Data Sheet
PT116xxHBBN
Page 1/5
P/N
312301xx
xx=number of poles
2014/01/27
Illustration
see enlarged drawing at the end of the document
Product specification
• pin header, solderable
• centerline 5.08 mm, direction of connection 90°
• closed ends
• color black
• codeable
• Connection data
V / A 300 / 15
13.5 A / 320 V / 4 kV / 3 / IEC 61984
Page 2/5
P/N
312301xx
xx=number of poles
2014/01/27
Data Sheet
PT116xxHBBN
Technical Data
General Data
Solder pin length
min. number of poles
max. number of poles
Insulating material class
clearance/creepage dist.
protection category
Overvoltage category
Pollution degree
Rated voltage
Rated test voltage
3.45 mm
2
24
CTI 600
4.08 mm
IP 00
III
3
320 V
4 kV
III
2
800 V
4.0 kV
Connection data
V/A
300 / 15
Material
insulating material
flammability class
contact pin material
contact pin surface
PA66
V0
CuFe
Ni + Ag
Climatic properties
upper limit temperature
lower limit temperature
105 °C
-40 °C
General
solderability
Tolerance
Acc. to JEDEC JESD22-B102E 245°C/5s
ISO 2768 -mH
II
2
800 V
4 kV
Page 3/5
P/N
312301xx
xx=number of poles
2014/01/27
Data Sheet
PT116xxHBBN
Matching Part to
P/N
312131
312141
312491
312501
ASP046
Product name
RP036xxHBLC Typ 213
RP036xxHBLD Typ 214
RP016xxVBLC Typ 249
RP016xxSBLC Typ 250
SP046xxVBNC ASP046
Accessories
P/N
700024-01-9
700523-0157 (on request)
700523-0257 (on request)
Product name
700024
Geh_Kappe_swg_Block
Geh_Kappe_swg_Block
Data Sheet
PT116xxHBBN
Illustration
Drawing
L=(pole size - 1) x centerline + 6.28 [0.247]
Page 4/5
P/N
312301xx
xx=number of poles
2014/01/27
Data Sheet
PT116xxHBBN
PCB Layout
Powered by TCPDF (www.tcpdf.org)
Page 5/5
P/N
312301xx
xx=number of poles
2014/01/27
很抱歉,暂时无法提供与“31230103”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+8.048931+1.04135
- 10+6.8335810+0.88411
- 100+5.80859100+0.75150
- 500+5.18465500+0.67078
- 1000+4.937041000+0.63874
- 5000+4.407095000+0.57018
- 10000+4.1969010000+0.54298
