. Thermal, 48VIN, 12Vout, 0.6A For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2A11 SCT2A11 Typical Application Circuit L1 33uH VOU T=3.3V IOU T=600mA SW GND C1 2.2uF VIN VIN =24~100V C7 22 uF C4 0.1uF C2 0.1uF R1 100K BST R5 63.5K SCT2A11 R2 Optional EN NC RT FB R4 2K C8 68p R6 20K R3 510K Figure 16. VOUT=3.3V, IOUT=0.6A Application Circuit L1 47uH VOU T=5V IOU T=600mA SW GND C1 2.2uF VIN VIN =24~100V C7 22 uF C4 0.1uF C2 0.1uF R1 100K R5 105K BST SCT2A11 EN R2 Optional C8 100p NC R4 2K RT R6 20K FB R3 510K Figure 17. VOUT=5V, IOUT=0.6A Application Circuit L1 82uH VOU T=12V IOU T=600mA SW GND C1 2.2uFx2 VIN VIN =24~100V C7 22 uF C4 0.1uF C2 0.1uF R1 100K BST R5 280K SCT2A11 EN R2 Optional C8 100p NC R4 2K RT FB R6 20K R3 510K Figure 18. VOUT=12V, IOUT=0.6A Application Circuit For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2A11 15 SCT2A11 Layout Guideline Proper PCB layout is a critical for SCT2A11’s stable and efficient operation. The traces conducting fast switching currents or voltages are easy to interact with stray inductance and parasitic capacitance to generate noise and degrade performance. For better results, follow these guidelines as below: 1. Power grounding scheme is very critical because of carrying power, thermal, and glitch/bouncing noise associated with clock frequency. The thumb of rule is to make ground trace lowest impendence and power are distributed evenly on PCB. Sufficiently placing ground area will optimize thermal and not causing over heat area. 2. Place a low ESR ceramic capacitor as close to VIN pin and the ground as possible to reduce parasitic effect. 3. For operation at full rated load, the top side ground area must provide adequate heat dissipating area. Make sure top switching loop with power have lower impendence of grounding. 4. The bottom layer is a large ground plane connected to the ground plane on top layer by vias. The power pad should be connected to bottom PCB ground planes using multiple vias directly under the IC. The center thermal pad should always be soldered to the board for mechanical strength and reliability, using multiple thermal vias underneath the thermal pad. Improper soldering thermal pad to ground plate on PCB will cause SW higher ringing and overshoot besides downgrading thermal performance. It is recommended 8mil diameter drill holes of thermal vias, but a smaller via offers less risk of solder volume loss. On applications where solder volume loss thru the vias is of concern, plugging or tenting can be used to achieve a repeatable process. 5. Output inductor should be placed close to the SW pin. The area of the PCB conductor minimized to prevent excessive capacitive coupling. 6. The RT terminal is sensitive to noise so the RT resistor should be located as close as possible to the IC and routed with minimal lengths of trace. 7. UVLO adjust, RT resistors and feedback components should connect to small signal ground which must return to the GND pin without any interleaving with power ground. 8. Route BST capacitor trace on the top layer to provide wide path for topside ground. 9. For achieving better thermal performance, a four-layer layout is strongly recommended. VOUT Output capacitors GND Inductor Top layer ground area 1 Input bypass capacitor VIN GND SW VIN BST BST Capacitor Programmable UVLO resistors NC EN Thermal VIA RT FB RT Resistor GND Feedback resistors Top layer ground area Figure 26. PCB Layout Example 16 For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2A11 SCT2A11 PACKAGE INFORMATION ESOP8/PP(95x130) Package Outline Dimensions Symbol A A1 A2 b c D D1 E E1 E2 e L  Dimensions in Millimeters Min. Max. 1.300 1.700 0.000 0.100 1.350 1.550 0.330 0.510 0.170 0.250 4.700 5.100 3.050 3.250 3.800 4.000 5.800 6.200 2.160 2.360 1.270(BSC) Dimensions in Inches Min. Max. 0.051 0.067 0.000 0.004 0.053 0.061 0.013 0.020 0.007 0.010 0.185 0.201 0.120 0.128 0.150 0.157 0.228 0.244 0.085 0.093 0.050(BSC) 0.400 0° 0.016 0° 1.270 8° 0.050 8° NOTE: 1. 2. 3. 4. 5. 6. Drawing proposed to be made a JEDEC package outline MO-220 variation. Drawing not to scale. All linear dimensions are in millimeters. Thermal pad shall be soldered on the board. Dimensions of exposed pad on bottom of package do not include mold flash. Contact PCB board fabrication for minimum solder mask web tolerances between the pins. For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2A11 17 SCT2A11 TAPE AND REEL INFORMATION NOTICE: The information in this document is subject to change without notice. Users should warrant and guarantee the third party Intellectual Property rights are not infringed upon when integrating Silicon Content Technology (SCT) products into any application. SCT will not assume any legal responsibility for any said applications. 18 For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2A11
