SC8815QDER
SC8815QDER
    SOUTHCHIP(南芯)
    SC8815QDER
SC8815QDER 数据手册
SC8815 DATASHEET SOUTHCHIP SEMICONDUCTOR SOUTHCHIP CONFIDENTIAL SC8815 High Efficiency, Synchronous, Bi-Directional Buck-Boost Charger Controller with I2C Interface 1 Description 2 Features SC8815 is a synchronous buck-boost charger controller • Buck-Boost Battery Charger for 1 to 6 Cell Batteries which can support reverse discharging operation. It can • Charging Management including Trickle Charge, support up to 36V battery voltage, so can be used to CC Charge, CV Charge and Charge Termination effectively manage the charging for 1~6 cell Li-ion • Buck-Boost Reverse Discharging Mode batteries no matter adapter voltage is higher, lower or • Wide VBAT Range: 2.7 V to 36 V, 40V sustainable equal to battery voltage. When a system needs to • Wide VBUS Range: 2.7 V to 36 V, 40V sustainable generate an output from the battery, SC8815 can also • I2C Programmable Charging Current and Voltage discharge the cells and delivers desired output up to • I2C Programmable Discharging Output Voltage 36V. • I2C Programmable Input / Output Current Limit Through its I2C interface, user can set the charging / • I2C Programmable Switching Frequency discharging mode easily, and program the charging • High Efficiency Buck-Boost Conversion current, charging voltage, reserve output voltage, • 10-bit ADC resources current other • Charging Status Indication parameters flexibly. Besides that, SC8815 integrates • Event Detections, including Automatic Adapter limits, switching frequency and 10-bit ADC, so user can read the VBUS / VBAT voltage Insert and Automatic Load Insert Detection and current in real time, simplifying the system design. • Power Path Control SC8815 supports internal current limit, over voltage • Under Voltage Protection, Over Voltage Protection, protection, output short protection and over temperature Over Current Protection, Short Circuit Protection protections to ensure safety under different abnormal and Thermal Shutdown Protection conditions. • QFN-32 Package The SC8815 is in a 32 pin 4x4 QFN package. 4 3 Device Information Applications • Power Bank with Fast Charge Function • USB Power Delivery • Type C Hub • Industrial Power Supplies Part Number Package Dimension SC8815QDER 32 pin QFN 4.0mm x 4.0mm x 0.75mm Copyright © 2017, Southchip Semiconductor Technology (Shanghai) Co., Ltd. SC8815 DATASHEET SOUTHCHIP SEMICONDUCTOR 5 SOUTHCHIP CONFIDENTIAL Typical Application Circuit OTG = 0, charging OTG = 1, discharging AC adapter / Micro USB VBAT VBUS + PGND LD1 SW1 BT1 HD1 SNS1N SNS1P USB_A VCC VDRV VBUS LD2 FB SW2 BT2 SC8815 HD2 GPO SNS2P PGATE SNS2N ACIN VBATS COMP AGND CP /CE ADIN INT SCL SDA VDD PSTOP VBAT INDET Host Control Copyright © 2017, Southchip Semiconductor Technology (Shanghai) Co., Ltd. 2 SC8815 DATASHEET SOUTHCHIP SEMICONDUCTOR 6 SOUTHCHIP CONFIDENTIAL Terminal Configuration and Functions 24 23 VDRV VCC LD2 22 PGND 25 SW2 21 LD1 26 HD2 20 SW1 27 BT2 19 HD1 28 VBAT /CE 18 BT1 29 SNS2P PSTOP 17 VBUS 30 6 31 7 32 8 SNS1N Top View SNS2N 12 13 14 FB 15 16 VBATS 11 ADIN 10 AGND SCL 9 INT ACIN SDA INDET 33 PGND COMP 1 2 3 PGATE/DITHER GPO 5 CP 4 SNS1P TERMINAL I/O DESCRIPTION SNS1P I Positive input of a current sense amplifier. Connect to one pad of the current sense resistor (typical 10 mΩ) on the power path to sense the current into or out from VBUS. 2 GPO O Open drain output for general purpose. It is controlled by GPO_CTRL bit. User can use this pin to drive external PMOS with a pull up resistor. 3 CP O Driver for external charge pump circuit. (CHARGE PUMP NOT RECOMMENDED. It is suggested to leave this pin floating, and connect VDRV with VCC. Consult local FAE if charge pump is needed) 4 PGATE/DITHER IO PMOS gate driver controlled by PGATE bit, used to control the external PMOS on the power path. This pin can be configured through I2C for switching frequency dithering function. Connect a ceramic capacitor (typical 100nF) from this pin to ground when for frequency dither function. 5 INDET I Connect this pin to a USB-A port to detect the load insertion event. When an insertion event is detected, the IC sets INDET bit and outputs an INT interrupt pulse to inform MCU. 6 ACIN I Connect this pin to AC adapter input node or micro-USB port to detect an AC adapter insertion event. When an insertion event is detected, the IC sets AC_OK bit and outputs an INT interrupt pulse to inform MCU. 7 /CE I NUMBER NAME 1 Chip enable control. Pull this pin to logic low to enable the IC; pull this pin to logic high to disable the IC. This pin is internally pulled low. Copyright © 2017, Southchip Semiconductor Technology (Shanghai) Co., Ltd. 3 SC8815 DATASHEET SOUTHCHIP SEMICONDUCTOR 8 PSTOP I SOUTHCHIP CONFIDENTIAL Power stop control. Pull this pin to logic low to enable the power blocks; pull this pin to logic high to disabled the power blocks, and the IC enters into Standby mode. In Standby mode, only the AC adapter and load insert detection functions and the I2C circuits keep working. This pin is internally pulled low. I2C interface clock. Connect SCL to the logic rail through a pull up resistor (typical 10 kΩ). The IC works as a slave, and the I2C address is 0x74H. 9 SCL I 10 SDA I/O I2C interface data. Connect SDA to the logic rail through a pull up resistor (typical 10 kΩ). 11 INT O An open drain output for interrupt signal. The IC sends a logic low pulse at INT pin to inform the host if an interrupt event happens. 12 AGND I/O Analog ground. Connect PGND and AGND together at the thermal pad under IC. 13 ADIN I ADC input pin. Apply an analog signal (≤ 2.048V) to this pin, the internal 10-bit ADC can convert this analog signal to digital signals, and store the digital values in a register. 14 FB I Feedback node for VBUS voltage. Connect a resistor divider from VBUS to FB to set the VBUS discharging output voltage in external way. The FB reference can also be programmed through I2C. 15 COMP I Connect resistor and capacitor at this pin to compensate the control loop. 16 VBATS I Sense node for VBAT voltage. Connect to VBAT rail if internal way is selected for VBAT charging termination voltage setting; connect a resistor divider at VBATS external way is selected. 17 SNS2N I Negative input of a current sense amplifier. Connect to one pad of the current sense resistor (typical 10 mΩ) on the power path to sense the current into or out from battery. 18 SNS2P I Positive input of a current sense amplifier. Connect to the other pad of the current sense resistor (typical 10 mΩ) on the power path to sense the current into or out from battery. 19 VBAT I Power supply to the IC. Connect to the battery positive node. Place a 1 μF capacitor from this pin to PGND as close to the IC as possible. 20 BT2 I Connect a 100nF capacitor between BT2 pin and SW2 pin to bootstrap a bias voltage for high side MOSFET driver. 21 HD2 O Gate driver output to control the external high side power MOSFET. 22 SW2 I/O Switching node. Connect to the inductor. 23 LD2 O Gate driver output to control the external low side power MOSFET. 24 VCC O Output of an internal 5V linear regulator. Connect a 1 μF capacitor from VCC pin to PGND as close to the IC as possible. 25 VDRV I Power supply input for internal driver circuits. One way of getting the power supply is to connect VCC to this pin directly. Another way is to use the CP driver to implement a charge pump between VCC and VDRV pin. (CHARGE PUMP WAY IS NOT RECOMMENDED. CONSULT LOCAL FAE IF CHARGE PUMP IS USED) 26 PGND I/O Power ground. Connect PGND and AGND together at the PGND thermal pad under IC. 27 LD1 O Gate driver output to the external low side MOSFET. 28 SW1 I/O Switching Node. Connect to the inductor. 29 HD1 O Gate driver output to the external high side MOSFET. Copyright © 2017, Southchip Semiconductor Technology (Shanghai) Co., Ltd. 4 SC8815 DATASHEET SOUTHCHIP SEMICONDUCTOR SOUTHCHIP CONFIDENTIAL 30 BT1 I Connect a 100nF capacitor between BT1 pin and SW1 pins to bootstrap a bias voltage for high side MOSFET driver. 31 VBUS I Power supply to the IC. Connect to the VBUS rail. Place a 1 μF capacitor from this pin to PGND as close to the IC as possible. 32 SNS1N I Negative input of a current sense amplifier. Connect to one pad of the current sense resistor (typical 10 mΩ) on the power path to sense the current into or out from VBUS. 33 Thermal Pad PGND thermal pad. Connect PGND and AGND together at the thermal pad under IC. Copyright © 2017, Southchip Semiconductor Technology (Shanghai) Co., Ltd. 5 SC8815 DATASHEET SOUTHCHIP SEMICONDUCTOR 7 Specifications 7.1 Absolute Maximum Ratings SOUTHCHIP CONFIDENTIAL over operating free-air temperature range (unless otherwise noted) (1) MIN MAX Unit -0.3 6.5 V PSTOP -0.3 6 V SCL, SDA, INT, ADIN, COMP -0.3 5 V FB -0.3 30 V VBUS, SNS1N, SNS1P, GPO, PGATE, INDET, ACIN, VBATS, SNS2N, SNS2P, VBAT, SW2, SW1, /CE -0.3 40 V VBUS to SNS1P, SNS1N -0.3 11 V VBAT to SNS2P, SNS2N -0.3 11 V SNS1P to SNS1N -10 10 V SNS2P to SNS2N -10 10 V BT1, HD1, BT2, HD2 -0.3 45 V BT1 to HD1, BT2 to HD2 -0.3 6.5 V TJ Operating junction temperature range -40 150 °C Tstg Storage temperature range -65 150 °C CP, LD2, VCC, VDRV, LD1 HD1 to SW1, BT1 to SW1, BT2 to SW2, HD2 to SW2 Voltage range at terminals(2) (1) Stresses beyond those listed under absolute maximum ratings may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under recommended operating conditions is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. (2) All voltage values are with respect to network ground terminal. 7.2 Thermal Information THERMAL RESISTANCE(1) QFN-32 (4mmX4mm) UNIT θJA Junction to ambient thermal resistance 35 °C/W θJC Junction to case resistance 7 °C/W (1) 7.3 Measured on JESD51-7, 4-layer PCB. Handling Ratings PARAMETER DEFINITION (2) ESD(1) Human body model (HBM) ESD stress voltage (3) Charged device model (CDM) ESD stress voltage MIN MAX UNIT -2 2 kV -750 750 V (1) Electrostatic discharge (ESD) to measure device sensitivity and immunity to damage caused by assembly line electrostatic discharges into the device. (2) Level listed above is the passing level per ANSI, ESDA, and JEDEC JS-001. JEDEC document JEP155 states that 500-V HBM allows safe manufacturing with a standard ESD control process. (3) Level listed above is the passing level per EIA-JEDEC JESD22-C101. JEDEC document JEP157 states that 250-V CDM allows safe manufacturing with a standard ESD control process. 7.4 VBUS Recommended Operating Conditions VBUS voltage range Copyright © 2017, Southchip Semiconductor Technology (Shanghai) Co., Ltd. MIN MAX UNIT 2.7 36 V 6 SC8815 DATASHEET SOUTHCHIP SEMICONDUCTOR SOUTHCHIP CONFIDENTIAL VBAT VBAT voltage range 2.7 CBUS, CBAT VBUS Capacitance, VBAT capacitance 30 L Inductance 2.2 10 µH RSNS1/2 Current Sensing Resistor 5 10 mΩ TA Operating ambient temperature -40 85 C TJ Operating junction temperature -40 125 C Copyright © 2017, Southchip Semiconductor Technology (Shanghai) Co., Ltd. 36 V µF 7 SC8815 DATASHEET SOUTHCHIP SEMICONDUCTOR 7.5 SOUTHCHIP CONFIDENTIAL Electrical Characteristics TJ= 25°C and VBUS = 5V, VBAT = 10.8V unless otherwise noted. PARAMETER TEST CONDITIONS MIN TYP MAX UNIT 2.7 V SUPPLY VOLTAGE VUVLO_VBUS VUVLO_VBAT IQ_VBAT IQ_VBUS ISB_VBAT VBUS under-voltage lockout threshold Rising edge 2.5 Hysteresis 170 VBAT under-voltage lockout threshold Rising edge 2.4 Hysteresis 170 VBUS = 5V PSTOP = L, non-switching 2.4 4 mA 2.4 4 mA PSTOP = L, non-switching 25 40 μA VBUS open PSTOP = H, AD_START = 0 17 40 μA VBUS open PSTOP = H, AD_START = 1 0.65 1.2 mA Quiescent current into VBAT Quiescent current into VBUS Standby current into VBAT VBUS = 5V PSTOP = termination L, after charging mV 2.6 V mV ISB_VBUS Standby current into VBUS PSTOP = H, AD_START = 0 12 50 μA ISD_VBAT Shutdown current into VBAT /CE = H, VBUS = open 10 20 μA PSTOP = L, VBUS = 9V 5.0 5.3 V PSTOP = L, VBUS = 5V 4.96 5 V 3 V 30 mA VCC, DIRVER AND POWER SWITCH VCC VCC regulation voltage PSTOP = H,VBAT=3.6V PSTOP = L VBUS = 5V, VCC = 4.5V IVCC_LIM VCC current limit 17 PSTOP = L VBUS = 9V, VCC = 4.5V 25 PSTOP = H VDRV VDRV regulation voltage mA 160 1 mA change pump connected VBUS = 5V, IDRV = 0mA 5.8 6.2 6.5 V change pump connected VBUS = 9V, IDRV = 30mA 5.7 6.1 6.4 V RHS/LS_PU High/low side MOS driver pull up resistor 4 Ω RHS/LS_PD High/low side MOS driver pull down resistor 1 Ω REFERENCE VOLTAGE IN CHARGING MODE VBATS_ext VBATS reference voltage for external setting VBAT_SEL = 1 VBATS_int VBATS accuracy for internal setting, over VBATS target VBAT_SEL = 0, CSEL = 00 VCELL_SET=000~111 VTRICKLE_int Trickle charge threshold voltage for internal setting VBAT_SEL = 0, Cell number = N VCELL_SET = 000~1111, TRICKLE_SET = 0 2.73*N VBAT_SEL = 0, Cell number = N 2.31*N Copyright © 2017, Southchip Semiconductor Technology (Shanghai) Co., Ltd. 1.197 1.203 1.209 V 0.5 % 2.94*N 3.15*N V 2.52*N 2.73*N V -0.5 8 SC8815 DATASHEET SOUTHCHIP SEMICONDUCTOR SOUTHCHIP CONFIDENTIAL VCELL_SET = 000~1111, TRICKLE_SET = 1 VTRICKLE_ext Trickle charge threshold for external setting, over VBAT target VBAT_SEL = 1, TRICKLE_SET = 0 65 70 75 % VBAT_SEL = 1, TRICKLE_SET = 1 55 60 65 % VEOC EOC voltage threshold, over VBAT target VBAT_SEL = 0/1 97% 98% 99% VRECH Recharge threshold voltage, over VBAT target VBAT_SEL = 0/1 94.8% 95.8% 96.8% 4.5V target VINREG_SET = 0x2C, VINREG_RATIO = 0 4.3 4.5 4.7 V 15V target VINREG_SET = 0x95, VINREG_RATIO = 0 14.7 15 15.3 V 4.48V target VINREG_SET = 0x6F, VINREG_RATIO = 1 4.4 4.5 4.6 V 10V target VINREG_SET = 0xF9, VINREG_RATIO = 1 9.8 10 10.2 V 103% 105.5% 108% VINREG VBAT_OVP VINREG reference voltage VBAT OVP threshold, over VBAT target VBAT_SEL = 0/1 VCLAMP 125 mV REFERENCE VOLTAGE IN DISCHARGING MODE VFB VBUS FB reference voltage for external setting FB_SEL = 1, VBUSREF_E_REF target from 0.5V to 2.048V -2% 2% FB_SEL = 0 VBUS_RATIO = 1 (5x) VBUS = 3.6 ~10.24V -2% 2% FB_SEL = 0 VBUS_RATIO = 0 (12.5x) VBUS = 9 ~ 24V -2% 2% VBUS OVP threshold, rising edge VBUSREF_I_SET = 1V VBUSREF_E_SET = 1V 107.3% Hysteresis VBUSREF_I_SET = 1V VBUSREF_E_SET = 1V VBUS reference voltage accuracy for internal setting VBUS_OVP 110% 113% 3% CURRENT LIMIT IBUS_LIM IBUS current limit accuracy Charging mode, 6A target IBUS_RATIO = 01 (6x) IBUS_LIM = 0x7F -10% 10% Charging mode, 3A target IBUS_RATIO = 10 (3x) IBUS_LIM = 0x7F -10% 10% Discharging mode, 6A target IBUS_RATIO = 01 (6x) IBUS_LIM = 0x7F -10% 10% Discharging mode, 3A target IBUS_RATIO = 10 (3x) IBUS_LIM = 0x7F -10% 10% Copyright © 2017, Southchip Semiconductor Technology (Shanghai) Co., Ltd. 9 SC8815 DATASHEET SOUTHCHIP SEMICONDUCTOR IBAT_LIM ITRICKLE IEOC IBAT current limit accuracy SOUTHCHIP CONFIDENTIAL Charging mode, 6A target IBAT_RATIO = 0 (6x) IBAT_LIM = 0xFF -10% 10% Charging mode, 12A target IBAT_RATIO = 1 (12x) IBAT_LIM = 0xFF -10% 10% Discharging mode, 6A target IBAT_RATIO = 0 (6x) IBAT_LIM = 0xFF -15% 15% Discharging mode, 12A target IBAT_RATIO = 1 (12x) IBAT_LIM = 0xFF -15% 15% Trickle charge current, over IBAT_LIM setting 10% Trickle charge current, over IBUS_LIM setting 22% EOC current threshold, over IBUS_LIM / IBAT_LIM setting EOC_SET= 0 4% EOC_SET= 1 10% ERROR AMPLIFIER GmEA Error amplifier gm ROUT Error amplifier output resistance (1) ISINK_COMP COMP sink current ISRC_COMP COMP source current IBIAS_FB FB pin input bias current 0.12 0.15 0.18 mS 20 MΩ LOOP_SET = 0/1 25 μA LOOP_SET = 0 18 μA LOOP_SET = 1 32 μA FB_SEL = 1 FB in regulation 50 nA SWITCHING fSW Switching frequency FREQ_SET = 00 (150kHz) 140 155 170 kHz FREQ_SET = 01 (300kHz) 270 305 330 kHz FREQ_SET = 11 (450kHz) 400 450 500 kHz POWER PATH MANAGEMENT RPU_PGATE PGATE pin pull up resistor EN_PGATE = 0 20 kΩ RPD_PGATE PGATE pin pull down resistor EN_PGATE = 1 6 kΩ VCLAMP Clamp voltage from VBUS to PGATE pin EN_PGATE = 1 RRD_GPO GPO pin pull down resistor GPO_CTRL = 1 6.9 7.35 7.7 6 V kΩ DETECTION VAC_DET AC detection threshold VSHORT Short circuit detection threshold 2.9 3.1 3.4 V 0.95 1 1.05 V 0.75 1 1.25 MΩ 0.4 V I2C AND LOGIC CONTROL RPD PSTOP pin internal pull down resistor VIL PSTOP, SCL, SDA input low voltage VIH PSTOP, SCL, SDA input high voltage ISINK_INT INT pin sink current 1.2 VINT = 0.4V Copyright © 2017, Southchip Semiconductor Technology (Shanghai) Co., Ltd. 0.3 V 0.375 0.45 mA 10 SC8815 DATASHEET SOUTHCHIP SEMICONDUCTOR ISINK_SCL/SDA SCL/SDA pin sink current tPULSE Interrupt pulse width (logic low) SOUTHCHIP CONFIDENTIAL VSCL/SDA = 0.4V mA 100 0.6 1 1.5 ms SOFTSTART tdeglitch Deglitch time for charging PSTOP = L, OTG_SET = 0 VBUS = 5V, from PSTOP low to IC starting charging 220 ms tSS Internal soft-start time VBUS from 0V to 5V in discharging mode VBUS_Ratio = 1 (5x) 12 ms 165 °C 15 °C THERMAL SHUTDOWN TSD Thermal shutdown temperature (1) Thermal shutdown hysteresis (1) Copyright © 2017, Southchip Semiconductor Technology (Shanghai) Co., Ltd. 11 SC8815 DATASHEET SOUTHCHIP SEMICONDUCTOR 8 its current limit value first. For example, if IBUS current limit is set to 3A, IBAT limit is set to 10A, and when IBUS reaches 3A, IBAT is only 6A, which is much lower than IBAT limit 10A, then the IC limits the IBUS at 3A. Detailed Description 8.1 SOUTHCHIP CONFIDENTIAL Charging Mode Charging mode and discharging mode is selected by EN_OTG bit. When EN_OTG bit is 0, the IC works in charging mode. The current flows from VBUS to VBAT to charge the battery cells. When in charging mode, the IC charges the battery cells according to below typical charging profile. When battery voltage is lower than trickle charge threshold, the IC charges the cells with small charging current; when cell voltage is higher than the threshold, the IC enters into Constant Current charging phase, and charges the cells with constant current set by IBUS limit or IBAT limit. When the cell voltage reaches the termination voltage target, the IC enters into Constant Voltage charge phase, and charges the cells with gradually decreased current until the current is lower than termination current threshold. Once termination voltage and termination current conditions are satisfied, the IC enters into End of Charge phase. In this phase the IC can either terminate the charging or keep charging the cells. Termination voltage Recharge-threshold It is not allowed to set any of the current limits to 0A. Keep the minimum current limit above 0.3A. 8.1.3 CV Charge (Constant Voltage Charge) The battery target voltage can be set internally, by CSEL bits and VCELL_SET bits. The CSEL bits set the battery cell numbers connected in series, and VCELL_SET bits set the battery voltage per cell. For example, if the battery cells are in xp2s connection (several cells are connected in parallel, and two cells in series) and the cell voltage is 4.3V, the user should set CSEL to 01 (2S), and set VCELL_SET bits to 011 (4.3V). When the battery charging voltage is set internally, the user should connect VBATS pin to VBAT terminal to sense the battery voltage, and the VBAT_SEL bit should be set to 0. If VBAT_SEL is set to 1, it means the battery voltage is set externally. Under this condition, the user should use resistor divider at VBATS pin to set the target voltage as below. VCELL_SET and CSEL bits don’t work. The reference of VBATS is 1.2V. CC (constant current) charge VBAT = VBATS_REF× (1+ RUP ) RDOWN Trickle charge threshold EOC indication VBAT Trickle charge current + Termination current Trickle charge CC (constant current) charge CV (constant voltage) charge End of recharge charge VBATS A. VBAT_SEL = 0 Figure 1 Typical Charging Profile 8.1.1 Trickle Charge The trickle charge voltage threshold can be set to 60% or 70% of 4.2V/cell by TRICKLE_SET bit. When in trickle charge phase, the charging current is reduced to a small value for the good of battery cells. If ICHAR_SEL bit is 0, the IBUS is reduced to 22% of the IBUS current limit set value; if ICHAR_SEL bit is 1, the IBAT is reduced to 10% of IBAT current limit set value. VBAT Rup + VBATS Rdown B. VBAT_SEL = 1 If trickle charging phase is not needed, the user can set DIS_TRICKLE bit to 1 to disable it. 8.1.2 CC Charge (Constant Current Charge) When cell voltage is higher than the trickle threshold, the IC charges the battery cells with constant current set by IBUS limit or IBAT limit, which are set respectively through IBUS_LIM_SET and IBAT_LIM_SET registers. The current limit value can be changed dynamically, and is also related to the current sense resistor and ratio bits. Please see Register Map section for details. In charging mode, the IC regulates the current which reaches Figure 2 Battery voltage setting When the battery cell voltage reaches 98% of the cell target voltage, the IC enters into CV charge phase. In this phase, the VBAT voltage is regulated at target value, and the charging current reduces gradually. 8.1.4 EOC (End of Charge) When both of below voltage condition and current condition for EOC detection are satisfied, the IC enters into EOC Copyright © 2017, Southchip Semiconductor Technology (Shanghai) Co., Ltd. 12 SC8815 DATASHEET SOUTHCHIP SEMICONDUCTOR phase, and informs the MCU through EOC interrupt bit. 1. 2. the cell voltage is higher than 98% of set value the IBUS or IBAT current (decided by ICHAR_SEL bit) is lower than 1/10 or 1/25 (decided by EOC_SET bit) of its current limit value SOUTHCHIP CONFIDENTIAL changed dynamically, and the recommended VBUS voltage range is from 3V to 36V. When VBUS is lower than 10.24V, it is suggested to set the VBUS_RATIO to 5x, and so the minimum changing step is 10mV/step; when VBUS is higher than 10.24V, VBUS_RATIO should be set to 12.5x, and the minimum changing step is 25mV/step. In EOC phase, the IC can terminate the charging process or keep charging the battery cells, which can be set by DIS_TERM bit. If IC keeps charging, it regulates the battery cell voltage at set value. If FB_SEL is set to 1, the VBUS voltage target is set externally, that is, by the resistor divider connected at FB pin, and can be calculated as below. 8.1.5 Even if VBUS is set externally, the user can still change the VBUS voltage dynamically by changing the reference voltage VBUSREF_E through VBUSREF_E_SET and VBUSREF_E_SET2 registers. The default VBUSREF_E is 1V, and recommended VBUSREF_E voltage range is from 0.7V to 2.048V. Recharge If the IC terminates the charging process after EOC is detected, the battery voltage may drop slowly due to leakage or operation current from battery cells. Once the VBAT voltage drops below 95% of the set voltage, the EOC bit is cleared, and the IC enters into CC charge phase and recharges the battery. 8.1.6 Self-adaptive Charging Current (VINREG) The IC features dynamic power management. The allowed minimum VBUS operation voltage is VINREG threshold, which can be set by VINREG_SET register and VINREG_RATIO bit dynamically. During charging, if the IBUS charging current is higher than adapter’s current capability, the adapter will be overloaded and the VBUS voltage is pulled low. Once the IC detects the VBUS voltage drops at VINREG threshold, it reduces the charging current automatically and regulates the VBUS voltage at VINREG threshold. 8.1.7 Battery Impedance Compensation The IC provides the function of battery impedance compensation. User can set the impedance through IRCOMP bits, then the VBAT target voltage in CV phase is compensated as VBAT_cmp = VBAT_set + min(IBAT∙IRCOMP, VCLAMP) Where, VBAT_cmp is the compensated battery voltage target; VBAT_set is the originally set battery termination target; IBAT is the charging current at battery side; IRCOMP is the resistance compensation value set by IRCOMP bits; VCLAMP is the allowed maximum compensation value, fixed at 125mV. User should carefully evaluate the real battery impedance. If the value set by IRCOMP bits is higher than the real value, it will cause over charge. 8.2 Discharging Mode When EN_OTG bit is set to1, the IC enters into discharging mode. In discharging mode, the battery (VBAT) is discharged and the current flows from VBAT to VBUS. If FB_SEL is set to 0, the VBUS output voltage is set internally, through VBUSREF_I_SET and VBUSREF_I_SET2 registers and the VBUS_RATIO bit. The VBUS can be VBUS = VBUSREF_E x (1+ RUP ) RDOWM Please see Register Map section for details. The IBUS current limit and IBAT current limit are still functional in discharging mode and can be changed dynamically. It is not allowed to set any of the current limits to 0A. Keep the minimum current limit above 0.3A. 8.2.1 Soft Start The IC integrates soft-start control to generate VBUS voltage in discharging mode. When VBUS is lower than VSHORT (typ. 1V), both IBUS and IBAT current limits are fold back to 1/10 of the setting value. Meanwhile, the IC ramps up the internal reference voltage gradually (~10ms) to avoid inrush current. If there is a load at VBUS at the beginning of the startup, the IC may fail to boost the VBUS voltage beyond VSHORT due to the 1/10 current limits for both IBUS and IBAT. If startup with loading is required, user shall set the DIS_ShortFoldBack bit to 1 to disable the current limit fold back function. After startup, the user can set DIS_ShortFoldBack bit back to 0, so to enable this function for short circuit protection. See VBUS Short Protection section for details. 8.2.2 Slew Rate Setting When the VBUS voltage is changed dynamically through reference voltage (VBUSREF_I_SET and VBUSREF_I_SET2 registers or VBUSREF_E_SET and VBUSREF_E_SET2 registers), the reference voltage change rate can be controlled through SLEW_SET bits. For example, the VBUS is set in internal way with 5x ratio, and the VBUSREF_I = 1V at first (VBUS = 5V), then the user sets the VBUSREF_I voltage to 1.6V to get 8V output. If the slew rate is 2mV/ μs, the VBUS voltage will increase to 8V in 600mV / 2mV/μs = 300μs. 8.2.3 PFM Operation The IC supports PFM operation in discharging mode by setting EN_PFM bit to 1. In PWM mode, the IC always works with constant switching frequency for the whole load range. This helps achieve the best output voltage performance, but Copyright © 2017, Southchip Semiconductor Technology (Shanghai) Co., Ltd. 13 SC8815 DATASHEET SOUTHCHIP SEMICONDUCTOR the efficiency is low at light load condition because of the high switching loss. In PFM mode, the IC still works with constant switching frequency under heavy load condition, but under light load condition, the IC automatically changes to pulse frequency modulation operation to reduce the switching loss. The efficiency can be improved under light load condition while output voltage ripple will be a little larger compared with PWM operation. Below figure shows the output voltage behavior of PFM mode. SOUTHCHIP CONFIDENTIAL 8.5 Phone Insert Detection If connecting INDET pin to USB-A port as shown in Typical Application Circuit, the IC can detect the phone detection. Once the IC detects a phone is inserted, it sets the INDET interrupt bit to inform MCU. The INDET bit is cleared after it is read by MCU. 8.6 Adapter Attachment / Detachment Detection If connecting ACIN pin to Micro-USB port as shown in Typical Application Circuit, the IC can detect the attachment / detachment of the adapter. PFM operation at light load PFM VOUT Vout Normal VOUT Change to PWM operation at heavy load Figure 3 PFM mode illustration 8.3 ADC for Voltage and Current Monitor The IC integrates a 10-bit ADC, so the IC can monitor the VBUS/VBAT voltages and IBUS/IBAT current no matter in charging mode or discharging mode. Besides these, the IC provides an analog input: ADIN pin for 10-bit ADC sampling. The maximum voltage the ADC can sample at ADIN pin is 2.048V, and the sampling resolution is 2mV/step. The ADC function is enabled after AD_START bit is set to 1. When ADC is enabled in standby mode, the IC will 0.5mA~1mA operation current. Please see Register Map section for details. 8.4 Power Path Management The IC offers power path management function at PGATE and GPO pins. The PGATE pin can be used to drive PMOS connected at VBUS. The PGATE pin is connected to a 6 kΩ pull down resistor internally when EN_PGATE is set to 1, and the maximum voltage between VBUS and PGATE is clamped at 7.35V; when EN_PGATE is set to 0, PGATE pin is connected to VBUS rail through a 20 kΩ pull up resistor internally The GPO pin is an open drain output, so external pull up resistor is needed. When GPO_CTRL bit is set to 0, GPO outputs high impedance; when GPO_CTRL is set to1, GPO is pulled down internally and the pull down resistance is 6 kΩ. User can use PGATE pin and GPO pin to control the isolation MOSFETs between adapter input and USB output as shown in Typical Application Circuit. However, the MCU or system controller controls the bits through I2C interface, which takes time for communication, so the PMOS may not be turned on/off very quickly. In the application where the isolation PMOS needs to be controlled very fast, it is suggested to use the I/O pins of MCU to control the PMOS on/off directly. Once the ACIN pin voltage is higher than 3V, which means the adapter is inserted, the IC sets the AC_OK interrupt bit to inform MCU about the attachment. If the ACIN pin voltage is lower than 3V, which means the adapter is removed, the IC clears AC_OK bit to inform the MCU about the detachment. 8.7 Switching and Frequency Dithering The IC switches in fixed frequency which can be adjusted through FREQ_SET bits. The switching dead time can also be set through DT_SET pins. Please see Register Map section for details. The IC also offers frequency dithering function. This function can be enabled by setting EN_DITHER bit to 1. When the function is enabled, the switching frequency is not fixed, but varies within +/- 5% range. For example, if the switching frequency is set to 300kHz (FREQ_SET = 01), the frequency will change from 285kHz to 315kHz gradually and then back to 285kHz back and forth. The time it varies from the lowest to the highest frequency or from highest to lowest frequency can be controlled by a capacitor connected at PGATE/DITHER pin as below equation shows. For example, if 100nF capacitor is connected, the time is 1.2 ms. T_dither = 120 mV × C 10 μA When EN_DITHER is set to 1, the PGATE driver function is disabled, and the PGATE/DITHER pin only operates for dithering function. 8.8 VCC Regulator and Driver Supply The IC integrates a regulator which is powered by VBUS voltage and generates a 5V voltage at VCC pin with typically 25 mA driving capability. When in Standby mode, the VCC voltage is not regulated and has very limited current capability. It is not suggested to use VCC in Standby mode. The internal driving circuit is powered from VDRV pin, and user should provide a supply at VDRV pin to power the circuit. The user can connect VCC to VDRV directly, or connect an external power supply to VDRV. Besides the two ways, the IC offers a charge pump driver at CP pin, which can pump the VCC voltage to power VDRV pin. With charge pump circuit, the IC can regulate the VDRV voltage at 6V. Copyright © 2017, Southchip Semiconductor Technology (Shanghai) Co., Ltd. 14 SC8815 DATASHEET SOUTHCHIP SEMICONDUCTOR SOUTHCHIP CONFIDENTIAL Charge pump is not recommended for VDRV. Consult local FAE if charge pump is used. 8.11 Protection VCC = 5V 8.11.1 VBUS Over Voltage Protection User can enabled / disable VBUS over voltage protection in discharging mode by DIS_OVP bit. When OVP is enabled, the IC stops switching when VBUS is higher than the target voltage by 10%. VCC CP VDRV 8.11.2 The IC implements VBAT over voltage protection in both charging mode and discharging mode. Once the VBAT voltage is higher than target voltage by 10%, the IC stops switching. A. connect VC to VDRV directly (HIGHLY RECOMMENDED) VDRV = 6V VCC = 5V 8.11.3 VCC VBAT Over Voltage Protection CP In discharging mode, if the VBUS voltage is detected lower than VSHORT (typ. 1V), the IC sets the VBUS_SHORT interrupt bit to inform the MCU. In the same time, it reduces IBUS limits to 22% of the set values and IBAT limit to 10% of the set value at the same time to protect the IC. If DIS_ShortFoldBack bit is set to 1, the current limits will not be reduced. VDRV B. Use charge pump to power VDRV (NOT RECOMMEND) External supply (=300mA SC8815 DATASHEET SOUTHCHIP SEMICONDUCTOR SOUTHCHIP CONFIDENTIAL Table 7 0x06H IBAT_LIM_SET Register Bit Mode 7-0 R/W Bit Name IBAT_LIM_SE T Default value @POR 1111 1111 Description Notes Set IBAT current limit, which is valid for both charging and discharging modes. IBAT_LIM (A) = IBAT_LIM_SET+1 256 × IBAT_RATIO × 10 mΩ RS2 IBAT_LIM_S ET must be >=300mA RS2 is the current sense resistor at VBAT side. IBAT_LIM_SET range: 0 ~ 255 0000 0000: 0 0000 0001: 1 0000 0010: 2 … 1111 1111: 255 (default) E.g., if RS2 = 10 mΩ, the default IBAT current limit is (255+1)/256 x 12 x 10 mΩ / 10 mΩ = 12 A Table 8 0x07H VINREG_SET Register Bit Mode 7-0 R/W Bit Name VINREG_SET Default value @POR 0010 1100 Description Notes Set VINREG reference voltage for charging mode. VINREG = (VINREG_SET+1) × VINREG_RATIO (mV) VINREG_SET range: 0 ~ 255 0000 0000: 0 0000 0001: 1 … 0010 1100: 44 (default) … 1111 1111: 255 If VINREG_RATIO = 1 (40x), the default VINREG voltage is 1.8V, and the maximum VINREG voltage which can be set is 10.24V; If VINREG_RATIO = 0 (100x), the default VINREG voltage is 4.5V, and the maximum VINREG voltage which can be set is 25.6V. Table 9 0x08H RATIO Register Bit Mode Bit Name Default value @POR Description 7-6 R/W Reserved 00 Internal use. Don’t overwrite this bit. 5 R/W Reserved 1 Internal use. Don’t overwrite this bit. Copyright © 2017, Southchip Semiconductor Technology (Shanghai) Co.,Ltd. Notes SC8815 DATASHEET SOUTHCHIP SEMICONDUCTOR 4 R/W IBAT_RATIO 1 SOUTHCHIP CONFIDENTIAL IBAT_LIM setting ratio 0: 6x 1: 12x (default) 3-2 R/W IBUS_RATIO 10 IBUS_LIM setting ratio 00: not allowed 01: 6x Set this bit during PSTOP pin is high Set this bit during PSTOP pin is high 10: 3x (default) 11: not allowed 1 R/W VBAT_MON_ RATIO 0 Ratio setting for VBAT voltage monitor 0: 12.5x (default) 1: 5x Set this bit during PSTOP pin is high The battery voltage is monitored through ADC and can be calculated as below: VBAT = (4 x VBAT_FB_VALUE + VBAT_FB_VALUE2 + 1) x VBAT_MON_RATIO x 2 mV VBAT_FB_VALUE and VBAT_FB_VALUE2 are ADC register values. For 1S and 2S battery applications (VBAT < 9V), set this bit to 1. 0 R/W VBUS_RATIO 0 Set the ratio for VBUS voltage setting and VBUS voltage monitor. 0: 12.5x (default) 1: 5x Set this bit during PSTOP pin is high Table 10 0x09H CTRL0_SET Register Bit Mode Bit Name Default value @POR 7 R/W EN_OTG 0 Description Notes Enable OTG operation 0: set the charger to work in charging mode (default) 1: set the charger to work in discharging mode 6 R/W Reserved 0 Internal use. Don’t overwrite this bit. 5 R/W Reserved 0 Internal use. Don’t overwrite this bit. 4 R/W VINREG_RAT IO 0 VINREG setting ratio 0: 100x (default) 1: 40x Set this bit to 1 when VBUS < 12V. 3-2 R/W FREQ_SET 01 Switching frequency setting 00: 150kHz 01: 300kHz (default) Set this bit during PSTOP pin is high 10: 300kHz 11: 450kHz 1-0 R/W DT_SET 00 Switching dead time setting Copyright © 2017, Southchip Semiconductor Technology (Shanghai) Co.,Ltd. Set this bit during SC8815 DATASHEET SOUTHCHIP SEMICONDUCTOR SOUTHCHIP CONFIDENTIAL 00: 20ns (default) PSTOP pin is high 01: 40ns 10: 60ns 11: 80ns Table 11 0x0AH CTRL1_SET Register Bit Mode 7 R/W Symbol Default value @POR ICHAR_SEL 0 Description Charging current selection 0: IBUS as charging current, the trickle charging current and termination current will be based on IBUS (default) Notes Set this bit during PSTOP pin is high 1: IBAT as charging current, the trickle charging current and termination current will be based on IBAT 6 R/W DIS_TRICKLE 0 Trickle charge control 0: enable trickle charge phase (default) 1: disable trickle charge phase 5 R/W DIS_TERM 0 Charging termination control 0: enable auto-termination (default) 1: disable auto-termination 4 R/W FB_SEL 0 VBUS voltage setting control, only for discharging mode 0: internal VBUS setting, VBUS output voltage is set by VBUS_RATIO bit and VBUSREF_I_SET bits (default) Set this bit during PSTOP pin is high Set this bit during PSTOP pin is high Set this bit during PSTOP pin is high 1: external VBUS setting, VBUS output voltage is set by resistor divider at FB pin 3 R/W TRICKLE_SET 0 Trickle charge phase threshold setting 0: 70% of VBAT voltage setting (default) 1: 60% of VBAT voltage setting 2 R/W DIS_OVP 0 Set this bit during PSTOP pin is high OVP protection setting for discharging mode 0: enable OVP protection (default) 1: disable OVP protection 1 R/W Reserved 0 Internal use. Don’t overwrite this bit. 0 R/W Reserved 1 Internal use. Don’t overwrite this bit. Table 12 0x0BH CTRL2_SET Register Bit Mode Symbol Default value @POR 7-4 R/W Reserved 0000 3 R/W FACTORY 0 Description Internal use. Don’t overwrite this bit. Factory setting bit. MCU shall write this bit to 1 after power up. Copyright © 2017, Southchip Semiconductor Technology (Shanghai) Co.,Ltd. Notes SC8815 DATASHEET SOUTHCHIP SEMICONDUCTOR 2 R/W EN_DITHER 0 SOUTHCHIP CONFIDENTIAL Enable switching frequency dithering function at PGATE pin: 0: disable frequency dithering function, PGATE pin used as PMOS gate control (default) Set this bit during PSTOP pin is high 1: enable frequency dithering function, PGATE pin used to set the frequency dithering 1-0 R/W SLEW_SET 01 Slew rate setting for VBUS dynamic change in discharging mode 00: 1mV/μs 01: 2mV/μs (default) Set this bit during PSTOP pin is high 10: 4mV/μs 11: 8mV/μs Table 13 0x0CH CTRL3_SET Register Bit Mode 7 R/W Symbol EN_PGATE Default value @POR 0 Description Notes PGATE control 0: PGATE outputs logic high to turn off PMOS (default) 1: PGATE outputs logic low to turn on PMOS 6 R/W GPO_CTRL 0 GPO output control 0: Open drain output (default) 1: Logic low output 5 R/W AD_START 0 ADC control 0: stop ADC conversion (default) 1: start ADC conversion, MCU can read the voltage/current values from ADC registers 4 R/W ILIM_BW_SEL 0 ILIM loop bandwidth setting: 0: 5kHz (default) 1: 1.25kHz 3 R/W LOOP_SET 0 Loop response control 0: Normal loop response (default) 1: Improve the loop response 2 R/W DIS_ShortFold Back 0 Set this bit during PSTOP pin is high Set this bit during PSTOP pin is high IBUS and IBAT current foldback control for VBUS short circuit condition, only valid in discharging mode 0: IBUS and IBAT current limit value are fold-back to 22% and 10% of setting value respectively (default) 1: disable fold-back. 1 R/W EOC_SET 1 Current threshold setting for End Of Charging (EOC) detection 0: 1/25 of charging current 1: 1/10 of charging current (default) 0 R/W EN_PFM 0 PFM control under light load condition, only for discharging mode 0: disable PFM mode (PWM mode enabled) (default) 1: enable PFM mode Copyright © 2017, Southchip Semiconductor Technology (Shanghai) Co.,Ltd. Set this bit during PSTOP pin is high SC8815 DATASHEET SOUTHCHIP SEMICONDUCTOR SOUTHCHIP CONFIDENTIAL Table 14 0x0DH VBUS_FB_VALUE Register Bit Mode 7-0 R Symbol VBUS_FB_VA LUE Default value @POR 0000 0000 Description Notes The highest 8-bit of the ADC reading of VBUS voltage (total 10-bit). VBUS voltage is calculated as VBUS = (4 x VBUS_FB_VALUE + VBUS_FB_VALUE2 + 1) x VBUS_RATIO x 2 mV VBUS_FB_VALUE range: 0 ~ 255 0000 0000: 0 0000 0001: 1 0000 0010: 2 …. 1111 1111: 255 Table 15 0x0EH VBUS_FB_VALUE_2 Register Bit Mode 7-6 R Symbol VBUS_FB_VA LUE2 Default value @POR 00 Description Notes The lowest 2-bit of the ADC reading of VBUS voltage (total 10-bit). VBUS voltage is calculated as VBUS voltage is calculated as VBUS = (4 x VBUS_FB_VALUE + VBUS_FB_VALUE2 + 1) x VBUS_RATIO x 2 mV VBUS_FB_VALUE2 range: 0 ~ 3 00: 0 01: 1 10: 2 11: 3 5-0 Reserved 00 0000 Table 16 0x0FH VBAT_FB_VALUE Register Bit Mode 7-0 R Symbol VBAT_FB_VA LUE Default value @POR 0000 0000 Description The highest 8-bit of the ADC reading of VBAT voltage (total 10-bit). VBAT voltage is calculated as VBAT = (4 x VBAT_FB_VALUE + VBAT_FB_VALUE2 + 1) x VBAT_MON_RATIO x 2 mV VBAT_FB_VALUE range: 0 ~ 255 0000 0000: 0 0000 0001: 1 Copyright © 2017, Southchip Semiconductor Technology (Shanghai) Co.,Ltd. Notes SC8815 DATASHEET SOUTHCHIP SEMICONDUCTOR SOUTHCHIP CONFIDENTIAL 0000 0010: 2 …. 1111 1111: 255 Table 17 0x10H VBAT_FB_VALUE_2 Register Bit Mode 7-6 R Symbol VBAT_FB_VA LUE_2 Default value @POR 00 Description Notes The lowest 2-bit of the ADC reading of VBAT voltage (total 10-bit). VBAT voltage is calculated as VBAT = (4 x VBAT_FB_VALUE + VBAT_FB_VALUE2 + 1) x VBAT_MON_RATIO x 2 mV VBAT_FB_VALUE_2 range: 0 ~ 3 00: 0 01: 1 10: 2 11: 3 5-0 Reserved 00 0000 Table 18 0x11H IBUS_VALUE Register Bit Mode 7-0 R Symbol IBUS_VALUE Default value @POR 0000 0000 Description Notes The highest 8-bit of the ADC reading of IBUS current (total 10-bit). IBUS current is calculated as IBUS (A) = (4 x IBUS_VALUE + IBUS_VALUE2 + 1)×2 10 mΩ × IBUS_RATIO × 1200 RS1 IBUS_VALUE range: 0 ~ 255 0000 0000: 0 0000 0001: 1 0000 0010: 2 …. 1111 1111: 255 Table 19 0x12H IBUS_VALUE_2 Register Bit Mode 7-6 R Symbol IBUS_VALUE 2 Default value @POR 00 Description The lowest 2-bit of the ADC reading of IBUS current (total 10-bit). IBUS current is calculated as IBUS (A) = (4 x IBUS_VALUE + IBUS_VALUE2 + 1)×2 10 mΩ × IBUS_RATIO × 1200 RS1 Copyright © 2017, Southchip Semiconductor Technology (Shanghai) Co.,Ltd. Notes SC8815 DATASHEET SOUTHCHIP SEMICONDUCTOR SOUTHCHIP CONFIDENTIAL IBUS_VALUE2 range: 0 ~ 3 00: 0 01: 1 10: 2 11: 3 5-0 Reserved 00 0000 Table 20 0x13H IBAT_VALUE Register Bit Mode 7-0 R Symbol IBAT_VALUE Default value @POR 0000 0000 Description Notes The highest 8-bit of the ADC reading of IBAT current (total 10-bit). IBAT current is calculated as IBAT (A) = (4 x IBAT_VALUE + IBAT_VALUE2 + 1)×2 10 mΩ × IBAT_RATIO × 1200 RS2 IBAT_VALUE range: 0 ~ 255 0000 0000: 0 0000 0001: 1 0000 0010: 2 …. 1111 1111: 255 Table 21 0x14H IBAT_VALUE_2 Register Bit Mode 7-6 R Symbol IBAT_VALUE 2 Default value @POR 00 Description Notes The lowest 2-bit of the ADC reading of IBAT current (total 10-bit). IBAT current is calculated as IBAT (A) = (4 x IBAT_VALUE + IBAT_VALUE2 + 1)×2 10 mΩ × IBAT_RATIO × 1200 RS2 IBAT_VALUE2 range: 0 ~ 3 00: 0 01: 1 10: 2 11: 3 5-0 Reserved 00 0000 Table 22 0x15H ADIN_VALUE Register Bit Mode Symbol Default value @POR Description Copyright © 2017, Southchip Semiconductor Technology (Shanghai) Co.,Ltd. Notes SC8815 DATASHEET SOUTHCHIP SEMICONDUCTOR 7-0 R ADIN_VALUE 0000 0000 SOUTHCHIP CONFIDENTIAL The highest 8-bit of the ADC reading of ADIN voltage (total 10-bit). ADIN voltage is calculated as VADIN = (4 x ADIN_VALUE + ADIN_VALUE2 + 1) x 2 mV ADIN_VALUE range: 0 ~ 255 0000 0000: 0 0000 0001: 1 0000 0010: 2 …. 1111 1111: 255 Table 23 0x16H ADIN_VALUE_2 Register Bit Mode 7-6 R Symbol ADIN_VALUE 2 Default value @POR 00 Description Notes The lowest 2-bit of the ADC reading of ADIN voltage (total 10-bit). ADIN voltage is calculated as VADIN = (4 x ADIN_VALUE + ADIN_VALUE2 + 1) x 2 mV ADIN_VALUE_2 range: 0 ~ 3 00: 0 01: 1 10: 2 11: 3 5-0 Reserved 00 0000 Table 24 0x17H STATUS Register Bit Mode Symbol Default value @POR Description 7 R Reserved 0 Reserved 6 R AC_OK 0 1: AC adapter is inserted 5 R INDET 0 1: USB-A load insert is detected at INDET pin 4 R Reserved 0 Reserved 3 R VBUS_SHORT 0 1: VBUS short circuit fault happens in discharging mode 2 R OTP 0 1: OTP fault happens 1 R EOC 0 1: EOC conditions are satisfied 0 R Reserved 0 Copyright © 2017, Southchip Semiconductor Technology (Shanghai) Co.,Ltd. Notes SC8815 DATASHEET SOUTHCHIP SEMICONDUCTOR SOUTHCHIP CONFIDENTIAL Table 25 0x19H MASK Register Bit Mode Symbol Default value @POR Description 7 R/W Reserved 1 Internal use. Don’t overwrite this bit. 6 R/W AC_OK_Mask 0 1: Interrupt is disabled 5 R/W INDET_Mask 0 1: Interrupt is disabled 4 R/W Reserved 0 Internal use. Don’t overwrite this bit. 3 R/W VBUS_SHORT_ Mask 0 1: Interrupt is disabled 2 R/W OTP_Mask 0 1: Interrupt is disabled 1 R/W EOC_Mask 0 1: Interrupt is disabled 0 R/W Reserved 0 Internal use. Write this bit to 1 after power up. Copyright © 2017, Southchip Semiconductor Technology (Shanghai) Co.,Ltd. Notes SC8815 DATASHEET SOUTHCHIP SEMICONDUCTOR MECHANICAL DATA QFN32L(0404x0.75-0.40) Copyright © 2017, Southchip Semiconductor Technology (Shanghai) Co.,Ltd. SOUTHCHIP CONFIDENTIAL
SC8815QDER
物料型号:SC8815
器件简介:SC8815是一款高效率、同步、双向升降压充电器控制器,具有I2C接口。它支持1至6节电池的升降压电池充电器,可以支持反向放电操作。SC8815能够管理1~6节锂离子电池的充电,包括涓流充电、CC充电、CV充电和充电终止,同时具有宽VBAT范围(2.7V至36V)和宽VBUS范围(2.7V至36V)。
引脚分配:SC8815采用32引脚4x4 QFN封装,每个引脚具有特定的功能和电源要求。例如,SNS1P和SNS1N用于电流感应放大器的正负输入,VBAT和VBUS提供电源,SW1和SW2为开关节点,连接到电感等。
参数特性:SC8815具有多个可编程参数,包括充电电流和电压、放电输出电压、输入/输出电流限制、开关频率等。此外,它还集成了10位ADC,可以实时读取VBUS/VBAT电压和电流,简化了系统设计。
功能详解:SC8815支持多种充电模式,包括涓流充电、恒流充电和恒压充电,并具有充电终止和再充电功能。在放电模式下,它可以调节VBUS电压,并支持PFM操作以提高轻载效率。此外,它还具备多种保护功能,如过压保护、短路保护和过温保护。
应用信息:SC8815适用于多种应用,如带有快速充电功能的移动电源、USB Power Delivery Type C Hub和工业电源供应。
封装信息:SC8815采用32引脚QFN封装,尺寸为4.0mmx4.0mmx0.75mm。
SC8815QDER 价格&库存
很抱歉,暂时无法提供与“SC8815QDER”相匹配的价格&库存,您可以联系我们找货
