Data Sheet
RT015xxHDWC
Page 1/4
P/N
310011xx
xx=number of poles
2015/03/10
Illustration
see enlarged drawing at the end of the document
Product specification
• screw type terminal block, solderable
• centerline 5.00 mm, direction of connection 90°
• wire protector, fittable without loss of poles
• color gray
• Connection data
V / A / AWG 300 / 15 / 22 - 14
1.5 mm² 130 V / 17.5 A / T60
Page 2/4
P/N
310011xx
xx=number of poles
2015/03/10
Data Sheet
RT015xxHDWC
Technical Data
General Data
Tightening torque SEV
Tightening torque UL
Solder pin length
min. number of poles
max. number of poles
Insulating material class
clearance/creepage dist.
protection category
Overvoltage category
Pollution degree
Rated voltage
Rated test voltage
0.4 Nm
3.5 lb-in
3.8 mm
2
22
CTI 600
2.6 mm
IP 10
III
3
200 V
2.5 kV
III
2
500 V
2.5 kV
II
2
500 V
2.5 kV
Connection data
extended wiring UL
Wire range extended to No. 30 AWG for factory-wiring. Two same size wires No.
22-18 AWG Cu Sol/Str for field-wiring; No. 30-18 Cu Sol/Str factory-wiring.
V / A / AWG
300 / 15 / 22 - 14
1.5 mm²
Material
insulating material
flammability class
terminal body material
terminal body surface
screw surface
wire protector material
wire protector surface
screw thread
PA66
V0
CuZn
Ni + Sn
Zn Cr(VI)-frei/free
CuSn
Sn
M3
Climatic properties
upper limit temperature
lower limit temperature
105 °C
-40 °C
General
solderability
Tolerance
Acc. to JEDEC JESD22-B102E 245°C/5s
ISO 2768 -mH
Data Sheet
RT015xxHDWC
Illustration
Drawing
L=(pole size - 1) x centerline + 5 [0.197]
Page 3/4
P/N
310011xx
xx=number of poles
2015/03/10
Data Sheet
RT015xxHDWC
PCB Layout
Powered by TCPDF (www.tcpdf.org)
Page 4/4
P/N
310011xx
xx=number of poles
2015/03/10
很抱歉,暂时无法提供与“31001103”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 50+14.4447450+1.86783
- 500+5.68085500+0.73458
- 国内价格 香港价格
- 1+10.698261+1.38338
