RTC8563SOF
RTC8563SOF
    LPSEMI(微源)
    SOP8
    RTC8563SOF
RTC8563SOF 数据手册
Preliminary Datasheet RTC8563S I2C Real Time Clock/Calendar General Description Applications The RTC8563S is a CMOS real time clock/calendar, which provides seconds, minutes, hours, day, date, month, and year information. The number of days in each month and leap years are automatically adjusted. The clock can operate in two modes: one is the 12-hour mode with an AM/PM indicator,the other is the 24-hour mode. The clock/calendar is full binary-coded decimal (BCD). In addition, the RTC8563S contains a programmable clock output, a timer, an alarm, a voltage-low detector. All address and data are transferred serially via I2C bus and The RTC8563S operates as a slave device on the serial bus. The built-in word address register is incremented automatically after each written or read data byte. The RTC8563S is designed to operate on very low power consumption. ■ Security Access Controller, Door Controller ■ Time Recorder ■ Mobile Telephones ■ Public Phone Bill Meter, Smart Card Payphone ■ MP3/MP4 Player ■ IC Water-Flow Meter, IC Gas Meter Order Information RTC8563S □ □ □ F: Pb-Free MS: MSOP-8 SO: SOP-8 Features ■ Provides Year, Month, Day, Weekday, Hours, Minutes and Seconds Information ■ Century Flag ■ Wide Operating Voltage: 1.8V to 5.5V ■ Low Power Consumption: 0.25μA at VDD = 3.0 V ■ I2C-bus Interface ■ Programmable Clock Output (32.768 kHz, 1024 Hz, 32 Hz and 1 Hz) ■ Alarm and Timer Functions ■ Built-in Power Voltage Detecting Circuit ■ I2C -bus Slave Address: Read A3H and Write A2H ■ Open-Drain Interrupt Pin RoHS compliant and 100% lead(Pb)-free Marking Information Please see website. Typical Application Circuit RTC8563S Sep.-2013 Email: marketing@lowpowersemi.com www.lowpowersemi.com Page 1 of 15 Preliminary Datasheet RTC8563S Functional Pin Description Pin Configurations MSOP-8 / SOP-8 Application Ciucuit Absolute Maximum Ratings RTC8563S Sep.-2013 Email: marketing@lowpowersemi.com www.lowpowersemi.com Page 2 of 15 Preliminary Datasheet RTC8563S Electrical Characteristics RTC8563S Sep.-2013 Email: marketing@lowpowersemi.com www.lowpowersemi.com Page 3 of 15 Preliminary Datasheet RTC8563S Sep.-2013 Email: marketing@lowpowersemi.com RTC8563S www.lowpowersemi.com Page 4 of 15 Preliminary Datasheet RTC8563S Sep.-2013 Email: marketing@lowpowersemi.com RTC8563S www.lowpowersemi.com Page 5 of 15 Preliminary Datasheet RTC8563S Application Information Register Organization RTC8563S Sep.-2013 Email: marketing@lowpowersemi.com www.lowpowersemi.com Page 6 of 15 Preliminary Datasheet RTC8563S Sep.-2013 Email: marketing@lowpowersemi.com RTC8563 www.lowpowersemi.com Page 7 of 15 Preliminary Datasheet RTC8563 Sep.-2013 Email: marketing@lowpowersemi.com RTC8563S www.lowpowersemi.com Page 8 of 15 Preliminary Datasheet RTC8563S Reset The RTC8563S includes an internal reset circuit which is active whenever the oscillator is stopped. In the reset state the I2C-bus logic is initialized and all registers, including the address pointer, are cleared with the exception of bits FE, VL, TD1, TD0, TESTC and AE which are set to logic 1. Voltage-Low Detector and Clock Surveillance The RTC8563S has an on-chip voltage-low detector. When VDD drops below VLOW, bit VL in the seconds register is set to indicate that the integrity of the clock/calendar information is no longer guaranteed. The VL flag can only be cleared by software. When VDD decreased slowly up to VLOW, bit VL will be set. This will indicate that the time may be corrupted. I2C-Bus Description I2C-Bus Interface The RTC8563S supports I2C-bus transmission protocol. The I2C-bus is for bidirectional, two-line communication between different ICs or modules. The two lines are a serial data line (SDA) and a serial clock line (SCL). Both lines must be connected to a positive supply via a pull-up resistor. A device that sends data onto the bus is defined as a transmitter and a device receiving data as a receiver. The device that controls the message is called a master. The devices that are controlled by the master are referred to as slaves. The master device generates the serial clock (SCL), controls the bus access, and generates the START and STOP conditions. The RTC8563S operates as a slave on the I2C-bus. A typical bus configuration using this 2-wire protocol is show in Figure 7. RTC8563S Sep.-2013 Email: marketing@lowpowersemi.com www.lowpowersemi.com Page 9 of 15 Preliminary Datasheet RTC8563S Sep.-2013 Email: marketing@lowpowersemi.com RTC8563S www.lowpowersemi.com Page 10 of 15 Preliminary Datasheet RTC8563S Sep.-2013 Email: marketing@lowpowersemi.com RTC8563S www.lowpowersemi.com Page 11 of 15 Preliminary Datasheet RTC8563S Device Addressing Before any data is transmitted on the I2C-bus, the device which should respond is addressed first. The addressing is always carried out with the first byte transmitted after the start procedure. The RTC8563S acts as a slave receiver or slave transmitter. Therefore the clock signal SCL is only an input signal, but the data signal SDA is a bidirectional line. The RTC8563S slave address is shown in Table 7. Table 7. Slave address The address byte contains the 7-bit RTC8563S address, which is 1010001, followed by the direction bit (R/W). The R/W bit is a 1 for a read, and a 0 for a write. After receiving and decoding the address byte the device inputs an acknowledge on the SDA line. The RTC8563S then begins to transmit data starting with the register address pointed to by the register pointer. If the register pointer is not written to before the initiation of a read mode the first address that is read is the last one stored in the register pointer. Read/Write Cycles The I2C-bus configuration for the different RTC8563S read and write cycles is shown in Figure 11, Figure 12 and Figure 13. The word address is a 4-bit value that defines which register is to be accessed next. The upper four bits of the word address are not use. RTC8563S Sep.-2013 Email: marketing@lowpowersemi.com www.lowpowersemi.com Page 12 of 15 Preliminary Datasheet RTC8563S Sep.-2013 Email: marketing@lowpowersemi.com RTC8563S www.lowpowersemi.com Page 13 of 15 Preliminary Datasheet RTC8563S Packaging Information RTC8563S Sep.-2013 Email: marketing@lowpowersemi.com www.lowpowersemi.com Page 14 of 15 Preliminary Datasheet RTC8563S Sep.-2013 Email: marketing@lowpowersemi.com RTC8563S www.lowpowersemi.com Page 15 of 15
RTC8563SOF
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光隔离型光电开关,具有高灵敏度和高抗干扰性,适用于工业自动化、机器人、传感器等领域。
3. 引脚分配:EL817共有5个引脚,分别为VCC、GND、OUT、IN1、IN2。
4. 参数特性:工作电压为5V,工作电流为10mA,响应时间为1ms。
5. 功能详解:EL817通过光电转换实现信号隔离,提高系统稳定性和抗干扰能力。
6. 应用信息:广泛应用于工业自动化、机器人、传感器等领域。
7. 封装信息:采用DIP-5封装。
RTC8563SOF 价格&库存
很抱歉,暂时无法提供与“RTC8563SOF”相匹配的价格&库存,您可以联系我们找货
