S3MCG
S3MCG
    SK(時科)
    SMC(DO-214AB)
    S3MCG
S3MCG 数据手册
S3ACG THRU S3MCG Surface Mount General Purpose Silicon Rectifiers Reverse Voltage - 50 to 1000 V PINNING Forward Current - 3 A PIN FEATURES • For surface mounted applications • Low profile package • Glass Passivated Chip Junction • Easy to pick and place • Lead free in comply with EU RoHS 2011/65/EU directives DESCRIPTION 1 Cathode 2 Anode 2 1 MECHANICAL DATA • Case: SMC • Terminals: Solderable per MIL-STD-750, Method 2026 • A pprox. Weight: 0.22g / 0.0077oz Top View Marking Code: S3A~S3M Simplified outline SMC and symbol Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %. Symbols S3ACG S3BCG S3DCG S3GCG S3JCG S3KCG S3MCG Units Parameter Maximum Repetitive Peak Reverse Voltage V RRM 50 100 200 400 600 800 1000 V Maximum RMS voltage V RMS 35 70 140 280 420 560 700 V Maximum DC Blocking Voltage V DC 50 100 200 400 600 800 1000 V Maximum Average Forward Rectified Current I F(AV) 3 A Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load I FSM 90 A Maximum Instantaneous Forward Voltage at 3 A VF 1.0 V IR 5 100 μA Cj 40 pF RθJA RθJC 40 16 °C/W T j , T stg -55 ~ +150 °C Maximum DC Reverse Current T a = 25 °C at Rated DC Blocking Voltage T a =125 °C Typical Junction Capacitance (1) Typical Thermal Resistance (2) Operating and Storage Temperature Range (1)Measured at 1 MHz and applied reverse voltage of 4 V D.C (2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. REV.08 1 of 3 S3ACG THRU S3MCG Fig.2 Typical Reverse Characteristics Instaneous Reverse Current(μ A) Average Forward Current (A) Fig.1 Forward Current Derating Curve 3.0 2.0 1.0 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 50 75 100 125 150 175 100 T J =125°C 10 1.0 T J =25°C 0.1 00 Case Temperature (°C) Junction Capacitance ( pF) Instaneous Forward Current (A) 10 1.0 60 80 100 120 140 T J =25°C 100 10 T J =25°C 0.1 0.4 1 0.6 0.8 1.0 1.2 1.4 1.6 1.8 0.1 Fig.6 Maximum Non-Repetitive Peak Forward Surage Current 128 112 96 80 64 48 32 16 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 10 1.0 10 Reverse Voltage (V) Instaneous Forward Voltage (V) Peak Forward Surage Current (A) 40 Fig.4 Typical Junction Capacitance Fig.3 Typical Forward Characteristic 100 Number of Cycles REV.08 20 percent of Rated Peak Reverse Voltage (%) 2 of 3 100 S3ACG THRU S3MCG PACKAGE OUTLINE SMC Plastic surface mounted package; 2 leads E A A1 A C b D L E1 VM A SMC mechanical data A E D E1 A1 C L b max 2.62 7.0 6.2 8.0 0.21 0.31 1.6 3.25 min 2.00 6.5 5.6 7.6 0.05 0.15 0.9 2.75 max 103 276 244 315 8.3 12 63 128 min 79 256 220 299 2.0 5.9 35 108 UNIT mm mil Marking The recommended mounting pad size Type number 3.8 (150) S3ACG 4.1 (160) 4.3 (170) 4.1 (160) mm Unit : (mil) REV.08 3 of 3 Marking code S3A S3BCG S3B S3DCG S3D S3GCG S3G S3JCG S3J S3KCG S3K S3MCG S3M
S3MCG 价格&库存
很抱歉,暂时无法提供与“S3MCG”相匹配的价格&库存,您可以联系我们找货
