品名
:SMD 蜂鸣器
产品型号
:cy-SMD-8503-3016
供应商
:常州超音电子有限公司
日期
:2013.10.11
客户
Approved By
Checked By
Made
By
地址:常州市武进庙桥新联工业集中区 58 号.
电话:0519-88298758
传真:0519-86464158
网址:www.smdbuzzer.net
cy-SMD-8503-3016
DATE:2013.10.11
1﹒Electrical Characteristics
Oscillation Frequency (Hz)
Operating Voltage (VO-p)
Rated Voltage (VO-p)
VER .:0
2731
2.5~4.5
3.6
Current Consumption (mA/max.)
100 at Rated Voltage
Sound Pressure Level (dB/min.)
85at 10cm at Rated Voltage
Coil Resistance (Ω)
16± 3
Operating Temperature (℃)
-30 ~ +70
Storage Temperature (℃)
-40 ~ +85
PS:Vp-p=1/2duty , square wave
2﹒Typical Frequency Response Curve
3﹒Dimensions and Material
3-1 Shape
Unit : mm
3-2 Material
Housing
Tol:±0.3
LCP plastic resin (Color : Black)
Leading Pin
Tin Plated Brass
Weight (Gram)
0.8
4﹒Recommend Driving Circuit
The base current Ib should high enough so that it saturates the collector current of the
transistor with the CB load.
5. TESTING METHOD
.Standard Measurement conditions
Temperature:25±2℃
Humidity:45-60%
.Acoustic Characteristics
The oscillation frequency, current consumption and sound pressure are measured by the
measuring instruments shown below.
10cm
FUNCTION
GENERATOR
AMPERE
METER
SOUNDER
MICROPHONE
In the measuring test, buzzers is placed as follows:
SAMPLE
MICROPHONE
1OCM
dB
METER
6. RELIABILITY
ITEMS
Coldness
withstanding
Hotness
withstanding
Humidity
withstanding
METHOD OF TEST AND MEASUREMENTS
After 98 hours of being exposed to -30℃
environment, should be returned to normal
environment for 2 hours, then re-proceed to test.
After 98 hours of being exposed to +80℃
After 98 hours of being exposed to 40℃ 95%RH
environment in actual operation, should be
returned to normal environment for 2 hours, then
re-proceed to test.
PERFORMANCE
No abnormality
shall exist
No abnormality
shall exist
No abnormality
shall exist
Durability
Testing after 1,000 hours actual continuous
operation. (at standard measurement conditions)
No abnormality
shall exist
Drop
withstanding
A natural drop from 75cm high down to the
ground.
No abnormality
shall exist
Vibration
withstanding
Vibration of 2,000 cycles per minute, 2mm
amplitude, applied in X, Y and Z directions for 30
minutes each.
No abnormality
shall exist
7.Soldering Condition
(1)Recommendable reflow soldering condition is as follows
(Reflow soldering is twice)
after heat of product goes down to normal.
Heat resistant line
(Used when heat resistant reliablity test is performed)
(2)Manual soldering
Manual soldering temperature 350 C within 10 sec.
CARRIER REEL
1K PCS BUZZER
8. PACKAGE METHOD
INNER BOX
1 ROLL CARRIER REEL
CARTON BOX
10 INNER BOX
10K PCS BUZZER
Unit:mm
很抱歉,暂时无法提供与“CY-SMD-8503-3016”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.69360
- 10+2.99160
- 30+2.64600
