PS30U200CT
PS30U200CT
    PINGWEI(平伟)
    TO220AB-3
PS30U200CT 数据手册
PS30U200CT&PS30U200FCT PS30U200CT&PS30U200FCT 30.0AMPS. SCHOTTKY BARRIER RECTIFIERS FEATURE .High current capability .Ultra low forward voltage drop .Low power loss, high efficiency .High surge capability .High temperature soldering guaranteed 260°C /10seconds, 0.25"(6.35mm)from case. TO-220AB PS30U200CT ITO-220AB PS30U200FCT MECHANICAL DATA .Case: Molded with UL-94 Class V-0 recognized Flame Retardant Epoxy .Mounting position: any Single phase, half wave, 60Hz,resistive or inductive load. For capacitive load, derate current by 20% MAXIMUM RATINGS (TC=25℃ unless otherwise noted) Parameter Symbol PS30U200CT&PS30U200FCT Units Maximum Recurrent Peak Reverse Voltage VRRM VRMS VDC 200 V 140 V 200 V Maximum RMS Voltage Maximum DC blocking Voltage Maximum Average Forward Rectified Current Per Leg Total device at TC =100°C Peak Forward Surge Current 8.3ms single half sine-wave superimposed on rated load (JEDEC method) Operation Junction Temperature and Storage Temperature A 30.0 IFSM 175.0 A CJ TJ, TSTG 300 pF -55 to +150 °C Per Leg Typical Junction Capacitance (Note 1) 15.0 IF(AV) Maximum Mounting torque, M3 or 6-32 srew 1.1N•m (10 lbf•in) ELECTRICAL CHARACTERISTICS-( Per Leg)(TC=25℃ unless otherwise noted) Parameter Symbol Test conditions TJ=25℃ Forward voltage drop VF TJ=125℃ Reverse leakage current IR TJ=25℃ TJ=125℃ IF=5A IF=15A IF=5A IF=15A VR=200V VR=200V Units Typ Max 0.74 —— 1.04 1.20 0.61 —— 0.74 0.80 --- 100 μA --- 10 mA V THERMAL CHARACTERISTICS (TC=25℃ unless otherwise noted) Parameter Symbol PS30U200CT PS30U200FCT Units Typical Thermal Resistance (Note 2) R(JC) 2.0 3.0 °C /W Notes: 1. Measured at 1.0 MHz and applied reverse voltage of 4.0Vdc 2. Thermal Resistance from Junction to Case 1 PS30U200CT&PS30U200FCT RATING AND CHARACTERISTIC CURVES FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE FIG.2-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS 30.0 INSTANEOUS FORWARD CURRENT,(A) AVERGE FORWARD RECTIFIED CURRENT,(A) 100 15.0 Single Phase Half Wave 60Hz Resistive or inductive Load 0 0 50 100 150 Tj=25℃ 1 0.1 200 Tj=125℃ 10 CASE TEMPERTURE,(℃) 0.7 0.5 0.3 0.9 1.1 INSTANEOUS FORWARD VOLTAGE,(V) FIG.4-TYPICAL REVERSE CHARACTERISTICS FIG.3-MAXIMUN NON-REPETITIVE FORWARD SURGE CURRENT 200 150 8.3ms Single Half Sine-Wave (JEDEC Method) INSTANEOUS REVERSE CURRENT,(mA) PEAK FORWARD SURGE CURRENT,(A) 100 100 50 0 10 TJ=125℃ 1 0.1 0.01 1 10 100 NUMBER OF CYCLES AT 60Hz 2 TJ=25℃ 0.001 0 40 80 120 160 PERCENT OF RATED PEAK REVERSE VOLTAGE,(V) 200 PS30U200CT&PS30U200FCT PACKAGE OUTLINE DIMENSIONS TO-220AB B L TO-220AB Min Max A .573(14.55) .603(15.32) B ―― .412(10.5) C .103(2.62) .113(2.87) D .140(3.56) .160(4.06) E .510(13.0) .560(14.3) F .027(0.68) .037(0.94) G .148(3.74) .154(3.91) H .230(5.84) .270(6.86) I .175(4.44) .185(4.86) J .100(2.54) .110(2.79) K .014(0.35) .025(0.64) L .045(1.14) .055(1.40) P .095(2.41) .105(2.67) N .043(1.10) .055(1.38) Dim I C H G A PIN 1 2 3 N D E J F P K Dimensions in inches and (millimeters) ITO-220AB B L G ITO-220AB Min Max A .571(14.5) .610(15.5) B .383(9.72) .406(10.3) C .110(2.80) .126(3.20) D .133(3.38) .162(4.10) E .512(13.0) .551(14.0) F .028(0.70) .035(0.90) G .114(2.90) .138(3.50) H .268(6.80) .291(7.40) I .162(4.10) .185(4.70) J .102(2.60) .110(2.80) K .018(0.45) .026(0.65) L .097(2.46) .113(2.86) P .890(2.25) .113(2.85) N .043(1.10) .055(1.38) Dim I C H A P IN 1 2 3 N D E J F P K Dimensions in inches and (millimeters) 3 PS30U200CT&PS30U200FCT Marking and packaging illustration 1、Marking SYMBOL XX XXXXX XXX A B XXX Explanation A B C D Trademark Product Name Date Code Product Information C D 2、Packaging A B C Tube Inside Box 类别 TO-220 Tube(50EA per tube ) TO-220 Inside Box(1K per box) TO-220 outside Box(6K per box) Outside Box A(mm) B(mm) C(mm) 530±5 7±0.8 33±1 542±5 82±2 78±1 555±5 285±5 245±5 4
PS30U200CT 价格&库存
很抱歉,暂时无法提供与“PS30U200CT”相匹配的价格&库存,您可以联系我们找货
