SCT2452STER
SCT2452STER
    SCT(芯洲科技)
    ESOP8
    SCT2452STER
SCT2452STER 数据手册
SILICON CONTENT TECHNOLOGY SCT2452 Rev 1.1 3.8V-36V Vin, 5A, High Efficiency Synchronous Step-down DCDC Converter with Programmable Frequency FEATURES DESCRIPTION • • • • The SCT2452 is 5A synchronous buck converters with wide input voltage, ranging from 3.8V to 36V, which integrates a 45mΩ high-side MOSFET and a 20mΩ low-side MOSFET. The SCT2452, adopting the peak current mode control, supports the Pulse Skipping Modulation (PSM) with typical 25uA low quiescent current which assists the converter on achieving high efficiency at light load or standby condition. Wide Input Range: 3.8V-36V Up to 5A Continuous Output Current 0.8V ±1% Feedback Reference Voltage Integrated 45mΩ High-Side and 20mΩ Low-Side Power MOSFETs Pulse Skipping Mode (PSM) with 25uA Quiescent Current in Sleep Mode 100ns Minimum On-time Adjustable Soft-start Time Adjustable Frequency 100KHz to 1.1MHz External Clock Synchronization Frequency Spread Spectrum (FSS) Modulation for EMI Reduction Precision Enable Threshold for Programmable Input Voltage Under Voltage Lock Out Protection (UVLO) Threshold and Hysteresis Low Dropout Mode Operation Derivable Inverting Voltage Regulator Over-voltage and Over-Temperature Protection Available in an ESOP-8 Package • • • • • • • • • • • APPLICATIONS • Battery Pack Powered System - Cordless Power Tools, Cordless Home Appliance, Drone, Aero Modeling, GPS Tracker etc. Cigarette Lighter Adapters, Chargers LCD Display USB Type-C Power Delivery, USB Charging Industrial and Medical Distributed Power Supplies Optical Communication and Networking System Automotive System • • • • • • The SCT2452 features programmable switching frequency from 100 kHz to 1.1 MHz with an external resistor, which provides the flexibility to optimize either efficiency or external component size. The converter supports external clock synchronization with a frequency band from 100kHz to 1.1MHz. The SCT2452 allows power conversion from high input voltage to low output voltage with a minimum 100ns on-time of highside MOSFET. The SCT2452 is an Electromagnetic Interference (EMI) friendly buck converter with implementing optimized design for EMI reduction. The SCT2452 features Frequency Spread Spectrum FSS with ±6% jittering span of the 500kHz switching frequency and modulation rate 1/512 of switching frequency to reduce the conducted EMI. The SCT2452 offers cycle-by-cycle current limit and hiccup over current protection, thermal shutdown protection, output over-voltage protection and input voltage under-voltage protection. The device is available in an 8-pin thermally enhanced SOP-8 package. TYPICAL APPLICATION 100 BOOT VIN L1 SW VOUT C5 VIN GND SCT2452 EN SS C1 C2 RT/CLK R4 R1 FB C4 R2 90 Efficiency(%) C3 80 VIN=24V, VOUT=5V 70 VIN=24V, VOUT=3.3V VIN=12V, VOUT=5V 60 VIN=12V,VOUT=3.3V 50 0.001 0.01 0.1 1 10 Output Current (A), Freq.=500KHz For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2452 1 SCT2452 REVISION HISTORY NOTE: Page numbers for previous revisions may differ from page numbers in the current version. Revision 1.0: Release to product Revision 1.1: Updated Max Vin Transient voltage DEVICE ORDER INFORMATION PART NUMBER PACKAGE MARKING PACKAGE DISCRIPTION SCT2452STE 2452 8-Lead Plastic ESOP 1) For Tape & Reel, Add Suffix R (e.g. SCT2452STER) ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION Over operating free-air temperature unless otherwise noted(1) DESCRIPTION MIN MAX UNIT VIN -0.3 38 V VIN Transient (300ms) (2) -0.3 42 V EN -0.3 38 V BOOT -0.3 44 V SW -1 38 V BOOT-SW -0.3 6 V -0.3 6 V -40 150 °C -65 150 °C SS, FB, RT/CLK Operating junction temperature TJ(2) Storage temperature TSTG (1) (2) (3) BOOT 1 VIN 2 EN 3 RT/CLK 4 Thermal Pad 8 SW 7 GND 6 SS 5 FB Figure 1. 8-Lead Plastic E-SOP Stresses beyond those listed under Absolute Maximum Rating may cause device permanent damage. The device is not guaranteed to function outside of its Recommended Operation Conditions. The max VIN transient voltage is guaranteed by design and verified on bench. The IC includes over temperature protection to protect the device during overload conditions. Junction temperature will exceed 150°C when over temperature protection is active. Continuous operation above the specified maximum operating junction temperature will reduce lifetime. PIN FUNCTIONS NAME NO. BOOT 1 VIN 2 EN 3 RT/CLK 4 2 PIN FUNCTION Power supply bias for high-side power MOSFET gate driver. Connect a 0.1uF capacitor from BOOT pin to SW pin. Bootstrap capacitor is charged when low-side power MOSFET is on or SW voltage is low. Input supply voltage. Connect a local bypass capacitor from VIN pin to GND pin. Path from VIN pin to high frequency bypass capacitor and GND must be as short as possible. Enable pin to the regulator with internal pull-up current source. Pull below 1.1V to disable the converter. Float or connect to VIN to enable the converter. The tap of resistor divider from VIN to GND connecting EN pin can adjust the input voltage lockout threshold. Set the internal oscillator clock frequency or synchronize to an external clock. Connect a resistor from this pin to ground to set switching frequency. An external clock can be input directly to the RT/CLK pin. The internal oscillator synchronizes to the external clock frequency with PLL. If detected clocking edges stops, the operation mode automatically returns to resistor programmed frequency. For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2452 SCT2452 FB 5 SS 6 Inverting input of the trans-conductance error amplifier. The tap of external feedback resistor divider from the output to GND sets the output voltage. The device regulates FB voltage to the internal reference value of 0.8V typical. Connect a cap to ground, program the soft start time. GND 7 Ground SW Thermal Pad 8 Regulator switching output. Connect SW to an external power inductor Heat dissipation path of die. Electrically connection to GND pin. Must be connected to ground plane on PCB for proper operation and optimized thermal performance. 9 RECOMMENDED OPERATING CONDITIONS Over operating free-air temperature range unless otherwise noted PARAMETER DEFINITION VIN VOUT TJ Input voltage range Output voltage range Operating junction temperature MIN MAX UNIT 3.8 0.8 -40 36 36 125 V V °C MIN MAX UNIT -2 +2 kV -0.5 +0.5 kV ESD RATINGS PARAMETER VESD DEFINITION Human Body Model(HBM), per ANSI-JEDEC-JS-001-2014 specification, all pins(1) Charged Device Model(CDM), per ANSI-JEDEC-JS-0022014 specification, all pins(2) (1) JEDEC document JEP155 states that 500V HBM allows safe manufacturing with a standard ESD control process. (2) JEDEC document JEP157 states that 250V CDM allows safe manufacturing with a standard ESD control process. THERMAL INFORMATION PARAMETER RθJA RθJC THERMAL METRIC Junction to ambient thermal resistance(1) Junction to case thermal resistance(1) SOP-8L 42 45.8 UNIT °C/W (1) SCT provides RθJA and RθJC numbers only as reference to estimate junction temperatures of the devices. RθJA and RθJC are not a characteristic of package itself, but of many other system level characteristics such as the design and layout of the printed circuit board (PCB) on which the SCT2452 is mounted, thermal pad size, and external environmental factors. The PCB board is a heat sink that is soldered to the leads and thermal pad of the SCT2452. Changing the design or configuration of the PCB board changes the efficiency of the heat sink and therefore the actual RθJA and RθJC. For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2452 3 SCT2452 ELECTRICAL CHARACTERISTICS VIN=24V, TJ=-40°C~125°C, typical value is tested under 25°C. SYMBOL PARAMETER TEST CONDITION Power Supply VIN Operating input voltage ISHDN IQ Quiescent current from VIN pin VIN rising 3.5 400 1 EN=0, no load EN floating, no load, nonswitching, BOOT-SW=5V Power MOSFETs RDSON_H High-side MOSFET on-resistance RDSON_L VBOOT-VSW=5V Low-side MOSFET on-resistance Reference and Control Loop VREF Reference voltage of FB Current Limit and Over Current Protection High-side power MOSFET peak ILIM_HS current limit threshold Low-side power MOSFET souring ILIM_LSSRC current limit threshold Over current protection hiccup wait THIC_W time Over current protection hiccup restart THIC_R time V 3.7 V mV μA 3 25 μA 45 mΩ 20 mΩ 0.8 0.808 V 6.8 8 9.2 A IEN_L Enable pin pull-up current EN=1V IEN_H Enable pin pull-up current EN=1.5V Iss SS pin current cycle 8192 cycle 1.03 1.1 1 1.5 Switching Frequency and External Clock Synchronization FRANGE_RT Frequency range using RT mode 100 FSW Switching frequency 450 FRANGE_CLK Frequency range using CLK mode Frequency spread spectrum in percentage of Fsw Minimum on-time RRT=200 kΩ(1%) A 512 1.18 Enable low threshold UNIT 36 9 VEN_L tON_MIN MAX 0.792 Enable and Soft Startup VEN_H Enable high threshold FJITTER TYP 3.8 Input UVLO Threshold Hysteresis Shutdown current from VIN pin VIN_UVLO MIN 1.25 V V 2 μA 5.5 uA 3 uA 500 100 1100 kHz 550 kHz 1100 kHz ±6 % VIN=24V 100 ns VFB/VREF rising VFB/VREF falling BOOT-SW falling Hysteresis TJ rising Hysteresis 110 105 2.36 300 170 25 % % V mV °C °C Protection VOVP VBOOTUV TSD 4 Feedback overvoltage with respect to reference voltage BOOT-SW UVLO threshold Thermal shutdown threshold For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2452 SCT2452 100 100 90 90 80 80 Efficiency(%) Efficiency(%) TYPICAL CHARACTERISTICS 70 60 70 60 VIN=36V, VOUT=3.3V VIN=36V, VOUT=5V VIN=36V, VOUT=12V 50 40 0.001 0.01 0.1 VIN=24V, VOUT=3.3V VIN=24V, VOUT=5V VIN=24V, VOUT=12V 50 1 40 10 0.001 0.01 Output Current(A) Figure 2. Efficiency vs Load Current, Vin=36V 1 10 Figure 3. Efficiency vs Load Current, Vin=24V 100 5.01 90 5.00 Output Voltage (V) Efficiency(%) 0.1 Output Current(A) 80 70 60 VIN=12V,VOUT=3.3V 50 4.99 4.98 VIN=24V, VOUT=5V 4.97 VIN=12V,VOUT=5V VIN=12V,VOUT=5V 40 0.001 0.01 0.1 1 4.96 0.001 10 0.01 Output Current(A) 0.1 1 10 Output Current(A) Figure 4. Efficiency vs Load Current, Vin=12V Figure 5. Load Regulation (Vout=5V) 1,100 3.31 Switching Frequency (kHz) 1,000 Output Voltage (V) 3.31 3.30 3.30 900 800 700 600 500 400 300 200 3.29 0 10 20 30 40 100 0 100 Input Voltage (V) 200 300 400 500 600 RT (kΩ) Figure 6. Line Regulation (Iout=5A) Figure 7.Clock Frequency vs RT/CLK Resistor For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2452 5 SCT2452 38 8 36 Quiescent Current (uA) 40 9 Shutdown Current (uA) 10 7 6 5 4 3 2 34 32 30 28 26 24 22 1 20 0 -50 -25 0 25 50 75 100 -50 125 -25 0 25 Temperature (ºC) Figure 8. Shutdown Current vs Temperature 75 100 125 Figure 9.Quiescent Current vs Temperature 1.22 9.00 1.21 8.00 Ien_1P5V_post (uA) EN Rising Threshold (V) 50 Temperature (ºC) 1.20 1.19 1.18 1.17 7.00 6.00 5.00 4.00 3.00 1.16 2.00 -50 -25 0 25 50 75 100 125 -50 -25 0 Temperature (ºC) 25 50 75 100 125 Temperature (°C) Figure 11. EN Pull-up Current vs Temperature Figure 10. EN Threshold vs Temperature 0.808 10 0.806 8 0.802 Current ( A ) Vref (V) 0.804 0.800 0.798 0.796 6 4 2 0.794 0.792 -50 -25 0 25 50 75 100 125 0 -50 -25 0 25 50 75 100 Temperature (°C) Figure 12. Reference Voltage vs Temperature 6 For more information www.silicontent.com Figure 13. Peak Current Limit vs Temperature © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2452 125 SCT2452 FUNCTIONAL BLOCK DIAGRAM VIN 2 1.5uA 4uA Thermal Shutdown 20K EN 3 + EN LOGIC VIN UVLO Reference 1.21V VREF VCC VCC 3uA SS HS MOSFET Current limit Boot Charge 6 Slop FB 5 0.8V + + EA + + Control Logic 4 8 SW 7 GND VCC 0.88V RT/CLK BOOT Boot UVLO PWM OVP 1 Oscillator With PLL CLK LS MOSFET Current limit Figure 14. Functional Block Diagram For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2452 7 SCT2452 OPERATION Overview The SCT2452 is a 3.8V-36V input, 5A output, EMI friendly synchronous buck converter with built-in 45mΩ Rdson high-side and 20mΩ Rdson low-side power MOSFETs. It implements constant frequency peak current mode control to regulate output voltage, providing excellent line and load transient response and simplifying the frequency compensation design. The switching frequency is programmable from 100kHz to 1.1MHz with two setting modes, resistor setting frequency mode and the clock synchronization mode, to optimizes either the power efficiency or the external components’ sizes. The SCT2452 features a programmable soft-start time to avoid large inrush current and output voltage overshoot during startup. The device also supports monolithic startup with pre-biased output condition. The seamless mode-transition between PWM mode and PSM mode operations ensure high efficiency over wide load current range. The quiescent current is typically 25uA under no load or sleep mode condition to achieve high efficiency at light load. The SCT2452 has a default input start-up voltage of 3.5V with 400mV hysteresis. The EN pin is a high-voltage pin with a precision threshold that can be used to adjust the input voltage lockout thresholds with two external resistors to meet accurate higher UVLO system requirements. Floating EN pin enables the device with the internal pull-up current to the pin. Connecting EN pin to VIN directly starts up the device automatically. The SCT2452 implements the Frequency Spread Spectrum FSS modulation spreading of ±6% centered selected switching frequency. FSS improves EMI performance by not allowing emitted energy to stay in any one receiver band for a significant length of time. The SCT2452 full protection features include the input under-voltage lockout, the output over-voltage protection, over current protection with cycle-by-cycle current limiting and hiccup mode, output hard short protection and thermal shutdown protection. Peak Current Mode Control The SCT2452 employs fixed frequency peak current mode control. An internal clock initiates turning on the integrated high-side power MOSFET Q1 in each cycle, then inductor current rises linearly. When the current through high-side MOSFET reaches the threshold level set by the COMP voltage of the internal error amplifier, the highside MOSFET turns off. The synchronous low-side MOSFET Q2 turns on till the next clock cycle begins or the inductor current falls to zero. The error amplifier serves the COMP node by comparing the voltage of the FB pin with an internal 0.8V reference voltage. When the load current increases, a reduction in the feedback voltage relative to the reference raises COMP voltage till the average inductor current matches the increased load current. This feedback loop well regulates the output voltage to the reference. The device also integrates an internal slope compensation circuitry to prevent subharmonic oscillation when duty cycle is greater than 50% for a fixed frequency peak current mode control. The SCT2452 operates in Pulse Skipping Mode (PSM) with light load current to improve efficiency. When the load current decreases, an increment in the feedback voltage leads COMP voltage drop. When COMP falls to a low clamp threshold (400mV typically), device enters PSM. The output voltage decays due to output capacitor discharging during skipping period. Once FB voltage drops lower than the reference voltage, and the COMP voltage rises above low clamp threshold. Then high-side power MOSFET turns on in next clock pulse. After several switching cycles with typical 1A peak inductor current, COMP voltage drops and is clamped again and pulse skipping mode repeats if the output continues light loaded. This control scheme helps achieving higher efficiency by skipping cycles to reduce switching power loss and gate drive charging loss. The controller consumption quiescent current is 25uA during skipping period with no switching to improve efficiency further. Enable and Under Voltage Lockout Threshold The SCT2452 is enabled when the VIN pin voltage rises about 3.5V and the EN pin voltage exceeds the enable threshold of 1.18V. The device is disabled when the VIN pin voltage falls below 3.1V or when the EN pin voltage is 8 For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2452 SCT2452 below 1.1V. An internal 1.5uA pull up current source to EN pin allows the device enable when EN pin floats. EN pin is a high voltage pin that can be connected to VIN directly to start up the device. For a higher system UVLO threshold, connect an external resistor divider (R1 and R2) shown in Figure 15 from VIN to EN. The UVLO rising and falling threshold can be calculated by Equation 1 and Equation 2 respectively. Vrise = 1.18 ∗ (1 + Vfall VIN R1 ) − 1.5uA ∗ R1 R2 (1) 1.5uA 4uA R1 EN R1 = 1.1 ∗ (1 + ) − 5.5uA ∗ R1 R2 (2) R2 20K + 1.21V where • Vrise is rising threshold of Vin UVLO • Vfall is falling threshold of Vin UVLO Figure 15. System UVLO by enable divide Output Voltage The SCT2452 regulates the internal reference voltage at 0.8V with 1% tolerance over the operating temperature and voltage range. The output voltage is set by a resistor divider from the output node to the FB pin. It is recommended to use 1% tolerance or better resistors. Use Equation 3 to calculate resistance of resistor dividers. To improve efficiency at light loads, larger value resistors are recommended. However, if the values are too high, the regulator will be more susceptible to noise affecting output voltage accuracy. 𝑉𝑂𝑈𝑇 𝑅𝐹𝐵_𝑇𝑂𝑃 = ( − 1) ∗ 𝑅𝐹𝐵_𝐵𝑂𝑇 𝑉𝑅𝐸𝐹 (3) where • RFB_TOP is the resistor connecting the output to the FB pin. • RFB_BOT is the resistor connecting the FB pin to the ground. Programmable Soft-Start The SCT2452 features programmable soft-start time to prevent inrush current during start-up stage. The soft-start time can be programmed easily by connecting a soft-start capacitor Css (Css is the C6 on Figure 18) from SS pin to ground. The SS pin sources an internal 3µA current charging the external soft-start capacitor Css when the EN pin exceeds turn-on threshold. The device adopts the lower voltage between the internal voltage reference 0.8V and the SS pin voltage as the reference input voltage of the error amplifier and regulates the output. The soft-start completes when the voltage at the SS pin exceeds the internal reference voltage of 0.8V. The soft-start capacitor value can be calculated going with following equation 4. Attention should be taken here that the programmed soft-start time should be larger than 4ms. 𝐶𝑠𝑜𝑓𝑡−𝑠𝑡𝑎𝑟𝑡 = 𝑡𝑠𝑠 ∗ Where: • • 3𝑢𝐴 0.8𝑉 (4) CSS is the soft-start capacitor connected from SS pin to the ground tss is the soft-start time Switching Frequency and Clock Synchronization The switching frequency of the SCT2452 is set by placing a resistor between RT/CLK pin and the ground, or For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2452 9 SCT2452 synchronizing to an external clock. In resistor setting frequency mode, a resistor placed between RT/CLK pin to the ground sets the switching frequency over a wide range from 100KHz to 1.1MHz. The RT/CLK pin voltage is typical 0.5V. RT/CLK pin is not allowed to be left floating or shorted to the ground. Use Equation 5 or the plot in Figure 16. to determine the resistance for a switching frequency needed. 𝑅𝑇(𝐾𝛺) = 100000 𝑓𝑠𝑤(𝐾𝐻𝑧) RT/CLK (5) Oscillator With PLL CLK where, Figure 16. Setting Frequency and Clock Synchronization fsw is switching clock frequency In clock synchronization mode, the switching frequency synchronizes to an external clock applied to RT/CLK pin. The synchronization frequency range is from 100KHz to 1.1MHz and the rising edge of the SW synchronizes to the falling edge of the external clock at RT/CLK pin with typical 66ns time delay. A square wave clock signal to RT/CLK pin must have high level no lower than 2V, low level no higher than 0.4V, and pulse width larger than 80ns. In applications where both resistor setting frequency mode and clock synchronization mode are needed, the device can be configured as shown in Figure 16. Before an external clock is present, the device works in resistor setting frequency mode. When an external clock presents, the device automatically transitions from resistor setting mode to external clock synchronization mode. An internal phase locked loop PLL locks internal clock frequency onto the external clock within typical 85us. The converter transitions from the clock synchronization mode to the resistor setting frequency mode when the external clock disappears. Frequency Spread Spectrum To reduce EMI, the SCT2452 implements Frequency Spread Spectrum (FSS). The FSS circuitry shifts the switching frequency of the regulator periodically within a certain frequency range around the programmed switching frequency. The jittering span is ±6% of the switching frequency with 1/512 swing frequency. This frequency dithering function is effective for both frequency programmed by resistor placed at RT/CLK pin and an external clock synchronization application. Bootstrap Voltage Regulator and Low Drop-out Operation An external bootstrap capacitor between BOOT pin and SW pin powers the floating gate driver to high-side power MOSFET. The bootstrap capacitor voltage is charged from an integrated voltage regulator when high-side power MOSFET is off and low-side power MOSFET is on. The UVLO of high-side MOSFET gate driver has rising threshold of 2.7V and hysteresis of 350mV. When the device operates with high duty cycle or extremely light load, bootstrap capacitor may be not recharged in considerable long time. The voltage at bootstrap capacitor is insufficient to drive high-side MOSFET fully on. When the voltage across bootstrap capacitor drops below 2.35V, BOOT UVLO occurs. The converter forces turning on low-side MOSFET periodically to refresh the voltage of bootstrap capacitor to guarantee the converter’s operation over a wide duty range. During the condition of ultra-low voltage difference from the input to the output, SCT2452 operates in Low Drop-Out LDO mode. High-side MOSFET remains turning on as long as the BOOT pin to SW pin voltage is higher than BOOT UVLO threshold 2.7V. When the voltage from BOOT to SW drops below 2.4V, the high-side MOSFET turns off and low-side MOSFET turns on to recharge bootstrap capacitor periodically in the following several switching cycles. Low-side MOSFET only turns on for 100ns in each refresh cycle to minimize the output voltage ripple. Low-side MOSFET may turn on for several times till the bootstrap voltage is charged to higher than 2.7V for high-side MOSFET working normally. The effective duty cycle of the converter during LDO operation can be approaching to 100% 10 For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2452 SCT2452 During slowing power up and power down application, the output voltage can closely track the input voltage ramping down thanks to LDO operation mode. As the input voltage is reduced to near the output voltage, i.e. during slowing power-up and power-down application, the off-time of the high side MOSFET starts to approach the minimum value. Without LDO operation mode, beyond this point the switching may become erratic and/or the output voltage will fall out of regulation. To avoid this problem the SCT2452 LDO mode automatically reduces the switching frequency to increase the effective duty cycle and maintain regulation. 5.50 Vout (V) 5.00 4.50 0-A 1-A 2-A 4.00 3-A 4-A 5-A 3.50 4 4.5 5 5.5 6 6.5 Vin (V) Figure 17. LDO Operation Characteristic ( Vout =5V ) Over Current Limit and Hiccup Mode The inductor current is monitored during high-side MOSFET Q1 and low-side MOSFET Q2 on. The SCT2452 implements over current protection with cycle-by-cycle limiting high-side MOSFET peak current and low-side MOSFET valley current to avoid inductor current running away during unexpected overload or output hard short condition. When overload or hard short happens, the converter cannot provide output current to satisfy loading requirement. The inductor current is clamped at over current limitation. Thus, the output voltage drops below regulated voltage with FB voltage less than internal reference voltage continuously. The COMP voltage ramps up to high clamp voltage 3.7V typical. When COMP voltage is clamped for 512 cycles, the converter stops switching. After remaining OFF for 8192 cycles,the device restarts from soft starting phase. If overload or hard short condition still exists during soft-start and make COMP voltage clamped at high for 512 cycles,the device enters into turning-off mode again. When overload or hard short condition is removed, the device automatically recovers to enters normal regulating operation. The hiccup protection mode above makes the average short circuit current to alleviate thermal issues and protect the regulator. Over voltage Protection The SCT2452 implements the Over-voltage Protection OVP circuitry to minimize output voltage overshoot during load transient, recovering from output fault condition or light load transient. The overvoltage comparator in OVP circuit compares the FB pin voltage to the internal reference voltage. When FB voltage exceeds 110% of internal 0.8V reference voltage, the high-side MOSFET turns off to avoid output voltage continue to increase. When the FB pin voltage falls below 105% of the 0.8V reference voltage, the high-side MOSFET can turn on again. For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2452 11 SCT2452 Thermal Shutdown The SCT2452 protects the device from the damage during excessive heat and power dissipation conditions. Once the junction temperature exceeds 170C, the internal thermal sensor stops power MOSFETs switching. When the junction temperature falls below 145C, the device restarts with internal soft start phase. 12 For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2452 SCT2452 APPLICATION INFORMATION Typical Application C12 0.1uF BOOT L1 5.5uH C8 C9 47uF 47uF VIN=3.8V~36V VIN R1 180K C1 C3 C4 C5 C2 4.7uF 4.7uF 4.7uF 4.7uF 0.1uF R2 43K VOUT=3.3V IOUT=5A SW GND C10 47uF C11 47uF EN SS RT/CLK FB C13 Optional R5 31.6K SCT2452 C6 10nF R3 200K R6 10.2K Figure 18. SCT2452 Design Example, 3.3V Output with Programmable UVLO Design Parameters Design Parameters Example Value Input Voltage 24V Normal 3.8V to 36V Output Voltage 3.3V Maximum Output Current 5A Switching Frequency 500 KHz Output voltage ripple (peak to peak) 16.5mV Transient Response 1.25A to 3.75A load step ∆Vout = 135mV Start Input Voltage (rising VIN) 5.76V Stop Input Voltage (falling VIN) 4.66V For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2452 13 SCT2452 Output Voltage The output voltage is set by an external resistor divider R5 and R6 in typical application schematic. Recommended R6 resistance is 10.2KΩ. Use equation 6 to calculate R5. where: 𝑉𝑂𝑈𝑇 𝑅5 = ( − 1) ∗ 𝑅6 𝑉𝑅𝐸𝐹 Table 1. R5, R6Value for Common Output Voltage (Room Temperature) (6) • VREF is the feedback reference voltage, typical 0.8V VOUT R5 R6 1.8 V 12.7 KΩ 10.2 KΩ 2.5 V 21.5 KΩ 10.2 KΩ 3.3 V 31.6 KΩ 10.2 KΩ 5 V 53.6 KΩ 10.2 KΩ 12 V 143 KΩ 10.2 KΩ 24V 294 KΩ 10.2 KΩ Switching Frequency Higher switching frequencies support smaller profiles of output inductors and output capacitors, resulting in lower voltage and current ripples. However, the higher switching frequency causes extra switching loss, which downgrads converter’s overall power efficiency and thermal performance. The 100ns minimum on-time limitation also restricts the selection of higher switching frequency. In this design, a moderate switching frequency of 500 kHz is selected to achieve both small solution size and high efficiency operation. The resistor connected from RT/CLK to GND sets switching frequency of the converter. The resistor value required for a desired frequency can be calculated using equation 7, or determined from Figure 7. 𝑅3 (KΩ) = 100000 Table 2. RFSW Value for Common Switching Frequencies (Room Temperature) (7) fsw (KHz ) where: • fSW is the desired switching frequency Fsw R3 (RFSW) 200 KHz 500 KΩ 330 KHz 301 KΩ 500 KHz 200 KΩ 1100 KHz 90.9 KΩ Under Voltage Lock-Out An external voltage divider network of R1 from the input to EN pin and R2 from EN pin to the ground can set the input voltage’s Under Voltage Lock-Out (UVLO) threshold. The UVLO has two thresholds, one for power up when the input voltage is rising and the other for power down or brown outs when the input voltage is falling. For the example design, the supply should turn on and start switching once the input voltage increases above 5.7V (start or enable). After the regulator starts switching, it should continue to do so until the input voltage falls below 4.64 V (stop or disable). Use Equation 8 and Equation 9 to calculate the values 173 kΩ and 42 kΩ of R1 and R2 resistors. Vrise = 1.18 ∗ (1 + Vfall = 1.1 ∗ (1 + 𝑅1 ) − 1.5uA ∗ R1 𝑅2 𝑅1 ) − 5.5uA ∗ 𝑅1 𝑅2 (8) (9) Inductor Selection There are several factors should be considered in selecting inductor such as inductance, saturation current, the RMS current and DC resistance(DCR). Larger inductance results in less inductor current ripple and therefore leads to lower output voltage ripple. However, the larger value inductor always corresponds to a bigger physical size, 14 For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2452 SCT2452 higher series resistance, and lower saturation current. A good rule for determining the inductance to use is to allow the inductor peak-to-peak ripple current to be approximately 20%~40% of the maximum output current. The peak-to-peak ripple current in the inductor ILPP can be calculated as in Equation 10. 𝐼𝐿𝑃𝑃 = Where • • • • • 𝑉𝑂𝑈𝑇 ∗ (𝑉𝐼𝑁 − 𝑉𝑂𝑈𝑇 ) 𝑉𝐼𝑁 ∗ 𝐿 ∗ 𝑓𝑆𝑊 (10) ILPP is the inductor peak-to-peak current L is the inductance of inductor fSW is the switching frequency VOUT is the output voltage VIN is the input voltage Since the inductor-current ripple increases with the input voltage, so the maximum input voltage in application is always used to calculate the minimum inductance required. Use Equation 11 to calculate the inductance value. 𝐿𝑀𝐼𝑁 = Where • • • • • • 𝑉𝑂𝑈𝑇 𝑉𝑂𝑈𝑇 ∗ (1 − ) 𝑓𝑆𝑊 ∗ 𝐿𝐼𝑅 ∗ 𝐼𝑂𝑈𝑇(𝑚𝑎𝑥) 𝑉𝐼𝑁(𝑚𝑎𝑥) (11) LMIN is the minimum inductance required fsw is the switching frequency VOUT is the output voltage VIN(max) is the maximum input voltage IOUT(max) is the maximum DC load current LIR is coefficient of ILPP to IOUT The total current flowing through the inductor is the inductor ripple current plus the output current. When selecting an inductor, choose its rated current especially the saturation current larger than its peak operation current and RMS current also not be exceeded. Therefore, the peak switching current of inductor, ILPEAK and ILRMS can be calculated as in equation 12 and equation 13. 𝐼𝐿𝑃𝐸𝐴𝐾 = 𝐼𝑂𝑈𝑇 + 𝐼𝐿𝑃𝑃 2 𝐼𝐿𝑅𝑀𝑆 = √(𝐼𝑂𝑈𝑇 )2 + Where • • • • (12) 1 ∗ (𝐼𝐿𝑃𝑃 )2 12 (13) ILPEAK is the inductor peak current IOUT is the DC load current ILPP is the inductor peak-to-peak current ILRMS is the inductor RMS current In overloading or load transient conditions, the inductor peak current can increase up to the switch current limit of the device which is typically 8A. The most conservative approach is to choose an inductor with a saturation current rating greater than 8A. Because of the maximum ILPEAK limited by device, the maximum output current that the SCT2452 can deliver also depends on the inductor current ripple. Thus, the maximum desired output current also affects the selection of inductance. The smaller inductor results in larger inductor current ripple leading to a higher maximum output current. For this design, use LIR=0.2 or 0.3, and the inductor value is calculated to be 5uH, the RMS inductor current is 6A and the peak inductor current is 7.2A. The chosen inductor is a WE 744325550, which has a saturation current For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2452 15 SCT2452 rating of 12A and a RMS current rating of 10A. This also has a typical inductance of 5.5µH at no load and 4.7 µH at 6A load. The inductor DCR is 10.3 mΩ. Input Capacitor Selection The input current to the step-down DCDC converter is discontinuous, therefore it requires a capacitor to supply the AC current to the step-down DCDC converter while maintaining the DC input voltage. Use capacitors with low ESR for better performance. Ceramic capacitors with X5R or X7R dielectrics are usually suggested because of their low ESR and small temperature coefficients, and it is strongly recommended to use another lower value capacitor (e.g. 0.1uF) with small package size (0603) to filter high frequency switching noise. Place the small size capacitor as close to VIN and GND pins as possible. The voltage rating of the input capacitor must be greater than the maximum input voltage. And the capacitor must also have a ripple current rating greater than the maximum input current ripple. The RMS current in the input capacitor can be calculated using Equation 14. ICINRMS = IOUT ∗ √ VOUT VOUT ∗ (1 − ) VIN VIN (14) The worst case condition occurs at VIN=2*VOUT, where: (15) ICINRMS = 0.5 ∗ IOUT For simplification, choose an input capacitor with an RMS current rating greater than half of the maximum load current. When selecting ceramic capacitors, it needs to consider the effective value of a capacitor decreasing as the DC bias voltage across a capacitor increases. The input capacitance value determines the input ripple voltage of the regulator. The input voltage ripple can be calculated using Equation 16 and the maximum input voltage ripple occurs at 50% duty cycle. ∆VIN = IOUT VOUT VOUT ∗ ∗ (1 − ) fSW ∗ CIN VIN VIN (16) For this example, three 4.7μF, X7R ceramic capacitors rated for 50 V in parallel are used. And a 0.1 μF for highfrequency filtering capacitor is placed as close as possible to the device pins. Bootstrap Capacitor Selection A 0.1μF ceramic capacitor must be connected between BOOT pin and SW pin for proper operation. A ceramic capacitor with X5R or better grade dielectric is recommended. The capacitor should have a 10V or higher voltage rating. Output Capacitor Selection The selection of output capacitor will affect output voltage ripple in steady state and load transient performance. The output ripple is essentially composed of two parts. One is caused by the inductor current ripple going through the Equivalent Series Resistance ESR of the output capacitors and the other is caused by the inductor current ripple charging and discharging the output capacitors. To achieve small output voltage ripple, choose a low-ESR output capacitor like ceramic capacitor. For ceramic capacitors, the capacitance dominates the output ripple. For simplification, the output voltage ripple can be estimated by Equation 17 desired. ∆VOUT = 𝑉𝑂𝑈𝑇 ∗ (𝑉𝐼𝑁 − 𝑉𝑂𝑈𝑇 ) (17) 8 ∗ 𝑓𝑆𝑊 2 ∗ 𝐿 ∗ 𝐶𝑂𝑈𝑇 ∗ 𝑉𝐼𝑁 Where • ΔVOUT is the output voltage ripple 16 For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2452 SCT2452 • • • • • fSW is the switching frequency L is the inductance of inductor COUT is the output capacitance VOUT is the output voltage VINis the input voltage Due to capacitor’s degrading under DC bias, the bias voltage can significantly reduce capacitance. Ceramic capacitors can lose most of their capacitance at rated voltage. Therefore, leave margin on the voltage rating to ensure adequate effective capacitance. Typically, two 47μF ceramic output capacitors work for most applications. Inverting Power application The SCT2452 can be used to convert a positive input voltage to a negative output voltage. Typical applications are amplifiers requiring a negative power supply. C3 BOOT L1 GND SW VIN VIN GND SCT2452 C1 C2 EN SS RT/CLK FB C4 R1 C5 R2 R4 VOUT Figure 19. SCT2452 Inverting Power Supply For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2452 17 SCT2452 Application Waveforms 18 Figure 20. Power up Figure 21. Power down Figure 22.Load Transient (0.5A-4.5A, 250mA/us) Figure 23. Load Transient (1.5A-3.5A, 250mA/us) Figure 24. SW and Vout Ripple Figure 25. Thermal, 3.3Vout/5A For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2452 SCT2452 Layout Guideline Proper PCB layout is a critical for SCT2452’s stable and efficient operation. The traces conducting fast switching currents or voltages are easy to interact with stray inductance and parasitic capacitance to generate noise and degrade performance. For better results, follow these guidelines as below: 1. Power grounding scheme is very critical because of carrying power, thermal, and glitch/bouncing noise associated with clock frequency. The thumb of rule is to make ground trace lowest impendence and power are distributed evenly on PCB. Sufficiently placing ground area will optimize thermal and not causing over heat area. 2. Place a low ESR ceramic capacitor as close to VIN pin and the ground as possible to reduce parasitic effect. 3. For operation at full rated load, the top side ground area must provide adequate heat dissipating area. Make sure top switching loop with power have lower impendence of grounding. 4. The bottom layer is a large ground plane connected to the ground plane on top layer by vias. The power pad should be connected to bottom PCB ground planes using multiple vias directly under the IC. The center thermal pad should always be soldered to the board for mechanical strength and reliability, using multiple thermal vias underneath the thermal pad. Improper soldering thermal pad to ground plate on PCB will cause SW higher ringing and overshoot besides downgrading thermal performance. it is recommended 8mil diameter drill holes of thermal vias, but a smaller via offers less risk of solder volume loss. On applications where solder volume loss thru the vias is of concern, plugging or tenting can be used to achieve a repeatable process. 5. Output inductor should be placed close to the SW pin. The area of the PCB conductor minimized to prevent excessive capacitive coupling. 6. The RT/CLK terminal is sensitive to noise so the RT resistor should be located as close as possible to the IC and routed with minimal lengths of trace. 7. UVLO adjust and RT resistors, soft start components should connect to small signal ground which must return to the GND pin without any interleaving with power ground. 8. Route BOOT capacitor trace on the other layer than top layer to provide wide path for topside ground. 9. For achieving better thermal performance, a four-layer layout is strongly recommended. VOUT Output capacitors GND Inductor Top layer ground area Via Input bypass capacitor Via 1 BOOT SW VIN VIN GND Programmable UVLO resistors EN SS Thermal VIA RT/CLK FB Small signal ground Softstart Capacitor Feedback resistors Freq. set resistor GND Top layer ground area Figure 26. PCB Layout Example For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2452 19 SCT2452 PACKAGE INFORMATION eSOP8/PP(95x130) Package Outline Dimensions Symbol A A1 A2 b c D D1 E E1 E2 e L  Dimensions in Millimeters Min. Max. 1.300 1.700 0.000 0.100 1.350 1.550 0.330 0.510 0.170 0.250 4.700 5.100 3.050 3.250 3.800 4.000 5.800 6.200 2.160 2.360 1.270(BSC) Dimensions in Inches Min. Max. 0.051 0.067 0.000 0.004 0.053 0.061 0.013 0.020 0.007 0.010 0.185 0.201 0.120 0.128 0.150 0.157 0.228 0.244 0.085 0.093 0.050(BSC) 0.400 0° 0.016 0° 1.270 8° 0.050 8° NOTE: 1. 2. 3. 4. 5. 6. Drawing proposed to be made a JEDEC package outline MO-220 variation. Drawing not to scale. All linear dimensions are in millimeters. Thermal pad shall be soldered on the board. Dimensions of exposed pad on bottom of package do not include mold flash. Contact PCB board fabrication for minimum solder mask web tolerances between the pins. TAPE AND REEL INFORMATION 20 For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2452 SCT2452 For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2452 21 SCT2452 RELATED PARTS PART NUMBERS SCT2451 SCT2430A SCT2431A SCT2430 SCT2432 SCT2433 DESCRIPTION COMMENTS 36V Vin, 5A Synchronous Step-down DCDC Converter with Adjustable Soft Start Time 36V Vin, 3.5A Synchronous Step-down DCDC Converter with 100KHz-1.1MHz Programmable Switching Frequency 36V Vin, 3.5A Synchronous Step-down DCDC Converter with Adjustable Soft Start Time 40V Vin, 3.5A Synchronous Step-down DCDC Converter with 100KHz-2.2MHz Programmable Switching Frequency 40V Vin, 3.5A Synchronous Step-down DCDC Converter with 100KHz-2.2MHz Programmable Switching Frequency, Programmable Soft Start Time and Internal-compensation 40V Vin, 3.5A Synchronous Step-down DCDC Converter C3 BOOT VIN 45mΩ / 20mΩ HS/LS MOSFETs Programmable soft start time Freq. = 570KHz 55mΩ / 30mΩ HS/LS MOSFETs Internal 4ms Soft-time Freq. = 100KHz-1.1MHz adjustable. Clock synchronization 55mΩ / 30mΩ HS/LS MOSFETs Programmable soft start time Freq. = 570KHz 80mΩ / 50mΩ HS/LS MOSFETs Internal 4ms Soft-time Freq. = 100KHz-2.2MHz adjustable. Clock synchronization 80mΩ / 50mΩ HS/LS MOSFETs Programmable soft start time Freq. = 100KHz-2.2MHz adjustable. Clock synchronization Internal Compensation 80mΩ / 50mΩ HS/LS MOSFETs Internal 2ms Soft-time Freq. = 570kHz Fix. Clock synchronization L1 SW C5 VIN GND SCT2451 EN COMP C1 C2 SS FB VOUT R1 R3 C4 R2 C6 Figure 27. SCT2451 Typical Application NOTICE: The information in this document is subject to change without notice. Users should warrant and guarantee the third party Intellectual Property rights are not infringed upon when integrating Silicon Content Technology (SCT) products into any application. SCT will not assume any legal responsibility for any said applications. 22 For more information www.silicontent.com © 2019 Silicon Content Technology Co., Ltd. All Rights Reserved Product Folder Links: SCT2452
SCT2452STER 价格&库存
很抱歉,暂时无法提供与“SCT2452STER”相匹配的价格&库存,您可以联系我们找货
SCT2452STER
    • 1+4.40000
    • 100+3.14160
    • 1000+3.11168
    • 4000+3.08000
    库存:57
