31205102
31205102
    METZCONNECT
    插件,P=5mm
    接线端子 间距P=5.00mm 2Pin(1x2) 直插
31205102 数据手册
Data Sheet RT045xxUBLC Page 1/4 P/N 312051xx xx=number of poles Illustration see enlarged drawing at the end of the document Product specification • screw type terminal block, solderable • centerline 5.00 mm, direction of connection 55° • lift system, fittable without loss of poles • color black • Connection data V / A / AWG 300 / 15 / 28 - 12 2.5 mm² 250 V / 24 A / T60 2013/05/03 www.metz-connect.com Page 2/4 P/N 312051xx xx=number of poles Data Sheet RT045xxUBLC Technical Data General Data Tightening torque SEV Tightening torque UL Solder pin length min. number of poles max. number of poles Insulating material class clearance/creepage dist. protection category Overvoltage category Pollution degree Rated voltage Rated test voltage 0.5 Nm 6 lb-in 3.4 mm 2 24 CTI 600 3.2 mm IP 20 III 3 250 V 2.5 kV III 2 630 V 6 kV II 2 630 V 4 kV Connection data V / A / AWG 300 / 15 / 28 - 12 2.5 mm² 250 V / 24 A / T60 Material insulating material flammability class terminal body material terminal body surface screw surface screw thread PA66 V0 CuZn Ni Zn Cr(VI)-frei/free M3 Climatic properties upper limit temperature lower limit temperature 105 °C -40 °C General solderability Tolerance For THR products acc. to IPC/JEDEC J-STD-020D-MSL 1 | For THT products max. 260 °C / 10 s ISO 2768 -mH 2013/05/03 www.metz-connect.com Data Sheet RT045xxUBLC Page 3/4 P/N 312051xx xx=number of poles Illustration Drawing L=(pole size - 1) x centerline + 5 [0.197] 2013/05/03 www.metz-connect.com Data Sheet RT045xxUBLC Page 4/4 P/N 312051xx xx=number of poles PCB Layout 2013/05/03 www.metz-connect.com Powered by TCPDF (www.tcpdf.org)
31205102 价格&库存
很抱歉,暂时无法提供与“31205102”相匹配的价格&库存,您可以联系我们找货
