31046103
31046103
    METZCONNECT
    插件,P=5mm
    排针 间距:5mm 1x3P 插件
31046103 数据手册
Data Sheet PR035xxVBHC Page 1/5 P/N 310461xx xx=number of poles 2013/12/05 Illustration see enlarged drawing at the end of the document Product specification • pin header, THR solderable • centerline 5.00 mm, direction of connection vertical 0° • fittable without loss of poles • color black • Tape & Reel packaging • Connection data V / A 300 / 10 13.5 A / 250 V / 4 kV / 3 / IEC 61984 Page 2/5 P/N 310461xx xx=number of poles 2013/12/05 Data Sheet PR035xxVBHC Technical Data General Data Solder pin length min. number of poles max. number of poles Insulating material class clearance/creepage dist. protection category Overvoltage category Pollution degree Rated voltage Rated test voltage 4.35 mm 2 24 CTI 400 4 mm IP 00 III 3 250 V 4.0 kV III 2 500 V 4 kV II 2 500 V 4.0 kV Connection data V/A 300 / 10 13.5 A / 250 V / 4 kV / 3 / IEC 61984 Material insulating material flammability class contact pin material contact pin surface PA46 V0 CuZn Ni + Ag Climatic properties upper limit temperature lower limit temperature 105 °C -40 °C General solderability Tolerance For THR products acc. to IPC/JEDEC J-STD-020D-MSL 1 | For THT products max. 260 °C / 10 s ISO 2768 -mH Page 3/5 P/N 310461xx xx=number of poles 2013/12/05 Data Sheet PR035xxVBHC Matching Part to P/N 311571 311571XX-002730 311571XX-002740 ASP145 ASP145XX22-301 ASP155 ASP155XX22-301 SP145XXHBNC (on request) SP155XXHBNC (on request) Product name RP095xxRBWC Typ 157 RP095xxBBWC Typ 157 RP095xxHBWC Typ 157 SP145xxHBNC ASP145 SP145xxHBPC with finger push-button SP155xxHBNC ASP155 SP155xxHBPC with finger push-button SP145xxHBNC ASP145 SP155xxHBNC ASP155 Data Sheet PR035xxVBHC Illustration Drawing L=(pole size - 1) x centerline + 4.8 [0.189] Page 4/5 P/N 310461xx xx=number of poles 2013/12/05 Data Sheet PR035xxVBHC PCB Layout Powered by TCPDF (www.tcpdf.org) Page 5/5 P/N 310461xx xx=number of poles 2013/12/05
31046103 价格&库存
很抱歉,暂时无法提供与“31046103”相匹配的价格&库存,您可以联系我们找货
  • 5000+3.349505000+0.43312
