AW9110BTQR
AW9110BTQR
    AWINIC(艾为)
    TQFN20L
    AW9110BTQR
AW9110BTQR 数据手册
AW9110B Nov. 2017 V1.1 10-LED Driver and GPIO Controller FEATURES GENERAL DESCRIPTION  10-channel LED constant-current driver, each channel can be used for GPIO  OUT0~OUT5 support 2 intelligent breathing mode: BLINK and SMART-FADE, breathing time is adjustable AW9110B is a 10-channel LED controller with I2C interface. Each channel can be used for GPIO. LED dimming combined with extended GPIO function, which can give full play to the application value of single chip.  Support 256 steps linearity dimming, IMAX is 37mA  Support GPIO input/output mode  GPIO input mode, internal 8μs debounce  Standard I2C interface  I2C interface and GPIO can operate at 1.8V  Support shutdown function, low level effective   Simple Voltage Range VCC: 2.5V~5.5V TQFN 3mmX3mmX0.75mm-20L Package AW9110B configures the current level to realize 256 steps linear dimming with I2C interface. The default IMAX current is 37mA. AW9110B strengthens the dropout performance of low 6 channel LED driver and only 60mV current source voltage drop can provide 20mA LED current that can make it more suitable for the driver of LCD backlight. When OUTx(x=0~9) works in a GPIO input mode, AW9110B detected input state to occur interrupt with internal 8μs debounce. AW9110B supports two intelligent breathing modes: BLINK mode and SMART-FADE mode. BLINK mode allows LED automatic to flash periodically according the setting time parameter. OUT0~OUT5 support intelligent breathing mode. APPLICATIONS Mobile Phones/ Portable Media Player AW9110B is available in TQFN3X3-20L package. The operating voltage range is 2.5V~5.5V. Home Appliances TYPICAL APPLICATION CIRCUIT VCCMCU VBAT 4.7kΩ(x2) VCC VCC SCL SDA SHDN MCU GND VBAT RGB OUT0 OUT1 OUT2 RGB OUT3 OUT4 OUT5 AW9110B LED OUT6 AD1 AD0 INTN GND Figure 1 OUT7 OUT8 OUT9 AW9110B Typical Application Circuit All trademarks are the property of their respective owners. www.awinic.com.cn 1 Copyright © 2014 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9110B Nov. 2017 V1.1 1 PIN CONFIGURATION AND TOP MARK SCL AD0 NC OUT9 OUT8 20 19 18 17 16 AW9110B TOP VIEW AW9110B MARKING SDA 1 15 GND VCC 2 14 OUT7 GND 3 13 OUT6 INTN 4 12 OUT5 SHDN 5 11 OUT4 9110B-AW9110BTQR XXXX-Manufactory Trace No OUT3 OUT2 OUT1 AD1 9 10 8 7 6 OUT0 9110B XXXX 2 PIN DEFINITION NO NAME 1 SDA Serial Data I/O for I2C Interface 2 VCC Power Supply 3 GND Power Ground 4 INTN Interrupt Output, Low Active 5 SHDN Shutdown Pin, Low Active 6 AD1 7 OUT0 Defaults to GPIO, LED driver configurable, support intelligence breathing mode. The default state after power on according to the level of AD1/AD0 PIN 8 OUT1 Defaults to GPIO, LED driver configurable, support intelligence breathing mode. The default state after power on according to the level of AD1/AD0 PIN 9 OUT2 Defaults to GPIO, LED driver configurable, support intelligence breathing mode. The default state after power on according to the level of AD1/AD0 PIN 10 OUT3 Defaults to GPIO, LED driver configurable, support intelligence breathing mode. The default state after power on according to the level of AD1/AD0 PIN 11 OUT4 Defaults to GPIO, LED driver configurable, support intelligence breathing mode. The default state after power on according to the level of AD1/AD0 PIN 12 OUT5 Defaults to GPIO, LED driver configurable, support intelligence breathing mode. The default state after power on according to the level of AD1/AD0 PIN 13 OUT6 Defaults to GPIO, LED driver configurable. The default state after power on according to the level of AD1/AD0 PIN 14 OUT7 Defaults to GPIO, LED driver configurable. The default state after power on according to the level of AD1/AD0 PIN 15 GND Power Ground 16 OUT8 Defaults to GPIO, LED driver configurable. The default state after power on according to the level of AD1/AD0 PIN 17 OUT9 Defaults to GPIO, LED driver configurable. The default state after power on according to the level of AD1/AD0 PIN 18 NC NC 19 AD0 I2C Address Pin 20 SCL Serial Clock Input for I2C Interface www.awinic.com.cn DESCRIPTION I2C Address Pin 2 Copyright © 2014 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9110B Nov. 2017 V1.1 3 FUNCTIONAL BLOCK DIAGRAM VCC GND POR INTN Interrupt Logic OSC LP Filter OUT0 OUT1 AD0 AD1 SCL SDA I2C I/F Cfg Register GPIO CTL Register OUT2 OUT3 CURRENT SOURCE LED DRIVE AND GPIO PORT OUT4 OUT5 OUT6 DIMx Register OUT7 OUT8 BLINK OUT9 SMARTFADE AW9110B Figure 2 FUNCTIONAL BLOCK DIAGRAM 4 TYPICAL APPLICATION CIRCUITS 4.1 Using single chip to realize 10-LED breathing or 6 LCD backlight control VCCMCU VBAT 6-LCD Backlight or Breathing LED 4.7kΩ(x2) VCC VCC SCL SDA SHDN MCU GND VBAT 1 2 RGB LED OUT0 OUT1 OUT2 RGB LED OUT3 OUT4 OUT5 AW9110B 4 white or colour breathing LED OUT6 AD1 AD0 INTN GND OUT7 OUT8 OUT9 1. When the anode of LED is connected to VBAT, AD1/AD0 of the chip should be connected to VBAT to ensure the default electricity state of GPIO is high or high resistance and the LED will be off. The default electricity state of GPIO is decided by AD1/AD0 level. 2. In AW9110B, the dropout performance of low 6-leds are strengthened, we suggest www.awinic.com.cn 3 these leds can be used when driving LCD backlight. Copyright © 2014 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9110B Nov. 2017 V1.1 4.2 Using single chip to realize 8-RGB control VBAT VCCMCU 1uF 4.7kΩ(x2) AD1 AD0 INTN GND RGB8 RGB7 RGB6 RGB5 AW9110B RGB4 1 RGB3 GND SCL SDA SHDN RGB2 MCU VCC OUT6 OUT7 OUT8 OUT9 RGB1 VCC OUT0 OUT1 OUT2 OUT3 OUT4 OUT5 1.When choosing this application, we must pay attention to the restrictions of light effect. If we need the led turn on at the same time and they are different color type, the led cathode cannot be connected to the same OUTx pin. Because the Vf of RGB is different; When we turn on RGB1 and RGB4 at the same time, RGB2 and RGB3 will be turned on. Because the anode and cathode of RGB1/2/3/4 are all on. So pay attention to the lighting effects when designing the hardware. www.awinic.com.cn 4 Copyright © 2014 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9110B Nov. 2017 V1.1 4.3 Using two chips to realize driving more LED VBAT VCCMCU 1uF RGB4 RGB5 RGB6 RGB7 RGB8 RGB5 RGB6 RGB7 RGB8 1 RGB4 AW9110B RGB3 GND RGB3 MCU VCC OUT6 OUT7 SCL OUT8 SDA OUT9 SHDN RGB2 4.7kΩ(x2) RGB1 VCC OUT0 OUT1 AD1 OUT2 AD0 OUT3 OUT4 INTN OUT5 GND VBAT 1uF 1 AD1 AD0 INTN GND RGB1 AW9110B RGB2 VCC OUT6 OUT7 SCL OUT8 SDA SHDN OUT9 OUT0 OUT1 OUT2 OUT3 OUT4 OUT5 1. The AD configurations are different, so 2 AW9110B can share the same I 2C bus. 2. When configuring the connection of AD1/AD0, the default electricity state of OUTx pin must be considered to avoid led on directly after AW9110B power on. www.awinic.com.cn 5 Copyright © 2014 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9110B Nov. 2017 V1.1 5 ORDERING INFORMATION Part Number Temperature Package Marking MSL Level ROHS Delivery Form AW9110BTQR -40℃~85℃ 3mm×3mm× 0.75mm AW9110B MSL3 ROHS+HF 6000 units/ Tape and Reel AW9110B Shipping R:Tape & Reel Package type TQ:Thin QFN 6 ABSOLUTE MAXIMUM RATINGS(NOTE 1) Parameter Range Supply Voltage range VCC -0.3V to 6 V SCL,SDA,AD0,AD1,INTN,SHDN,OUT0-9 PINS voltage range -0.3V to VCC Max power dissipation (PDmax,package@ TA=25℃) 3.2 W Package thermal resistance θJA 49℃/W Maximum Junction temperature TJmax 125℃ Storage temperature range -65℃ to 150℃ Lead temperature (Sodering 10 Seconds) 260℃ (2) ESD HBM(All Pins) 8000V Latch-up Test Condition:JEDEC STANDARD NO.78A FEBURARY 2006 +IT:+450mA -IT:-450mA NOTE1: Conditions out of those ranges listed in "absolute maximum ratings" may cause permanent damages to the device. In spite of the limits above, functional operation conditions of the device should within the ranges listed in "recommended operating conditions". Exposure to absolute-maximum-rated conditions for prolonged periods may affect device reliability. NOTE2: The human body model is a 100pF capacitor discharged through a 1.5kΩ resistor into each pin. Test method: MIL-STD-883G Method 3015.7 www.awinic.com.cn 6 Copyright © 2014 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9110B Nov. 2017 V1.1 7 ELECTRICAL CHARACTERISTICS Vcc=3.8V, TA=25℃ for typical values (unless otherwise noted) PARAMETER TEST CONDITION MIN 2.4 TYPE MAX UNIT 5.5 V Power supply voltage and current VCC Input voltage TA=-40℃~85℃ VPOR Power on reset voltage TA=-40℃~85℃ 1.8 2.3 V SHDN=0V,VIO=0V 0.1 2 μA ISHUTDOWN Current in Shutdown mode SHDN=0V,VIO=1.8V 8.5 uA SHDN=1.8V,VIO=1.8V 80 μA 80 μA 13 uA 2.1 mA VCC=2.5V,ISOURCE=10mA VCC-170 mV VCC=3.6V,ISOURCE=20mA VCC-250 mV VCC=5V,ISOURCE=20mA VCC-200 mV VCC=2.5V,ISINK=20mA 90 mV VCC=3.6V,ISINK=20mA 70 mV VCC=5V,ISINK=20mA 60 mV VCC=2.5V,ISINK=6mA 150 mV VCC=3.6V,ISINK=6mA 100 mV VCC=5V,ISINK=6mA 75 mV ISTANDBY Current in Standby mode GPMD_A=0x3F, GPMD_B=0x0F, GPIO_CFG_A=0x3F, GPIO_CFG_B=0x0F, AD1=AD2=1.8V Current in GPIO mode GPMD_A=0x3F, GPMD_B=0x0F, IACTIVE GPIO_CFG_A=0x00, GPIO_CFG_B=0x00, GPIO_OUTPUT_A=0x3F, GPIO_OUTPUT_B=0x0F, GPMD_A=0x00, GPMD_B=0x00 Current in LED mode ISEL=3, DIMx=0xFF Digital output VOH Output high level(OUT0~9) Output low level(OUT0~9) VOL Output low level (SDA,INTN) Digital input VIH Logic high level (SCL,SDA,SHDN,AD0,AD1,OUT0~9) VIL Logic low level (SCL,SDA,SHDN,AD0,AD1,OUT0~9) IIH,IIL Input current (SCL,SDA,AD0,AD1,OUT0~9) R_SHDN Resistant of shutdown pin CI Input capacitor (SCL,SDA,SHDN,AD0,AD1,OUT0~9) tSP_SHDN 1.4 VI=VCC or GND V -0.2 0.4 V +0.2 μA 100k Ω VI=VCC or GND 3 pF Low burr pulse width SHDN=VCC 10 μs Current Source ISEL=0,DIMx=FFH 37 mA Low-6(OUT0~5)output voltage drop IOUT=21mA,ISEL=01,DIMx=C0H 60 200 mV IOUT=21mA,ISEL=01,DIMx=C0H 80 250 mV LED driver ILED Vdrop1 Vdrop2 High-4(OUT6~9)output voltage drop www.awinic.com.cn 7 Copyright © 2014 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9110B Nov. 2017 V1.1 8 I2C INTERFACE TIMING Parameter Symbol MIN TYP fSCL Interface Clock frequency MAX UNIT 400 kHz tHD:STA 0.6 μS Low level width of SCL tLOW 1.3 μS High level width of SCL tHIGH 0.6 μS (Repeat-start) Start condition setup time tSU:STA 0.6 μS Data hold time tHD:DAT 0 μS Data setup time tSU:DAT 0.1 μS (Repeat-start) Start condition hold time Rising time of SDA and SCL tR 0.3 μS Falling time of SDA and SCL tF 0.3 μS tSU:STO 0.6 Time between start and stop condition tBUF 1.3 Maximum width noise input filter out(burr) tSP 0 Capacitor of the bus Cb Stop condition setup time μS 50 nS 400 pF VIH SDA VIL tBUF tLOW tHIGH tR tSP tF VIH SCL VIL Stop www.awinic.com.cn tHD:STA Start tHD:DAT 8 tSU:DAT tSU:STA Start tSU:STO Stop Copyright © 2014 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9110B Nov. 2017 V1.1 9 FUNCTIONAL DESCRIPTION AW9110B is a 10 channel co-anode current breathing led driver. There is 256 current levels configurable via register CTL.ISEL. The maximum driver current IMAX is 37mA. The led drivers and GPIO functions can be switch with configuring register GPMD_A/GPMD_B. The default status of OUT0~OUT9 are used for GPIO function. AW9110B supports two types of intelligent breathing modes: BLINK and SMART-FADE. In BLINK mode, AW9110B completes "fade-on" and "fade off" breathing periodically. In SMART-FADE mode, AW9110B runs "fade-on" and "fade off" independently with register GPIO_OUTPUT_A/GPIO_OUTPUT_B configuration. 9.1 SHUTDOWN AND RESET AW9110B enters shutdown mode when SHDN is low level. When SHDN is pulled up from shutdown state, AW9110B enters standby mode and will be reset to the default state. AW9110B offers two kinds of reset function:  Power on reset -- 5ms after power on, the chip is reset to the default state.  Hardware reset – keep SHDN low level over 20 μs, reset all internal circuit.  Software reset -- write 00H to register 7FH, reset all internal circuit. When AW9110B is reset, the default state of OUTx pin is GPIO. 9.2 LED DIMMING FUNCTION AW9110B led driver uses co-anode current source. In default status, the maximum driving current IMAX is 37mA. After power on, OUTx(x=0~9) used for GPIO. AW9110B can switch OUTx to led driver mode with configuring GPMD_A and GPMD_B, shown in table 4&5. AW9110B configures four dimming range by ISEL[1:0], 0~IMAX(default), 0~(3/4)IMAX, 0~(2/4)IMAX or 0~(1/4)IMAX, which means 256 steps dimming range: 0~37mA(default),0~27.75mA, 0~18.5mA or 0~9.25mA. ISEL[1:0] configuration is refer to table 3. The dimming level of each channel is configured by DIMx(x=0~9) register. 8-bits DIMx can be configured to 256 levels, from 00H to FFH. DIMx bit Dimming level 7 6 5 4 3 2 1 0 0 0 0 0 0 0 0 0 OFF 0 0 0 0 0 0 0 1 1/255×IMAX 0 0 0 0 0 0 1 0 2/255×IMAX …… …… 1 1 1 1 1 1 0 1 253/255×IMAX 1 1 1 1 1 1 1 0 254/255×IMAX 1 1 1 1 1 1 1 1 255/255×IMAX www.awinic.com.cn 9 Copyright © 2014 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9110B Nov. 2017 V1.1 9.3 GPIO FUNCTION When AW9110B is used in GPIO, the direction of OUTx is configured by GPIO_CFG_A/GPIO_CFG_B (table14, 15). When OUTx is configured to output, write GPIO_OUTPUT_A or GPIO_OUTPUT_B register (table12, 13) driver high or low level. The following table shows OUTx default output driving value after power on. AD1 AD0 OUT9 OUT8 OUT7 OUT6 OUT5 OUT4 OUT3 OUT2 OUT1 OUT0 GND GND 0 0 0 0 0 0 0 0 0 0 GND VCC 0 0 Hi-Z Hi-Z Hi-Z Hi-Z 1 1 1 1 VCC GND Hi-Z Hi-Z 0 0 0 0 0 0 0 0 VCC VCC Hi-Z Hi-Z Hi-Z Hi-Z Hi-Z Hi-Z 1 1 1 1 When OUTx is configured to input mode, the logic level of OUTx can be acquired with reading GPIO_INPUT_A or GPIO_INPUT_B register (table 10, 11). AW9110B can support 1.8V level logic. OUT0~OUT3 are default to PUSH-PULL driver. OUT4~OUT9 are default to OPEN-DRAIN driver and can be configured as PUSH-PULL driver with GPOMD (table 3). 9.4 INTERRUPT FUNCTION When OUTx is used for GPIO input, AW9110B detects the input state and produces interrupt request. Low level of INTN is active. INTN should be connected to pull-up resistor. AW9110B has built-in debounce filter. The input state with 8μs low-pass filter will be steady. The interrupt request will not be produced when input state changes in 8μs. In default status, GPIO interrupt is enabled (GPIO_INTN_A or GPIO_INTN_B setting, table16,17). Only enable interrupt function and configured to GPIO input mode, the interrupt will be produced on INTN. Clear the interrupt by reading register GPIO_INPUT_A, GPIO_INPUT_B register. The interrupt of OUT4~OUT9 only be cleared by read GPIO_INPUT_A register. The interrupt of OUT0~OUT3 only be cleared by read GPIO_INPUT_B register. The interrupts status can't be cleared by the other group. When AW9110B produces the interrupt request, the interrupt request will be reserved until reading GPIO_INPUT_A or GPIO_INPUT_B GPIO. The interrupt will be not cleared even if AW9110B switches to GPIO output, or disable GPIO interrupt function. 8μs remove jitter Remove interrupt timing OUT4~OUT9 INTN I2C BUS www.awinic.com.cn Read GPIO_INPUT_A Register 10 Copyright © 2014 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9110B Nov. 2017 V1.1 9.5 BLINK BREATHING MODE OUT0~OUT5 of AW9110B supports BLINK breathing mode. In this mode, AW9110B will complete periodic blink effect automatically until exit the BLINK mode or close breathing function. 1. Configure OUTx to led driver mode. According to application situation, set register EN_BRE to enable breathing mode. Set GPIO_CFG_A/B (Table 14,15,pay attention to the switch of GPIO and breathing function) to open BLINK function. 2. Configure the timing parameter for BLINK breathing effects: 3.  Blink delay——DLY_TMR(Table 9). When enable the BLINK mode, leds start blink after DLY_TMR time.  Fade-on process——FDON_TMR(Table 7). The time of fade-on effect has 6 kinds of choice (0ms~5040ms). The fade-on has 64 step dimming level and led turns on gradually from dark.  Full on process——FLON_TMR(Table 8). Full on state has 8 kinds of choice(0ms~20160ms). the led driving current of this period is decided by ISEL[1:0].  Fade-off process——FDOFF_TMR(Table 7). The time of fade-off effect has 6 kinds of choice (0ms~5040ms). The fade-off has 64 step dimming level and led turns off gradually from bright.  Full off process——FLOFF_TMR(Table 8). Full off state has 8 kinds of choice(0ms~20160ms). The led driving current is 0 in this period. After setting blinking parameter, enable GO control bit and the led in BLINK mode starts blink periodically and automatically. DLY_BRE of 6 channel, the parameter of BLINK mode, is independent configuration, which can make led be opened in turn. The fade-on/ fade-off/ full-on/ full-off parameter are same and can be modified at any time. The new configuration will be adjusted in the next breathing period. AW9110B exits BLINK mode by disable GPIO_CFG_A/B corresponding bit or disable EN_BRE setting. The difference is AW9110B will exit BLINK immediately by disable EN_BRE, but we must wait it complete breathing period by another one. repeat cycle 1 cycle Imax FDON_TMR FLON_TMR FLOFF_TMR FDOFF_TMR GO DLY0_TMR DLY1_TMR DLY2_TMR DLY3_TMR DLY4_TMR DLY5_TMR www.awinic.com.cn 11 Copyright © 2014 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9110B Nov. 2017 V1.1 9.6 SMART-FADE MODE The SMART-FADE mode of AW9110B is semi-automatic breathing, which will simplify 64 steps fade-on and fade-off interface operation into 1bit writing operation: Writing ’1’ means fade-on process and remaining all bright; Writing ’0’ means fade-off process and remaining all dark. Configure SMART-FADE mode: 1. Set EN_BRE register and open breathing mode according to the application; 2. Set GPIO_CFG_A/B (View table 14,15, pay attention to the switch of GPIO and breathing function), SMART-FADE mode is default; 3. Set GPIO_OUTPUT_A/B bit to complete fade-on or fade-off (View table 12,13, pay attention to the switch of GPIO and breathing function). The time of fade-on and fade-out in SMART-FADE mode is controlled by FDON_TMR and FDOFF_TMR. AW9110B exits SMART-FADE mode by disable EN_BRE. I2C interface operation Configurate OUTx into LED driver EN_BRE set FDON_TMR set FDOFF_TMR write GPIO_OUTPUT_A 01H write GPIO_OUTPUT_A 00H All bright OUT4 driving current All dark FDON_TMR www.awinic.com.cn 12 FDOFF_TMR Copyright © 2014 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9110B Nov. 2017 V1.1 10 I2C INTERFACE AW9110B supports the I²C serial bus and data transmission protocol in fast mode at 400 KHz. AW9110B operates as a slave on the I²C bus. Connections to the bus are made via the open-drain I/O pins SCL and SDA. The pull-up resistor can be selected in the range of 1k~10kΩ and the typical value is 4.7kΩ. AW9110B can support different high level (1.8V~3.3V) of this I2C interface. 10.1 Start and Stop Condition I2C start: SDA changes form high level to low level when SCL is high level. I2C stop: SDA changes form low level to high level when SCL is high level. SDA SCL S/Sr S: start condition Sr:repeat start condition P:stop condition 10.2 Data Transmission After the start condition, I2C bus sent an address of slave. AW9110B wait to receive slave address When receiving start condition. If the address from I2C bus is same as the address of AW9110B, the slave pull SDA to acknowledge. 10.3 Data Validity When SCL is in high level, SDA must remain one level stationary .Except start condition and stop condition, SDA level can change just in low level of SCL. www.awinic.com.cn 13 Copyright © 2014 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9110B Nov. 2017 V1.1 SDA SCL Data line stable Data effective Data allowed to change 10.4 Acknowledge ACK means the successful transfer of I2C bus data. After master sends 8bits data, SDA must be released; SDA is pulled to GND by slave device when slave acknowledges. When master reads, slave device sends 8bit data, releases the SDA and waits for ACK from master. If ACK is sent and I2C stop is not sent by master, slave device sends the next data. If ACK is not sent by master, slave device stops to send data and waits for I2C stop. Data Output Sender No Answer (NACK) Data Output Receiver Answer(ACK) Host Send Clock 2 1 8 9 Answer Clock Start Condition 10.5 Address AW9110B supply two address pins AD1,AD0. This allows single I2C bus can use four AW9110B at the same time. The high five bit of slave address is “10110”, the bit2 is AD1, and the bit1 is AD0. The bit0(LSB) is writing and reading flag bit, which define the next operation writing or reading. ‘1’ is read and ‘0’ is write. 1 0 1 1 0 AD1 AD0 R/W (The value of AD1 and AD0 is same as AD1 and AD0 PIN) www.awinic.com.cn 14 Copyright © 2014 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9110B Nov. 2017 V1.1 10.6 Writing Operation One data bit is transferred during each clock pulse. Data is sampled during the high state of the serial clock (SCL). Consequently, throughout the clock’s high period, the data should remain stable. Any changes on the SDA line during the high state of the SCL and in the middle of a transaction, aborts the current transaction. New data should be sent during the low SCL state. This protocol permits a single data line to transfer both command/control information and data using the synchronous serial clock. Each data transaction is composed of a Start Condition, a number of byte transfers (set by the software) and a Stop Condition to terminate the transaction. Every byte written to the SDA bus must be 8 bits long and is transferred with the most significant bit firstly. After each byte, an Acknowledge signal must follow. In a write process, the following steps should be followed: 1) Master device generates START condition. The “START” signal is generated by lowering the SDA signal while the SCL signal is high. 2) Master device sends slave address (7-bit) and the data direction bit (w = 0). 3) Slave device sends acknowledge signal if the slave address is correct. 4) Master sends control register address (8-bit) 5) Slave sends acknowledge signal 6) Master sends 8Bit data to be written to the addressed register 7) Slave sends acknowledge signal 8) Master generates STOP condition to indicate write cycle end SC L SD A 1 1 2 0 3 4 5 7bits slave address 1 1 0 6 7 8 9 1 2 3 4 5 6 7 8 9 1 2 3 Register address AD1 AD0 Start condition 0 A MSB 4 6 7 8 9 Register data LSB A MSB AW9110B answer AW9110B answer 5 It is reply clock from 8th clock rising edge to 9th cloCk falling edge;AW9110B pull-down SDA to answer, the host must release SDA, if not ,the leakage of electric will appear in this period. LSB A AW9110B answer Stop condition 10.7 Reading Operation In a read cycle, the following steps should be followed: 1) Master device generates START condition 2) Master device sends slave address (7-bit) and the data direction bit (w = 0). 3) Slave device sends acknowledge signal if the slave address is correct. 4) Master sends control register address (8-bit) 5) Slave sends acknowledge signal 6) Master generates STOP condition followed with START condition or REPEAT START condition 7) Master device sends slave address (7-bit) and the data direction bit (r = 1). www.awinic.com.cn 15 Copyright © 2014 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9110B Nov. 2017 V1.1 8) Slave device sends acknowledge signal if the slave address is correct. 9) Slave sends 8Bit data from addressed register. 10) Master sends acknowledge signal 11) If the master device sends acknowledge signal, the slave device will increase the control register address by one, then send the next data from the new addressed register. If master sends no acknowledge signal, the slave device stop to send data and wait for STOP condition. 12) If the master device generates STOP condition, the read cycle is ended. SCL 1 2 3 4 5 6 7 8 9 7bits slave address SDA 1 0 1 1 0 1 2 3 AW9110B answer AD1 AD0 0 4 5 6 Register address A MSB 7 8 9 1 2 S 4 5 6 7 8 9 1 A 7bits slave address AW9110B answer LSB A 3 1 0 1 1 0 AD1 AD0 Repeat start condition Start condition 1 Host is the data receiver this time;AW9110B is the sender . MSB 2 3 AW9110B answer 4 5 6 Reading data 7 8 9 LSB NA Host do not answer Stop condition 11 REGISTER DESCRIPTION 11.1 REGISTER OVERVIEW Table 1. AW9110B registers list Addr (HEX) W/R Defaut Value Function Description (HEX) 00H R xxH GPIO_INPUT_A OUT4~OUT9 port GPIO input state 01H R xxH GPIO_INPUT_B OUT0~OUT3 port GPIO input state 02H W/R Depend on AD1/ AD0 GPIO_OUTPUT_A OUT4~OUT9 port GPIO output state; Depend on AD1/ AD0 GPIO_OUTPUT_B 00H GPIO_CFG_A 03H 04H W/R W/R www.awinic.com.cn In SMART-FADE mode, OUT4~OUT5 can be used for “fade-on” and “fade-off” dimming control. OUT0~OUT3 port GPIO output state; In SMART-FADE mode, OUT0~OUT3 can be used for “fade-on” and “fade-off” dimming control. 16 OUT4 ~ OUT9 port GPIO input and output direction control; Copyright © 2014 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9110B Nov. 2017 V1.1 In breathing mode, control OUT4~OUT5 to enter into BLINK mode or SMART-FADE mode. 05H W/R 00H GPIO_CFG_B OUT0 ~ OUT3 port GPIO input and output direction control; In breathing mode, control OUT0~OUT3 to enter into BLINK mode or SMART-FADE mode. 06H W/R 00H GPIO_INTN_A OUT4~OUT9 enable interrupt function 07H W/R 00H GPIO_INTN_B OUT0~OUT3 enable interrupt function 08H~10H - - - Reserved 11H W/R 00H CTL Global Control 12H W/R FFH GPMD_A Switch OUT4~OUT9 LED driver mode or GPIO mode 13H W/R FFH GPMD_B Switch OUT0~OUT3 LED driver mode or GPIO mode 14H W/R 00H EN_BRE Enable LED breathing mode 15H W/R 00H FADE_TMR In BLINK or SMART-FADE mode, LED “fade-on” or “fade-off” time parameter 16H W/R 00H FULL_TMR In BLINK mode, LED light all on or all off time parameter 17H W/R 00H DLY0_BRE In BLINK mode,OUT0 blink delay time before start 18H W/R 00H DLY1_BRE In BLINK mode,OUT1 blink delay time before start 19H W/R 00H DLY2_BRE In BLINK mode,OUT2 blink delay time before start 1AH W/R 00H DLY3_BRE In BLINK mode,OUT3 blink delay time before start 1BH W/R 00H DLY4_BRE In BLINK mode,OUT4 blink delay time before start 1CH W/R 00H DLY5_BRE In BLINK mode,OUT5 blink delay timer before start 1DH~1FH - - - Reserve 20H W 00H DIM0 OUT0 port 256 steps dimming control 21H W 00H DIM1 OUT1 port 256 steps dimming control 22H W 00H DIM2 OUT2 port 256 steps dimming control 23H W 00H DIM3 OUT3 port 256 steps dimming control 24H W 00H DIM4 OUT4 port 256 steps dimming control 25H W 00H DIM5 OUT5 port 256 steps dimming control 26H W 00H DIM6 OUT6 port 256 steps dimming control 27H W 00H DIM7 OUT7 port 256 steps dimming control 28H W 00H DIM8 OUT8 port 256 steps dimming control www.awinic.com.cn 17 Copyright © 2014 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9110B Nov. 2017 V1.1 29H W 00H DIM9 OUT9 port 256 steps dimming control 2AH~7EH - - - Reserve 7FH W 00H RESET Write 00H,reset by software 11.2 REGISTER DETAIL Table 2. DIM0~DIM9(20H~29H),256 steps dimming configuration register Bit Symbol Description Default D[7:0] DIM 256 steps dimming level choice 00H 20H~29H corresponding to OUT0~OUT9 dimmer instruction; D[7:0] code from 0 to 255 corresponding to the current 0~IMAX Table 3. CTL(11H),Global control register Bit Symbol Description Default D7 GO Writing 1 to enable breathing in BLINK mode. 0 D[6:5] - - Remain D4 GPOMD OUT4~OUT9 driver option in GPIO application: 0 0:OPEN-DRAIN 1:PUSH-PULL D[3:2] - - Remain D[1:0] ISEL 256 dimming range option 00 00:0~37mA 01:0~27.75mA 10:0~18.5mA 11:0~9.25mA Table 4. GPMD_A(12H), GPIO control switch to LED driver register Bit Symbol Description Default D[7:6] - - Remain D5 GPMD_A5 OUT9 mode control 1 0:LED mode 1:GPIO mode D4 GPMD_A4 OUT8 mode control 1 0:LED mode www.awinic.com.cn 18 Copyright © 2014 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9110B Nov. 2017 V1.1 1:GPIO mode D3 GPMD_A3 OUT7 mode control 1 0:LED mode 1:GPIO mode D2 GPMD_A2 OUT6 mode control 1 0:LED mode 1:GPIO mode D1 GPMD_A1 OUT5 mode control 1 0:LED mode 1:GPIO mode D0 GPMD_A0 OUT4 mode control 1 0:LED mode 1:GPIO mode Table 5. GPMD_B(13H), GPIO control switch to LED driver register Bit Symbol Description Default D[7:4] - - Remain D3 GPMD_B3 OUT3 mode control 1 0:LED mode 1:GPIO mode D2 GPMD_B2 OUT2 mode control 1 0:LED mode 1:GPIO mode D1 GPMD_B1 OUT1 mode control 1 0:LED mode 1:GPIO mode D0 GPMD_B0 OUT0 mode control 1 0:LED mode 1:GPIO mode Table 6. EN_BRE(14H),EN_BREATHING REGISTER Bit Symbol Description Default D[7:6] - - Remain www.awinic.com.cn 19 Copyright © 2014 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9110B Nov. 2017 V1.1 D5 EN_BRE5 OUT5 enable breath mode 0 0:disable 1:enable D4 EN_BRE4 OUT4 enable breath mode 0 0:disable 1:enable D3 EN_BRE3 OUT3 enable breath mode 0 0:disable 1:enable D2 EN_BRE2 OUT2 enable breath mode 0 0:disable 1:enable D1 EN_BRE1 OUT1 enable breath mode 0 0:disable 1:enable D0 EN_BRE0 OUT0 enable breath mode 0 0:disable 1:enable Table 7. FADE_TMR(15H),Fade-on or fade-off time setting register in BLINK or SMART-FADE Bit Symbol Description Default D[7:6] - - Remain D[5:3] FDOFF_TMR Fade-off time setting 000 000:0ms 001:315ms 010:630ms 011:1260ms 100:2520ms 101:5040ms 110/111:0ms D[2:0] FDON_TMR Fade-on time setting 000 000:0ms 001:315ms 010:630ms www.awinic.com.cn 20 Copyright © 2014 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9110B Nov. 2017 V1.1 011:1260ms 100:2520ms 101:5040ms 110/111:0ms Table 8. FULL_TMR(16H),All-on or all-off time setting register in BLINK mode. Bit Symbol Description Default D[7:6] - - Remain D[5:3] FLOFF_TMR All-off time setting 000 000:0ms 001:315ms 010:630ms 011:1260ms 100:2520ms 101:5040ms 110:10080ms 111:20160ms D[2:0] FLON_TMR All-on time setting 000 000:0ms 001:315ms 010:630ms 011:1260ms 100:2520ms 101:5040ms 110:10080ms 111:20160ms Table 9. DLY0_BRE~DLY5_BRE(17H~1CH),delay to breath time setting register in BLINK Bit Symbol Description Default D[7:0] DLY_TMR Start time to delay breathing in BLINK mode 00H 00H:0ms 01H:315ms …… FFH:80640ms (per 1 unit: 315ms) www.awinic.com.cn 21 Copyright © 2014 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9110B Nov. 2017 V1.1 Table 10. GPIO_INPUT_A(00H),GPIO input state register Bit Symbol Description Default D[7:6] - - Remain D5 GPIO_INPUT_A5 OUT9 pin state x 0:Low level 1:High level D4 GPIO_INPUT_A4 OUT8 pin state x 0:Low level 1:High level D3 GPIO_INPUT_A3 OUT7 pin state x 0:Low level 1:High level D2 GPIO_INPUT_A2 OUT6 pin state 0:Low level 1:High level D1 GPIO_INPUT_A1 OUT5 pin state x 0:Low level 1:High level D0 GPIO_INPUT_A0 OUT4 pin state x 0:Low level 1:High level Table 11. GPIO_INPUT_B(01H),GPIO input state register Bit Symbol Description Default D[7:4] - - Remain D3 GPIO_INPUT_B3 OUT3 pin state x 0:Low level 1:High level D2 GPIO_INPUT_B2 OUT2 pin state x 0:Low level 1:High level D1 GPIO_INPUT_B1 OUT1 pin state x 0:Low level www.awinic.com.cn 22 Copyright © 2014 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9110B Nov. 2017 V1.1 1:High level D0 GPIO_INPUT_B0 OUT0 pin state x 0:Low level 1:High level Table 12. GPIO_OUTPUT_A(02H),GPIO output state register or as driver control in SMART-FADE mode Bit Symbol Description Default D[7:6] - - Remain D5 GPIO_OUTPUT_A5 Driving OUT9 pin state Decided to AD0 and AD1 0:Low level 1:High level D4 GPIO_OUTPUT_A4 Driving OUT8 pin state 0:Low level 1:High level D3 GPIO_OUTPUT_A3 Driving OUT7 pin state 0:Low level 1:High level D2 GPIO_OUTPUT_A2 Driving OUT6 pin state 0:Low level 1:High level D1 GPIO_OUTPUT_A1 GPMD_A1=1,as driving OUT5 pin state 0:Low level 1:High level GPMD_A1=0 & EN_BRE5=1, OUT5 in SMART-FADE mode 0->1:fade-on 1->0:fade-off D0 GPIO_OUTPUT_A0 GPMD_A0=1,as OUT4 pin state 0:Low level 1:High level GPMD_A0=0 & EN_BRE4=1, OUT4 in SMART-FADE mode 0->1:fade-on 1->0:fade-off www.awinic.com.cn 23 Copyright © 2014 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9110B Nov. 2017 V1.1 Table 13. GPIO_OUTPUT_B(03H),GPIO output state register or as driver control in SMART-FADE mode Bit Symbol Description Default D[7:4] - - Remain D3 GPIO_OUTPUT_B3 GPMD_B3=1,as driving OUT3 pin state Decided to AD0 and AD1 0:Low level 1:High level GPMD_B3=0 & EN_BRE3=1,OUT3 in SMART-FADE mode 0->1:fade-on control 1->0:fade-off control D2 GPIO_OUTPUT_B2 GPMD_B2=1, as driving OUT2 pin state 0:low level 1:high level GPMD_B2=0 & EN_BRE2=1,OUT2 in SMART-FADE mode 0->1:fade-on control 1->0:fade-off control D1 GPIO_OUTPUT_B1 GPMD_B1=1, as driving OUT1 pin state 0:low level 1:high level GPMD_B1=0 & EN_BRE1=1,OUT1 in SMART-FADE mode 0->1:fade-on control 1->0:fade-off control D0 GPIO_OUTPUT_B0 GPMD_B0=1, as driving OUT0 pin state 0:low level 1:high level GPMD_B0=0 & EN_BRE0=1,OUT0 in SMART-FADE mode 0->1:fade-on 1->0:fade-off Table 14. GPIO_CFG_A(04H),GPIO input or output select register or as BLINK,SMART-FADE Mode select Bit Symbol www.awinic.com.cn Description 24 Default Copyright © 2014 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9110B Nov. 2017 V1.1 D[7:6] - - Remain D5 GPIO_ CFG _A5 OUT9 input or output selection 0 0:output 1:input D4 GPIO_ CFG _A4 OUT8 input or output selection 0 0:output 1:input D3 GPIO_ CFG _A3 OUT7 input or output selection 0 0:output 1:input D2 GPIO_ CFG _A2 OUT6 input or output selection 0 0:output 1:input D1 GPIO_ CFG _A1 GPMD_A1=1, OUT5 input or output choice 0 0:output 1:input GPMD_A1=0 & EN_BRE5=1, OUT5 BLINK or SMART-FADE mode choice 0:SMART-FADE mode 1:BLINK mode D0 GPIO_ CFG _A0 GPMD_A0=1, OUT4 input or output choice 0 0:output 1:input GPMD_A0=0 & EN_BRE4=1, OUT4 BLINK or SMART-FADE mode choice 0:SMART-FADE mode 1:BLINK mode Table 15. GPIO_CFG_B(05H),GPIO input or output selection register, or used for BLINK,SMARTFADE mode choice Bit Symbol Description Default D[7:4] - - Remain D3 GPIO_ CFG _B3 GPMD_B3=1 , OUT3 input or output choice 0 0:output www.awinic.com.cn 25 Copyright © 2014 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9110B Nov. 2017 V1.1 1:input GPMD_B3=0 & EN_BRE3=1, OUT3 BLINK or SMART-FADE mode choice 0:SMART-FADE mode 1:BLINK mode D2 GPIO_ CFG _B2 GPMD_B2=1, OUT2 input or output choice 0 0:output 1:input GPMD_B2=0 & EN_BRE2=1, OUT2 BLINK or SMART-FADE mode choice 0:SMART-FADE 1:BLINK D1 GPIO_ CFG _B1 GPMD_B1=1, OUT1 input or output choice 0 0:output 1:input GPMD_B1=0 & EN_BRE1=1, OUT1 BLINK or SMART-FADE mode choice 0:SMART-FADE mode 1:BLINK mode D0 GPIO_ CFG _B0 GPMD_B0=1, OUT0 input or output choice 0 0:output 1:input GPMD_B0=0 EN_BRE0=1, OUT0 BLINK or SMART-FADE mode choice 0:SMART-FADE mode 1:BLINK mode Table 16. GPIO_INTN_A(06H),GPIO Enable Interrupt Register Bit Symbol Description Default D[7:6] - - Remain D5 GPIO_ INTN _A5 OUT9 enable interrupt 0 0:enable 1:disable www.awinic.com.cn 26 Copyright © 2014 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9110B Nov. 2017 V1.1 D4 GPIO_ INTN _A4 OUT8 enable interrupt 0 0:enable 1:disable D3 GPIO_ INTN _A3 OUT7 enable interrupt 0 0:enable 1:disable D2 GPIO_ INTN _A2 OUT6 enable interrupt 0 0:enable 1:disable D1 GPIO_ INTN _A1 OUT5 enable interrupt 0 0:enable 1:disable D0 GPIO_ INTN _A0 OUT4 enable interrupt 0 0:enable 1:disable Table 17. GPIO_INTN_B(07H),GPIO Enable Interrupt Register Bit Symbol Description Default D[7:4] - - Remain D3 GPIO_ INTN _B3 OUT3 enable interrupt 0 0:enable 1:disable D2 GPIO_ INTN _B2 OUT2 enable interrupt 0 0:enable 1:disable D1 GPIO_ INTN _B1 OUT1 enable interrupt 0 0:enable 1:disable D0 GPIO_ INTN _B0 OUT0 enable interrupt 0 0:enable 1:disable www.awinic.com.cn 27 Copyright © 2014 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9110B Nov. 2017 V1.1 12 TAPE AND REEL INFORMATION 12.1 Carrier Tape 12.2 PIN1 Direction User Direction of Feed www.awinic.com.cn 28 Copyright © 2014 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9110B Nov. 2017 V1.1 12.3 Reel Notes: 1. 2. 3. 4. 5. Material: polystyrene Flatness: maximum permissible 3mm All dimensions are in millimeters Surface resistivity: 105 to 1011 ohms/sq or less All unmarked tolerance: ±0.5 www.awinic.com.cn 29 Copyright © 2014 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9110B Nov. 2017 V1.1 13 PACKAGE DESCRIPTION PIN 1# DOT BY MARKING 1.650±0.050 Exp.DAP 3.000±0.050 PIN 1# IDENTIFICATION CHAMFER C0.300x45º 0.400±0.050 3.000±0.050 TQFN-20L (3 X 3mm) 1.650±0.050 Exo.DAP 0.400 Bsc 0.200±0.050 1.600 Ref. TOP VIEW BOTTOM VIEW 0.203 Ref. 0.750±0.050 0.000-0.050 SIDE VIEW 14 RECOMMENDED LAND PATTERN 0.3 0.3 4X(1.1) 4X(0.825) 20X(0.5) 20X(0.2) 16X(0.4) TOP VIEW www.awinic.com.cn 30 Copyright © 2014 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9110B Nov. 2017 V1.1 15 REFLOW Reflow profile Figure 17 Package Reflow Oven Thermal Profile Parameters for classification reflow profile Note: 1. All of the temperature parameters are measured from the top of package; 2、AW9817 is suitable for Pb-Free assembly. www.awinic.com.cn 31 Copyright © 2014 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9110B Nov. 2017 V1.1 16 REVISION HISTORY Vision Date V1.0 March 2017 V1.1 Nov. 2017 www.awinic.com.cn Revision Record First officially release Update the electrical characteristics Update the ordering information Add the recommended land pattern 32 Copyright © 2014 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9110B Nov. 2017 V1.1 17 DISCLAIMER Information in this document is believed to be accurate and reliable. However, Shanghai AWINIC Technology Co., Ltd (AWINIC Technology) does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. AWINIC Technology reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. Customers shall obtain the latest relevant information before placing orders and shall verify that such information is current and complete. This document supersedes and replaces all information supplied prior to the publication hereof. AWINIC Technology products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an AWINIC Technology product can reasonably be expected to result in personal injury, death or severe property or environmental damage. AWINIC Technology accepts no liability for inclusion and/or use of AWINIC Technology products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications that are described herein for any of these products are for illustrative purposes only. AWINIC Technology makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. All products are sold subject to the general terms and conditions of commercial sale supplied at the time of order acknowledgement. Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Reproduction of AWINIC information in AWINIC data books or data sheets is permissible only if reproduction is without alteration and is accompanied by all associated warranties, conditions, limitations, and notices. AWINIC is not responsible or liable for such altered documentation. Information of third parties may be subject to additional restrictions. Resale of AWINIC components or services with statements different from or beyond the parameters stated by AWINIC for that component or service voids all express and any implied warranties for the associated AWINIC component or service and is an unfair and deceptive business practice. AWINIC is not responsible or liable for any such statements. www.awinic.com.cn 33 Copyright © 2014 SHANGHAI AWINIC TECHNOLOGY CO., LTD
AW9110BTQR 价格&库存
很抱歉,暂时无法提供与“AW9110BTQR”相匹配的价格&库存,您可以联系我们找货
