8bitCMOS Data Buffer TM74HC245
Characterization
TM74HC245 is a 3-state Output Octal Bus Transceiver, mainly used in large-screen display, as
well as in other consumer electronics products to enhance drive. This product is excellent in
performance and reliable in quality.
Features
CMOS Technology
Wide voltage range: 3.0V-5.5V
Noninverting 3-state gate output
8-bit bidirectional transceiver
Package type: SOP20, SSOP20, TSSOP20
Block diagram of internal structure
Fig. 1
1
www.titanmec.com
©Titan Micro Electronics
V1.2
Pin arrangement
DIR
A0
A1
A2
A3
A4
A5
A6
A7
GND
1
19
3
18
4
17
5 Top View 16
6
15
7
14
8
13
9
12
10
11
VCC
OE
B0
B1
B2
B3
B4
B5
B6
B7
Fig. 2
Pin Function
Pin Name
Pin No.
I/O
Function Description
A0—A7
2—9
Data input and output
B0—B7
18—11
OE
19
I
DIR
1
O
GND
Output Enable
Direction control
DIR=1:A B
DIR=0:B A
Logic GND
VDD
10
Logic Power
Here are the ESD logo and descriptions provided as a reminder for electrostatic protection:
An integrated circuit is a static sensitive device. Since a considerable amount of static
electricity is likely to be generated in a dry season or a dry environment and electrostatic
discharge will damage integrated circuits, it is the advice of Titan that preventive measures
should be taken for all appropriate ICs are. Improper operation and welding may cause ESD damage
or performance degradation, and put the chip out of service.
Truth table
Output Enable
OE
Output Control
DIR
L
L
H
L
H
H
Operating state
Bn input, An output
An input, Bn output
High-impedance state
2
www.titanmec.com
V1.2
Limit parameter
Tested at 25℃, unless otherwise stated
TM74HC245
Parameter Name
Parameter Symbol
Limit
Logic Supply Voltage
Logic input voltage
Output drive current
Output Sink Current
Power loss
Operating temperature
Storage temperature
VDD
VI1
IOH
IOL
PD
Topt
Tstg
-0.5~+7.0
-0.5~VDD+0.5
-95
105
很抱歉,暂时无法提供与“TM74HC245”相匹配的价格&库存,您可以联系我们找货
