SHANGHAI
June 2006
MICROELECTRONICS CO., LTD.
SESD5Z5CL
Transient Voltage Suppressors for ESD Protection
General Description
Revision:C
Features
The SESD5Z5CL is designed to protect voltage
z
Small Body Outline Dimensions
sensitive components from ESD and transient voltage
z
Low Body Height
events. Excellent clamping capability, low leakage, and
z
Peak Power up to 75 Watts @ 8 x 20 _µs Pulse
fast response time, make these parts ideal for ESD
z
Low Leakage current
protection on designs where board space is at a
z
Response Time is Typically < 1 ns
premium.
Complies with the following standards
Applications
z
Cellular phones
z
Portable devices
z
Digital cameras
z
Power supplies
IEC61000-4-2
Level 4
15 kV (air discharge)
8 kV(contact discharge)
MIL STD 883E - Method 3015-7 Class 3
25 kV HBM (Human Body Model)
Functional diagram
SOD-523
Absolute Ratings (Tamb=25°C )
Symbol
Parameter
Value
Units
PPP
Peak Pulse Power (tp = 8/20μs)
75
W
TL
Maximum lead temperature for soldering during 10s
260
°C
Tstg
Storage Temperature Range
-55 to +155
°C
Top
Operating Temperature Range
-40 to +125
°C
Tj
Maximum junction temperature
150
°C
±15
±8
kV
40
A
16
kV
400
V
6.2A
12
V
5.2A
11.4
IEC61000-4-2 (ESD)
air discharge
contact discharge
IEC61000-4-4 (EFT)
ESD Voltage
Per Human Body Model
Per Machine Model
VC
Ipp (Peak Pulse Current
tp=8/20us)
ShangHai Sino-IC Microelectronics Co., Ltd.
1.
SESD5Z5CL
Electrical Parameter
Symbol
IPP
VC
VRWM
IR
IT
VBR
Parameter
Reverse Peak
Maximum
Current
Clamping Voltage @ IPP
Pulse
Working Peak Reverse Voltage
Maximum Reverse Leakage Current
@ VRWM
Test Current
Breakdown Voltage @ IT
Electrical Characteristics Ratings at 25°C ambient temperature unless otherwise specified.VF = 0.9V at IF = 10mA
VBR
Part Numbers
SESD5Z5CL
IT
VRWM
IR
VF
IF
C
Max.
Typ.
Typ. 0v bias
Min.
Typ.
Max.
V
V
V
mA
V
µA
V
mA
pF
5.8
6.7
7.8
1
5.0
1
1.25
200
3
*Surge current waveform per Figure 1.
1. VBR is measured with a pulse test current IT at an ambient temperature of 25℃.
Typical Characteristics
Fig1. Pulse Waveform
Fig2.Power Derating Curve
2.
SESD5Z5CL
Application Note
Electrostatic discharge (ESD) is a major cause of failure in electronic systems. Transient Voltage
Suppressors (TVS) are an ideal choice for ESD protection. They are capable of clamping the incoming
transient to a low enough level such that damage to the protected semiconductor is prevented.
Surface mount TVS offers the best choice for minimal lead inductance. They serve as parallel
protection elements, connected between the signal lines to ground. As the transient rises above the
operating voltage of the device, the TVS becomes a low impedance path diverting the transient current to
ground. The SESD5Z5C is the ideal board evel protection of ESD sensitive semiconductor components.
The tiny SOD-523 package allows design flexibility in the design of high density boards where the
space saving is at a premium. This enables to shorten the routing and contributes to hardening against
ESD.
SOD-523 Mechanical Data
Millimeters
Dim
INCHES
MIN
NOM
MAX
MIN
NOM
MAX
A
1.10
1.20
1.30
0.043
0.047
0.051
B
0.70
0.80
0.90
0.028
0.032
0.035
C
0.50
0.60
0.70
0.020
0.024
0.028
D
0.25
0.30
0.35
0.010
0.012
0.014
J
0.07
0.14
0.20
0.0028
0.0055
0.0079
K
0.15
0.20
0.25
0.006
0.008
0.010
S
1.50
1.60
1.70
0.059
0.063
0.067
The SINO-IC logo is a registered trademark of ShangHai Sino-IC Microelectronics Co., Ltd.
© 2005 SINO-IC – Printed in China – All rights reserved.
SHANGHAI SINO-IC MICROELECTRONICS CO., LTD
Add: Building 3, Room 3401-03, No.200 Zhangheng Road, ZhangJiang Hi-Tech Park, Pudong,
Shanghai 201203, China
Phone: +86-21-33932402 33932403 33932405 33933508 33933608
Fax: +86-21-33932401
Email: szrxw002@126.com
Website: http://www.sino-ic.net
3.
很抱歉,暂时无法提供与“SESD5Z5CL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.28869
- 200+0.23328
- 600+0.20250
- 2000+0.18404
- 8000+0.15542
- 16000+0.14678
