2SC945P
2SC945P
    ST(先科)
    TO92-3
    用于开关和音频放大器应用。该晶体管根据其直流电流增益细分为五个组,R、O、Y、P和L。推荐使用PNP晶体管2SA733作为互补类型。根据特殊要求,这些晶体管可以采用不同的引脚配置制造。
2SC945P 数据手册
2SC945 NPN Silicon Epitaxial Planar Transistor for switching and AF amplifier applications. The transistor is subdivided into five groups, R, O, Y, P and L, according to its DC current gain. As complementary type the PNP transistor 2SA733 is recommended. On special request, these transistors can be manufactured in different pin configurations. 1. Emitter 2. Collector 3. Base TO-92 Plastic Package Absolute Maximum Ratings (Ta = 25 OC) Parameter Symbol Value Unit Collector Base Voltage VCBO 60 V Collector Emitter Voltage VCEO 50 V Emitter Base Voltage VEBO 5 V Collector Current IC 150 mA Power Dissipation Ptot 250 mW Tj 150 O Tstg - 55 to + 150 O Junction Temperature Storage Temperature Range Characteristics at Ta = 25 OC Parameter DC Current Gain at VCE = 6 V, IC = 1 mA Current Gain Group Collector Base Cutoff Current at VCB = 40 V Emitter Base Cutoff Current at VEB = 3 V Collector Base Breakdown Voltage at IC = 100 µA Collector Emitter Breakdown Voltage at IC = 10 mA Emitter Base Breakdown Voltage at IE = 10 µA Collector Emitter Saturation Voltage at IC = 100 mA, IB = 10 mA Gain Bandwidth Product at VCE = 6 V, IC = 10 mA Output Capacitance at VCB = 6 V, f = 1 MHz R O Y P L C C Symbol Min. Typ. Max. Unit hFE hFE hFE hFE hFE 40 70 120 200 350 - 80 140 240 400 700 - ICBO - - 100 nA IEBO - - 100 nA V(BR)CBO 60 - - V V(BR)CEO 50 - - V V(BR)EBO 5 - - V VCE(sat) - - 0.3 V fT - 300 - MHz Cob - 2.5 - pF SEMTECH ELECTRONICS LTD. ® Dated:12/08/2016 Rev:02 2SC945 h FE - I C 360 Power Dissipation vs Ambient Temperature pulse d 320 300 280 DC CURRENT GAIN Power Dissipation: Ptot (mW) 250 200 150 100 50 240 VCE=6.0V 200 160 3.0V 120 2.0V 80 1.0V 0.5V 40 0 0 0 25 50 125 100 75 150 0.1 0.01 1 10 100 Ambient Temperature: Ta ( C) O COLLECTOR CURRENT, mA Collector current vs. collector emitter voltage Collector current vs. collector emitter voltage 1.0 100 80 0.9 0.8 0.7 0.6 0.5 10 4.5 4 8 3.5 0.4 3 6 0.3 Ic - mA Ic - mA 60 40 0.2 2.5 2 4 1.5 1 20 2 I B =0.1mA 0 0 0.4 0.8 1.2 1.6 IB=0.5 A 0 0 2.0 10 20 VCE, V 30 40 50 VCE, V Collector and base saturation Collector current vs. base emitter voltage voltage vs. collector current 100 10 VCE=6V pulsed pulsed VBE(sat) , V VCE(sat) , V 1 -25 C Ta= 25 C 75 Ic - mA C 10 1 IC/IB=10 VBE(sat) 20 50 50 0.1 VCE(sat) 20 0.1 0.01 0.2 IC/IB=10 0.01 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1 VBE , V 0.1 1 10 100 Collector Current, mA SEMTECH ELECTRONICS LTD. ® Dated:12/08/2016 Rev:02
2SC945P
- 物料型号: 2SC945 - 器件简介: 适用于开关和音频放大器应用的NPN硅外延平面晶体管。 - 引脚分配: 1. 发射极 2. 集电极 3. 基极,采用TO-92塑料封装。 - 参数特性: - 绝对最大额定值包括VCBO 60V, VCEO 50V, VEBO 5V, Ic 150mA, Ptot 250mW, 储存温度范围 -55°C 至 +150°C。 - 特征曲线在Ta = 25°C时,包括了不同电流增益群组(hFE)的最小值、典型值、最大值,以及集基截止电流(IcBo)、发射基截止电流(IEBO)、击穿电压等。 - 功能详解: 提供了功率增益随环境温度变化的图,以及集电极电流与集电极-发射极电压和基极-发射极电压的关系图。 - 应用信息: 推荐PNP型晶体管2SA733作为互补类型。 - 封装信息: 提供了TO-92塑料封装的说明。
