SAITW-A03T-064
SAITW-A03T-064
    JST
    无空隙、密封双向瞬态电压抑制器,旨在保护对电压敏感的组件免受ESD和瞬态电压事件的影响。
SAITW-A03T-064 数据手册
AITCONNECTOR Board-to-wire/Wire-to-wire Features ●Compliant with the Standard 0.64 Unsealed USCAR Footprints and USCAR Performance Standards ●Variations in PCB mountings 0.64 unsealed connector series compliant with the standard USCAR footprints. Variations of Keying / Color options and PC Board mounting features are available to satisfy customer's needs. Specifications JST K-A ¡Current rating: 5A DC max. ¡Voltage rating: 14V DC ¡Temperature range: -40°C to +100°C (including temperature rise in applying electrical current) ¡Contact resistance: Initial value/15mΩ max. After environmental testing/15mΩ max. ¡Insulation resistance: 100MΩ min. ¡Applicable wire: SAE/ AVSS / CAVS 0.3mm2 to 0.8mm2 ∗ Compliant with ELV/RoHS. ∗ Contact JST for details. 1 AIT CONNECTOR Female terminal Applicable wire range Size 1.6 S M 14 Model No. Conductor (mm2) Insulation O.D. Q’ty/reel (mm) qSAIT-A03T-M064 0.3 to 0.5 1.9 6,500 wSAIT-A03GF-M064 0.3 to 0.5 1.9 6,500 qSAIT-A02T-M064 0.75 to 0.8 1.9 6,500 wSAIT-A02GF-M064 0.75 to 0.8 1.9 6,500 Material and Finish qCopper alloy, tin-plated (reflow treatment) wCopper alloy, Contact area; gold -plated Barrel area; tin-plated 2.25 6.5 Male terminal Applicable wire range Size S M 6.4 7.5 Model No. Conductor (mm2) Insulation O.D. Q’ty/reel (mm) qSAITW-A03T-064 0.3 to 0.5 1.9 7,000 wSAITW-A03GF-064 0.3 to 0.5 1.9 7,000 qSAITW-A02T-064 0.75 to 0.8 1.9 7,000 wSAITW-A02GF-064 0.75 to 0.8 1.9 7,000 Material and Finish qBrass, tin-plated (reflow treatment) wBrass, Contact area; gold-plated Barrel area; tin-plated (22.7) 2 AIT CONNECTOR Male connector Top entry type 21.7 22.5 With boss ¡20 circuits 16.78 11 20 21.2 10 2.54 1 (7.21) 31.74 2.54 Screw hole type ¡8 circuits 21.7 22.5 21.7 22.5 ¡16 circuits 16.78 16.5 26.66 26.32 8 9 16 21.2 1 2.54 8 (7.21) 5 21.2 4 2.54 1 (7.21) 36.48 2.54 2.54 20.32 30.48 ¡18 circuits 21.7 22.5 Circuits 8 16 16.78 18 20.32 29.2 18 2.54 39.02 21.2 10 (7.21) 9 2.54 1 33.02 3 20 Model No. Q’ty/box Housing Color B08B-AIT-A2B-HS 96 Gray B08B-AIT-A2A-KS 96 Black B16B-AIT-A2A-KS 60 Black B16B-AIT-A2B-HS 60 Gray B18B-AIT-A2F-SS 60 Natural (White) B20B2-AIT-A2A-KS-(M) 510 Black B20B2-AIT-A2C-KS-(M) 510 Brown Material and Finish Housing: Glass-filled PA Pin: Brass, tin-plated AIT CONNECTOR Male connector Side entry type ¡52 circuits 24.6 24.6 ¡34 circuits 60.66 16 circuits Circuit No. 1 8 1 9 9 16 10 18 22.7 18 circuits 2.54 Circuit No. 2.54 18 circuits 16 circuits 18 circuits 1 9 1 8 1 9 10 18 9 16 10 18 22.7 82.55 88.46 2.54 54.75 2.54 20.5 22.5 ¡20 circuits Screw hole type ¡10 circuits 31.75 31.74 43.16 43.16 10 JST A K-A 1 10 11 20 22.7 17.73 1 2.54 Circuit No. Circuit No. 2.54 9× 2.54 Reinforcement type ¡4 circuits 19.7 19.7 ¡8 circuits 16.51 26.67 19.05 29.21 Circuit No. 4 1 3× 2.54 ¡20 circuits 21.7 Circuits 88 Black S08B1-AIT-A1A-KS 56 Black ∗∗ Black 22.7 20 2.54 Circuit No. 11 Housing Color S04B1-AIT-A1A-KS 20 10 Q’ty/box 8 1 Block 34.29 Model No. 4 10 1 8 7× 2.54 Type 31.74 17.73 1 17.73 Circuit No. ∗S10B-AIT-A1A-KS-(M) S20B-AIT-A2B-HS 24 Gray S20B-AIT-A2A-KS 24 Black S20B1-AIT-A2A-KS 36 Black S20B1-AIT-A2B-HS 36 Gray 2 Block 34 ∗S34B-AIT-A22-SS-(M) ∗∗ Natural (White) 3 Block 52 ∗S52B-AIT-A23-SS-(M) ∗∗ Natural (White) Material and Finish Housing: Glass-filled PBT Pin: Brass, tin-plated 9× 2.54 ∗Marked products display (LF)(SN) on a label. ∗∗Please contact JST. 4 AIT CONNECTOR Male connector ¡10 circuits Circuits Model No. Q’ty/box AITWSB-10-2AK 16.6 10 100 37 Material Housing: Glass-filled PBT, black TPA: Glass-filled PBT, red 2.54 20.4 23 C A 2.54 PC board layout Top entry type Screw hole type ¡8 circuits 7.62 33.02±0.05 φ3.4+0.1 0 2.54±0.05 2.72±0.05 φ1.1+0.1 0 2.54±0.05 22.86±0.05 φ3.4+0.1 0 2.54±0.05 ¡18 circuits 30.48±0.05 2.72±0.05 2.72±0.05 φ1.1+0.1 0 (Tin-plated) 2.54±0.05 ¡16 circuits 20.32±0.05 2.54±0.05 2.54±0.05 φ1.35+0.1 0 (No plating) φ1.1+0.1 0 17.78 φ3.4+0.1 0 2.54±0.05 2.5±0.05 With boss ¡20 circuits φ1.1+0.1 0 2.54±0.05 20.32 Side entry type Screw hole type ¡10 circuits ¡34 circuits 25.26 3.74 17.78 φ1.2±0.05 0.1 G H ×34 20.32 2.54 ¡20 circuits 22.86 2.54 22.86±0.05 φ1.2±0.05 2.54 0.1 G H H φ1.1+0.1 0 H 0.1 G H ×3 G Reinforcement type ¡4 circuits 53.06 35.56±0.05 0.1 G H ×52 2.54 (25.26) φ3.2+0.1 0 3.9 27.8 0.1 G H ×4 φ1.1+0.1 0 13.97±0.05 φ3+0.1 0 (Cu plated) (27.8) 53.06 φ1.1+0.1 0 24.13±0.05 φ3+0.1 0 29.21±0.05 (Cu plated) Crimping machine, Applicator Crimping machine Crimp applicator MKS-L Dies Crimp applicator with dies SAIT-A03( )-M064 MK/SAIT-A03-064 APLMK SAIT-A03-064 SAIT-A02( )-M064 MK/SAIT-A02-064 APLMK SAIT-A02-064 MK/SAITW-A03-064 APLMK SAITW-A03-064 MK/SAITW-A02-064 APLMK SAITW-A02-064 SAITW-A03( )-064 SAITW-A02( )-064 AP-K2N Note: When crimping operation is conducted using an applicator and die set other than the above, JST cannot guarantee the performance of the terminal. 5 φ3+0.1 0 (Cu plated) Note: 1. Tolerances are non-cumulative. 2. Hole dimensions differ according to the type of PC board and piercing method. The dimensions above should serve as guideline. Contact JST for details. 80.86 Strip terminal φ1.1+0.1 0 3 20.32 2.54 2.54 9.4±0.05 17.78 2.54 22.86±0.05 2.54±0.05 ±0.05 2.54±0.05 3 20.32 ¡20 circuits 17.78±0.05 9.4±0.05 27.8 9.4±0.05 3.74 ¡8 circuits 7.62±0.05 G H φ3.4+0.1 0 35.56 53.06 ¡52 circuits φ1.2±0.05 φ3.2+0.1 0 0.1 G H φ3.2+0.1 0 25.26 6±0.05 6 3 3.9 2.54±0.05 3±0.05 G
SAITW-A03T-064 价格&库存
很抱歉,暂时无法提供与“SAITW-A03T-064”相匹配的价格&库存,您可以联系我们找货
