SS210D
SS210D
    ST(先科)
    SMB(DO-214AA)
    电压:100V 电流:2A
SS210D 数据手册
SS22D THRU SS210D Surface Mount Schottky Barrier Rectifier Reverse Voltage - 20 to 100 V Forward Current - 2 A Features • The plastic package carries UL Flammability Classification 94V-0 • Low power loss, high efficiency • High forward surge current capability Mechanical Data • Case: SMB (DO-214AA) molded plastic body • Polarity: Color band denotes cathode end • Mounting Position: Any E T M E H C Maximum Ratings and Electrical Characteristics Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20%. O Parameter Symbols SS22D SS24D SS26D SS28D SS210D Unit Maximum Repetitive Peak Reverse Voltage VRRM 20 40 Maximum RMS Voltage VRMS 14 28 Maximum DC Blocking Voltage VDC 20 40 Maximum Average Forward Rectified Current IF(AV) 2 A Peak Forward Surge Current 8.3 ms Half Sine-wave Superimposed on Rated Load (JEDEC method) IFSM 50 A S Maximum Instantaneous Forward Voltage at 2 A Maximum DC Reverse Current at Rated DC Blocking Voltage VF Ta = 25 C Ta = 100 OC O Typical Thermal Resistance, Junction to Ambient 1) Typical Thermal Resistance, Junction to Terminal Operating Junction Temperature Range Storage Temperature Range 1) 1) IR 0.5 60 80 100 V 42 56 70 V 60 80 100 V 0.7 0.85 0.5 V 0.1 10 mA 5 RθJA 75 O RθJL 17 O Tj Tstg - 55 to + 125 C/W C/W - 55 to + 150 - 55 to + 150 Thermal resistance from junction to ambient and from junction to lead mounted on P.C.B. with 0.3" x 0.3" (8 mm x 8 mm) copper pad areas. SEMTECH ELECTRONICS LTD. ® Dated:23/10/2014 YJ Rev:02 C O C O SS22D THRU SS210D E T M E H C S SEMTECH ELECTRONICS LTD. ® Dated:23/10/2014 YJ Rev:02
SS210D 价格&库存
很抱歉,暂时无法提供与“SS210D”相匹配的价格&库存,您可以联系我们找货
