SMDJ28CA
SMDJ28CA
    YJSEMI(元捷)
    SMC(DO-214AB)
    SMDJ28CA
SMDJ28CA 数据手册
山东元捷电子科技 Shan dong YuanJie Electronic Technology Technical Information SMDJ SERIES Surface Mount Transient Voltage Suppressor Diodes )HDWXUHV ƹ Excellent clamping capability ◆ Low dynamic impedance ◆ Solder dip 260 °C max. 10 s, per JESD 22-B106 0HFKDQLFDO'DWD &DVHDO-214AB (SMC) Molded plastic body Terminals: Tin plated leads, solderable per J-STD- 002 and JESD22-B102 0RXQWLQJ3RVLWLRQAny 0D[LPXP5DWLQJV (OHFWULFDO&KDUDFWHULVWLFV Ratings at TA = 25°C unless otherwise specified PARAMETER SYMBOL Peak power dissipation, with a 10/1000us waveform(1)(2 ) Power dissipation, on infinite heat sink at TL=75℃(2) Peak forward surge current, 8.3 ms single half sine-wave unidirectional only (3) Operating junction and storage temperature range Maximum instantaneous forward voltage at 100A for unidirectional only(4) Junction to ambient Junction to lead Notes: (1) (2) (3) (4) (5) UNIT Max PPPM W 3000 PD W 6.5 IFSM A 300 TJ,TST G ℃ -55 to +150 VFM V 3.5/5.0 RθJ-A ℃/W 75 RθJ-L ℃/W 15 Non-repetitive current pulse, per Fig. 3 and derated above TA= 25℃per Fig.2. Mounted on 0.31 x 0.31" (8.0 x 8.0 mm) copper pads to each terminal Measured on 8.3ms single half sine-wave or equivalent square wave,duty cycle=4 pulses per minute maximum. VF=3.5V Max for devices of VBR≤220v,and VF=5.0v Max for devices of VBR>220v. Mounted on minimum recommended pad layout. Revision:2018-12-12 1 www.yjsemi.com.cn 山东元捷电子科技 Technical Information Shandong YuanJie Electronic Technology SMDJ SERIES Surface Mount Transient Voltage Suppressor Diodes ELECTRICAL CHARACTERISTICS(TA=25°C unless otherwise noted) Part No. SMDJ5.0A SMDJ6.0A SMDJ6.5A SMDJ7.0A SMDJ7.5A SMDJ8.0A SMDJ8.5A SMDJ9.0A SMDJ10A SMDJ11A SMDJ12A SMDJ13A SMDJ14A SMDJ15A SMDJ16A SMDJ17A SMDJ18A SMDJ19A SMDJ20A SMDJ22A SMDJ24A SMDJ26A SMDJ28A SMDJ30A SMDJ33A SMDJ36A SMDJ40A SMDJ43A SMDJ45A SMDJ48A SMDJ51A SMDJ54A SMDJ58A SMDJ60A SMDJ64A SMDJ70A SMDJ75A SMDJ78A SMDJ80A SMDJ85A SMDJ90A SMDJ100A SMDJ110A SMDJ120A SMDJ130A SMDJ140A SMDJ150A SMDJ160A SMDJ170A SMDJ180A SMDJ190A SMDJ200A SMDJ220A SMDJ250A SMDJ300A SMDJ350A SMDJ400A SMDJ440A SMDJ5.0CA SMDJ6.0CA SMDJ6.5CA SMDJ7.0CA SMDJ7.5CA SMDJ8.0CA SMDJ8.5CA SMDJ9.0CA SMDJ10CA SMDJ11CA SMDJ12CA SMDJ13CA SMDJ14CA SMDJ15CA SMDJ16CA SMDJ17CA SMDJ18CA SMDJ19CA SMDJ20CA SMDJ22CA SMDJ24CA SMDJ26CA SMDJ28CA SMDJ30CA SMDJ33CA SMDJ36CA SMDJ40CA SMDJ43CA SMDJ45CA SMDJ48CA SMDJ51CA SMDJ54CA SMDJ58CA SMDJ60CA SMDJ64CA SMDJ70CA SMDJ75CA SMDJ78CA SMDJ80CA SMDJ85CA SMDJ90CA SMDJ100CA SMDJ110CA SMDJ120CA SMDJ130CA SMDJ140CA SMDJ150CA SMDJ160CA SMDJ170CA SMDJ180CA SMDJ190CA SMDJ200CA SMDJ220CA SMDJ250CA SMDJ300CA SMDJ350CA SMDJ400CA SMDJ440CA Revision:2018-12-12 Peak Power Dissipation 10/1000μ sec(W) Reverse Stand-Off Voltage VRWM(V) Breakdown Voltage VBR (V) Min @ IT Breakdown Voltage VBR (V) Max @ IT Test Current IT (mA) Max Clamping Voltage VC (V)@ IPP Peak Pulse Current IPP (A) Reverse Leakage IR (μA) @ VRWM 3000 3000 3000 3000 3000 3000 3000 3000 3000 3000 3000 3000 3000 3000 3000 3000 3000 3000 3000 3000 3000 3000 3000 3000 3000 3000 3000 3000 3000 3000 3000 3000 3000 3000 3000 3000 3000 3000 3000 3000 3000 3000 3000 3000 3000 3000 3000 3000 3000 3000 3000 3000 3000 3000 3000 3000 3000 3000 5.0 6.0 6.5 7.0 7.5 8.0 8.5 9.0 10.0 11.0 12.0 13.0 14.0 15.0 16.0 17.0 18.0 19.0 20.0 22.0 24.0 26.0 28.0 30.0 33.0 36.0 40.0 43.0 45.0 48.0 51.0 54.0 58.0 60.0 64.0 70.0 75.0 78.0 80.0 85.0 90.0 100.0 110.0 120.0 130.0 140.0 150.0 160.0 170.0 180.0 190.0 200.0 220.0 250.0 300.0 350.0 400.0 440.0 6.40 6.67 7.22 7.78 8.33 8.89 9.44 10.00 11.10 12.20 13.30 14.40 15.60 16.70 17.80 18.90 20.00 21.10 22.20 24.40 26.70 28.90 31.10 33.30 36.70 40.00 44.40 47.80 50.00 53.30 56.70 60.00 64.40 66.70 71.10 77.80 83.30 86.70 88.80 94.40 100.00 111.00 122.00 133.00 144.00 155.00 167.00 178.00 189.00 200.00 211.00 224.00 246.00 279.00 335.00 391.00 447.00 492.00 7.00 7.37 7.98 8.60 9.21 9.83 10.40 11.10 12.30 13.50 14.70 15.90 17.20 18.50 19.70 20.90 22.10 23.30 24.50 26.90 29.50 31.90 34.40 36.80 40.60 44.20 49.10 52.80 55.30 58.90 62.70 66.30 71.20 73.70 78.60 86.00 92.10 95.80 97.60 104.00 111.00 123.00 135.00 147.00 159.00 171.00 185.00 197.00 209.00 220.00 232.00 247.00 272.00 309.00 371.00 432.00 494.00 543.00 10 10 10 10 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 9.20 10.30 11.20 12.00 12.90 13.60 14.40 15.40 17.00 18.20 19.90 21.50 23.20 24.40 26.00 27.60 29.20 30.80 32.40 35.50 38.90 42.10 45.40 48.40 53.30 58.10 64.50 69.40 72.70 77.40 82.40 87.10 93.60 96.80 103.0 113.0 121.0 126.0 129.6 137.0 146.0 162.0 177.0 193.0 209.0 226.8 243.0 259.0 275.0 291.6 307.8 324.0 356.0 405.0 486.0 567.0 648.0 713.0 326.09 291.26 267.86 250.00 232.56 220.59 208.33 194.81 176.47 164.84 150.75 139.53 129.31 122.95 115.38 108.70 102.74 97.47 92.59 84.51 77.12 71.26 66.08 61.98 56.29 51.64 46.51 43.23 41.27 38.76 36.41 34.44 32.05 30.99 29.13 26.55 24.79 23.81 23.15 21.90 20.55 18.52 16.95 15.54 14.35 13.23 12.35 11.58 10.91 10.29 9.75 9.26 8.43 7.41 6.17 5.29 4.63 4.21 1000 1000 500 200 100 50 25 10 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 2 www.yjsemi.com.cn 山东元捷电子科技 Technical Information Shandong YuanJie Electronic Technology SMDJ SERIES Surface Mount Transient Voltage Suppressor Diodes  Typical Characteristics 100 100 Non-Repetitive Pulse Waveform shown in Fige.3 TA=25℃ PPP or IPP(%) 75 PPPM(KW) 10 50 1.0 25 0.1 0.31×0.31"(8.0×8.0mm) Copper Pad Areas 0.1μs 1μs 0 10μs 100μs td(μs) 1.0ms 0 10ms FIG1:Peak Pulse Power Rating Curve 150 75 50 100 125 TJ(℃) 150 175 200 FIG2: Pulse Power or Current vs. Initial Junction Temperature 100 tr=10μs TJ=25℃ Pulse Width(td) is defined as the Point where the Peak Current Decays to 50% of IPPM Peak Value IPPM IPPM(%) 25 Rth(℃/W) 100 Half Value - IPP 2 IPPM 50 10 1 10/1000μs Waveform as Defined by R.E.A. td 0 0 1.0 2.0 3.0 0.1 0.001 4.0 T(ms) 0.01 0.1 1 tp(s) 10 100 1000 FIG4:Typical Transient Thermal Impedance FIG3: Pulse Waveform 7 TJ=TJMax. 8.3ms Single Half Sine-Wave 6 300 PD(W) IFSM(A) 5 4 3 2 1 0 0 0 10 Number of Cycles FIG5: Maximum Non-Repetitive Surge Current Revision:2018-12-12 0 100 25 50 75 100 125 150 175 200 TL(℃) FIG6:Steady State Power Dissipation 3 www.yjsemi.com.cn 山东元捷电子科技 Technical Information Shandong YuanJie Electronic Technology SMDJ SERIES Surface Mount Transient Voltage Suppressor Diodes  3DFNDJH2XWOLQH'LPHQVLRQV(unit:mm) DO-214AB (SMC) 0RXQWLQJ3DG/D\RXW(unit:mm) 3 4 3 4 3 Revision:2018-12-12 4 Dim Millimeters 3 98 3 6.80 3 38 4 3.00 4 4.00 www.yjsemi.com.cn
SMDJ28CA 价格&库存
很抱歉,暂时无法提供与“SMDJ28CA”相匹配的价格&库存,您可以联系我们找货
